Question about Noether's Theorem
In summary, according to Noether's Theorem, for every symmetry of the Lagrangian there is a corresponding conservation law, and vice versa. The invariance of the Lagrangian under time translation and space translation correspond to the conservation laws of energy and momentum, respectively. The invariance of the Lagrangian under rotation in space corresponds to the law of conservation of angular momentum. In classical mechanics, there is also a law of conservation of mass, which is linked to time translation invariance in relativistic mechanics. In non-relativistic mechanics, the Lagrangian depends on variables and parameters, and the mass of a particle is defined to be constant by convention. In field theories, everything depends on combinations of fields
lugita15
1,554
According to Noether's Theorem, for every symmetry of the Lagrangian there is a corresponding conservation law, and vice versa. For instance, the invariance of the Lagrangian under time translation and space translation correspond to the conservation laws of energy and momentum, respectively. Also, the invariance of the Lagrangian under rotation in space corresponds to the law of conservation of angular momentum.
In classical mechanics at least, there is also a law of conservation of (inertial) mass. What is the corresponding symmetry of the Lagrangian?
I think that the "usual" Lagrangian is defined to take care of discrete point particles only, and that the mass of a particle is defined to be constant. So, it doesn't make too much sense talking about a symmetry behind such conservation. One might say that what about in certain rocket problems, where the kinetic energy of a rocket is
[tex]T=\frac{1}{2}M(t)\dot x^2[/tex]
but one could equally well assert that the mass itself is constant, and take
[tex]T=\frac{1}{2}m\dot x^2[/tex]
[tex]V\rightarrow V-\frac{1}{2}M(t)\dot x^2 + \frac{1}{2}m\dot x^2[/tex]
However, in field theory, one has well defined differential equations for the density and current of a field, and the conservation of mass (locally) would corresponds to a verification of an equation in the form of
[tex]\frac{\partial \rho}{\partial t} + \nabla \cdot \mathbf{j}=0[/tex]
which, I believe, is related to a certain gauge invariance.
In non-relativistic mechanics, Lagrangian depends on variables (speeds) and parameters (masses). Variables are governed by equations of dynamics. Parameters are actually governed by you. You choose the parameters to be constants by definition. So no symmetry is necessary for conservation of mass.
In relativistic mechanics total mass M becomes variable. Because of the equivalence E = M*c^2, we may say that conservation of relativistic mass is linked, like energy, to time translation.
In field theories everything depends on combination of fields, which is associated with mass.
I disagree. I base my arguments on Landau's "Mechanics," volume 1 of his "Course of Theoretical Physics." Landau bases classical mechanics on three axioms:
(1) The Newton-Laplace Principle of Determinacy
(2) Hamilton's Principle of Least Action
(3) Galileo's Principle of Relativity
Based on these three axioms, he proves that the Lagrangian of a free particle in an inertial frame is proportional to the square of the magnitude of its velocity. He then defines the mass of a particle to be 2 times the constant of proportionality. He does not in any way define the mass to be constant. That is why I would like to know how the law of conservation of mass is constant.
Any further help would be greatly appreciated.
Thank You in Advance.
:smile:
Unfortunately, I do not have Landau's book. It would help to pinpoint the essentials of his proof.
And, in the viewpoint you described, something needs clarification:
1. what does Landau mean by a free particle?
2. how would one define the mass of a particle that is not free?
although 1. seems trivial, it's definition truly depends on how one develops the theory. For instance, I may accept the fact that L=T-V (derived from Newton's law which asserts that the mass of a fundamental particle is constant, and T by definition is Σ1/2mv^2, where m is a fundamental constant for each particle) and say a free particle is one who's Lagrangian is T, i.e. V=0. In this sense, the mass of a particle is by definition constant (which inherently comes from the fact T is 1/2 mv^2 where m is constant for a particle and L=T-V).
(Landau probably takes the following approach instead)
or one may define a free particle as one that moves in a straight line, in this sense, one does not konw that L=T-V, one merely has the Euler Lagrangian equations and one finds an L such that the motion describes a straight line (it turns out that L is proportional to v^2). In this sense then, V is not well defined, and I am not sure how one can define the mass of a non-particle (one that does not move in a straight line).
Use the link jdg812 provided for a good proof.
Landau defines an inertial frame to be a frame of reference "in which space is homogeneous and isotropic and time is homogeneous." A particle is defined to be executing free motion in such an inertial frame when and only when all the properties of its motion obey these symmetries. Using this definition of a free particle, we can draw many conclusions about the Lagrangian, L(x,v,t). Due to the homogeneity of space, the Lagrangian of a free particle annot explicitly depend on position. Due to the homogeneity of time, the Lagrangian of a free particle cannot explicitly depend on time. Therefore, the Lagrangian of a free particle can only depend on its velocity. Due to the isotropy of space, the Lagrangian of a free particle cannot depend on the direction of its velocity. Therefore, the Lagrangian of a free particle can only depend on the magnitude of its velocity. Then, using Galileo's principle of relativity, Landau proves that the Lagrangian of a free particle in an inertial frame can only be proportional to the square of the magnitude of its velocity.
A single particle, by itself, can only execute free motion, because there are no other particles in the universe which can possibly exert a force upon it. So now, consider a system of particles. Then the kinetic energy of a particle in that system is defined as the Lagrangian it would have if there were no other particles in the universe. The kinetic energy of the system is defined as the sum of the kinetic energies of the individual system. The potential function of a system is then defined as the kinetic energy of the system minus the Lagrangian of the system. As long as we're not talking about dissipative systems with friction and heat, we may make the additional assumption that the potential function of the system at a given time depends only on the positions of the particles in that system.
jdg812 said:
:smile:
What I meant to say is that the mass is defined to be 2 times the ratio of the Lagrangian to the square of the magnitude of the velocity. The term "constant of proportionality" is just a commonly used phrase, and in that context the word "constant" does not refer to a quantity the time derivative of which is identically zero. However, when you say that the mass is defined to be a constant, what you mean is that the time derivative of the mass is defined to be zero, I don't believe is necessarily true.
If I consider the mass to be a variable in the usual Lagrange's function, like this
[tex]
L(t,x,\dot{x},m,\dot{m})=\frac{1}{2}m\dot{x}^2 - V(x)
[/tex]
I immediately get something crazy out. The EOM for x is
[tex]
m\ddot{x} = -D_xV(x) - \dot{m}\dot{x}
[/tex]
and for m it is
[tex]
\dot{x} = 0
[/tex]
I would try to figure out a way to modify the Lagrange's function so, that we would still be getting something reasonable out, even when having the mass as a dynamic variable. Anyone having ideas about how that could be possible?
The reason why I'm asking this, that I've lately seen all kinds of tricks with different constraints and auxiliary variables, and I don't know them very well yet.
[tex]
[/tex]
Well, as the action should be minimised, you should get [itex]m=-\infty[/itex].
...and, if m is allowed to vary, then the EOM for x is
[tex]
\frac{d}{dt}(m\dot{x})=-D_xV
[/tex]
But I can't think of how you would adjust the Lagrangian to treat m as a dynamical variable and get [itex]\dot{m}=0[/itex] for its EOM.
[tex]
[/tex]
Good point! Since my edit button has not expired, I think I'm correcting my mistake now :rolleyes:
In fact the Euler-Lagrange equations will extremize the action, so it might as well be [itex]m=\pm\infty[/itex], or the path between some fixed points would become
[tex]
m(t)=\left\{\begin{array}{l}
m(t_0) = m_0\\
m(t) = \pm\infty\quad\quad\quad t_0<t<t_1 \\
m(t_1) = m_0\\
\end{array}\right.
[/tex]
hmhmhmh... this is very hypothetical anyway... Doesn't really matter what the m(t) should be. The truth is, that the action cannot be extremized by any well defined path, unless [itex]\dot{x}=0[/itex].
[itex]\dot{m}=0[/itex] would follow, if we defined a third variable [itex]\lambda[/itex], and then added a term [itex]\lambda\dot{m}[/itex] into the Lagrange's function, and no [itex]\dot{\lambda}[/itex] at all. The EOM of lambda would result in conservation of mass. The EOM of the m itself would still be a problem, however.
Sorry if I say a naive thing, but since for a free particle E = p^2/2m so m = p^2/2E, mass conservation shouldn't come from simultaneous energy and momentum conservation?
Men, what are you doing? :smile: The extremum in Lagrange method must be LOCAL There is no local extremum at [itex]m=\pm\infty[/itex]
Seems like a reasonable thing to do to me, it just shows that the Langrangian is bad.
What about Hamiltonian, is it bad as well? :smile:
thank you for the clarification. since m cannot depend on x, v or t, one conclude that m is indeed a constant in the case of a free particle. So, for an object, we may define the mass as the mass that one would obtain via the above fashion (separating that object far away from other objects). So, that mass by definition is a fundamental constant. In classical mechanics, one assumes from the existence of a trajectory that particles do not vanish. Since particles in a system do not vanish, the system's mass is always constant. Unless you have another definition of mass in mind that could be varied from situation to situation, it seems clear to me that this is a fundamental postulates of classical theory (ie each particle has a constant mass, and that particles do not vanish.)
indeed, as jdg812 says, unless you can associate a "dynamical" meaning to mass (putting m as a function of the coordinates, the velocity and time), mass is a parameter that we control. Also, noether theorem only deals with dynamical variables (or constants). In field theory, the density ρ(φ,∂t φ,∇φ,t) and current j(φ,∂t φ,∇φ,t) are well defined functions of the field, φ and it's derivatives. So it makes sense to talk about conservation of these quantities, or quantities of the form
ρ(φ,∂t φ,∇φ,t)+∫∇·j(φ,∂t φ,∇φ,t) dt (which is a well defined function of (φ,∂t φ,∇φ,t)), whose conservation would imply local conservation of mass. However, in the discrete case, the mass density is in the form of ∑mδ(r-r'), where r' is the position of the particle, you could say that ∫mδ(r-r') dV is conserved but this is trivially true since m itself is defined to be a constant.
(fixed some typo...edit: i mean φ,∂t φ,∇φ,t, not x,y,z,t, since the explicit form of ρ and j is unknown)
This is only true in the free particle case. What if you have a continuous distribution of particles under the influence of a force (the most general case)?
Hey guys:
There is nothing wrong with the Lagrangian or Hamiltionian formalism for mass, discrete, continuous, or what have you! Tim_lou has the right idea: if you want mass to be a dynamical variable, you must include its dynamics. This means that you must include some Lagrange density that describes the flow of mass. This means going to to field theory (even if it's discrete - then the mass-energy tensor has delta functions in it, no big whoop!).
Exactly the same thing happens in E&M: if you want to describe the behavior of a classical particle interacting with the electromagnetic field, you can just include the coulomb potential in the Lagrangian. BUT if you want to understand how the particle can affect the background field, and how that can feed back into the particle (backreaction), then you MUST take the EM field as dynamical, and therefore include Maxwell's Action in the picture. So the correct action would be:
[tex]S=\int dt\left[\frac{1}{2}m(\vec{v}+\frac{q}{c}\vec{A})^2 - q\phi\right] - \frac{1}{4}\int d^4x F_{\mu\nu}F^{\mu\nu} [/tex]
For the case of dynamical mass, the Maxwell term would be replaced by whatever dynamics controls the mass loss (Navier-Stokes, or some such beastie).
lugita15 said:
According to Noether's Theorem, for every symmetry of the Lagrangian there is a corresponding conservation law of the equation of dynamics, and vice versa. For instance, the invariance of the Lagrangian under time translation and space translation correspond to the conservation laws of energy and momentum, respectively. Also, the invariance of the Lagrangian under rotation in space corresponds to the law of conservation of angular momentum.
I added red text to your post. Now we may say:
#1 Noether's Theorem is a tautology. It just shows a link between some property of the equations of dynamics (conservation of some combination of variables) and some property of Lagrangian (some symmetry of it).
#2 If some kind of conservation is present in equations of dynamics, one may ask about linked symmetry of Lagrangian.
#3 If some kind of conservation is NOT present in equations of dynamics, the question about linked symmetry of Lagrangian is illegal.
For example:
#4. If the equations of dynamics are
m*dv/dt - F = 0,
your question is illegal.
#5 If the equations of dynamics are
m*dv/dt - F = 0
AND
dm/dt = 0
your question is legal
If the particles are interacting then we know from relativity that their mass cannot be constant, in general. All you have to do is, again, evaluate energy and momentum and then compute E^2 - (cp)^2; if E and p are constant for a given particle, then its mass will be constant too.
I think the problem is mainly relevant in the non-relativistic case. I'm not sure what the OP was thinking, however. He mentioned inertial mass, so it could be he was thinking about relativistic case too. But since the total mass of some system is not constant in the relativistic case, I guess it is better to restrict to the non-relativistic cases, so that the original claim about the conservation of mass would be true.
Another thing:
I've understood, that the masses of the point particles are in fact constants, and they are the masses of the fields that change. Were you talking about particles' masses carelessly, and perhaps meaning the "particle + field system" by a mere "particle"?
Another thing:
I intended "particle" as "point mass", as we usually do in classical mechanics.
I want to know about the classical case, not the relativistic case.
FAQ: Question about Noether's Theorem
1. What is Noether's Theorem?
Noether's Theorem is a fundamental principle in physics that states that for every continuous symmetry in a physical system, there exists a corresponding conserved quantity. It is named after German mathematician Emmy Noether, who first proved the theorem in the early 20th century.
2. What does Noether's Theorem tell us about conservation laws?
Noether's Theorem tells us that every conservation law in physics is a result of a fundamental symmetry in the underlying physical system. For example, the conservation of energy is a result of the time symmetry of physical laws.
3. How does Noether's Theorem relate to the laws of motion?
Noether's Theorem is closely related to the laws of motion in physics, specifically the principle of least action. It shows that for a system to be invariant under certain transformations, the equations of motion must satisfy certain symmetries, and vice versa.
4. Can Noether's Theorem be applied to all physical systems?
Yes, Noether's Theorem is a general principle that can be applied to all physical systems, as long as they exhibit continuous symmetries. This includes classical mechanics, electromagnetism, and quantum field theory.
5. Why is Noether's Theorem important in physics?
Noether's Theorem is important in physics because it provides a deeper understanding of the structure of physical laws and the conservation of physical quantities. It has also played a key role in the development of modern theories such as relativity and quantum mechanics.
