How Far Does a Rocket Sled Travel with Variable Acceleration?
In summary, the conversation discusses a motion question involving a rocket sled starting from rest and accelerating until it hits a water brake. The total distance traveled is calculated using equations for constant acceleration, and calculus is used to solve for the non-constant acceleration. The final total distance is found to be 2300m.
eluu
[SOLVED] Motion Question (Dynamics)
EDIT: I just realized this question was better suited in this forum than the engineering one, sorry :(
The rocket sled starts from rest and accelerates at a = 30 + 2t until its velocity is 400m/s. It then hits a water brake and its acceleration is a = -0.003v^2 m/s^2 until its velocity decreases to 100 m/s. What total distance does it travel?
v = u + at
s = ut + at^2/2
v^2 = u^2 + 2as
I'm pretty sure my first part is correct but here it is anyway:
v = u + at
v = u + (30 + 2t)t
*Sub in values and i get t = 8.508s, then i get s = 1701.652m from the other equation
For the next part I've done this:
a = -0.003v^2
v dv/dx = -0.003v^2
dv/v = -0.003dx *integrate both sides
ln(v) = -0.003x + C
when v = 400, x = 0, C = ln(400)
ln(v) = -0.003x + ln(400)
so when v = 100, i get x = 462.098m
So the total distance i get is 2163.750m but the answer says 2300m...
Where did i go wrong or is the answer given incorrect? :S
The equations you give only hold for constant acceleration. The acceleration function you give (a=30+2t) is not constant, and so you will need to use calculus to solve even the first part.
Ahh whoops, i see it now :)
Now i get the first part with t = 10s and a displacement of 1833.333m
Thanks cristo!
Thanks cristo!
You're welcome!
FAQ: How Far Does a Rocket Sled Travel with Variable Acceleration?
What is motion in physics?
Motion in physics is the process of an object changing its position over time. It involves the concepts of distance, displacement, speed, velocity, and acceleration.
What is the difference between speed and velocity?
Speed is a measure of how fast an object is moving, while velocity is a measure of both the speed and direction of an object's motion.
What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It can be positive (speeding up), negative (slowing down), or zero (constant speed).
What is Newton's first law of motion?
Newton's first law of motion, also known as the law of inertia, states that an object will remain at rest or in motion with a constant velocity unless acted upon by an external force.
How do forces affect motion?
Forces cause changes in an object's motion. They can cause an object to start moving, speed up, slow down, or change direction. Forces are described by their magnitude, direction, and point of application.
