Limit Question: Solving for (Infinity)^0 with n^(1/3) and (2+n^(1/3))^(1/n)
  • Thread starter transgalactic
  • Tags
    Limit
In summary, the conversation discusses finding the limit of [2+n^(1/3)]^(1/n) as n approaches infinity. The initial approach led to an indeterminate form of (infinity)^0, which is undefined. A suggested solution involves evaluating the limit of ln[2+n^(1/3)]^(1/n) and using L'Hopital's Rule to find a value of 1.
transgalactic
1,395
i added a file with the question and how i tried to solve it
lim [2+n^(1/3)]^(1/n)
in the end i always get (infinity)^0 type of object
then i got stuck
what to do next??
I am unable to see your file, so what limit are you looking for?
[tex]\lim_{x \to 0^-} [2+x^{\frac{1}{3}}]^{\frac{1}{x}} [/tex] or
[tex]\lim_{x \to 0^+} [2+x^{\frac{1}{3}}]^{\frac{1}{x}} [/tex] or
[tex]\lim_{x \to \infty} [2+x^{\frac{1}{3}}]^{\frac{1}{x}} [/tex] ?
Edit:
Just a thought- let [tex]p=\lim_{x \to \infty} \frac{1}{x}[/tex] and evaluate. Then substitute into [tex]\lim_{x \to \infty} [2+x^{\frac{1}{3}}]^p [/tex] and evaluate.
then i got stuck
what to do next??
As n goes to infinity, this goes to 1.
As n gets very large, you may approximate this by [itex] n^{1/(3n)}[/itex]. taking the natural log of this (or log in any base), you can show that the ln goes to 0 as n goes to infinity. hence the initial function tends to e^0 = 1.
ooohh sorry i forgot a part in the limit
its
n>>infinity
and i did got
lim n^[1/(3n)]
you say i need to take log
it will be
log X =1/(3n)
n
i didnt understand how to solve it that way
its
n>>infinity
Great.
Then, as I mentioned earlier, evaluate:
And plug into:
Any non-zero base, raised to the power of [tex]0[/tex], is...
your first limit P gives me 0
the second one is infinity
and infinity^0 is not 1
its undefined
its
n>>infinity
and i did got
lim n^[1/(3n)]
it will be
log X =1/(3n)
n
You need to consider the limit of [itex] \frac{\ln n}{n} [/itex]. The limit of this as n goes to infinity is zero. This is one of the basic limits and you probably can find the proof in yoru textbook.
For the second limit atqamar posted [tex]\lim_{x \to \infty} [2+x^{\frac{1}{3}}]^p [/tex] is going to be 1 because anything other than zero raised to the 0 power is 1. How did you get undefined?
Edit: How did you get infinity to the zero power? Thats not what the base is going to be
the base is :
2+ x^(1/3)
if x gose to infinity the the base gose to infinity
and p=0
it gives me (infinity)^0
and its undefined
transgalactic said:
the base is :
2+ x^(1/3)
and p=0
and its undefined
It is undefined because this is what is called an "indeterminate power"; other examples are 0^0 and 1^infinity. Nonetheless there will be a value for it.
The solution involves one of the more exotic applications of L'Hopital's Rule, since this first has to be wrestled into the form of an indeterminate ratio 0/0 or infinity/infinity.
You start off by taking the logarithm of your expression, which will be
lim n-> inf. (1/n) ln [2 + n^(1/3)] ; this now has the apparent result 0 · infinity (an indeterminate product).
You next rewrite this product as a ratio, since f · g = f / (1/g) ; it is usually best to put the logarithmic expression in the numerator to apply L'Hopital's Rule, since we're going to be taking derivatives:
lim n-> inf. ( ln [2 + n^(1/3) ] ) / n .
This now has the apparent value infinity/infinity, making it a candidate for L'Hopital's Rule. Differentiate numerator and denominator separately:
lim n-> inf. [ ( 1/{ 2 + n^(1/3) } ) · ( 1/{ 3 · n^(2/3) } ) ] / 1 [using the Chain Rule on the numerator]
Since n appears in the denominator raised to positive powers, once this compound fraction is simplified, the limit is (1/2)·(1/3)·0 = 0 .
This, however, is the natural logarithm of the original expression, so this limit is the natural logarithm of our original limit. So the original limit is e^0 = 1 .
This is a formal technique for dealing with such problems; as nrqed and atqamar point out, though, this one can sort of be "eyeballed" for a solution...
FAQ: Limit Question: Solving for (Infinity)^0 with n^(1/3) and (2+n^(1/3))^(1/n)
What is the value of (Infinity)^0?
The value of (Infinity)^0 is undefined, as any number raised to the power of 0 is equal to 1, but infinity is not a real number and therefore cannot be raised to any power.
How do you solve for (Infinity)^0?
You cannot solve for (Infinity)^0, as it is an undefined value. It is important to remember that infinity is not a number, but rather a concept of endlessness.
What is the significance of n^(1/3) in the equation?
n^(1/3) represents the cube root of n, which is a mathematical operation that can be applied to any real number. In this equation, it is being used to evaluate the limit as n approaches infinity.
How do n^(1/3) and (2+n^(1/3))^(1/n) relate to each other in this equation?
Both n^(1/3) and (2+n^(1/3))^(1/n) are being used to evaluate the limit as n approaches infinity. They are related in that they are both part of the same equation and are being used to find the solution for (Infinity)^0.
Is there a way to approximate the value of (Infinity)^0?
No, (Infinity)^0 cannot be approximated as it is an undefined value. It is important to remember that infinity is not a real number and cannot be manipulated or approximated in the same way that real numbers can.
