Causal paradoxes - how to solve them?
  • Thread starter Demystifier
In summary, the three most popular options are self-consistency, chronological protection, and parallel universes.
How to solve causal paradoxes?
  • Chronology protection
    Votes: 3 25.0%
  • Self-consistency
    Votes: 4 33.3%
  • Parallel universes
    Votes: 2 16.7%
  • Other
    Votes: 3 25.0%
  • Total voters
Demystifier
Insights Author
6,878
Under certain conditions, the theory of relativity suggests that closed causal loops can be formed, which seems to allow the causal paradoxes (like killing your grandfather and so). Namely, under certain conditions general relativity allows nontrivial spacetime topologies (like wormholes), while special relativity under certain conditions allows superluminal signaling (e.g. by tachyons). There are basically 3 types of solutions of such paradoxes:
1. Chronology protection:
The true laws of physics conspire so that such exotic topologies and superluminal velocities are not really possible. The problem is to explain it with the presently known physical laws.
2. Self-consistency:
Only self-consistent solutions are physical. It is related to the block-time view of the universe, in which time does not "lapse", but simply is, just like space. It is very much in spirit with the relativistic view of time. The problem is that it confronts with the subjective experience of time and the notion of "free will".
3. Parallel universes:
Seems too speculative and unscientific, but it seems that many people still like it.
So, what is your (favored) choice?
I gave a little nore background in post #8 of this thread.
I hope no stong gust of wind comes along, as it might cause me to fall off the fence.
It doesn't matter much, since nobody can experience a time travel.
Say, you time travel to London year 1777. Well, there was no You in the real 1777 London, so even if you'd somehow get yourself to a place that seemingly is 1777 London, it really is not.
Well I disagree. I voted for self-consistency, which would claim that you could 'go back' to London 1777 only if you were already in London in 1777. You may think that that's impossible since you weren't even born yet, but so long as you are able to get there then you were there already.
I was actually discussing the idea of self-consistency and free will with my roommate the other day (he was a religion and psych major as an undergrad). He claimed that this does ruin the idea of free will. I think it doesn't -- it's not that you would be forced to do what you already did if you travel back in time so much as you've already made those decisions. In that small time frame, you did exercise free will, so revisiting that time frame simply reveals to you the decisions you've already made. If you can't do something it's not due to a lack of free will, but instead due to what you've already done with your free will.
If I rephrase that one more time it will only make less sense than it already does.
How do you know there was no you in the real 1777 London? If the self-consistency option is correct, then any trip you made back in time was part of history all along, even before you decided to make it.
I think all three options are logically consistent, but realistically I'd have to go with chronology protection, from what I've read when physicists try to incorporate quantum physics into general relativity's time travel scenarios they always tend to find plausible reasons that time travel would become impossible...look at this article on analyses of time travel from string theory, for example.
avoiding paradoxes
I was tought that the best way to avoid paradoxes in SR is to start with its postulates, to define correctly the space-time coordinates of the involved events and to perform their Lorentz transformations.
There are no problems with causality in SR unless you allow for the possibility of faster-than-light particles or "tachyons". But in GR there are various solutions which seem to allow for time travel into the past (at least if you ignore quantum effects and allow for violations of the weak and null energy conditions), like traversable wormholes.
It is not that simple. In some cases, if you start with some arbitrarily chosen initial condition (initial "free will"), then further deterministic evolution necessarily breaks self-consistency. So, you are not free to choose the initial condition even the "first" time you attempt to do so. Nevertheless, in my opinion this is still not in contradiction with free will. It only means that free will, if exists, does not work in terms of initial conditions, but in a nonlocal way as a choice of the global self-consistent solution. (I would like to know what your religious roommate would think about such a modified notion of free will.)
One possibility that has been discussed before is the possibility that GR is actually just some "funky fields on a Minkowski space-time. Since there would be an underlying trivial topology, I believe there wouldn't be any time travel in this scenario.
I gather there are some consistency problems with this idea, though, in spite of the fact that it appears to work locally. I'm not sure I understand the arguments completely, in thinking about the issue I ask questions like "Is the magnitude of these fields finite or infinite at the event horizon of a black hole".
None of the above. Rather, I give up the postulate that space-time should be modeled as a
semi-Riemannian manifold and adopt a model of space-time where closed causal loops are impossible
by construction. Yes, this is radical, and not compatible with GR.
Old Smuggler said:
None of the above.
Rather, I give up the postulate that space-time should be modeled as a semi-Riemannian manifold and adopt a model of space-time where closed causal loops are impossible by construction.
Well I'm in the "Other" Category as well. However, I do not favor Space-Time as a valid interpretation of Special Relativity.
I prefer to apply SR to a more Classical expectation of an Absolute Space along with an Absolute Time to avoid causal paradoxes. Not only would this mean GR & QM are incomplete, but our current Classical assumptions of how we observe both Space and Time are likely not complete either. Do not know if that makes me more traditional or radical, certainly not a typical ‘Local Realist’.
RB
Hmmm, well I will first have to make sure I understand this myself :-p
By the way, I didn't quite say that my roommate was religious, just that he was a religion major in college. However, both he and I are in fact practicers of and believers in religions.
Also, do we know how you voted?
I like this possibility. Still, there remains a possibility of superluminal signals.
RB
I like this view. But the problem then is to explain why our current fundamental theories are invariant under relativistic transformations of space and time coordinates.
Well, this is actually a version of 1. Chronology protection.
FAQ: Causal paradoxes - how to solve them?
What is a causal paradox?
A causal paradox, also known as a causal loop or time loop, is a theoretical scenario where the cause and effect of an event are in a continuous loop, making it impossible to determine which event came first.
How do causal paradoxes arise?
Causal paradoxes often arise in science fiction and philosophy, but they also have real-world applications in fields such as quantum mechanics and time travel theory. They occur when the cause of an event is also the effect of that same event, creating a never-ending cycle.
Can causal paradoxes be solved?
Yes, there are several proposed solutions to causal paradoxes, although none have been proven to be universally applicable. Some solutions involve the concept of parallel universes or alternate timelines, while others suggest that the paradox is simply a flaw in our understanding of causality.
How can we avoid creating causal paradoxes?
One way to avoid creating causal paradoxes is to carefully consider the potential consequences of our actions and the potential chain of events that may result. It is also important to have a thorough understanding of causality and to avoid making assumptions about the linear nature of cause and effect.
What impact do causal paradoxes have on scientific research?
Causal paradoxes can have a significant impact on scientific research, particularly in fields such as time travel and quantum mechanics where the concept of causality is often challenged. They can also lead to new theories and ideas about the nature of time and causation, pushing the boundaries of our understanding of the universe.
