joey_m
- 22
Please be patient, as you are dealing with a relativity newbie here!
I've read Einstein's book, "Relativity: The Special and the General Theory", and I can't seem to figure out chapter nine, "The Relativity of Simultaneity".
To refresh your memory, there is a train moving at a constant velocity, and it is marked with two markers that are to be hit by lightning at the same moment. In the mid-point of these markers is an observer. There is also an observer on the railway platform at the same position when all of this is happening.
In the chapter, Einstein says that the observer on the train will see the lightning flash that he is approaching before the other flash. This makes sense, but it is an argument based on classical mechanics. I thought that regardless of the relative motion between an observer and a light source, the speed of light is supposed to be the same, meaning that the moving observer will see the light flashes coming to him at the same speed, from both sides, causing the observer on the platform to think that the moving guy's clock had to slow down and speed up, at the same time.
In other words, think of a light source that emits a beam of light at the moment that two objects, in the same position and of different velocities, are moving away from it. According to a neutral observer, the faster object's time slows down more, and they both witness the light coming towards them at the same speed. Well, what if the situation is exactly the same, except that one of the objects is going towards the light source at the moment of emission?
Because the speed of light is reference frame invariant, won't the object that is moving towards the light source still see the light beam coming towards it at the same constant speed? And won't the neutral observer only be able to explain this by way of saying that time speeds up for this object (coming to the light) while it slows down for the other object?
I thought special relativity only supports the slowing down of time. But if, according to a rest frame, objects are moving towards a light beam, it seems that its time would necessarily need to get quicker (according to the rest frame) in order for it to make sense that the moving object sees the light coming at the constant speed of light.
What am I missing here?
(No complicated math please! )
