Entropy-any direction would be appreciated
  • Thread starter hils0005
  • Tags
    Direction
In summary, a cup made of 100g of aluminum holds 200g of water at 50deg C. When a 10g piece of ice is placed in the cup of water, the final temperature can be determined by setting up equations for the change in temperature in terms of the heat flow from the water/cup to the ice and the final temperature, and solving for the equations. The specific heat of aluminum is 0.90 J/gC and the heat of fusion of water/ice is 79.5 cal/g. Joules/g C can be converted to Calories/g C by dividing by 4.187 Joules (= 1 Cal).
hils0005
62
A cup made of 100g of aluminum holds 200g of water at 50deg C, a 10g piece of ice is placed in the cup of water, what is the final temperature?
2. Homework Equations
Q=L(f)m
S=cm lnTf/Ti
specific heat of aluminum 0.90 J/gC
I think the first step is to determine S(ice)
Q=Lm=79.5 cal/g * 10g=795cal
S(ice)=Q/T=795/273K=2.91
S(water)=Q/T=-795/323K=-2.46
2.91-2.46=.45cal/K
then as 0deg C water goes to 50deg C?
I believe I should be using an integral as the ice will be changing the temp of the water?
S(ice)=cmln(Tf/Ti)
1cal/gC * 10g ln(795/323)=9
S(water)=cmln(Tf/Ti)
1cal/gC*200 ln(795/323)=180
So now I'm confused-because I believe I would need to know the final temp of the water before calculating S with the Steel??
I also do not understand how to convert J/gC to cal
Q=L(f)m
S=cm lnTf/Ti
This does not involve an entropy calculation. This is simply a heat flow calculation. You have to know the specific heat of Al, Water and Ice as well as the heat of fusion of water/ice. Then you have to set up equations for the change in temperature in terms of the heat flow from the water/cup to the ice and the final temp. Then solve the equations.
You can't convert Joules/g C to Calories. You can convert Joules/g C to Calories/g C by dividing by 4.187 Joules (= 1 Cal.)
AM
/gC.
I can provide some guidance on how to approach this problem. First, let's define entropy. Entropy is a measure of the disorder or randomness in a system. In simpler terms, it is a measure of how spread out or dispersed the energy is within a system. In this case, we can think of the cup of water as our system.
To solve this problem, we need to consider the changes in entropy that occur when the ice is added to the cup of water. The first step is to calculate the change in entropy of the ice. We can use the equation S=Q/T, where Q is the heat absorbed by the ice and T is the temperature at which the heat is absorbed. We know that the heat absorbed by the ice is equal to its latent heat of fusion, which is 79.5 cal/g. The temperature at which this heat is absorbed is the melting point of ice, 0°C or 273K. So, the change in entropy of the ice is 79.5 cal/g / 273K = 0.291 cal/K.
Next, we need to calculate the change in entropy of the water. This will involve a temperature change from 50°C to the final temperature, T. We can use the equation S=cm ln(Tf/Ti), where c is the specific heat of water (1 cal/g°C) and m is the mass of water (200g). So, the change in entropy of the water is 200g * 1 cal/g°C * ln(T/Ti). We can also rewrite this equation as S=Q/T, where Q is the heat absorbed by the water and T is the temperature at which the heat is absorbed. The heat absorbed by the water is equal to the heat released by the ice, which we calculated to be 79.5 cal/g. So, we can set up the equation as 79.5 cal/g = 200g * 1 cal/g°C * ln(T/Ti). Solving for T, we get T= 323K.
Therefore, the final temperature of the water will be 323K or 50°C. This means that the final temperature of the system will be 50°C, as the ice has melted and the energy has been dispersed throughout the system. The change in entropy of the system is the sum of the changes in entropy of the ice and water, which is 0
Related to Entropy-any direction would be appreciated
1. What is entropy?
Entropy is a measure of the disorder or randomness in a system. It is a concept used in physics, chemistry, and information theory to describe the amount of energy that is unavailable for work.
2. How is entropy related to the Second Law of Thermodynamics?
The Second Law of Thermodynamics states that the total entropy of a closed system will always increase over time. This means that as energy is converted from one form to another, some of it will inevitably be lost in the form of heat, increasing the overall entropy of the system.
3. Can entropy be reversed?
No, entropy cannot be reversed. The Second Law of Thermodynamics states that the total entropy of a closed system will always increase over time. While it is possible to decrease the entropy of a specific part of a system, the overall entropy will still increase.
4. How is entropy calculated?
Entropy is calculated using the equation S = k ln W, where S is the entropy, k is the Boltzmann constant, and W is the number of microstates in a system. The higher the number of microstates, the higher the entropy.
5. Does entropy only apply to physical systems?
No, entropy can also be applied to non-physical systems, such as information systems. In information theory, entropy is a measure of the uncertainty or randomness in a system. The more uncertain or random a system is, the higher its entropy.
23K
10K
