Potential Energy of a compressed gas cylinder
In summary: I'm lost on the last .5.Work done= integral (P-Pa)dV between V1 and V2, where V1 is the volume of the compression chamber and V2 is (V1+volume of barrel), and Pa is the outside pressure.When a volume of gas is compressed suddenly, it is generally an adiabatic process, and no heat is exchanged with the environment. But the temperature will change, and that has to be taken into account.In summary, Sean is looking to replace a steel compression spring with a gas cylinder. The spring is presently designed to absorb a known amount of kinetic energy which it ideally converts to potential energy (neglecting friction, y
Sean Powell
Hello,
This is not a homework problem, but an engineering office problem.
I’m looking to replace a steel compression spring with a gas cylinder. The spring is presently designed to absorb a known amount of kinetic energy which it ideally converts to potential energy (neglecting friction, yadda yadda) and compression is solvable by a simple formula. PE = ½*K*dL assuming the spring was fully relaxed to start.
When I impact a closed gas cylinder the force response is governed by PV=nRT and we can generally assume no major temperature changes during impact. That means force doubles at half stroke, quadruples at ¾ stroke, is 10 times at 90% stroke etc. I know enough to subtract ambient air pressure to get a correct baseline. My problem is the force is so low for the first half of the stroke and climbs so rapidly for the last 20% or so that I’m having a tough time predicting the response of stopping a rolling vehicle impact.
Ideally I need a formula for potential energy in a compressed gas cylinder if I know: Diameter, L1 (usually free length), P1 (usually atmospheric), L2 (new compressed length) and some basic assumptions like human breathable atmosphere not too far from sea level.
From here I think I can calculate peak force so I know how to design the ratchet mechanism so the car isn’t rebounded. Yes, I know I could probably do this better with a dampened spring but there are other design issues (and patents to get around).
Thanks in advance,
Sean
whether it's a spring or an isothermal (or adiabatic) gas cylinder being compressed, the general formula for work done in compressing is:
[tex] W = \int_{x_1}^{x_2} F(x) dx [/tex]
which for a relaxed spring is
[tex] W = \int_{x_1}^{x_2} K \cdot (x-x_1) dx = \frac{1}{2} K (x_2-x_1)^2 [/tex].
for the gas cylinder, you have to define what the dimensions of it are (the radius of the cross section, call it [itex]r_0[/itex], and its length [itex]L[/itex]. I'm setting [itex]x_1[/itex] to zero, with no loss of generality. the ambient pressure is [itex]P_0 = nRT/(\pi r_0^2 L)[/itex]
[tex] W = \int_{0}^{X} F(x) dx = \int_{0}^{X} \frac{P(x)-P_0}{\pi r_0^2} dx = \int_{0}^{X} \frac{nRT/\left(V(x)\right) - P_0}{\pi r_0^2} dx [/tex]
[tex] = \int_{0}^{X} \frac{nRT/\left(\pi r_0^2 \cdot(L-x)\right)-P_0}{\pi r_0^2} dx [/tex]
someone's got to blast out that integral for me. it has a log() in it, that's all that i know. everything other than x is constant.
I have given a simple and rough treatment for another situation much like this in another thread. It's nothing but work done during adiabatic expansion. Perhaps you can have a look at it.
https://www.physicsforums.com/showthread.php?p=1471310#post1471310
Hello Shooting Star.
Thanks for the input. You are correct, while system transfers no heat to the surroundings there probably is a sudden increase in temperature. That was something I did not consider.
In your link you submitted the following formula:
Since the process is quick, we’ll consider it to be adiabatic. Then, PV^g=K, where I am writing ‘g’ for gamma. For air, g=7/5. The value of K can be obtained by putting in the initial values of P and V, which you had given.
After integrating, W=K[V2^(-g+1)-V1^(-g+1)]/(-g+1) – Pa(V2-V1).
Which I think I follow fairly well and have all of the relavent information to fill out and calculate... but the units don't seem to be working out for me. Assuming gamma is unitless, P is N/m^2 & V is m^3 then K has the units of N*m^21/10? The (-g+1) term becomes -2/5 and after a bunch of crunching I see N*m^1.5 for the first chunk of the equation while the right hand portion is N/m^2*m^3 => N*m (please excuse my sloppy shorthand as I convert my hand scribbles into a post) Was the first part of the equation supposed to condense to N*m as well?
Am I making a math error or am I missing something more important here?
Sean
If you follow a consistent system of units, then there is no need to worry about the unit of K -- both sides will ultimately give you the dimension of energy. Just find the values, after converting everything to same units like kg, m ,s.
You have done some math error. I am getting that K has unit of Nm^(11/5). On the RHS inside the bracket it is v2^(-2/5). After multiplying by K, the unit is simply Nm. Both sides should have units of N*m, since that is the unit of energy.
Related to Potential Energy of a compressed gas cylinder
What is potential energy?
Potential energy is the energy an object possesses due to its position or state. It is the energy that is stored in an object, waiting to be released.
What is a compressed gas cylinder?
A compressed gas cylinder is a container that holds a gas under high pressure. It is a common way to store and transport gases such as oxygen, nitrogen, or carbon dioxide.
How is potential energy related to a compressed gas cylinder?
In a compressed gas cylinder, the gas is compressed to a smaller volume, which increases the pressure and stores potential energy. This potential energy can be released when the gas is allowed to expand and do work.
How is the potential energy of a compressed gas cylinder calculated?
The potential energy of a compressed gas cylinder can be calculated using the formula: PE = mgh, where m is the mass of the gas, g is the acceleration due to gravity, and h is the height of the cylinder. Alternatively, it can also be calculated using the formula: PE = 1/2kΔV^2, where k is the gas constant and ΔV is the change in volume.
What are some common applications of compressed gas cylinders?
Compressed gas cylinders have a wide range of applications, including powering tools and equipment, providing breathable air for scuba diving or medical use, and creating pressure for refrigeration and air conditioning systems. They are also used in industrial processes, such as welding and cutting, and in the production of food and beverages.
  • Thermodynamics
  • Thermodynamics
  • Science and Math Textbooks
