Evaluating the integral, correct?
  • Thread starter Thread starter Zack88
    Integral
The discussion revolves around evaluating the integral ∫ x² cos(mx) dx using integration by parts. The initial approach involves setting u = x² and dv = cos(mx) dx, leading to a recursive integration process. Participants highlight the need for multiple applications of integration by parts due to the polynomial and trigonometric nature of the integrand. The conversation also touches on typographical errors and the importance of clarity in mathematical notation. Ultimately, the integral is simplified to a form that can be easily evaluated, emphasizing the iterative nature of the integration process.
Zack88
Evaluate the integral
\int x^2 \cos mx dx
u = x^2
du = 2x
dv = \cos mx
v= \frac {\sin mx }{m}
(x^2)(sin mx / m) - [integral] (sin mx / m)(2x)
(x^2)(sin mx / m) - 2 [integral] (sin mx / m) (x)
[My final answer:] (x^2)(sin mx / m) + 2 (cos mx / m) + c
I believe you lost a term in evaluating the second term integral in this:
(x^2)(sin mx / m) - 2 [integral] (sin mx / m) (x) .
If you differentiate your final result,
(x^2)(sin mx / m) + 2 (cos mx / m) + c ,
you don't cancel out the additional terms beyond the original integrand...
i heard that i should do parts with xsinmx / m, should i do that?
Yes, you'll need to do that. In general, integration of functions defined by polynomials times sin kx, cos kx, or e^kx need multiple stages of integration by parts.
ok with doing parts again confuses me since i have xsinmx /m. The u should it be m? but then what is the derivative of m?
The 'm' is a constant, so that will not be involved in the integration. Make the integral
(1/m) · integral[ x sin(mx) ] dx . Now u = x and dv = sin(mx) dx . You can append the multiplicative constant (1/m) afterwards...
ok so now I have
x^2/m sinmx + 2/m [integral] xsinmx
u = x
du = dx
dv = sin mx
v = 1/m cos mx
and now I am lost
Ok let's start from scratch.
I=\int x^2\cos{mx}dx
u=x^2
du=2xdx
dV=\cos{mx}dx
V=\frac{1}{m}\sin{mx}
I=\frac{x^2}{m}\sin{mx}-\frac{2}{m}\int x\sin{mx}dx
Now we have to do Parts again.
u=x
du=dx
dV=\sin{mx}dx
V=\frac{-1}{m}\cos{mx}
I=\frac{x^2}{m}\sin{mx}-\frac{2}{m}\left(\frac{-x}{m}\cos{mx}+\frac{1}{m}\int\cos{mx}dx\right)
Now you can easily evaluate this Integral!
Ok, I'm officially done typing! Sorry about that, had too many typographical errors.
I=\frac{x^2}{m}\sin{mx}-\frac{2}{m}\left(\frac{-x}{m}\cos{mx}+\int\cos{mx}dx\right)
ok where did the last \int\cos{mx}dx\right) come from
By doing Parts again to evaluate ...
\int x\sin{mx}dx
ok i see now, thank you, sad part is I am not done with this question and i have one more just like it :(
Post it and we'll work on it step by step.
[integral] e^-x cos 2x dx
u = e^-x
du = -e^-x
dv = cos 2x
v = sin 2x / 2
I=\int e^{-x}\cos{2x}dx
u=e^{-x}
du=-e^{-x}dx
dV=\cos{2x}dx
V=\frac{1}{2}\sin{2x}
I=\frac{1}{2}e^{-x}\sin{2x}+\frac{1}{2}\int e^{-x}\sin{2x}dx
Ok done typing. Evaluate your current Integral, notice that your Original Integral reappears? Just move it to the left then divide by the constant and you're done!
ok so \frac{1}{2}\int e^{-x}\sin{2x}dx turns into -1/2e^-xcos2x + c?
You're supposed to have "2" Parts just like any Integration by Parts.
What is the other term?
so i don't take the integral just yet? i do another integration by parts?
Evaluate \frac{1}{2}\int e^{-x}\sin{2x}dx how you normally would.
u = e^-x
du = -e^-x
dv = sin 2x
v= -1/2 cos 2x
Yes, so now you've solved it?
not quite, I am not sure how to put it all together I know i'll have 1/2e^-xsin2x but I am not sure how to put in the new u, du, dv, and v
Look at what I did in post 9.
ok I am not done yet but have so far...
1/2e^-xsin2x + 1/2 (1/2 e^-x cos2 x
and that is where i stopped i didnt understand how you got + 1/m [integra] cosmx for post 9
By Parts.
uV-\int Vdu
lol sorry i saw (\frac{-x}{m}\cos{mx}+\frac{1}{m}\int\cos{mx}dx\right) as two different things
so now i have 1/2 e^-x sin 2x + 1/2 (1/2 e^-x cos 2x + [integral] 1/2 e^-x cos 2x)
so now do I finally take the integral (no more parts) to come out with the final answer?
  • · Replies 17 ·
