Second Quantization and Field Operators
In summary, creation and annihilation operators are linear functions that change the number of particles in a state. This is necessary for a theory that incorporates the creation and destruction of particles. The Hamiltonian must contain an operator that allows for this change in particle number. The non-zero off-diagonal elements of the S-matrix represent the probability of transitioning between states with different particle numbers. This is possible due to the time evolution operator and the fact that states with different particle numbers are not orthogonal.
mkrems
When defining a field operator, textbooks usually say that one can define an operator which destroys (or creates) a particle at position r. What does this really mean? Are they actually referring to destroying (or creating) a state who has specific quantum numbers associated with the geometry that they call r. Any insight would be appreciated. Thanks.
A creation operator is just a linear function that takes an n-particle state to an n+1-particle state, and an annihilation operator takes an n-particle state to an n-1-particle state (and the vacuum state to the 0 vector), so the really short answer to your question is "yes". A longer answer would explain stuff like what one-particle states are, and how the Hilbert space of n-particle states can be constructed from the Hilbert space of one-particle states.
Also, the term "second quantization" is kind of old-fashioned and useless.
Maybe in particle physics.
But not in solid state physics or even string theory.
mkrems,
A theory which incorporates the fact that particles are "created" and "destroyed" necessarily has to include an operator which, when applied to a state of N particles, gives a state of N+1 particles.
At the theoretical level, what we really mean when we say particles can be "created" or "destroyed" is that states of different particle number are no longer orthogonal. If particle number is constant, then the inner product between a state of 2 particles and a state of 3 particles would necessarily have to be zero. That is, given a state of 2 particles, the probability of observing 3 particles would be zero. Letting particle number vary means we now have non-zero probability of observing a different particle number than what we started with.
Basically, the only way to do this is for the Hamiltonian to be built from an operator which changes particle as described above. If the Hamiltonian did not have such a term, then the time-evolution of a pure state of N particles will only, can only, evolve into states of N particles, forever and ever, amen.
:bugeye:
Uh, states with different particle number ARE orthogonal. What you are referring to is the time evolution operator ; in other words, you are confusing final states and initial states. So it is correct that an n-particle FINAL state is not necessarily orthogonal to the TIME EVOLUTION of an m-particle INITIAL state.
However, an m-particle initial state is still orthogonal to an n-particle initial state, and similar for final ones.
In the end, we're talking about zero or non-zero elements of the S-matrix.
You give me pause, vanesch. I have been corrected here before. :smile: Here is how I understand it.
If states A and B are orthogonal, then given state A, the probability of observing state B is zero. Period. The only way you could ever observe state B is if it is not orthogonal to A.
Consider a Hydrogen atom with the electron in an excited state. In the absence of the EM field, the excited state is orthogonal to the ground state and no transition can theoretically ever occur. When you perturb the system with the EM field, then you find that the state |electron excited + zero photons> is NOT orthogonal to the state |ground state electron + photon(s)>, i.e., a transition can occur.
What else do non-zero off-diagonal elements of the S-matrix represent? If the probability of putting m particles in and getting n particles out is non-zero, that is the same thing as saying the states are not orthogonal.
If phi is a state of m particles and psi is a state of n particles:
[tex]P=|\langle \phi(t_1)|\psi(t_2)\rangle|^2[/tex]
Indeed: given an initial state of 5 electrons, the probability to have an initial state of 6 electrons is zero!
A *time-dependent* transition! At t = 0, your "probability for transition" is 0. After a time t, you have a finite probability of transition, which, in the approximation of Fermi's Golden Rule, is linear with t, so the coefficient will give you the "probability per unit of time" to decay.
The only thing that it means is that |electron excited + 0 photon> is not an eigenstate of the full hamiltonian.
Do you notice that you use "in" and "out" ?
Do you notice that you have a t1 and a t2 ?
Orthogonal states means: "have distinguishable properties".
Consider (in NR QM), the "position states" |x1> and |x2> . I hope you agree with me that for x1 not equal to x2, these are orthogonal states, right ?
Now, consider that we start with an electron in position state |x1>. A bit later, we find a non-zero probability to find it in state |x2>. Does that now mean that they are, after all, not orthogonal ? Of course not. It means that the TIME EVOLUTION operator U(t1,t2) has mapped |x1> onto a state that is not orthogonal to |x2>.
< x2 | U(t1,t2) | x1 > is non-zero. But that doesn't mean that < x2 | x1 > is non-zero, it only means that U(t1,t2) has a component | x2 > < x1 |.
Hey, I didn't say anything about time-independence.
There's a lot of history here, started by Heisenberg's initial solution of the harmonic oscillator by matrix mechanics. What he found was that linear combinations -- sum and difference of position and momentum operators made the algebra easier. They transformed one state into another: going from x to x' in configuration space is a translation; a, the destruction operator, for example, moves a state by -1, from a state with energy wN to one with E =W(n-1). These operators were once referred to as ladder operators and step operators. Step operators are used extensively in angular momentum theory, and, more generally, in the study of Lie groups.
Prof. Fock developed so called Fock space, in which the step operators create a representation of a space containing from 0 an infinite number of oscillators. So quantum fields form the basis of a very efficient formalism for systems and interactions that do not conserve particle number. You could, if you wanted, do all of quantum field theory with configuration wave functions -- the two approaches are connected bya unitary transformation -- and you would quickly find out why the usual formulation of QFT is so much in vogue.
By the way, 2nd quantization is a mis-characterization of QFT, which is nothing more than ordinary quantum theory in a Fock basis. A quantum field is simply a highly useful mathematical construct, just like say, a Bessel function, a vector, resolvents, complex numbers, in fact.
Regards,
Reilly Atkinson
But you said that "states of different number of particles are not orthogonal". Usually one woul dinterpret that statement as saying you meant "states of different number of particles at a given time are not orthogonal" which is what Patrick is saying is wrong.
I guess you meant states at different times which was not clear from your initial statement ( and if we start discussing states at different times, the time evolution of the system most be specified). I think that's the whole point of Patrick's objection.
1. As vanesch pointed out, states with different numbers of particles are always, repeat always orthogonal, quite independently of any time behavior. This is basic to the notion of Fock space;
<N| N+M> = 0 unless M=0 -- just put in your step operators, unless the number of a's on the left equals the number of a*'s on the right you get zero.
You might argue that as time goes on an initial state with fixed numbers of particles will generally evolve into a state with most any number of particles. This evolved state clearly then is no longer a state with a fixed N. Then you typically expand the state on the basis of the orthogonal |N> Fock states with N=0 to infinity.
The standard QFT interactions are built primarily on the 3-point interaction, which allows one particle to transform one to two, or two to one, or nothing to three, and three to nothing -- the two later types represent the vacuum creating, say, a electron positron pair along with a photon, or the other way around. Your statement about the Hamiltonian is correct
Regards,
Reilly Atkinson
It is an artifact of overcounting. The step where you consider the Schrödinger equation to be a classical field equation should be considered as quantizing minus one times, so overall it is 2 - 1 = 1. :smile:
Also, I've read that some people proposed calling quantizing gravity as "Third Quantization"
Philosophical reflection
See this amusing reflection of John Baez about the n'th quantization.
http://math.ucr.edu/home/baez/nth_quantization.html
I always made loose philosophical connections between string theory as a constrained case of higher order quantization.
If we are talking about indistinguishable particles, it seems clear that we can not distinguish between a multiparticle system or wether the SAME particle seems to be all over the place, or beeing "smeared out" like an extended object?
IE. is a state smeared out as an extended object, or do we have several indistinguishable objects? And what's the difference? :devil:
The multiparticle interpretation vs the "second quantization". IMO it seems to be different "interpretation" of the same thing. I always actually liked the name "second quantization".
It even suggest here an inductive scheme. Which is what Baez reflects on. And others have done so as well.
/Fredrik
/Fredrik
Can you tell me where I might find the spectral resolution of Baez's K operator -- as in, for example does K^^N, as N goes to infinity, converge to a finite result? From Baez's description it seems to me that K is a unitary operator; but I'm far from certain about ascribing that characteristic to K.
Thanks,
Reilly Atkinson
K is the map from the category of hilbert state vectors and linear operators on this space, to the category of "fock" state vectors and the linear operators on fock space.
K^inf would results in some infinite dimensional mess, increasing the degrees of freedom - this is why I don't think receipe along makes sense. It would not converge to anything useful IMO. But I still find the reflection interesting.
I make the following parallell association here...
Consider a distinguishable event x.
1) Either the event happens, or it doesn't {0,1}
2) Consider that we inflate our information capacity in on dimension, we can now consider that continuous probability that this event occures {p(x)} ~ [0,1] ~ R
3) Consider again that we inflate our information capacity in another dimension, we can now consider a continuous probability for a certain probability {p(p(x))} ~[0,1]x[0,1] ~ R^2
We go from point, to string, to plane; 0-brane, 1-brane, 2-brane.
I know this is fuzzy, but to try to formalize this isn't the interesting part IMO. It's the conceptual thing behind it.
This is connected to how I consider dimensionality to be dynamic, but I do not do it like above. Instead of considering a continuous string, one can cnosider "string bits", and that way it's easier to understand how objects of different dimensionality can morph into each other, as part of what I consider to be an optimation problem.
The limiting physical information capacity is my main guide here. A continuous string, may be recovered as an approximation but I've got a feeling that it contains far too much ghost degrees of freedom. I don't think the continuum is physically observable, and therefor I would prefer not to see it in the models either.
/Fredrik
My original association is that if one like me, consider that the information has subjective reality in the observers microstructure then the state of knowledge of a point, can in fact look like a string. IE. the IMAGE of a point, can look like a string due to uncertainty. This is the coupling I make. But there seems to be more than one way to interpret this.
/Fredrik
It seems most stringers consider the string real in another way, and rather thinkgs that the string is compactified and looks like a point. But that way of thinking is similar to the bird -> frog projection I don't think makes sense.
I prefer to say that the frogs uncertainty inflates the point into a string. And I think this can be understood without actually postulating the existends of strings.
That said I don't like the string theory foundations as it stands but it's still interesting reflections to compare views. So even though I disagree, I can see where the strings come from. It's just that I would choose to see if quite differently.
/Fredrik
I think the preferred dimensionality might be understood as a generalization of the principle of maximum entropy. A too high dimensionality will decrease the certainty of information for obvious reasons, since the degrees of freedom we have no control of are inflated. A too low dimensionality will not be stable, since it keeps changing - ie the degrees of freedom is too low to describe the situation.
I'm sure there has been a lot of work on this. But I see this as part of the problems that aren't yet solved to satisfaction. It's in this larger task I find the reflection on the quantization procedure as an induction step food for though, but not alone the solution.
Reillty, this is what I mean before when I don't think unitariy in the most general case can be maintained. To maintain it, I think we are forced to increas our degrees of freedom beyond what we can relate to. And I think the results is that we get lost in a landscape too large to relate to.
I think there may be another way, that instead of applying the standard QM procedure over and over again - tweak the procedure. I think there will still be a procedure, but then we can find a physical meaning of the procedural progress - time!
Thats my vision, but don't ask me to prove it, I can't. But it's the trac I'm tuned in on.
/Fredrik
K is a functor, -- neither an operator, nor unitary. It maps from one Hilbert space to a
quite different one. E.g., from a 1-particle Hilbert space to a multiparticle Fock space.
That means it's not an operator, because operators act from one space to the same space.
Also, it can't be bijective, since (eg) the Fock space is larger than the 1-particle space.
Therefore, K can't have a well-defined inverse in the usual sense. Preserving an
Hermitian inner product also doesn't make sense here, since the spaces are different.
The interesting part IMO, is to, if one for a second forgets about specifics like "particle" concepts and so on, and instead just considers abstract spaces of distinguishable states,
In that context, how can we interpret the "second quantization".
We have on state space, and inflates it to a larger state space? For what purpose? Well seemingly do fit our observations, and maintain unitarity. The smaller state space was too small (too few degress of freedom).
And how can one interpret what is happening if we repeat the same trick? What if the fock space is also too small?
a) What if we do the third quantization? And what would be physical interpretation be?
b) Is there another way? and how are these ways related.
And then, by induction, what would the n'th quantization mean?
And now the point I find interesting, does the quantization procesure itself have any physical significance? or is it just a human paperdragon?
/Fredrik
The way I understand (n+1)-th quantisation, which can be wrong, so be careful, is this: if you have a classical theory with configuration space and lagrangian, then you "quantize" this system by assigning an independent dimension of Hilbert space to each point of the configuration space. In other words, what was a configuration in the classical theory (a point in configuration space) now becomes a basis state in the quantized description, and a general quantum state is now a superposition of all of these base states, which can be represented by a "wave function" over configuration space. The value of the wave function at a point of configuration space is of course nothing else but the component in the quantum state of its related base state (the coefficient in the basis expansion).
Now, this wavefunction obeys a certain dynamics, given by the Schroedinger equation and with some hocus pocus, you can see this again as a classical system with dynamics. But this time, the "configuration space" resembles the original Hilbert space. If you look upon this dynamics as a classical system, you can AGAIN quantify it. So this time, quantum states of the first system label the independent basis states of the second system.
The hocus pocus is related to the fact that the Schroedinger equation is first order in time, and one needs a second-order system in order to be able to consider it as the configuration space of a classical system.
Simple application: one-particle classical system --> simple classical dynamics with 3-dim configuration space. Quantum system: "wavefunctions in space" hilbert space. Hocus pokus: scalar field in space. Quantizing again: quantum field theory of scalar fields.
I personally find one problem of all this is how to make a distinction between distinguishable states and state of the dynamics describing the evolution of the former states. Because why would me make an distinction between states and states? It doesn't make sense.
To me, the dynamical rules, hamiltonians and whatever we use, are part of the total state and should in some sense be observable. So that all we have is a sort of self evolution.
The separation of initial conditions and laws comes out as a flaw. Because the law itsel can be considered as part of the initial conditions. And how can we describe distinguishable states in state spcec and distinguishable laws in lawspace on an equal footing, so that the self-evolution is part of the state and no "external" laws are needed.
I think a sensible descriptions should be able to define the future pointer without any external construct. Which suggests to me that the predictable part of the differential dynamics should be encoded in the set of initial information, in principle at the same level as the traditional "state".
As soon as someone say langrangian I get headache. I try my best to avoid anything that fools me into classical thinking. I've studied all that, but I find it easier to forget everything you ever "learned" and try to think from scratch. I think there must be a better way to seee the meaning of the action principles, and I connects it to the concepts of subjective probability. I even think of classical action as related to plausability. In classical mechanics course the ultimate motivation is that it agrees with Newtons mechanics. The deeper motivation is still lacking.
I try to play stupid, becuse it's less confusing: I am an observer lost in space, how I can define this lagrangian or hamiltonian, and how does it help me survive :) And how does this process interfere with the mentioned description? Is this process even part of hte physical interactions?
/Fredrik
I think I am fuzzy as usual. A clarification.
My main message wasn't that I disagree with what Vanesch said, which it may seem like. I rather want to say that I think this problem need to understood together with the problem of time, and he problem of choosing observables.
In my thinking, the information capacity of any observer is self-regulatory. And there is a selective evolutionary pressure which causes inconsistency observes to loose information capacity. And it's tempting to associate this to loosing mass or energy. But I'm not clear on the exact connection. I'm still sleepless due to this.
Since I associate "mass or energy" with confidence it measn that loosing it means loosing confidence - or that the uncertainty increases. By increasing the degrees of freedom, like you do what you replace a number with a probability distribution, that's only an option if your information capacity allows for it. And there are probably different ways to use any given capacity. If you can make observations on a set of events, and you see that this events just keeps flipping, the question is how to best make use of your capacity? Form the average? and then you still end up with oscillations around the average - howto resolve that? perhaps if there is a pattern in the oscillations themselves this could give more bang for the buck. Then this patter itself could be stable. Or not. If not, similar expansions can go on and build a complex microstructure with has evolved to surviva in a given environment. Then the expectations might have a physical reality in this microstructure.
In this strange sense, "a superposition" can be understood to appear due to internal transformations, who in turn are driven by an optimation. There is a selection for transformations, where those transformations who doesn't make sense simply loose their confidence and go away.
In this, everything does acquire mass/energy (I'm still not clear on this), including the transformations themselves. Which means that there is a constraint on the possible transoformations especially for simple systems. Perhaps the the standard model could be understood as the simplest possible selections? So the defining characteristics of the expected structures are their interacting properties, what they "really look like" inside is a question that makes no sense.
I was hoping to continue with a toy model I have to see if I can define the optimation problem, whos solution would be the superposition or more properly the transform that generates it as the best guess. But then I started reading rovelli's book and got into sidetracks.
IMO, the quantization mystery has two issues.
a) the inflation of the degrees of freedom like vanesch describes - but this would then compete for encoding capacity, and inflating something will shrink something else, unless you inflate the number of distinguishable microstates of the observer.
b) the superpositon principle, or the complex amplitude thing vs standard probability.
I think the two are related.
/Fredrik
My question was and is pretty simple minded. The unitary transformation to which I referred is that between the Hilbert space for an infinite number of particles (or oscillators, say in a small oscillation system with an infinite number of oscillators. ) In this case, so-called 2nd quantization is just a unitary map away from the particle representation. Further, this type of mapping is ubiquitous -- see Boguliubov's treatment of superfluidty, see the work done on superconductivity. The basic version goes like: q and p <-> a and a*, with q = a + a*, p-> i (a*-a), apart from constants. q,p <-> a*,a is clearly acomplished by a unitary transformation.
From the perspective above, what are the steps and definitions for 3rd quantization? And, note that the K orperator must be equivalent to a unitary transformation, at least for 2nd quantization. And, it's straightforward to write down a representation of this unitary form for the K operator.
I would presume that for this next step, K must be embedded in a space larger than the q,p/a*,a space. But I do not have a clue waht this larger space would be. Help.
Regards,
Reilly Atkinson
back to the original question...i have been studying these things for the past few days and wrote a latex document on the subject. nothing really new here, but i tried to focus on pedagogy and examples so that someone with a basic knowledge of QM can understand 2nd quantization. take a look at my paper and let me know what you think!
http://www.physics.ucsd.edu/~mkrems/research-physics/secondquantization.pdf
Nice job. I went through very quickly, and it seems to me that you have it right. Many texts cover the same material, often in the same fashion as yours. Congrats.
Regards,
Reilly Atkinson
I guess I don't understand the question... :-(
No,... wait... 2nd quantization is the passage from 1 degree of freedom (1-particle Hilbert
space) to infinite degrees of freedom (many-particle Hilbert/Fock space). That's not a
unitary mapping.
What you wrote is just a mapping between 1-particle operators. However, the Bogoliubov
transformations act (in general) between inequivalent (disjoint) Fock spaces (i.e., between
distinct Fock spaces, each constructed cyclically from different orthogonal vacua).
(I'd better not attempt any further response to the rest of your post now until the
question becomes clearer.)
I'm not sure I understood your reflection in this context either.
As I see it the Boguliubov transformation is unitary, but doesn't directly have anything two do with the quantization procedure as such or maybe you see a connection that I'm missing?
I rather rather see it as a transformation between observers within the same quantization so to speak. Indeed this is also interesting but I don't see the direct connection to the discussion of quantization, relative to a specific observer? But it seems this could be a different discussion which I think of as appearing "later" in the reconstruction I have in mind?
But then I think there is different ways of attacking these things, and I can only speak for how I prefer to attack it but I don't expect everyone to agree, and I could certainly change my mind.
IMO, the notion of "particles" and the problems how to maintain a consistent particle interpretation in higher quantisations, does not have anything directly to do with the formal second quantization as I see it at least. That's why I personally try to not use those words. I see that almost as an "interpretational" kind of issue.
The only reason I said fock space above is to compare it to the standard interpretation. But IMO it's just a hilbert space in the same way as the original hilbert space - though anothre hilbert space, not the same one.
I think in terms of relative to the observer, distinguishable states of a distinguishable microstructure. This is why indistinguishable events can only be counted and correlated with other events and thereby - indirectly - be distinguished as always appearing correlated to other events, that effectively becomes a label.
If we call these events particle detections of detections or something else is IMO not the interesting part. "Particle" is IMO just a label for these things. I have no preconceptual ideas of properties particle may have. And just because of this, using the particle word brings more confusion that it resolves IMHO.
I think in terms of what we can observere and distinguish. And the question is, how can we best organized and exploit this data to predict what we will observe next? If we know this well, we can reorganized ourselves to be optimally fit in this environment. If we fail, the chance is that we(the observer) is destabilised. Relabeling the names of things doesn't change anything.
This is a more abstract view, but IMHO it gets cleaner, and there is no need to bring in visual elements from classical mechanics. It doesn't help me at least. It's only a diversion that found more desctructive than constructive. But that's just me.
Perhaps someone else can give some more sensible comments on particle interpretations specifically. I really don't want to corrupt my brain to even think about it. I go get headache and it's not leading me anywhere :)
The way I see quantization is how one ideally distinguishable states of a microstructure, now for whatever reason now has become to uncertain and unpredictable that it destabilises the support of the microstructure itself! and here the observations are focused in the observations of the first state. So that we know ask not what is this state, but rather what do we know about this state in a sense that our confidence is quantified, beyond the simplistic {true,false}. So we are inflating a boolean state space to a continuum probability [0,1]. So what this does is that it increases the degrees of freedom in the microstructure. And in my personal thinking, this microstructure lives in the structure that defines the observer. This is why the infinite quantization does not make sense. A finite observer can not support that structure.
Then we can parametrise this continuum. So that our information of the first state (which wasn't definite) is again definite. Now if for whatever reason, the observer finds that this still doesn't make sense, he can again consider the information of the information. Second quantization.
And so on - but WHY does this make sense? What distingusishes this from any arbirary scheme?
But in this view I ignored the dynamics, and the "trick" that suddently a superposition can be treated as real state in further quantizations. The complete understanding is IMO still not in my head at least. But in short I think that superpositioned states ARE real. They are realized in the observers microstructurs as dynamical correlations. And these correlations can ba rated. Here I see the issue of inertia coming in. A superposition can be assigned inertia which can explain it's stability.
I'm still thinking about this. I think one needs to bring some structure into this. There is so much semiclassical thinking going on that to speak for myself at least, it's easy to loose track of your own reasoning and where assumptions to in and where conclusion come out. I have started to form my own personal structure of this and I am reasonably clear on some things, but the entire picture is complex. The most hairy parts is the dynamics and how the microstructure evolves. Creating and collapsing of microstructres in the way I use the word I see related to the origin of inertia. When the microstructure looses it's inertia it collapses, and similarly the inertia of deviations somehow DRIVES the formation of new structures.
This is more interesting, but also more complex. And would need it's own thread. And I probably have more questions than answers anyway. Perhaps someone else who knows more can share their views.
So in my thinking, I'm questioning the formalism of quantum field theory, which is really no different in principle from QM, except for the space-time part, which I consider to be a separate problem - though still entangled. If we try to analyse this from scratch, one might want to release oneself from what we think we know, and requestion in, and along the way see what's good and what's not good. It's what I try to do as far as my tiny head allow me to :rolleyes:
/Fredrik
About this, I even think of these transformations as non-deterministic. The point IMHO is that, one observer can not just transform his state and somehow figure out with certainty everybody elses opinon. The flaw in this is IMO that the transformation itself contains information! And this can sit nowhere else but in the observers microstructure, and it's dynamical just as everything else.
The knowledge of this transformation is physical information IMO. This is part of the problem with GR + QM IMO. And i think different people do have different views here. And my view is probably not the most common one, but I never made a poll on it.
This view makes everything float I know. But I stick to it because I think it's the way things are. I'm trying to acknowledge the limits and make the best possible predictions given these constraints.
/Fredrik
  • #31
Fra and strangerep Quite honestly, I don't understand at all what you are saying.
Just for fun, I've gone to my library to see if, somehow I've misled myself into some dicey territory. So, Dirac(in Quantum Mechanics), Landau and Lifschitz (Quantum Mechanics; the Nonrelativistic Theory) March Young and Sampathar(The Manybody Problem in Quantum Mechanics.)Ian D. Lawrie(A Unified Grand Tour of Theoretical Physics) Mandel and Wolf(Optical Coherence and Quantum Optics with a particularly elegant discussion), Feynman in his groundbreaking paper, Theory of Positrons, Bloch and Nordsieck in Radiation Field of the Electron(1937), which solved the problem of the infrared divergence -- they all agree with me -- because that's where I learned about 2nd quantization.
And, my discussion of the unitary transformation is in total agreement with these authors. Second quantization i's basically pretty simple and straightforward, and has been a staple, an old chestnut, of much of physics throughout the history of modern QM. My discussion above could almost be a quote from any of the above references.
That is strangerep, all these authors agree that the mapping is as I suggested, Fock space is merely a representation of an infinite number of degrees of freedom. You have a very heavy job to demonstrate your claim, which is totally at odds with usual practice, and is not supported by many, many authors of significant stature.
This discussion provides a great example that physics has a history, and if you do not know about it, then you are very likely to make mistakes.
Fra - Bogulubov is taking a standard Fock space, and using a unitary transformation to another Fock space. Quantization? -- in the eye of the beholder. I you take his transformed states back to configuration space, you will find a different mix of states than you would get with the standard Fock transformation. That's by most definitions, a different quantization scheme.
So, you can find confirmation of my discussion in hundred(thousands?) of of books and articles and dissertations.
Regards,
Reilly Atkinson
  • #32
Yes, but that's not the whole story.
All I said was that 1st quantization is the passage from classical to single-particle (1-dof)
quantum. 2nd quantization is the passage from 1-dof quantum to inf-dof quantum.
There's nothing new in such a statement.
You seem to think I'm saying something non-standard, made up out of my own head.
But I'm not. The textbooks you mentioned don't talk much (if at all) about the issues
of inequivalent unitary representations in infinite-dimensions. Umezawa's "Thermofield
Dynamics..." (ch2, I think) explains some of the extra subtleties on a pedagogical level.
Haag's "Local Quantum Physics" also discusses it, though at a more demanding level.
However, I sense from your answer that I'm annoying you, so I'll shut up now until
I find out what the actual point of disagreement is here. I suspect we're currently
just talking past each other.
P.S: I don't understand Fra either. Too fuzzy.
  • #33
First let me say that I've got a lot of respect for your views. And your comments on inequivalent unitary representations are, I think, correct, and I need to review the topic, which I certainly will. Whether we agree, thus remains to be seen. But, in any event, I'll bet we would both write out the QED interaction and the typical potential energy for a second quantized system in much the same fashion. I suspect, as you apparently do, our differences are not as great as I might have once thought.
Annoyed? Not at all. Quite the contrary. Regards,
Reilly
  • #34
Fra -- There are times when you are one hell of a thinker.And I'm sure there are some good nuggets in your posts here.You would be doing us all a favor if you could give a precis, a summary of your posts.
Thanks, Reilly
  • #35
Reilly thanks for the nice words. Indeed I am fuzzy, but this is not easy stuff, it's a snapshot of the process that's fuzzy and the more clear direction and strategy I see may be subjective. Reality is fuzzy and that is stressful.
I think I'm slowly starting to see your point of view now, and I think that view is simplifying away some of the mystery without resolving it. I can say that when reading Dirac's classic : Principles of QM - I think I disagree with his reasoning very early in the book - and the first point is on the notion of probability. Sure, anything that fulfills the axioms of probability is a probability, but that's not the real problem at all. It's how that connects to real measuremnts, done by real observers subject to real constraints. He ignores a range of these issues. He seems content with imagining that "in principle". But that is a mistake IMHO. It's not that he is formally unclear, it's that he is physically unclear IMHO. Now, then he further builds onto this framework. I am going back to the first point of objection, and rework it from there. Now this doesn't mean redoing history, its not that bad at all.
It would be naive of me to even attempt a clear and precise description of my view here. At least now, easter coming up and all and this is a passion of mine, not a job. Meaning I don't have 8 hours / day to spend on this. But I will get back to it as soon as I have done more work myself.
Reilly, let me get back to this. I do think about these things and I do intend to produce some writings. That will explain my point of view, from start to finish. Sorry if I cause confusion. Sooner or later I'll probbly post more. I temporarily put my own work aside to read up on rovelli and penrose's view on foundational QM and QG, because I sensee a connection. but as soon as I've done that I'll resume where I left off.
/Fredrik
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
