Proof of Lorentz Geom. Not Holding in All Acc. Frames - Example
In summary: The observer on the disk will report a circumference of the disk of C'. The circumference of the disk is the circumference of the disk measured by the observer not on the disk.
Phymath
184
obviously the equations of tidal forces and geodesic deviation are very similar to lead one to motivate yourself to explore gravity as not a field but as a curved geometry, Einstein also said that if each accelerated frame is locally an inertial one the euclidean geometry of Lorentz can not hold, which also motivated him to explore the geometry instead of a field. can some one explain/give me an example of Lorentz geometry not holding in all accelerated frames, basically prove the second statement.
I am trying to understand why Einstein abandons a field for geometry yes the equations are similar very similar still that is not enough to say it is proof that they are the same, E&M and classic gravity have similar mathematical qualities but they are (as far as we know) not the same. please help me out here proof or giving an example of the second statement, thank you.
An excerpt from "Of pots and holes: Einstein’s bumpy road to general relativity", Michel Janssen, http://www.tc.umn.edu/~janss011/
Consider a circular disk serving as a merry-go-round in Minkowski space-time (see Fig. 3). Let one
observer stand on the merry-go-round and let another stand next to it. The person next to the disk will say
that he is at rest and that the person on the disk is subject to centrifugal forces due to the disk’s rotation (see
the drawing on the left in Fig. 3). Invoking the equivalence principle, the person on the disk will say that
she is at rest in a radial gravitational field and that the person next to the disk is in free fall in this field (see
the drawing on the right in Fig. 3).24
Now have both observers measure the ratio of the circumference and the diameter of the disk. The person
next to the disk will find the Euclidean value π. The person on the disk will find a ratio greater than π.
After all, according to special relativity, the rods she uses to measure the circumference are subject to the
Lorentz contraction, whereas the rods she uses to measure the diameter are not.25 The spatial geometry for
the rotating observer is therefore non-Euclidean. Invoking the equivalence principle, Einstein concluded
that this will be true for an observer in a gravitational field as well. This then is what first suggested to
Einstein that gravity should be represented by curved space-time.
Thank you that does show me a good example however I would like to check if i fully understand it.
the two observers both measure the diameter of the disk to be the same, now using the method i am about to describe, this is how they determine the circumference of the disk.
As the observers pass each other at closest approach they both start their individual clocks, and as the closest approach occurs again the both stop their clocks. The observer not on the disk will say that the circumference of the disk must be: C = v*t where t is the time measured for one full revolution. Both should agree on the velocity because they both could say the other is moving with respect to each other but still both would observe the same velocity of each other. using this idea the time on the clock of the observer not on the disk would be:
t = pi d/v
where d is the diameter of the disk and v is the velocity of the person on the disk. since the person on the disk would experience time dilation they would report a time for one full revolution of
t' = gamma*t where the gamma is the typical Lorentz transformation factor
therefore the person on the disk would observe a circumference of the disk they were on of
C' = d*t' -> which gives pi' d/v = gamma* d*pi/v -> pi' = gamma*pi
so the person on the disk would find that his constant of pi is smaller then 3.14159... and thus non-euclidean, and also would say that gravity must be deforming the geometry because of the equivalence.
is this a correct analysis?
That problem contains the twin paradox in disguise. Each observer can claim he is stationary and the other observer is rotating around some center. So it's 'paradoxical' why the final result picks out one of them versus the other, why 'pi' is smaller for one of them. The resolution is that the situation just like in the twin paradox is not symmetrical, the observer not on the disk, is implicitly assumed to be really inertial, while the rotating observer is accelerating with respect to the inertial frame so he is never inertial.
I think the correct formula is
t (time interval in the inertial frame) = gamma t' (proper time interval measured by the accelerated clock on the disk),
where the Lorentz factor gamma >=1.
When you apply the time dilation formula, the proper time interval t' (measured by two events happening at the same place of the measuring clock frame) is dilated in any other frame. The above formula is also in agreement with the twin paradox: the non-accelerating twin measures bigger time t (ages more), than the accelerating twin t'.
Since the above is the opposite of your formula, the final answer is reversed: the rotating observer will measure smaller circumference/radius ratio: pi' = pi / gamma. That is the opposite of what the citation is claiming.
FAQ: Proof of Lorentz Geom. Not Holding in All Acc. Frames - Example
What is the Lorentz Geometric Proof?
The Lorentz Geometric Proof is a mathematical proof that was developed by Hendrik Lorentz in the late 1800s to explain the concept of time dilation and length contraction in special relativity.
What is the main idea behind the Lorentz Geometric Proof?
The main idea behind the Lorentz Geometric Proof is that the laws of physics, specifically the laws of electromagnetism, are invariant in all frames of reference moving at a constant velocity.
Why does the Lorentz Geometric Proof not hold in all accelerated frames?
The Lorentz Geometric Proof relies on the assumption that the frames of reference are moving at a constant velocity. In accelerated frames, the laws of physics are no longer invariant and therefore the proof does not hold.
Can you provide an example where the Lorentz Geometric Proof does not hold?
One example where the Lorentz Geometric Proof does not hold is in the case of a rotating disk. In this scenario, the frame of reference is constantly changing its velocity and therefore the proof does not apply.
Are there any alternative proofs to the Lorentz Geometric Proof?
Yes, there are alternative proofs, such as the Minkowski spacetime diagram and the Lorentz Transformation equations, that can also explain the concept of time dilation and length contraction in special relativity.
