Why does the charge on a conductor accumulate at sharp points?
In summary, Halliday and Resnick's example involving two spheres shows that the charge on a conductor accumulates at sharp points. This is because the electric field is greater near sharp points, and this causes the charge to be more bunched up.
fantispug
105
Why does the charge on a conductor accumulate at sharp points? I've read one or two explanations, but I don't follow them, and when I try to think about it I reach the opposite conclusion.
Halliday and Resnick has an example where a large conducting sphere and a small conducting sphere are attached by a long wire (which we neglect the effects of). Since the spheres are a long way away if we charge the system both the spheres become positively charged, the larger sphere has more charge (proportional to radius) but a lower electric field at the surface (inversely proportional to radius).
To my this implies that having a smaller radius of curvature can cause something to have less charge. Why doesn't it?
(Incidentally in Griffiths I found a formula for the charge density of an ellipsoid, but I found it difficult to integrate to find the charge on a part of the ellipsoid with small/large radius of curvature - in this case there is more charge density near points of small radius of curvature, but since they have a smaller area I think it could be like the Halliday and Resnick case where there is less actual charge).
Let's talk about electrons in a negatively charged conductor. The electrons all exert force on each other by Culomb's law. Since they are in a conductor they will move (f=ma) until all of the forces on each electron are balanced. When they are in the interior of the charged conductor the net force is towards the surface. However, once they get to the surface they cannot leave (unless they are heated and have a lot of KE), all they can do is move around the surface.
So, consider the force on one surface electron due to the neighboring surface electrons. If there is any curvature to the surface then the net force on the electron will not be parallel to the surface. However, since the electron is constrained to not leave the conductor, only the component of the net force which is parallel to the surface can cause motion of the electron. In an area with small radius of curvature the component of the force parallel to the surface is small, and therefore more electrons are required to exert the same force. This results in an accumulation of charges around regions with a small radius of curvature.
Likes AhmedSalimi and gracy
"Halliday and Resnick has an example where a large conducting sphere and a small conducting sphere are attached by a long wire (which we neglect the effects of). Since the spheres are a long way away if we charge the system both the spheres become positively charged, the larger sphere has more charge (proportional to radius) but a lower electric field at the surface (inversely proportional to radius)."
In this H&R example, each sphere has the same potential, so that the charge Q on each sphere is proportional to its radius R. The surface charge density is proportional to
Q/R^2~V/R, and thus is larger for the smaller radius.
Likes gracy
The force is inversely proportional to the square of the distance, and an area with a small radius of curvature the charges are more bunched together (since circumference is proportional to radius), and every charge exerts a force, so I don't find it obvious whether the force would increase or decrease overall.
Moreover the force on each charge need not be the same, the total force just needs to cancel.
Again using the two sphere example, the charge on the smaller sphere is less. But in general it should be that on an area with less radius of curvature the charge is greater. Why is it different here?
I'm happy to take it as given that the electric field is greater near sharp points; I've seen much experimental evidence to this effect, and it can be shown this is true for an ellipsoid. This implies that the charge density is greater near points of less radius of curvature. But this doesn't necessarily imply the total charge is greater - again as shown in the instructive two sphere example.
This should really be simple and obvious but I just can't understand it.
The charge density should be more, not the total charge.
The argument given by Dalespam not only shows why the charge density should be more at regions with high curvature, but also why the charge should accumulate at the surface.
Likes gracy
OK, first what you are trying to understand here is why the charges are more bunched together, so you should not assume the conclusion you are trying to explain.
fantispug said:
The force is inversely proportional to the square of the distance, ... and every charge exerts a force, so I don't find it obvious whether the force would increase or decrease overall.
Correct, the force is inversely proportional to the square of the distance, but only the component of the force parallel to the surface will cause motion. As the radius of curvature decreases so does the parallel component of the force. Since that decreases either you need more charges or smaller distances, both of which result in an increase of charge density.
As you said, the force on each charge need not be the same, and in general it will not be, but the total force due to the other charges also need not cancel, only the component of that force parallel to the surface need cancel. In general, the charges in a region with a small radius of curvature will have a much greater net force due to the other charges, but that net force will always be normal to the surface.
Likes gracy
Sorry DaleSpam, I knew it was only the components parallel to the surface, I just thought about it implicitly.
When I was talking about bunching up I meant that on a surface of small radius of curvature the points are closer together than on a surface of large radius of curvature. (e.g. on a sphere the furthest point is 2*Radius away - the smaller the radius the closer the other points are).
(Incidentally, that the force normal to the surface at regions of high radius of curvature is greater is interesting - I wonder if you could measure the greater electromagnetic pressure somehow.)
I still don't follow the logic in:
Shooting star: That's what I keep thinking. Maybe the charge density is greater, but since the surface area goes as R^2 this doesn't necessarily imply that the total charge in this region is more.
But there are numerous things telling me otherwise (including the textbook that originally provoked this question), e.g. this (which gives a 1D argument, but it's not intuitive to me that this scales up to 2D) and this http://www.physics.lsa.umich.edu/demolab/demo.asp?id=293 which is (supposedly) actually measuring the charge.
It seems unlikely that they'd all be wrong, but it makes sense to me if they are.
It was given in Griffiths (and derived somewhere else, I'll have to check out my library) that on a conductor in the shape of an ellipsoid
[tex]\frac{x^2}{a^2}+\frac{y^2}{b^2}+\frac{z^2}{c^2}=1[/tex]
with total charge Q, the charge distribution is
[tex]\sigma=\frac{Q}{4 \pi a b c} \left(\frac{x^2}{a^4}+\frac{y^2}{b^4}+\frac{z^2}{c^4}\right)^{-\frac{1}{2}}[/tex]
So, for simplicity set a=b=R, c=2R, write x^2+y^2=r.
Then
[tex]\sigma=\frac{Q}{8 \pi R^3} \left(\frac{r^2}{R^4}+\frac{z^2}{(2R)^4}\right)^{-\frac{1}{2}}[/tex]
So at r=0,z=2R
[tex]\sigma=\frac{Q}{4 \pi R^2} [/tex]
Locally the area is like [tex]\pi R^2[/tex] (this is easier to see with a diagram), so
[tex]q\approx\frac{Q}{4}[/tex]
At r=R, z=0:
[tex]\sigma=\frac{Q}{8 \pi R^2}[/tex]
Area goes like [tex]\pi (2R)^2 [/tex]
so charge goes as
[tex]q\approx\frac{Q}{2}[/tex]
So the charge density at the sharp point (z=2R) is double the charge density at the round point (r=R), but the charge is half. (This is very similar to the two spheres example).
So this would imply that charge does not necessarily accumulate at sharp points, but charge density does.
Is there a flaw in my reasoning, or are all these other things wrong?
If I had the equipment I'd try to actually measure it, but I don't.
Yes, there are two effects that show this. First, the E field can be extremely high just outside the surface of a conductor near a sharp point (the "electromagnetic pressure" you are speaking of). And second, when a conductor is heated up to the point that charges can leave the surface they tend to start leaving primarily from sharp points where the large normal force can help push the charges off.
Correct.
Electron ejection into a vacuum
I have a follow-on question:
Suppose that two equal negatively-charged metal spheres, suspended in a vacuum, are in tangential contact. Does the high curvature at the point of contact act to aid the ejection of electrons into the vacuum? This seems like the inverse of the example above: here the insulating vacuum is the space with the sharp point.
Thanks for your insight.
(Sorry for the delayed response.)
When the two conducting spheres are just touching each so that there is only one point of contact, the curvature is infinite or undefined there. The surface charge density [itex]\sigma[/itex] is infinite at that point, and things as usual become intractable.
A better and realistic way would be to consider the slight flattening that occurs when you press two objects, and the circle of intersection is not a strictly 2-d thing, but also a bit smoothed out. In this case, the [itex]\sigma[/itex] is highest in that circular region, and leakage of charge will be the most from this region.
This leads to an interesting result. Suppose two conducting spheres combined have non-zero charge. Now they are connected by a very long wire such that the surface area of the wire is much more than the two spheres. Then the lion’s share of the charge of the whole system will be on the surface of the wire, because the curvature of the wire is much greater than that of the spheres. (Obviously, I am not talking of mini-spheres as small as the wire.)
Likes gracy
Shooting Star said:
When the two conducting spheres are just touching each so that there is only one point of contact, the curvature is infinite or undefined there. The surface charge density [itex]\sigma[/itex] is infinite at that point.
Correction:
Please read "The surface charge density [itex]\sigma[/itex] is zero at that point."
Just to clarify the last post a bit, it is a well known fact that the charge on the surface of a conductor tends to accumulate at a sharp convexity and tends to vanish at a sharp concavity. If we join the two spheres, and press a bit, and then smooth out this 2-d circle of intersection, it becomes a sharply concave surface in that region, and the [itex]\sigma[/itex] will be very low in this region.
What I had wanted to say in the last post was basically to join the two spheres by a cylinder, and make the joins smooth. Then [itex]\sigma[/itex] may be high on the cylinder, if it's radius is small compared to its height. But on second thoughts, in practice probably the join between two spheres should be considered to be a concave surface, if we just press and flatten the point where they are touching.
We are talking about extrinsic curvatures of the surfaces here, not intrinsic or Gaussian curvatures.
Likes gracy
Related to Why does the charge on a conductor accumulate at sharp points?
1. Why does a charge accumulate at sharp points?
A charge accumulates at sharp points because of the phenomenon known as "corona discharge." When a conductor has a sharp point, the electric field at that point is much higher than the surrounding area. This causes the air molecules around the point to ionize, creating a plasma. The plasma then conducts the charge, leading to an accumulation of charge at the sharp point.
2. Is this accumulation of charge dangerous?
In most cases, the charge accumulation at sharp points is not dangerous. However, in certain situations, such as in lightning rods or high voltage equipment, the accumulated charge can lead to electrical discharge, which can be hazardous. Proper safety measures should always be taken when dealing with high voltage and sharp points.
3. Can the shape of the conductor affect the charge accumulation?
Yes, the shape of the conductor can affect the charge accumulation at sharp points. A pointed conductor will have a higher electric field and therefore a higher charge accumulation compared to a rounded or flat conductor. This is why lightning rods are designed with sharp points to attract and safely dissipate the high voltage from lightning strikes.
4. How does the material of the conductor affect charge accumulation?
The material of the conductor can also affect charge accumulation at sharp points. Conductors made of materials with higher electrical conductivity, such as copper or silver, will have a higher charge accumulation compared to materials with lower conductivity, such as rubber or plastic. This is because conductors with higher conductivity allow for easier flow of electrons, leading to a higher charge accumulation.
5. Can the charge accumulation at sharp points be controlled?
Yes, the charge accumulation at sharp points can be controlled by various methods. One way is by using conductive coatings or materials on the sharp points to reduce the electric field and prevent corona discharge. Another method is by using rounded or blunt tips on conductors to reduce the electric field and minimize charge accumulation. Additionally, grounding the conductors can also help dissipate the accumulated charge.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
