Does pressure resist acceleration?
In summary, pressure does not affect the mass (which is how I interpret the concept "resisting acceleration") of an isolated system of a box containing a pressurized gas.
Xeinstein
90
Suppose we have a box at rest that is filled with a uniform gas. We denote the volume by V and the pressure by p. Suppose next that we apply a small force to the box and accelerate it until it has a speed v. Once it is at speed v, the gas in the box has acquired a kinetic energy, so one might think that the total energy that we had to add to the box in order to accelerate the gas in it would have been equal to its kinetic energy. But this is not the whole story, because the Lorentz contraction has shortened the length of the box and therefore changed its volume. Making a box smaller when it contains a gas with pressure requires one to do work on it, in other words to put some energy into the gas. This extra energy represents the extra inertia of the gas.
The key question is: Is it harder to accelerate the gas because it takes work not only to accelerate the existing energy but also to compress the gas as the Lorentz contraction demands? In other words, the moving box will contract but the gas in it will resist the Lorentz-contraction of the box
Didn't you just do this one?
On 23 Jan 08, "Lorentz contraction of box filled with gas."
In its own frame, the box has not shrunk.
There are not any issues related to the Lorentz contraction of the volume of the box. This was addressed in the previous thread, and that issue should continue to be discussed in that thread.
The idea of "resisting acceleration" is essentially the idea of mass. The short answer is that pressure does not affect the mass (which is how I interpret the concept "resisting acceleration") of an isolated system of a box containing a pressurized gas.
Using the SR defintion of mass, pressure does NOT contribute to mass, ever. In some GR applications, however, pressure does contribute to mass. There are actually several concepts of mass in GR, one of the most relevant here is the concept of Komar mass. Note that the term "mass" actually has several different meanings! (We have the SR defintion, and we have several different GR definitions). This is not widely appreciated and occasaionally causes confusion, angst, and long arguments.
One might well ask then:
Is the SR mass of a box containing a pressurized gas different than the GR Komar mass? The answer to this question is no. The reason that the answer is no is that while the pressure in the interior of the box does contribute to the Komar mass, making it higher, the tension in the walls of the box also contributes to the Komar mass, making it lower. The net effect is that there is no change in the mass of the box due to the pressure terms.
This assumes that the box is an isolated system. If the box is not an isolated system, the answer gets more complicated.
That one has been hijacked
The question is this: The moving box will contract, but how about the gas, will the gas in it contract also? Will the gas resist the contraction of the box?
The box does not become smaller in the frame comoving with it, so there is no work expanded in compressing the gas.
The total energy for the system box+gas at rest is
[tex]E_0=m_0c^2[/tex]
where [tex]m_0[/tex] is the proper mass of the box+gas.
The total energy when the system has stopped accelerating and has reached cruising speed [tex]v[/tex] is :
[tex]E_1=\gamma m_0c^2[/tex]
If the system is accelerated slowly, there is no energy radiation, hence the same value [tex]m_0[/tex] is used in both expressions. This was also pointed out earlier by pervect.
The total work is:
[tex]W=E_1-E_0=(\gamma-1)m_0c^2[/tex]
I gave my answer, a good one, in #4 of that thread:
https://www.physicsforums.com/showpost.php?p=1583385&postcount=4
The short answer is that the moving box does not contract in its own frame, and that relativity is frame independent.
A fuller answer can be found in
https://www.physicsforums.com/showthread.php?t=117773
I get the impression that the simple answer is not satisfying you, and you either missed the longer answer above in the flurry, or that it is going over your head.
Perhaps we need to take a step back.
How about telling us a little bit about your background with respect to SR, so we can try to answer your questions in a manner that will be helpful to you?
Do you understand "frame independence"?
Do you understand that the box does not contract in its own frame? Do you understand the logic of working the problem in the simplest possible frame, and then applying the above principle of "frame independence" to get the correct answer in other frames?
I mentioned "invariant mass" before. Do you understand that concept, and its relevance to the answer to your question?
I have the feeling that communication just isn't happening here, and I'm afraid I don't know how to fix that.
The total work is:
Finally, I figure out what's wrong with your argument.
I can give you a hint: you jump around in different frames
In both the initial lab-frame and final co-moving frame, the box is at rest,
Then can we say the total work is zero? No, of course not
So it's clear that we must stay in one single frame, i.e. the initial lab-frame in which the box is moving at end of acceleration. In this frame, the moving box does indeed contract and compress the gas in it
I can give you a hint: you jump around frames
No, everything is calculated from the frame the box was originally at rest. So , you continue to write nonsense.
Not really, the box gets accelerated up to speed [tex]v[/tex] in the lab frame, as per your description. So, this is the second nonsense.
So we must stay at one frame, i.e. the initial, lab-frame
Exactly as I did.
Now, you are indeed mixing frames. Some moderator ought to close this thread. Pervect?
Exactly as I did.
I don't think you understand relativity at all and continue to write nonsense.
It's clear from the similar thread, titled "Lorentz contraction of box filled with gas", that you are wrong about Lorentz-contraction. Your biggest problem is that somehow, you believe Lorentz-contraction is an illusion, Not real. In fact, most people in the forum of that thread disagree with you and you couldn't explain, in the lab-frame, why the thin thread between two spaceships breaks in the Bell spaceship paradox.
I think it's obvious that you jump around in different frames, from the initial lab-frame to the final co-moving frame. You said that the box does not become smaller in the frame co-moving with it, I think that's well-known and we all agree with it. But you can't extrapolate that and claim Lorentz-contraction of moving object is Not physically real. So the question is: does the box become smaller in the lab-frame (in which the box is moving)? If yes, will it compress the gas in it? you can find the answer in Schutz's book: Gravity from the Ground Up, at page 194; This is the kind question that really test your understanding of Lorentz-contraction.
Would you be surprised if I tell you that Schutz disagree with you and claim "pressure does resist acceleration"? Since Schutz is such a big shot in relativity, I don't think you have a chance...
In his book "Gravity from the Ground Up", page 194, in the box of 15.4 Investigation: How pressure resists acceleration" It says: it is harder to accelerate the gas because it takes work not only to accelerate the existing energy but also to compress the gas as the Lorentz-contraction demands.
Here is the link to that page in the book: Gravity from the Ground Up
http://books.google.com/books?id=P_...ts=eYBnh8oGoa&sig=ZkzEIBINItUiFyMW5-uvjt1kMus
I hope you can learn something about Lorentz-contraction from Schutz's book
1effect said:
More correctly said:
-the modern view is that the contraction is not physical, it is just a geometric (trigonemetric) artifact of the Lorentz-Einstein transforms : http://en.wikipedia.org/wiki/Length_contraction#A_trigonometric_effect.3F
-we do not have any experimental confirmation to the contrary :
http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html#Length_Contraction
Xeinstein said:
If the contraction is "Not physical", then can you tell us why the thin thread connected between two spaceships break in Bell's spaceship paradox?
1effect said:
Firstly, "Bell's paradox" is a thought experiment, not a real one, so it has no bearing on my statement pertaining to the absence of experimental confirmation for length contraction.
Secondly, here is a very good explanation. The calculations do not use length contraction.
I think that anybody that knows physics realized already that both [tex]E_0[/tex] and [tex]E_1[/tex] are calculated in the same frame. I cannot help you if you don't know elementary relativity.
The box does not become smaller. A moving observer will measure it thru light signals as being smaller.
Yes, I read the book. It is interesting to note afew things:
-you already knew the answer when you started your threads
-what you did not know, and this is really interesting for the mainstream people watching this thread, is that Schutz made a mistake on the page you are citing (p.194). It happens to the very best, even to famous professors :-)
Can you spot the mistake?
I had to snip your ramblings on the Bell's paradox.
Do you mean that the length of the box is "frame independent"? It's the same in all frames? I think only the space-time interval is "frame-independent", but the distance or length is Not.
Yes, I do understand "frame independence" and the box does not contract in "its own frame". I think that's well-known and we all agree with. So that's not the question.
The question is this: Does the box contract in "the lab-frame" in which the box is moving? If yes, will it compress the gas in it? That's all we need to know.
Xeinstein said:
Yes, I understand that the box does not contract "in its own". I think that's well-known and we all agree with. So that's not the question.
The question is this: Does the box contract "in the lab-frame" in which the box is moving? If yes, will it compress the gas in it?
The answers are "no" and "no".
Do you believe that Lorentz-contraction of moving object is "an illusion" or it's real?
The length of the box depends on who observes it. Length is therefor not a frame-independent quantity.
Whether or not you consider length to be "real" depends on your philosophy. "Real" is a very vague term. "Independent of the observer" is a much more precise term. When you say "real" I think you probably mean "independent of the observer", but it's hard to be sure. If you mean something else by *real*, please give a short example of what you mean by "real", and some examples. (Are bricks real? How do you know they are real). Please try not to get too far into the philosphy in this forum, however - but sometimes a little philosphical disussion is unavoidable in order to answer non-philoophical questions.
The length of a physical object is thus not a property of the object alone. It is depends both on the object, and on the observer - specifically on the frame in which the observer resides.
For an example of a property of a physical object that is a property of the object alone, consider the Lorentz interval, or proper length, of the object.
Now, onto energy, mass, and momentum.
The box also has energy, momentum, and mass. The energy and momentum of the box depend on the observer. This is the same in relativity as it is in Newtonian mechanics - the kinetic energy of an object depends both on the object and who observers it.
In relativity, the energy and momentum together comprise the energy-momentum 4-vector. The energy-momentum 4-vector, however, is not a property of the box alone - like length, it depends on both the box and the observer. (But it transforms in standard and well understood manner, making it very useful and fundamental).
The invariant mass of the box, however, is a quantity which depends only on the box, *if* we assume that the box is an isolated system (as it is in this example). This invariant mass can be computed from the energy momentum 4-vector. To make the equations simple, chose units such that c=1. Then the invariant mass of the box is E^2 - |p|^2, where E is the energy of the box, and |p| is its momentum
I haven't responded to the rest of your post, because you're getting off on the wrong track :-(.
I just want to reply to the question that the thread title asks. Yes.
Pressure contributes inertia. Inertia resists acceleration.
However this does not have much to do with the Lorentz contraction and that box example. The best thing to do, I think, is to forget about Lorentz contraction, and the box of gas, and special relativity
I think other people have pointed out that the Lorentz contraction does not change the pressure measured in the box. So this line of reasoning seems fruitless.
Instead, think of the sun. I believe that part of the gravitational attraction of the sun, which the Earth feels, is due to the pressure in the core (as a simple consequence of the GR equation). Part of it is due to the kinetic energy associated with the temperature at the core. Besides the obvious contribution of particle masses, the gravitational mass of the sun is compounded of several things, including pressure.
The gravitational mass and the inertia of the sun are the same. Therefore a portion of the inertial mass of the sun is contributed by the pressure-----the pressure everywhere in the sun contributes somewhat, but I mentioned the core pressure especially because I suspect it is high enough to have a noticeable effect.
It would be fun to know the percentage of the mass of the sun which is attributable to internal pressure. Maybe someone more knowledgeable than I has a source for this. Please correct me if I am wrong. I'm just reasoning from the Einstein field equation of GR, which in effect features both energy density and pressure on the right hand side.
I don't think it has anything to do with pressure change or not. If you check Schutz's calculation in his book, the pressure p is a constant but the volume of the gas does change (page 194 in his book: Gravity from the Ground Up). So this is not the question
Hello Marcus,
So we both agree "pressure resists acceleration", but how?
Since you are one of the knowledgeable "Astro/Cosmo Guru", so let me ask you an honest question, The question is this: Does the box contract "in the lab-frame" in which the box is moving? If yes, will it compress the gas in it?
Please Note: If both the box and the gas contract at the same time, then there is No compression. If somehow the box contracts but the gas does Not, then the box has to compress the gas in it. In other words, will the gas resist the contraction of the box, as Lorentz-contraction demands. That's all we need to know.
Why? Just because I asked you an honest question.
Did you delete or modify some of the text in your previous posts?
Somehow, there are a few sentences missing?
I remember something like this "pressure dose Not resist acceleration"
It seems to me that you are pushing your own point of view, which as nearly as I can tell is incorrect, rather than asking questions and trying to understand the answers.
I really *am* trying to get you on the right track, right now in my opinion you are going off on a non-productive tangent and basically "not getting it".
Some of the issues involved here are subtle. So let's start with some of the issues that are not.
What I'd ideally like for you to come away with from this thread is an understanding of the concept of invariant mass in special relativity (and if not that much, at least a desire to learn more about it), and how this concept relates to "resistance to acceleration".
If we could accomplish that much, it might be time to get into the GR issues, which are also present.
Hello russ_wallers,
We all agree that "in its own frame", the box has not shrunk.
So that's Not the question. The question is this: Does the box contract "in the lab-frame" in which the box is moving? If yes, will it compress the gas in it? In other words, will the gas resist the contraction of the moving box, as Lorentz-contraction demands? That's all we need to know, thanks...
If yes, will it compress the gas in it? ...
"No" and "no". How many times do u need to ask the same question?
Hello all.
I have been following this thread and in general i am out of my depth but it does throw up a question which seems relevant to me.
The box is contracted in the "moving" frame as observed from the "stationary" frame. Are the sizes of molecules of the gas and their separation distances also affected by the relative motion.
At a more fundamental level is everything affected dimensionally by the relative motion.
Matheinste.
matheinste said:
Hello all.
No, they are not. Uniform relative motion does not affect either the size of the molecules, nor the separation distances between molecules. The box does not contract, either in the proper frame , nor in the observer frame, so the pressure remains constant.
The above is not true for the general case of non-uniform (accelerated) motion. In this situation, the outcome depends heavily on the way of accelerating the objects.
You seem to have a misconception about the nature of the Lorentz contraction. You seem to be thinking of it as an active process, as opposed to a transformation of measurements between frames. Example: Imagine a can of beer sitting on the table. A rocket ship goes by at high speed and--amazingly enough--observers on the rocket are able to perform measurements of the beer can as they fly by. Is the can and its contents Lorentz contracted? Of course! Does that somehow increase the pressure in the can? Do you expect anything unusual to happen to the can of beer? Do you think that pressure can somehow increase so as to burst the can as viewed in the frame of the rocket? I'm being a bit facetious, but I hope you see the point.
Of course, subtle things can happen when you accelerate an object. (See all the discussions about the Bell spaceships.) But your first sentence said "We all agree that "in its own frame", the box has not shrunk." That implies that you have accelerated the box in such a way as to preserve its proper length (as opposed to stretching or squashing it), thus you have introduced no stresses on the box or its contents whatsoever.
Of course. As measured from the moving frame.
As measured from the "stationary" frame, the separation distances between molecules will be contracted.
As measured from the moving frame, the separation distances between molecules will be contracted.
Sure, as a measurement process, not as an active process (see your previous post to Xeinstein).
Interestingly enough, this is the error in the Schutz text, Schutz takes the contraction as an active proces when he calculates the mechanical work [tex]p\Delta V[/tex] resulting from such contraction. This type of contraction, due to measurement effects, cannot be responsible for any mechanical work. Subtle are the ways of relativity.
I think matheinste was clearly talking about observations made in the moving frame:
To answer his question "No" just adds to the confusion. :wink:
Otherwise, I agree with you. And, for the life of me, I don't understand what Schutz was doing. (I don't have his book; just going by what I see on that link.)
Happens to the very famous :-)
Xeinstein said:
No, that's Not true. In either frames ,the lab frame (the box is moving) or the box co-moving frame (the box is at rest), pressure does Not increase, it's the same before or after acceleration. If you follow Schutz's calculation in his book, the pressure is a constant but the volume of the gas Does change, that's Lorentz-contraction all right
Here's the link to his calculation :
The point is that Schutz made a mistake, [tex]\Delta V=0[/tex] this is why the pressure does not change. For the 5-th time.
If by [tex]\Delta V=0[/tex] you are saying that change in volume due to relative motion is zero, then that implies that change in length due to relative motion is also zero and you are seriously mistaken.
If change in length (length contraction) is imaginary then change in clock rate (time dilation) is also imaginary, because they go hand in hand. There is plenty of experimental evidence that time dilation is not imaginary.
You might have noticed that Einstein and Lorentz state that [itex] L = L_o \sqrt(1-v^2/c^2)[/itex] and not [itex]L=L_o[/itex] which is what [itex]\Delta V=0[/itex] and [itex]\Delta L=0[/itex] implies.
Why does Special Relativity have all those those complicated transformation formulas if no real physical transformations occur? Why does anybody bother if they are all imaginary and have no consequences? Kind of makes relativity pointless.
So that's Not the question. The question is this: Does the box contract "in the lab-frame" in which the box is moving? [/QOUTE]
Yes, if the box is accelerated relative to the lab then it will physically length contract relative to its length when it was at rest in the lab. Of course an observer that co-moving with the box will not be able to measure this length contraction. It is only measurable by the observer with relative motion to the box.
Lorentz contraction demands that length (and volume) contracts. Lorentz contraction does not demand that that gas resists the contraction.
Despite real physical length contraction the pressure does not increase. I have gone to great lengths to demonstrate this in another thread by several methods. Here is yet another way of looking at it but this is more informal than the other arguments I gave in the "Proof that gas pressure is invariant" thread:
In classical experiments to determine the gas laws they found that when the temperature of a quantiy of enclosed gas is reduced that the volume reduced by a proportinal amount if the pressure is kept constant. The constant pressure means that the gas does not "resist" the contraction in volume as the temperature is reduced. Temperature can be thought of as a measure of the average kinetic energies of the particles in the sample of gas. Be warned however that temperature is a complex subject and there are several interpretations of exactly what we mean by temperature when we consider the relativistic case. In a simplyfied viewpoint reducing the kinetic energy of the particles in the box relative to the box is similar to reducing the temperature of the gas and results in a reduction of volume without any change of pressure. When the box is accelerated to a velocity relative to us, time dilation basically causes the particles to slow down in a manner similar to reducing the temperature and this combined with the contracted volume of the box is consistent with no change in pressure and with no "resistance" to contraction of the box and no resistance to the acceleration of the box due to gas compression.
In another post you asked if length contraction of the gas particles themselves results in a reduction of pressure in the moving frame. The answer is no. According to the gas laws the pressure within a container is independant of the size or mass of the gas molecules (to a first aproximation). The formula PV = nRT contains no term for the size or mass of the molecules, only the number of molecules (n). This is of course for an ideal gas.
  • #31
This is not what Doc Al and I are talking about.
Have u read starting with post 23?
  • #32
I have re-read the posts and it is still not clear what you mean by [itex]\Delta V=0[/itex].
Could you clarify what you mean?
In post #22 you state :
Have you changed your position on that statement?
When the box is moving relative to an observer the observer will measure the box to be length contracted. Whether that length contraction is real or not depends on whether it was the box that accelerated relative to the observer or whether the observer accelerated relative to the box.
To give a further example. Say we have 2 observers at rest with respect to each other and each with an identical box of gas. Observer A with his box accelerates to velocity v relative to observer B. Both observers will measure the other observer's box to be contracted. We can express this situation as:
(Volume A) < (Volume B) according to observer B
and
(Volume B) < (Volume A) according to observer A.
The expression
[(Volume A) < (Volume B)] AND [(Volume B) < (Volume A)]
is a logical contradiction as they both cannot be true at the same time.
We can resolve the contradiction by saying that the box that accelerated (box A) really length contracted while the volume of box B only appears to have length contracted. Box B never accelerated so it has not undergone any physical change. The apparent length contraction of box B according to observer A comes about because A is making measurements with rulers that length contracted during his acceleration and with clocks that are running at a slower rate due to his time dilation.
We can apply this logic to the Twin's paradox. Twin A accelerates away from twin B for a while. Both twins measure the ageing rate of the other twin to be slower than their own ageing rate. However when twin A returns twin B discovers that twin A really was ageing slower while twin A realizes that his measurement of twin B's slower ageing rate was an illusion. This is because A was making measurements with rulers and clocks that have physically altered during acceleration.
In the case of the twins and time dilation we can show that for at least one observer the Lorentz transformations have a real outcome. One twin really is older than the other one.
  • #33
and
The expression
the box does not accelerate, it is in uniform motion.
  • #34
If the box has always been moving at velocity (v) with respect to us and we have no history of the box (or ourselves) accelerating then there is insuffient information to determine if the contraction of the volume (V) is "real" or "apparent".
Either way we would measure the box to contracted according to [itex] \Delta V = V_0 - V_0 \sqrt{1-v^2/c^2}[/itex].
How do you justify [itex] \Delta V =0 [/itex] ?
  • #35
do you understand the xchange with Doc Al?
