Topological order - string-net condensation + loop quantum gravity
In summary, Xiao-Gang Wen is a physicist who has written a textbook on quantum field theory of many-body systems, and has done research on topological order and its potential to provide a unified origin for particles in our universe. Lee Smolin is a physicist who is aware of Wen's work and is trying to combine loop quantum gravity with quantum chromodynamics. Fotini Markopoulou is a physicist working on pre-geometric background independent approaches to quantum gravity, which start with a microscopic theory and have the potential to emerge as geometry and gravity. There are also other promising research directions for combining loop quantum gravity with the standard model, such as preon braiding and noncommutative geometry.
jal
549
I've just read
Quantum field theory of many-body systems
Xiao-Gang Wen
His web page
http://dao.mit.edu/~wen/
I thought that his book might be easier than his papers. hehehe It's a textbook.
I did get to learn a few things.
Here is what wiki says about the subject.
In physics, topological order is a new kind of order (a new kind of organization of particles) in a quantum state that is beyond the Landau symmetry-breaking description.
http://en.wikipedia.org/wiki/Topological_order
Why is topological order important? Landau symmetry-breaking theory is a cornerstone of condensed matter physics. It is used to define the territory of condensed matter research. The existence of topological order appears to indicate that nature is much richer than Landau symmetry-breaking theory has so far indicated. The exciting time of condensed matter physics is still ahead of us. Some suggest that topological order (or more precisely, string-net condensation) has a potential to provide a unified origin for photons, electrons and other elementary particles in our universe.
http://en.wikipedia.org/wiki/String-net_condensation
For strings labeled by the positive integers, string-nets are the spin networks studied in loop quantum gravity. This has led to the proposal by Wen and Levin, [1] , and Smolin, Markopolou and Tomasz, [2] that loop quantum gravity's spin networks can give rise to the standard model of particle physics through this mechanism, along with fermi statistics and gauge interactions. To date, a rigorous derivation from LQG's spin networks to Wen's spin lattice has yet to be done.
I found the following trying to make the relationship with LQG
http://arxiv.org/abs/hep-th/0611197
Quantum Graphity
Tomasz Konopka, Fotini Markopoulou, Lee Smolin
(Submitted on 17 Nov 2006) )
“We argue (but do not prove) that under certain conditions the spins in the system can arrange themselves in regular, lattice-like patterns at low temperatures. When the graph is frozen, the model is closely related to a model of Levin and Wen [4, 5, 6] which has emergent gauge degrees of freedom.”
p.7
“…it is helpful to first consider the graph of “on” links to be frozen in a particular configuration, say a regular cubic lattice where the minimal loops in the graph are plaquettes. In this case, these terms reduce to the rotor model of Levin and Wen [6]”
Xiao-Gang Wen ends his book with the following:
“What is the origin of gauge field – geometrical or dynamical?
What is the origin of Fermi statistics – given or emergent?
In this book, we favor the dynamical and emergent origin of gauge bosons and fermions. The gauge bosons and the Fermi statistics may just be collective phenomena of quantum many-boson systems, and nothing more.”
Has anyone got any other link that try to make the relationship with LQG?
jal
From reading some of Lee Smolin's latest papers, and his students, I get the impression that he is aware of Xiao-Gang Wen's work and that he is trying to combine LQG with QCD.
See his presentation at Loop 07
Has he identified any problem that might be insurmountable?
jal
We did a discussion at https://www.physicsforums.com/showthread.php?t=161868
The universe as a "string-net liquid"
p. 472
fig.10.9
Xiao-Gang Wen uses 2 cubes with position #1 plaquete is shared by both cube OR is there two plaquete in the same position. Therefore, he has 11 positions for the fermions.
If he was to expand to more than two cubes then all the plaquete positions would be shared/doubled. There would never be a certainty of minimum distance between the plaquetes or a certainty on the number of plaquetes.
Cubic packing does not preserve the identity of each plaquete.
Cubic packing does not preserve minimum length.
His math might works (I’ll let others decide) but his picture of having cubes (a cubic lattice) will not work but it is close to being right. (after all, cubic packing and hex. packing preserve the volume.)
However, by using hex. packing in 3d packing you get the 12 plaquete positions and they would not be shared and you would be able to keep minimum distances and the math should work with that picture.
As a result, you can use the double tetra, (LQG, spin nets) because in the center of the spinning plaquetes is the double tetra.
http://arxiv.org/PS_cache/gr-qc/pdf/0703/0703097v1.pdf
New directions
in Background Independent
Quantum Gravity
Fotini Markopoulou
20 March 2007
1) Is spacetime geometry and general relativity fundamental or emergent?
2) Is spacetime geometry, if present, dynamical or fixed?
Our main focus in this chapter is a new, fourth, category that is currently under development and constitutes a promising and previously unexplored direction in background independent quantum gravity. This is pre-geometric background independent approaches to quantum gravity. These start with an underlying microscopic theory of quantum systems in which no reference to a spatiotemporal geometry is to be found. Both geometry and hence gravity are emergent.
Note: Minimum length scale imposes a geometry.
Xiao-Gang Wen said in his book that his model could be applied to QCD but he did not develop it.
Is Lee Smolin trying to make the link of LQG and QCD?
jal
jal
Where is Smolin expressly trying to do this?
I wonder which research direction is most promising for combining LQG + SM = TOE
preon braiding, (i.e Sundance)
condense matter (i.e Wen)
noncommuative geometry (i.e Connes)
4D "string" (i.e Baez)
I like your short-list of research directions. All could succeed, and turn out to be equivalent versions so I will not try to pick the best (likewise all could fail but I see no clear loser either---they are all worth exploring.)
Just to keep track of progress---there is some news or rumor about putting LQG together with Connes NCG. You can see what the program is in Grimstrup's latested paper but this is already a year old. I think some important progress has been made on that program which hasn't gotten put on arxiv yet. So I will just recall last year's paper to give an idea of the program:
http://arxiv.org/abs/hep-th/0601127
Intersecting Connes Noncommutative Geometry with Quantum Gravity
Johannes Aastrup, Jesper M. Grimstrup
19 pages, 4 figures
(Submitted on 18 Jan 2006)
"An intersection of Noncommutative Geometry and Loop Quantum Gravity is proposed. Alain Connes' Noncommutative Geometry provides a framework in which the Standard Model of particle physics coupled to general relativity is formulated as a unified, gravitational theory. However, to this day no quantization procedure compatible with this framework is known. In this paper we consider the noncommutative algebra of holonomy loops on a functional space of certain spin-connections. The construction of a spectral triple is outlined and ideas on interpretation and classical limit are presented."
the goal is to build a spectral triple on the space of connections (realized as a limit of productgroups Gn)
to understand Grimstrup and Aastrup's work one must know what a spectral triple is---it is the basic object in Connes NCG where he derives the Standard Model from a certain spectral triple.
If Grimstrup et al can make a spectral triple that meets Connes specifications and which is based on a space of spacetime geometries (i.e. on a space of connections) then it can include both a version of LQG and also the essentials of Particle Physics.
this is why I think it would be good to glance at the above paper, even though it is a year old and only describes work-in-progress
thanks to both of you for keeping an alert watch. Ensabah's list is a good one I think. EACH approach to the goal should be watched IMO.
Hi ensabah6
Look at his Physics talks and you tell me.
http://www.thetroublewithphysics.com/Talks.html
• Particle physics from quantum gravity (Spring 2006)
• Emergence of chiral matter from quantum gravity ('t Hooft conference, summer 2006
Hi Marcus
At the end of the day there has to be a dynamic structure.
jal
19 pages, 4 figures
Well thanks Marcus.
Considering that Alaine Connes is the founder of NCG, and Carlo Rovelli is a major LQG researcher, authoring a textbook in the subject, and Rovelli and Connes are friends and correspondants, has Alaine Connes weighed in some sort of QG for NCG -- for example a LQG+NCG?
For example, would a QG of NCG change his prediction for the higgs boson mass of 170 GEV? Would a NCG of LQG help identify its SC limit? For that matter have other LQG-NCG researchers weighed in on Grimstrup and Aastrup work?
I forget to mention
Stephen Alexander's paper "lqg and electroweak unification"
Related to Topological order - string-net condensation + loop quantum gravity
1. What is topological order?
Topological order is a type of order that emerges in certain physical systems, where the properties of the system are determined by the global topology rather than local interactions between particles.
2. What is string-net condensation?
String-net condensation is a phenomenon that occurs in certain topologically ordered systems, where strings formed by the movement of particles condense to form a new collective excitation known as a string-net. This process can lead to the emergence of new properties and phases of matter.
3. What is loop quantum gravity?
Loop quantum gravity is a theoretical framework that attempts to reconcile the theories of general relativity and quantum mechanics. It proposes that space and time are made up of discrete, quantized units and that gravity arises from the interactions between these units.
4. How do topological order and loop quantum gravity relate?
There is ongoing research exploring the potential connections between topological order and loop quantum gravity. Some theories suggest that topological order may be a fundamental feature of space-time at the quantum level, and that loop quantum gravity may provide a way to mathematically describe this topological structure.
5. What are the potential applications of studying topological order and loop quantum gravity?
Studying topological order and loop quantum gravity has the potential to deepen our understanding of fundamental physics and may lead to new insights and technologies. Some possible applications include advancements in quantum computing, more accurate models of black holes, and a better understanding of the early universe.
  • Beyond the Standard Models
  • Quantum Physics
