Dark Matter: Canadian Astronomers Suggest It May Not Exist
In summary, Two Canadian astronomers have proposed that dark matter, a mysterious substance thought to make up the majority of matter in the universe, may not actually exist. They argue that modified gravity theories can explain observed phenomena just as well as dark matter theories, without requiring belief in unseen metaphysical entities. However, this theory is still being studied and has yet to be fully proven. Other scientists argue that dark matter is necessary to explain a wide range of observations on different length scales. The debate continues as scientists try to understand the true nature of the universe.
Ivan Seeking
Staff Emeritus
1,759
Two Canadian astronomers think there is a good reason dark matter, a mysterious substance thought to make up the bulk of matter in the universe, has never been directly detected: It doesn't exist. [continued]
http://www.space.com/scienceastronomy/071029-mm-mog-theory.html
Astronomy news on Phys.org
First, I doubt the Bullet cluster can be explained by modified gravity.
Second, even if so, modified gravity theories have a major problem with explaining observations on all scales. Hints of dark matter has been observed on a wide range of length scales, and while you may be able to fit one of the observations with modified gravity the same fitting won't generally work on the other scales.
Seeing as how I'm not a mind reader, I guess I'll have to wait to see the paper hit Arxiv before I place any bets on that one.
Here's an earlier cosmological overview paper on this topic.
http://arxiv.org/PS_cache/arxiv/pdf/0710/0710.0364v2.pdf
As far as I can tell it does seem to "fit" just fine. What exactly was your complaint with his overview presentation?
It seems to me that putting all your eggs in the Lambda-CDM theory (or any cosmological theory that is based on metaphysical constructs) has serious scientific drawbacks. His mathematical presentation of this modified gravity theory looks mathematically sound to me. It looks just as sound as any Lambda model I've ever looked at, and it requires a lot less faith in unseen and unproven forces of nature. I'm certainly looking forward to seeing how they explain the lensing data from the bullet cluster analysis.
Wait and see. Anyway, I think the words by Douglas Clowe are not so strong.
The 'Bullet Cluster' greatly constrains the nature of a universe devoid of 'Dark Matter'. Too strong to survive, IMO. Liking DM is optional. Consider how many years it took to detect' the atom.
There is a physical difference however. In the case of the atom, we could in fact "detect" the presence of matter in controlled laboratory conditions, and we knew there were different forms of matter based on their chemical properties. The atoms could be manipulated in controlled scientific conditions. Dark matter however is not like that. Nobody knows what "dark matter" is made of, or if it even exists because it is a mathematical construct that is based upon pure observation of objects that are light years away from us, and that we could never hope to "control" in any scientific sense. There is no real "testing" that can go on because it's a mathematical hypothesis at this point in time, not a physical entity that we can play with in a lab.
The modified gravity theory is also a purely mathematical construct that is designed to explain the same pure observations of objects and events that are light years away from us. Like dark matter theory, there is no obvious way to "test" this idea in a controlled scientific experiment.
Both of these mathematical theories seem explain these distant observations, each in their own unique mathematical way. How then do we determine which theory is the "better" scientific theory?
The decision to label on theory as "better" than another is ultimately a subjective judgment call. The way I personally make that choice is for me to see how well the idea conforms to what I can observe, and how few (or how many) metaphysical entities it relies upon. For my money, the fewer the metaphysical entities it requires, the better. I'm much more open to modified gravity theory, and theories that attempt to concentrate (normal) mass along the axial plane of the galaxy, to explain distant movements, than I am open to concepts about "dark matter". I've never seen any dark matter show up in any controlled scientific lab test. I therefore have no physical evidence that it even exists in nature.
This particular modified gravity theory does not require that I put faith in a metaphysical entity, and therefore I personally find it more attractive than a 'dark matter' explanation for the same events and observations. Both ideas seem to solve the problem mathematically, but dark matter theories require that I put faith in something that nobody can demonstrate actually exists in nature.
Hopefully at the LHC.
According to the most popular dark matter models (WIMPs) you wouldn't have, since the particles have masses around and above the electroweak scale. (100 GeV-10 TeV.)
Could it be black dwarfs, white dwarfs, planets ..anything except stars out there that we can not see then they play the role of dark matter? I think by now, scientists only observe stars and consider them matter. How about other stuff?
The mainstream [itex]\Lambda[/itex]CDM model has two types of Dark Matter, baryonic and non-baryonic DM.
The total amount of DM is about 27% of the total density, and therefore mass, of the universe. The Big Bang in the standard model can only produce about 4% of the total density as baryonic matter, mainly ordinary hydrogen and helium, (Note the visible baryonic matter, stars and nebulae, comprise only 0.3% of the total), and therefore about 23% of the total has to be some unknown non-baryonic species. Neutrinos, axions and other exotic particles have been candidates at one time or another.
There are a number of different types of observations: galaxy rotation curves, galaxy cluster dynamics, cluster gravitational lensing, large scale structure formation rates and the analysis of the CBM fluctuations, which is evidence that something is out there - but what?
Alternatively if all these observations are all to be explained by a modified theory of gravitation then that theory would have a mountain to climb, and explaining the Bullet Cluster is a particularly difficult case for such a theory.
Until the DM particle(s) have been identified in the laboratory (LHC?), their properties measured and found to be concordant with astronomical and cosmological constraints, we shall not really know what we are talking about.
For example, as another alternative, if the expansion rate of the early universe were different to that of the standard model, due to the action of some as yet unknown scalar field for example, then the amount of baryonic matter able to be produced in the BB would change and such a scenario might provide a third possibility; that all DM is in fact baryonic in nature. But then you would have to explain where it all is today and why it cannot be 'seen'!
The mainstream [itex]\Lambda[/itex]CDM model is the best thing we have going, at the moment.
Garth
Big Bang Nucleosynthesis puts upper limits on the amount of baryonic (i.e. ordinary) matter in the universe. This can also be seen from observations of the CMB.
Thus, ordinaty matter can only make up a fraction of the total amount of dark matter needed. The major part must be non-baryonic.
Edit: I see Garth was faster...
Thanks Garth and El. I can say one word by now: Wait.
Experimental proof is the gold standard. Dark matter is not unlike neutrinos [which also took a long time to experimentally confirm], only more elusive. I am extremely confident it will be detected, but not by the LHC. It sprang, IMO, from energies far beyond the capabilities of terrestrial laboratories. There are a number of very good experiments currently underway that take different approaches. I'm confident one or more will succeed - very likely by the end of this decade. See:
http://hepwww.rl.ac.uk/UKDMC/dark_matter/other_searches.html
for examples.
Can you even describe a LHC test that might "falsify" the notion of DM?
That's quite an energy range wouldn't you agree? Should we be able to be a bit more specific? It seems to me that WIMPS are but one "possible" theory related to DM, so this problem still seems to come back to the same issue.
Is there any controlled scientific LHC test that you would accept as a falsification of the existence of DM? I ask this because I know of no controlled scientific test that demonstrates that DM exists in the first place, and there is at least one other theory on the table that doesn't requires DM at all. If we can't empirically demonstrate that DM even exists in nature, and we can't falsify the idea in any controlled scientific test, and it isn't necessary to use DM to describe events in the universe, doesn't that put the concept of DM *outside* of the realm of science?
Controlled experimental evidence is indeed the gold standard of science. In science it is also true that the burden of proof is always on the one making the claim.
But there is a very significant difference between neutrino theory prior to their detection in controlled experiments and DM theory today. In the case of neutrinos, it was a series of controlled scientific tests that led us to hypothesize the existence of neutrinos. In these controlled scientific tests, we found evidence that there was a small amount of missing energy in certain known (and identified) particle decay reactions. If neutrinos did not exist to account for this missing energy, then the law of conservation of energy would have been violated. It was a known law of physics, and controlled scientific testing that led us to hypothesize the existence of neutrinos. More importantly we already knew which particle decay reactions created them, and we knew where them came from. That allowed us to create additional tests that could verify their existence.
With DM however, there are no controlled tests that demonstrate they exist, and no laws of physics that require that they exist. More importantly however, pure observation of objects that are light years away do not contain any control mechanism of any sort. There is also more than a single way to account for the lensing patterns in the Bullet Cluster data, and there is more than one way to account for the movements of galaxies, some of which do not require DM at all. We can't even be sure that DM exists based on these observation, and we have no idea where DM comes from, or how to test for it. More telling however is the fact that we have absolutely no way to falsify the concept.
for examples.
Which scientific test would falsify the DM theory? If the theory cannot be falsified, and there is no empirical evidence that DM even exists, then what makes DM theory superior (in a scientific sense) from modified gravity theory?
Just to keep the pot boiling...
Durrer and Maartens' overview article for the dark energy issue of GRG published on today's physics ArXiv: Dark Energy and Dark Gravity
Observations provide increasingly strong evidence that the universe is accelerating. This revolutionary advance in cosmological observations confronts theoretical cosmology with a tremendous challenge, which it has so far failed to meet. Explanations of cosmic acceleration within the framework of general relativity are plagued by difficulties. General relativistic models are nearly all based on a dark energy field with fine-tuned, unnatural properties. There is a great variety of models, but all share one feature in common -- an inability to account for the gravitational properties of the vacuum energy. Speculative ideas from string theory may hold some promise, but it is fair to say that no convincing model has yet been proposed. An alternative to dark energy is that gravity itself may behave differently from general relativity on the largest scales, in such a way as to produce acceleration. The alternative approach of modified gravity (or dark gravity) provides a new angle on the problem, but also faces serious difficulties, including in all known cases severe fine-tuning and the problem of explaining why the vacuum energy does not gravitate. The lack of an adequate theoretical framework for the late-time acceleration of the universe represents a deep crisis for theory -- but also an exciting challenge for theorists. It seems likely that an entirely new paradigm is required to resolve this crisis.
Garth
LHC could falsify many of the most popular models. If in the future energies up to ~10 TeV will be probed without finding anything, then WIMPs are in big trouble. Of course people can after that always try to build coco-models which would still avoid experimental constraints, but probably with a lot af fine-tuning (maybe even of the order needed for modified gravity theories!).
The WIMP hypothesis rests not only on its ability to explain all "dark matter"-observations (on all observed scales) and correctly account for the formation of large scale structure, but also on motivations from pure particle physics. We expect there to be new physics around the electroweak scale, and if one of these new particles turns out to be stable it automatically (if it was in thermal equilibrium in the early universe) would give a relic density of exactly the order needed to explain all dark matter. (This is the so called "WIMP miracle".)
I do not find it very unlikely that one of the expected new particles would happen to be stable. (Like e.g. the neutralino in the MSSM.) At least I find it much more likely than the curve fitting (and abandonness of the well tested GR) going on in modified gravity theories. However, that is of course a personal taste. If LHC or any direct or indirect detection experiments won't find anything within a decade, I will probably abandon my current position.
This is just wrong. See my post above.
Try looking at this issue from a skeptics perspective for a second. These tests you describe are essentially a fishing expedition. Your (they're) "fishing" for anything in an energy range that is quite vast, and covers several orders of magnitude. That's not at all like the neutrino postulation process where we could define our theoretical numbers with some precision, and we even had identified the particle physical interactions that were the likely release point of neutrinos. Even after we cover this entire energy range, we still can't be sure about what other "whack-a-mole" versions of DM might crop up. I find it a tad disconcerting that we're hoping for a "miracle". I need some hard evidence here.
Well, that seems like a very ironic case of finger pointing from where I sit, especially since GR has essentially been abandoned in Lambda-CDM theory as I percieve it. GR as Einstein taught GR to his students, had no dark matter component, nor any dark energy component, and it certainly had no inflation component. Even Einstein's famous addition of a constant to GR he later rejected as his greatest blunder. In Lambda-CDM theory, the GR related to known types of mass that Einstein referred to in GR only makes up about 4% of the whole picture. From my perspective Lambda-CDM theory has abandoned 96% of GR in favor of a theory that relegates the GR that Einstein described (GR related to known forms of mass) to bit player status.
If I could see evidence from a controlled experiment, like beta decay reactions in the case of neutrinos, that required that we posit a theory like dark matter to uphold known laws of physics, then I might be willing to "wait and see" as you are willing to do. As it is, I simply don't see any actual physical evidence from any controlled tests that demonstrates that DM exists, or even hints that DM exists in nature.
All I've seen thus far to support the theory of DM is another mathematical theory related to what *might* be happening to objects that are light years away us and that are based on pure observations that are lacking any sort of control mechanisms. It's a bit like pointing to that same event in the sky and claiming that "something-I-never-heard-of-before" did it. From a scientific point of view, I am forced to take the skeptics approach. If the LHC comes up with any actual direct physical evidence that DM actually exists in nature, and affects objects in nature, then I"ll have to abandon my current position that DM does not exist. Skepticism is a part of the scientific method. The burden of proof in science is always on the one making the claim. If others believe that DM can affect objects at a distance, let them first show us that DM can effect objects in a lab. I'll keep an open mind on this subject, but I'll need to see some hard physical evidence that demonstrates that DM even exists before I feel any sort of confidence in the idea that DM can effect objects at a great distance.
No, "they" are not "fishing" within that energy range. It will be covered in a systematic way.
After we have searched that energy range we will hopefully have found something. If not, WIMPs are dead to me.
I don't think you got my "miracle". I am not saying we have to wait for a "miracle" to find dark matter, but that the "miracle" is already there on theoretical grounds. The "miracle" gives us a chance of solving two problems at the same time (hierarchy problem and dark matter.)
Note that I am not saying dark matter (in the form of WIMPs) exist. Only that I find it a reasonable explanation which is much more likely than modified gravity.
GR is not abandoned in LCDM, and I cannot see why you are under that impression. The energy-momentum tensor is just a collection of everything that contributes to the energy density of the universe, and not just the forms of energy that happened to "be known" when Einstein forumlated his theory. To say that the inclusion of dark matter abandons GR is just as saying that the inclusion of neutrinos abandons GR.
Dark matter is just as much "matter like" as ordinary matter and should hence be included as matter in the energy-momentum tensor.
Regarding the cosmlogical constant: The cc is part of GR. The symmetries of GR allows for it and there is no reason a priori to put it to zero.
I guess you are quite alone with your perspective.
The hints that DM exists in nature are plenty (galaxy dynamics, cluster dynamics, large scale formation dynamics, hiearchy problem). Each one of these scales may separately be solved by other things than WIMPs (e.g. modified gravity theory, another modified gravity theory, again another modified gravity theory, and divergence canceling physics without stable particles.), but the strength of WIMPs lies in the simultaneous solution.
As you say there are yet no laboratory experiments that demonstrate the existence of dark matter. I am not saying WIMP dark matter definitely exists, but just that it is the most reasonable explanation we have come up with.
And I don't think anyone claims that the existence of particle dark matter is definite.
And that is exactly what we currently are trying to do.
The point here is that the search for WIMPS is unlike the search for the neutrino. In the case of the neutrino, we already had some idea of where these particles came from, and we understood the source of the particle in question. We also understood how the theorized particle tied back into particle physics.
In the case of the fabled "WIMP" particle, we have no known particle interaction source, and there is no known particle that has these properties. The is no known particle interaction that results in "missing" mass or energy that might explain where WIMPS come from. Essentially we're just dragging a huge net through a very wide energy spectrum, and hoping to find something.
Here's where I think a skeptical approach is warranted. If and when this search for WIMPS leads to something tangible, *then* (and only then) will WIMPS become "alive" to me. At this moment in time, I see zero evidence for WIMPS. In science, the burden of proof always falls to the one making the claim because a negative cannot ever be disproved. If and when I see tangible evidence to suggest that WIMP exist in nature, and have some effect on matter, *then* I'll be interested in studying them. At the moment however I have no evidence that WIMPS exist.
Why? What is more "reasonable" about WIMPS it in your opinion? What makes them "better" than MACHOS for instance?
That's a bit misleading. While your point about "known" particles is valid, DM is not actually "known" to exist at this point in time. While I have no problem with you coming up with a GR theory that includes neutrinos because they are "known" to exist, I would have a problem with you inserting invisible things into GR theories. That part about "known" particles is a valid point in your argument, but DM is not "known" to actually exist.
I see absolutely no scientific validity for including inflation, and dark forces in GR since they have not been shown to exist in nature, and are not "known" to exist in nature. It would be like me handing you a completely new theory related to a half dozen invisible forces that you've never heard of before, and then tying it loosely back to a variation of Einstein's GR theory. Suppose I did all that and started relegating normal matter and normal GR to a 5% role in the process. You wouldn't let me claim that my invisible forces are "known" to exist. They don't exist as far as anyone "knows" from controlled experimentation.
This is a claim that you simply cannot backup with results from controlled scientific experiments. In other words you simply "assume" that dark matter exists, and that it is like normal matter in that respect. However, you cannot show that it is so in a controlled scientific experiment. You simply have *faith* that DM exists, and that it has properties that are similar to normal mass. You can't backup that claim via science, it's something I simply have to accept (on faith) as part of your theory. Unfortunately I don't accept that DM exists, let alone that it has similar gravitational properties without some tangible evidence of these claims from controlled scientific experimentation.
If your search for WIMPS leads to some tangible evidence that WIMPS exist, and it can be shown that they act like normal matter as it relates to the forces of gravity, *then* your statement is no longer a statement of faith, but rather it will become a statement of fact. Until then however, it's purely an act of faith on your part to even make that claim.
GR (from a mathematical point of view) does indeed allow us to insert a constant. Einstein did it himself and then called it his greatest blunder. The fact we can do it, doesn't mean we "should" do so. Just because I can do it, does not mean I can claim that my half dozen new theorized invisible forces can be inserted into GR. I can't slap unknown forces of nature to GR and then claim that I'm still basing my theory on GR. The fact you *can* add a constant to GR doesn't mean you *should* do so, or that it's correct. Einstein regretted adding a constant to GR in fact.
But MOND theories and modified gravity theories explain these events too. Neither of these options require DM to explain such observations. That fact that there is "missing mass" observed in some distant observation is not an automatic guarantee that this "missing mass" requires WIMPS. For all you know that missing mass is in the form of MACHOS, or something far more mundane than WIMPS or axions.
It seems to me that this is a subjective judgment call, not a scientific statement of fact.
It evidently is very "reasonable" from your current perspective. From my EU perspective however, it's like me claiming that this "missing mass" was in the form of invisible potatoes, and that I believe that my theory about invisible potatoes is "reasonable". I don't know how to define "reasonable" when it relates to a particle (or in this case several metaphysical constructs) that has never been shown to exist in nature.
In science however, the burden of proof always falls the person who is making the claim. If you believe that DM can have an effect on normal matter, then it is up to you to demonstrate this claim. If you cannot demonstrate that claim in controlled experiments, then it can only be considered an act of faith, not a scientific solution. A lot of people seem to have "faith' that DM exists. I simply do not share that faith. I take a more skeptical approach to science. I expect to see evidence that something exists in nature before I simply *assume* that it exists and has an effect on distant objects.
If and when WIMPS or axions, or Macho's are shown to exist, then your theory becomes less of an act of faith, and more of a statement of fact. At the moment however, I can only describe your search for DM (particularly WIMPS) as an act of faith. Science requires leaps of faith at times, if only faith in the idea so that the new idea can be tested. I'm not suggesting we should eliminate faith from science, but I can't personally put much faith in the notion of DM when there are other viable scientific theories to explain these observations that do not require DM. If however DM can be shown to exist in controlled scientific experiments, *then* I'll become a lot more interested in the idea.
M.M., you are making a straw-man. Don't try to insinuate I am claiming that WIMPs exist. All I am saying is that there are good hints for its existence.
BBN (and CMB data) put an upper limit on the number of baryons. MACHOS are baryonic dark matter, and hence cannot make up all the dark matter needed. Moreover, the formation of large scale structures does not work as well.
I really cannot see how you even can see a problem with invoking dark matter in the energy-momentum tensor? What is wrong with postulating a WIMP candidate (of which we of course know the equation of state and can hence plug into the energy-momentum tensor) and then use GR to calculate its consequences? I simply cannot see where you find a problem with this?
Yes, we assume e.g. a WIMP model. The model tells us it has the same properties as ordinary matter (i.e. the same equation of state). Then we use GR. Again, where is the problem?
Yes, GR includes a cosmological constant term. Wheter or not it should be put to zero is up to experiments to decide.
MOND theories have problems explaining all scales at the same time. (Also, they of course provide no solution to the hierarchy problem.)
Then you need to do some reading.
Go on and calculate the relic density and structure formation scenario for your potatoes. Also make sure they can explain the astronomical observations on all scales, and that they are not already excluded by existing experiments. Please also motivate their existence by something totally unrelated to dark matter. (I guess the hierarchy problem won't work here though...)
While I have no problem with you suggesting that there are "good hints" for the existence of 'missing mass', we cannot even be certain of what form that missing mass might take. While I have no real problem with a MACHO oriented explanation for "missing mass", or even a neutrino oriented explanation for 'missing mass' (now that we know that neutrinos have mass), I do have a very huge problem with assuming that this missing mass is in the form of a WIMP. I have a problem with that idea because as far as I know, WIMPS do not exist in nature. That is an extraordinary claim. It would be akin to me jumping to the conclusion that that an object we saw in the sky together, that neither one of us could happen to identity at that moment, is "probably" from another planet. I'll grant you that there seems to be mass that we cannot easily identify, but I have no evidence that this missing mass exists in WIMPS through any controlled scientific test. If and when you find controlled scientific evidence of WIMPS, and can show me tangible properties of WIMPS based on these controlled tests, then I'll be happy to let you suggest that WIMPS might do the trick as it comes to explaining that missing mass problem, and those galaxy rotation patterns.
It seems to me that most of the presumed "dark matter" theories show that the missing mass is found around the outer edge of the galaxy. IMO that is much more easily explained in terms of a MACHOS (that act like a large asteroid belt) than being due to any sort of subatomic particle. It seems to me that a subatomic particle would be more apt to follow the typical mass bodies of a galaxy, since they would presumably be created in, and released from these normal mass particles.
Well, BBN really puts no upper limit on the number of baryons. The bigger the BANG, the more the baryons. It does put an upper limit on heavy atoms. Even the BBN stage of BB theory however has a serious "problem" in the first second or so of the process. As electrons, protons and neutrons, and other forms of mass began to form, the forces of gravity should have pulled the whole thing back together again in an instant. Without relying upon a metaphysical construct from the start (Guth's theorized inflation field), the whole BBN process would preclude expansion from ever occurring.
Even more interesting is the fact that the CMB data actually shows that there is a "hole" in the universe that should not even exist according to the inflation theory. Form the very first instant, the BANG theory relies upon unproven forces of nature, and these theorized forces of nature have already failed some key observational tests.
I don't see the correlation here between baryonic dark matter, and any notion that it "cannot" makeup all the dark matter needed. As far as I know from tangible science, that's the only kind of "dark mass" that you have to work with. There isn't any other form of "dark matter" that I am aware of based on controlled scientific tests.
I don't actually have any problem with you invoking MACHOS in the energy-momentum tensor. I have a huge problem with you invoking unproved forms of matter and energy into the energy-momentum tensor however, just as you would have a problem with me invoking non-baryonic invisible potatoes in the energy-momentum tensor. If I cannot provide you with strong evidence of non-baryonic invisible potatoes from controlled scientific experimentation, then I have no business trying to stuff them into a GR based math formula.
But you don't even know the actual energy state of a WIMP, or even if it exists yet. You have a very vague idea here that involves many orders of magnitude of an energy state, and nothing in the way of tangible, physical, empirical evidence to show that it actually exists in nature. You can postulate it's existence if you like, but then you are obligated to show that it actually exists before you point at distant events and claim that WIMPS did it.
The problem is that you have never demonstrated that WIMPS physically exist in reality. You don't have any empirical evidence that WIMPS even exist, and no known form of mass acts like a WIMP. That's the problem.
"Pure" GR (GR without metaphysical constructs), does not require any sort of 'constant' to describe the gravitation attraction of the energy-momentum tensor. It works fine with real mass made of real particles to describe the gravitational attraction properties of matter. If there are other forces of nature acting on objects of mass, those forces of nature probably have "properties" that are based on the specific type of energy involved, and GR would not be necessary to describe these forces. GR is great for describing the attraction force of mass objects. There is no evidence that GR *should* be used to try to describe all the external forces of nature that act on mass as one big gargantuan math formula. If the external influences on matter are EM oriented, perhaps Alfven's MHD theories would be better suited when it comes to doing the math.
There's a bigger problem however. The math we have done with Lambda-CDM theory turns out to have a gaping hole in it, despite a nearly homogeneous prediction of inflation.
I can see why Einstein called the introduction of this constant as his greatest blunder, because even if there are external forces of nature acting on mass bodies, these forces will have mathematical properties that are directly related to the force involved, that are not necessarily even related to the gravitational component. IMO the Lambda-CDM theory isn't "pure" GR. It's a loosely GR oriented theory with a liberal dose of metaphysics mixed in, it's about 96% metaphysics in fact.
MOND theorists, and modified gravity theorists seem to disagree with you. WIMP theories have serious problems explaining all time scales at the same time as well, particularly that first serious problem about showing that they actually exist in nature.
I think you're taking my statements a bit too literally here. I don't actually have any faith in invisible potatoes, or WIMPS or axions, or anything 'invisible' to physics here on earth. As I suggested earlier, if and when you can show me evidence that WIMPS actually exist in nature, and you can demonstrate their influence on photons and protons and neutrons and electrons in controlled scientific tests, then I'll be happy to entertain WIMP theories. Until then, I will consider WIMP theories to be pretty "wimpy, wimpy, wimpy". :) Sorry, I just couldn't resist.
I absolutely have no philosophical problem with you inserting baryonic mass (MACHOS) into GR theories. It's only when you attempt to insert unproven entities into GR that I get uncomfortable. Extraordinary claims require extraordinary evidence. If you claim that non-baryonic forms of mass exists, the onus of responsibility to demonstrate your claim falls to you. That is how science has always worked, and I'm not asking for the moon here. As long as you keep inserting things like DE, (non baryonic) DM and inflation into GR, I'm going to require that you demonstrate that these things actually exist in nature. I will willingly let you toss MACHOS or neutrino mass into GR and mix them liberally. I will however require additional empirical evidence of any other form of "dark matter" that you might attempt to toss into GR. It seems like this is a very fair and reasonable request on my part since it SOP for all areas of science, not simply astronomy.
What about direct-detection experiments like CDMS and Liquid Xenon? Both are finally becoming sensitive enough to probe the heart of parameter space where WIMPs are thought to exist. If nothing is seen within 5 to 10 years then that will raise some serious questions, but I think for now we need to sit and wait.
If someone comes up with a modified gravity theory which can explain what we're seeing, that doesn't make it right.
M.M., this is getting silly. You are still making a straw-man. You still do not seem to get the difference beween a hypothesis and a fact. (WIMP dark matter is a hypothesis, not a claimed fact.) And please, try to shorten the posts. I do not find time to answer all of your comments, but I'll do a few.
As I said, MACHOs are baryonic. Baryons cannot make up more than a fraction of the dark matter needed (due to constraints from BBN).
You have a lack of knowledge here. The WIMPs (if they exist) were created at the big bang. That is why one talks about the "relic density". Furthermore, huge super computer simulations (e.g. the "Millenium simulation") have simulated the universe's structure formation including WIMPs. The resulting distributions agree very well with the observations we make. In fact, simulations without (cold) dark matter fails to reproduce the observed structures. Your impression that the dark matter gets distributed in the same way as baryonic matter is simply false.
Yes it does. I don't have the energy to go into this. All I will say is that the scientific community agrees with me.
No, I have no problem with you invoking potatoes into the energy-momentum tensor, why would I? Your arguing about what is allowed in the energy-momentum tensor and not appears very strange to me.
Argh, what i do is to postulate a WIMP and calculate its consequencies. I know its equation of state perfectly (its just the same as for matter, simply because it is matter, i.e. pressure=0. If I would postulate a very light particle it would have the same equation of state as radiation: pressure=density/3)
No, that is not a problem since I postulate a model for a dark matter particle. Of course that doesn't prove the particle exists, but it doesn't stop me from calculating its properties.
WIMPs have mass (by construction). Hence it interacts gravitationally.
First, you certainly belong to a minority then.
Second, even if you somehow refuse to allow the cosmological constant in "pure" GR, what does this have to do with dark matter? Dark matter can still be invoked in "pure" GR.
In fact I know it exists: neutrinos, electrons, positrons. I don't know wheter WIMPs exists, and I have never claimed so either. Stop insinuating that.
If I follow your reasoning, how could you put in MACHOs when you don't no if they exist?
(Edit: Actually, I think my last question goes right to the heart of this discussion. Please focus on that one.)
But the reverse is also true. Just because non-baryonic dark matter theories can explain what we're seeing, that doesn't mean non-baryonic dark matter exists in nature. It's a hypothesis, that may or may not be true.
All I'm suggesting is that astronomers seem very convinced that the can tell us what was occurring 13.7 billion years ago. I'm far less convinced that we have all the 'big picture" details correct, and I therefore entertain a much larger range of theories as it relates to cosmology.
Of course, that only makes sense. Everyone should be comfortable with the possibility that dark matter may not exist. There's not much point in arguing over it thought - the modified gravity people need to come up with predictions we can test, and the dark matter folks need to wait and hope one of these direct-detection experiments gets a hit.
Actually I do understand that difference. I'm just not convinced that mainstream astronomy understands that difference. I'm always hearing astronomers talk about metaphysical constructs as though we are certain that they exist, and that's the way things happened in some distant past. I keep hearing things like "The universe is about 13.7 billion light years old, plus or minus a few billion years." The only way that could possibly be true is *if* all the various metaphysical hypothetical entities of Lambda-CDM theory pan out. If even one of them does not exist in nature (particularly inflation), that age estimate will be completely meaningless. It is not "fact" that there was ever a "big bang". It is not "fact" that DE and non-baryonic DM exist, or that inflation ever existed in nature. I tend to ruffle a lot of feathers when I say that in public, but it's certainly true that Lambda-CDM theory is not fact, nor is the age of the universe "fact", nor is the notion that there was a "big bang', a factual statement. These are all "theories", or as you said "hypothesis" that may or may not be fact. The "fact" is that inflation has not be demonstrated, and that DE has not been demonstrated, and that non-baryonic forms of DM have not been demonstrated. Lambda-CDM is but one theory among many competing theories. Those are the facts.
I'll try to focus on the specific issues, and the specific areas of my concern. We seem to agree that non-baryonic forms of matter of all sorts are "hypothetical" entities, and we cannot be sure that such things even exist in nature.
Here is where we seem to take different paths. From my perspective, if it is true that baryons cannot make up more than a fraction of the dark matter needed to make your theory work correctly, then IMO it is time for you to scrap (or at least devalue the importance of) your gravity centric theory. There are only certain forms of "matter" that we can be sure actually exists in nature, and you don't have any evidence of any non-baryonic forms of matter.
Well, ok, if you say so. I stand corrected. From my perspective however, that is like me claiming that something you never heard of before was created in the big bang. I will grant you that this is in fact the theory behind WIMPS, but from my vantage point that is a "hypothesis" that has no empirical support. I am skeptical of any theory that begins with an unproven premise related to a hypothetical entity. It's like me "assuming" that something else was created in a bang (like invisible potatoes) and yet offering you absolutely no scientific evidence to support my claim that invisible potatoes exist in reality.
Well, the basic problem from my perspective is that you have no empirical evidence that WIMPS exists in reality, so from my way of looking at your theory, it has a big "flaw" in it. You also have no empirical evidence showing how a WIMP does or does not interact with matter, so any computer simulations will be based on ad-hoc "properties" that you have assigned to the particle in your computer code. I have absolutely no way to verify any of this based on physics or physics experiments. If you had empirical evidence that demonstrated that WIMPS existed, and you could show how they interacted with normal matter, then your computer code would be based on known laws of physics. Since that is not the case with non-baryonic forms of matter, these are metaphysical simulations that are based on unsupportable properties about a theoretical form of matter. I would have to assume the simulations were done correctly, but that the "properties" that were assigned to the theoretical property were completely "made up". They cannot be based on empirical evidence that shows how these particles physically interact with baryonic matter based on controlled experimentation.
I think this is really the heart and soul of our disagreement. It represents the fork in the road where we seem to part company. I don't have any problem at all with you putting "known" physical entities into GR theories. Adding neutrinos and MACHOS to GR are absolutely and completely fine by me because I know for a fact that these items exist in nature. I do however have a huge problem with stuffing *unproven* entities into a GR formula. My invisible potatoes form of mass is a "foul" and it is unacceptable, because I can't demonstrate that invisible potatoes exist in nature. It is therefore invalid for me to put these items into a GR formula *without* ever demonstrating that they actually exist in nature. It doesn't matter whether or not my invisible potato theory matches some distant observation, I still need to verify that invisible potatoes exist in nature and have some effect on nature in controlled experiments.
It seems equally strange to me that you would allow things to be "slapped on" to GR theory without expecting some kind of empirical evidence that such things even exist in nature. From my perspective, that's like expecting you to accept my invisible potato theory at face value because invisible potatoes *might* exist, and they might come in all sizes, from macroscopic sizes, to subatomic sizes. My invisible potato variation of GR theory is not actually GR theory any longer. It's a purely metaphysical extension of GR theory.
And likewise, both my "large" (big potato) and my "tiny" (subatomic) variation of invisible potato theory follows the equation state of matter just perfectly, simply because it is "matter", i.e. pressure=0.
I'm afraid that my slapping unproven properties onto my invisible potato theory isn't making my potato theory any more believable simply by virtue of me adding "properties" (that I can't actually verify) to my potatoes. You can't stop me from calculating it's properties, but that doesn't mean you are obligated to accept my invisible potato theory. I might tell you that invisible potatoes have mass by construction, but then this "construction' of mine is purely hypothetical, and completely arbitrary.
That is irrelevant from my perspective by the way.
MACHOS can certainly be invoked in pure GR, and neutrinos can be invoked in pure GR, because we have "physics" (real physics) to fall back on as it relates to verifying the "properties" of these *known* forms of mass. Invisible potatoes cannot be invoked in pure GR, because there is no real "physics" to verify anything I might claim about invisible potatoes. If I tell you that they pass through normal matter, you can't verify it via physics. It is a purely metaphysical construct. I can't invoke invisible potatoes in pure GR without turning that variation of GR into a metaphysical variation of GR.
I'm not insinuating anything, and please don't take our conversation personally. I'm simply pointing out that all theories have "limits" and "flaws". Lambda-CDM theory is no different. It relies upon unproved metaphysical constructs. That's all I'm insinuating.
We can toss in as much baryonic matter (in any form) into a GR theory as we please, because any form of baryonic matter has "testable" properties. If we add these kinds of things to GR theory, we are not making any "extraordinary" claims. We know that baryonic matter exist in nature. It is only if we make the "extraordinary" claim that some new form of matter exists (invisible potatoes), and is responsible for these observations, that we take on an additional burden of proof. We take on this burden of proof by virtue of postulating a new (unevidenced) form of matter. My "beef" is that you are attempting to explain a distant event with an unproven metaphysical construct (WIMPS), not that you are proposing the existence of "missing mass" in some distant observation.
We know that planets exist in nature. We are therefore welcome to explain that missing mass with planets and planetary materials. We know that asteroids exist in nature. We are therefore welcome to explain that missing mass with asteroids. We don't know that WIMPS or invisible potatoes exist in nature, so it is not acceptable for us to use such things to explain distant observations. If an when we have evidence that WIMPS actually exist in nature *then* I will have no problem with you suggesting that this missing mass is in the form of non-baryonic matter. There is an extra burden of proof on our theory if we wish to attribute distant events on an unproven form of matter. We must also prove that such forms of matter actually exist and that they interact with baryonic matter exactly as we specified.
But that works both ways. What controlled scientific test shows that non-baryonic forms of mass exist in nature? When a theory fails a key "prediction" as Lambda-CDM failed to predict the non-homogeneous nature of our universe, what then should we do with Lambba-CDM theory, particularly the inflation hypothesis of Lambda-CDM theory? Guth proposed inflation to "solve a monopole problem" as he perceived it, and to explain the homogeneous layout of the physical universe. We now know that the universe is not homogeneous in layout and nobody can demonstrate that monopoles exist, or that inflation solved a "missing monopole problem".
Well, hope does spring eternal, but IMO it's a poor substitute for hard empirical evidence. If and when I see someone demonstrate the existence of non-baryonic forms of mass, I'll be quite happy to entertain non-baryonic form of matter in GR theory. Of course I will still need to see some evidence that "dark energy" causes "space" (whatever that is) to expand, and that inflation actually exists before I'll buy into those aspects of the Lambda-CDM theory. I'm not imposing any special requirements on any particular theory, but I will require that each and every theory meet basic scientific requirements. One of those requirements is that extraordinary claims always require extraordinary evidence. So far I see lots of extraordinary claims in Lambda-CDM theory (DE, DM, inflation), and very little in the way of supporting evidence. That is not to say that non-baryonic forms of mass *cannot* exist, it's just that I do have any evidence that the *do* exist. That is also true of DE and inflation. I can't disprove a negative, so the burden of proof must fall to the individual that makes the claim. If someone makes the extraordinary claim that non-baryonic forms of mass exists, they will need to support that statement with solid empirical evidence. That is SOP (standard operating procedure) for all branches of science.
The point is that it has been shown that baryonic matter cannot explain what we observe. Neither can the non-baryonic matter we know of. Then we have in principle two alternatives:
1) There is matter of some form not contained in the Standard Model out there.
2) There is only Standard Model matter, and it's the laws of gravity which need to be altered.
We then need to make hypothesis' in both cases. Either we cook up some new form of matter, plug it into the existing equations, and see if it can explain the observations. Or we cook up some new laws of gravity, calculate the predictions, and see if it can explain the data.
First of all, when it comes to matching the observed data, the attempts with some forms of matter (WIMPs) are quite successfull, while the attempts with altering the laws of gravity have big problems.
Secondly, WIMPs have good theoretical motivations from particle physics, while modified gravity theories are mearly curve fitting.
This is why I (and most professionals) favors dark matter particles over modified gravity. (With that I am not saying WIMPs exists, only that it looks much more promising than any modified gravity theory.)
  • #31
Count Iblis said:
I've skimmed through about 65 pages of "theory" thus far, and I didn't see a single mention of a control mechanism of any sort. Can someone start by cluing me in as to the page number that relates to the control mechanism(s) that they used?
  • #32
Count Iblis said:
The DAMA claim is highly controversial. No other experiment have been able to confirm their claimed signal. Also, the DAMA colaboration refuse to make their data publicly available. The general opinion is that the DAMA results are highly uncertain and should not be used as a claim for detection of dark matter.
  • #33
None of the other experiments use the same methods. There is room to explain both the positive results of DAMA and the negative results of CDMS and other searches. Only if one assumes that DM is a neutralino can one say that the other searches have excluded DAMA (but even in that case there is still a small window for light WIMPS, as P Gondolo and G Gelmini have pointed out).
Now, I don't agree with the sentiments raised by Michael Mozina in this thread, but the very common attitude that "other searches have ruled out DAMA", even though they are still compatible is an example of theory ruling out an experimental result, the theory being the favored neutralino WIMP candidate.
Of course, the DAMA results need to be confirmed by independent searches. However, it is entirely possible that the current searches won't detect dark matter, as the DAMA team have pointed out in their recent articles, as their signal rejection methods to separate nuclear recoil signals from other signals may throw away signals from DM that interact in different ways.
  • #34
While I'm am sure that you (in very good faith) believe that this statement is true, I do not believe that you can scientifically demonstrate it to be true. EU theory can explain galaxy rotation patterns without dark matter. MOND and modified gravity theories do so as well. Other than the known particles of particle physics, I don't have any evidence that other forms of matter exist. It's therefore not even logical to me to *assume* that there are absolutely no other ways to explain this seeming amount of "missing mass" without resorting to unproven forms of matter. For all I know, our current technology is simply 'primitive' when it comes to identifying various forms of standard matter at a distance, including electrons that flow though the plasmas of space/time. Before I can accept your statement as fact, I must know with great confidence that no other possible options remain, and I simply don't feel that all other theories can be disregarded so quickly.
There are plenty of such theories out there by the way.
http://archives.cnn.com/2002/TECH/space/07/23/sun.iron/index.html
That seems like a reasonable possibility to me considering the scale of the distances in question, and our inability to verify that our laws of gravity (as we understand them) apply to all cosmological distances and densities.
We can also explore EU theories related to electron flows through the arms of the galaxies and through the solar systems. We can explore a lot of possible options here.
This seems like a subjective judgment all to me. WIMPS have big problems with detection and verification too. The concept of suggesting that one theory has a "big problem" seems to have a very subjective component.
IMO the whole notion of dark matter, particularly the non-baryonic forms of dark matter, dark energy and inflation are merely curve fitting exercises as well IMO. We can't figure out the fast spin rate of stars near the edges of galaxies, so liberally curve fit in some 'dark matter' to make it work. We can't figure out the acceleration of our universe, so we sprinkle in a lot of "dark energy". We need some way to explain homogeneous mass layouts, and to explain why matter didn't implode the moment in formed? Toss in some inflation! It's just a different way of curve fitting from my perspective.
The problem here I think is partly related to age. I'm old enough to remember BB theories that predated DE and inflation. In my day, "dark matter" meant nothing more than "matter we cannot identify with our primitive technology" and generally related to MACHO types of "structures". As I see it, the whole BB theory has become more and more stuffed full of curve fitting metaphysical forces and unproven forms of matter. Lambda-CDM theory is nothing like the BB theories I was exposed to as a child. The notion therefore that WIMP theories are "promising" seems again to be a very subjective judgment call. I can't prove that you're wrong about the existence of WIMPS, but then you can't prove that you're right either. I tend to favor a skeptical approach to science, where the burden of proof falls to the one making the claim. IMO you can't provide any controlled experimental evidence to suggest that WIMPS exist, and I don't know how you would even attempt to put a control mechanism on a WIMP experiment because you don't seem to think that they originate in other forms of matter, but they are a relic of an event that you could never hope to duplicate in controlled conditions. I can't disprove a negative, and I can't even think of decent way to test your concept scientifically using controlled experiments. You must therefore provide evidence that WIMPS exist. So far I haven't see any empirical evidence that WIMPS exist. I therefore can't find anything scientifically superior about a theory that relies heavily upon such forms of mass.
  • #35
You are right in that there's still some models left to explore before the DAMA result is "ruled out". (I just said no other experiment have been able to confirm the signal.)
I think much of the scepticism agains DAMA stems from the "non-public" policy for their data. What do you think of this problem?
