Inertia Moment for Racing Motorcycle Wheels
In summary, the formula for calculating the force required to turn a motorcycle at speed is based on the wheel's moment of inertia and precession.
kl3640
Hi, I'm hoping you kind folks can help me out. I'm a motorcycle racer, and I'm trying to find a *simple* formula for calculating how much mass addition/reduction to a wheel will increase/decrease the force required to change the direction of the motorcycle when at speed.
Basically, to turn a motorcycle, you push on the handlebar in the direction that you want to turn, which "deflects" the wheel. The problem is that when you're going fast, the wheels (and other engine internals) are moving fast and so steering the bike at speed a certain amount requires more force than steering it the same amount at a lesser speed. So I'm interested in knowing how to calculate, for a (for my purpose) uniform disc rotating around its center axis, how much difference additional or subtractional weight would make on the force required to turn the bike at a given speed.
For example, if the wheel weighs, let's say, 12 pounds, I want to know how to calculate how much "force" is required to pivot it on its axis at, say, 100mph.
I need a formula that I can understand, because I've been out of college physics and calculus so long that I don't remember what all of the greek symbols represent, and so on.
Thanks in advance for any help with this problem.
No, you push it in the *opposite* direction. Didn't you ever notice?
That's incorrect. People often make that mistake because they don't differentiate between a bike at speed and one going very slowly. At speed, pushing in the opposite direction is a technique known as "counter-steering," whereby you push on the *inside* opposite handlebar quickly to create a rapid deflection which causes the wheel to correct in the other direction, thus helping to initiate the lean. That's not the usual technique for altering a bike at speed's direction. Typically, you only do that at very very slow speeds to actually physically turn the handlebar, because the bike is moving to slowly to actually lean it to turn it. At speed, the handlebars themselves don't actually "rotate" in the steering head as you would think, such as when riding a bicycle around a parking lot. The counter-steering technique isn't used often at speed.
At speed, a motorcycle steers by leaning over in the direction of the turn, and that lean is initiated in a normal circumstance by pushing mostly *downwards* on the handlebar that's on the same side as the desired turn, and by using other parts of the body to create the forces necessary to initiate the turn.
In fact, racing bikes have steering stabilizers to prevent the handlebars from actually moving, because all of the steering is done by leaning, and any excessive movement of the handlebars could upset the suspension, or potentially succumb to a harmonic called "head-shake" or a "tank-slapper" where the handle-bar violently moves back-and-forth out of the rider's control.
kl3640 is correct, lightarrow. Countersteering is counterintuitive at first, but it is one of the ways of steering a motorcycle at speed (mostly used on streetbikes, not so much on dirtbikes, for reasons having to do with traction).
The other main technique for steering a streetbike at speed (mainly lighter sportbikes), is "body steering". That's where you use weight shifts on the footpegs to turn the bike, and let the front end find its own turn angle that matches the lean angle and bike speed. Racers typically use a mix of these two techniques, according to personal preference. Personally, I prefer 100% body steering, whether on the racetrack or on the street, but again, that's personal preference.
So to your question, kl3640... The two basic concepts you will use to do your calculations are "Moment of Inertia" and "Torque/Precession". The moment of inertia ratios with the mass, and with the distance the mass is out from the axle:
http://en.wikipedia.org/wiki/Moment_of_inertia
If you click on the Table of Moments of Inertia in that link, you'll start to see some basic formulas for the I values of various geometries. A real sportbike wheel is a mix of some mass between the axle and the rim (to support the rim), and mass at the radius of the rim (and the tire). You can actually measure the I for a real wheel by spinning it up with a known torque (get out your torque wrench and a stopwatch, and get creative).
Once you know the moment of inertia I for your two (different) wheels, you will use the equations related to precession to figure out how much torque it takes to displace the wheels and lean the bike. I honestly am no expert on this part, but I think the correct term to look into is "torque-induced precession", where the spinning of the gyroscopic I resists the motion that you are trying to cause with the torque:
http://en.wikipedia.org/wiki/Precession#Torque-induced
For your countersteering case with no body steering input, your torque is put into yawing the front wheel, to get it out from under the CG of the bike, and cause tip-in. For the bodysteering example, the torque is from the unbalanced weight on the two footpegs, resisted by the gyroscopic spinning of the two wheels.
I'll have to look into this a bit more to give a better answer. Let us know how far you get with this intro, though.
Berkeman, that's what I was hoping for - thank you. I'll proceed with this and let you know how it works for me (I'm ultimately hoping to get a simplified equation that somehow represents the different in work required to initiate a turn, so that different weights of a wheel, i.e., before and after powdercoating and the related weight difference, can be used to determine how they will affect handling performance particularly related to steer-in and transition).
Also, a related question if you don't mind: assuming that nothing changes about the wheel except for weight (i.e., the diameter and other relevant real-world dimensions remain constant), can I just ignore the tire as it would be a constant in both circumstances?
To induce a lean on a bicycle, motorcycle, or unicycle, a rider steers outwards to initiate a lean. The outwards steering can be the result of a rider applying an outwards steering torque force on the handlebars (counter-steering), or the result of the rider leaning inwards, causing the motorcycle to lean outwards (since the center of mass won't move sideways without a sideways force at the contact point between tires and pavement (or a side wind)), and the self-correcting geometry causes an outwards steering reaction to the motorcycle being leaned outwards. Deliberate counter-steering is best, since body leaning doesn't provide as quick as a response, and at high speeds on a motorcycle, body leaning provides no lean inducing steering response.
The rate of precession from gyroscopic effects is less than the desired rate of lean (roll) for a normal situation. The faster the speed, the more pronounced this effect becomes. At moderately slow speeds, a motorcycle has a tendency to remain or return to a vertical state, while at high speeds a motorcycle has a tendency to remain at it's current lean angle. At high speeds, it takes about the same amount of counter-steering effort to decrease lean as it does to increase lean.
From a previous post:
Two wheeled vehicle vertical stability is due to steering geometry, specifically trail. There are radio controlled motorcycles that don't require any special algorithims or gyro sensors to work, they just use a lot of trail, and a steering servo with a low resistance to small "non-commanded" movements caused by trail effect, allowing the self correction process to work.
Trail is the distance from where the front tire pivot point axis would intercept the pavement, back to the point where the front tire actually makes contact with the pavement.
When a bicycle is vertical, the trail creates a castor effect (like the wheels on a shopping cart), creating a tendency for the front tire to move in the direction traveled.
When a bicycle is leaned, the trail creates a inwards steering torque force on the front tire. This is because contact patch moves laterally when steering and vice versa. Suspend a bicycle off the ground. Steer left, and the contact patch area on the front tire will move right and vice versa. This lateral motion is relativly large on a radio control motorcycle, and moderate for human controlled bicycles / motorcycles. To see this effect, a person can hold a bicycle by the rear seat and lean it over, and the front tire will steer inwards.
Getting back to a leaned bicycle, gravity results in downwards force on the center of mass, and the pavement in turn generates an upwards force on the tires. At the front tire of a bicycle, this upwards force is applied "behind" the pivot axis and causes the front tire to steer inwards, and given suffiecient inwards steering and speed, the lean angle of the bicyle will be reduced until it is vertical again (it may overcorrect due to momentum).
The amount of trail effect determines the minimal speed required for vertical stability. At or above this minimum speed, a bicycle will be vertically stable, auto-correcting for any reasonable amount of lean introduced. If there is excessive trail, flex, or momentum, in the bicycle, constant overcorrection can occur, resutling in speed wobble.
Gyroscopic reaction generates lean angle stability (as opposed to vertical stability). As speed increases, a bicycle will tend to hold a lean angle and resist changes in lean angle, including the vertical stablity reaction from trail. In the case of motorcycles at high speeds, 100+mph, the lean stability dominates, and the motorcycle just holds a lean angle with no perceptible tendency to straighten up.
The moment of inertia "I" is the sum of all the little masses that make up the wheel, ratioed with the square of the distance out from the axle. So it's the sum (or integral in the sense of calculus) of all the little mR^2 contributions.
So the contribution from the tire will be constant, and the contribution from changing the wheel shape or weight distribution would be slightly non-linear with weight, depending on the distribution of that weight with respect to distance from the axle.
I doubt powder coating will make much difference -- what is the change in overall weight for the full wheel+tire assembly for powder coated versus non-powder coated? What is it for the front and for the back wheels?
Cool post, Jeff.
I'm not sure what you mean by "outwards." Let me give an example: On a track, at high speed, in order to steer left I will exert pressure on the left bar. So I agree with the above statement except that I and many other racers (road-racers - I race both track and off-road, and they require very different techniques) would disagree with the this part, "Deliberate counter-steering is best, since body leaning doesn't provide as quick as a response, and at high speeds on a motorcycle, body leaning provides no lean inducing steering response..." only because nobody on a track who's at all fast does one one or the other in isolation. Doing what you're stating occurs far more commonly in street-riding situations, where body inputs are minimal.
I argue that because on the track while most of us do what is called "counter-steering" (i.e., pushing the bar in the direction of the intended turn to initate the lean), we also set up our bodies to shift the center of gravity of the bike for the turn (i.e., hanging off the side and dragging our knees) to enter the corner faster and carry more speed through the turn. While that itself isn't for the purpose of intiating the turn, what we do in the process is shift weight to the appropriate foot, release pressure with the inside thigh and exert pressure with the outside thigh. Then, because we also have shifted our body-weight towards the inside of the turn, it helps to affect, in conjunction with the steering inputs, the lean of the bike in the direction of the intended turn.
Depending on what is considered "high speed," I can weave my race bike back and forth, and around a complete turn in fact, with nothing but my legs, with my hands completely off the bars.
I'm not sure why the move was ever dubbed "counter-steering" because the goal isn't to really turn the handlebars in the classic sense, but to rather lean the bike to the side of the intended turn. In that respect, pushing on the bars in that direction (and actually, as we do on the track, pulling on the opposite side) makes more intuitive sense to me. But I suppose that the move does technically deflect the wheel in the opposite direction, for however miniscule of a degree and moment.
Well, I (as are all racers) are obsessed with weight (our bodies, our gear, and our bikes). We generally concern ourselves with rotational mass and then sprung weight (that is weight carried by the bike's suspension) and then unsprung non-rotating items, in that order. So, for example, one of the best investments a racer can make is to buy lighter wheels. Even if the weight savings from replacing a stock unsprung part is the same or slightly greater but much cheaper, the wheel or crankshaft or stator will affect performance more because it willl affect more than just acceleration and braking, but also handling. In the case of sprung vs. unsprung weight, the attention should first be focused on sprung weight in order to better optimize the suspension, which contributes to all aspects of the machine's handling.
The reason that I want to be able to do the calculation is because I want to figure out things like the disadvantage of powdercoating in quantitiave terms, but also for things like ceramic vs. steel bearings, etc.
Also, I want to be able to sniff-out if things like this are BS or not:
"Each ounce of weight reduction on the rim is equal to about 24 pounds of weight at 100MPH!"
That's from the website of Mavic, a manufacturer of high-end racing wheels for motorcycles & mountainbikes.
hanging off
I don't race, but from what I see in motorcycle races, the riders hang off before initiating the actual turns. In order to hang off, some counter-pressure has to be applied to the steering to keep the bike from leaning outwards during the period of time when the rider is shifting his weight inwards.
weight in wheels versus rest of motorcycle
The typical approximation is that weight in the wheels is effectively double what it would be for the rest of the motorcycle. 1 lb of mass at the perimeter of the tire is equivalent to 2 lbs of mass at the non-moving parts of the motorcycle, regardless of speed.
Imagine a linear forwards force applied to the axis of a hollow cylinder (a very thin wheel). This forwards linear force is opposed by the friction force which peforms the angular acceleration (rotation) of the hollow cylinder.
The angular inertia of a hollow cylinder, Ic = M x R^2 (M = mass of cylidner, R = radius).
In equation form: LF - FF = M LA, LF is linear force, FF is friction force, M is mass, and LA is linear acceleration.
LF is a constant.
AA (angular acceleration) = T (torque) / Ic
AA = LA (linear acceleration) / R (assuming no slippage here)
LA = AA x R
Torque = FF x R
LA = ((FF x R) x R) / (M x R^2)
LA = FF / M
FF = LA x M
So substituting in the first equation:
LF - FF = LA x M
LF - (LA x M) = LA x M
LF = 2 x (LA x M)
LF / M = 2 x LA
LA = 1/2 (LF / M)
So linear acceleration of a wheel is 1/2 of what it would be if it wasn't for the increase in angular speed. For example, if friction force FF=0, then you'd have LA - 0 = LF/M. So weight at the perimeter of the tire affects acceleration by twice as much as the same weight would on a non-moving part of a motorcycle.
You set up your body to the side ahead of the turn typically, so that your turn-in is smooth, and you don't have to be sliding sideways on the seat as you transition into the turn. For pure body steering turn-in, you shift your weight onto the inside peg, unweight the outside peg, and pull in with the outside thigh. This buckles the bike into the turn, and the front end stabilizes at the turn angle that matches your speed and lean angle (and the fall line of the turn, etc. -- very exciting entering the Corkscrew at Laguna Seca!). You can also quicken the turn-in lean with a roll axis push-pull on the bars (different from the yaw axis push-pull of countersteering).
When you use a combination of body steering and countersteering, you are using the yaw push-pull on the bars to help displace the CG of the bike, to help the bike lower itself into the lean.
In my experience (on the track), countersteering alone is just not enough to control a bike at speed through complex curves. I tried and tried to hit the Corkscrew right with just countersteering (before I learned bodysteering), and my reactions were just not fast enough to control the complex line. But with bodysteering, controlling the path of the bike becomes much more intuitive, since the bike is steering the front end itself, and you are only concerned with shifting your weight to do the overall line control.
The main reason that I switched to 100% body steering for my street riding, is that countersteering relies on you making these non-intuitive push-pull motions with your arms, and when you get into emergency situations (cars dodging in front of you, or you getting into a decreasing-radius turn too hot), the first thing that happens is that your arms tense up, which decreases your ability to deal with the emergency. Not good. Using 100% body steering avoids this handicap, in my experience, and makes emergency maneuvers much more of an intuitive deal.
EDIT -- Here's the Corkscrew at Laguna Seca, for those who don't know the turn already:
http://www.corgifan.com/blogger/americanflyers2.jpg
http://www.motorcycle-usa.com/photos/corkscrew.jpg
LF is a constant.
Torque = FF x R
LA / R = (FF x R) / (M x R^2)
LA = FF / M
FF = LA x M
LF - FF = LA x M
LF = 2 x (LA x M)
LF / M = 2 x LA
LA = 1/2 (LF / M)
The act of hanging off itself will pull the bike in the direction of the hanging-off, which is why it helps in steering the bike more effectively. Typically a rider will move off to the side when approaching a corner, just before the corner. Usually this is done in conjunction with the less-sharp part of the turn (i.e., to stay on the racing line, which at that point isn't too drastically departed from the previous approach line). So I'm not 100% sure what inputs I would use at that point - it's not too complex a procedure so I normally don't pay attention but what you say seems to be correct, which is that since the hanging off causes the bike to turn in that direction, if the hanging is done before the bike is desired to be turned quite so much then some pressure is exerted on the opposite handlebar. My next even is coming up on 4/5-4/6 at JenningsGP so I'll try to pay attention to what exactly I do at that moment.
Separately, thanks for this info, this is very helpful to me. Perhaps you can explain something to me, to make it easier for me to calculate the difference in modifications to the static mass of an object that rotates in the direction of travel and the work required to overcome it at speed (i.e., the amount of effort I need to exert to divert a bike at speed from a straight line in order to initiate a turn):
Is there a proportional relationship between the static mass of an object, such as a wheel, and the rotational inertia, such that if I increase the static mass of the wheel uniformly (i.e., NOT just towards the center or the edge) by some percent X, I can then derive the increase in the rotational inertia by that same percent X?
To be honest, I'm not really interested in the absolute #'s, I'm really just interested in figuring out how I can simply calculate the effect of a weight increase/reduction on a rotating object (rotating in the direction of travel) on the effort required to deviate the vehicle from its current course (i.e., initiate a lean).
Is there a simple proportional relationship that I can use to infer how much more or less work I'll have to do steer the bike? Even if it's not a lot of work, it makes a difference because there are some looong races (like the last one was 52 laps at Daytona) so that little bit adds up over time with respect to muscle fatigue.
counter-steering
I defer to Keith Code:
http://www.vf750fd.com/blurbs/countercode.html
Note the "no bs" motorcyle is a 600 road racer replica, with little trail effect. When there is little trail effect, then body leaning can't be used to steer a motorcycle. On street motorcycles, at least ones with a lot of trail effect, I can sit up with my hands off the handlebars and do mild turns with body leaning, but this only works for a limited range of speeds, about 35mph to 45mph, depending on the motorcycle. As mentioned before at racing speeds, 100mph, the trail effect is virtually gone, and body leaning will do virtually nothing. I've read a few comments about this with regard to Daytona, where the riders go onto the banked section, exiting the banked turn at around 180mph, and nearly horizontal. It takes a huge amount of counter-steering effort just to get the bikes back to vertical, one of the comments that stuck in my mind is that a rider either knows about counter-steering when coming out of the banked turn, or the rider ends up in the infield (plowing into something hard at high speed is not good).
effect of mass on a wheel
Angular inertias related to wheel:
Thin circular hoop: I = M x R^2
Solid disk: I = 1/2 x M x R^2
Say you only increase the weight of the spokes of a wheel but not the rim, and treat the spokes of a wheel as a solid disk, using a front wheel in this example.
wheel radius = 8.5 inch (17 inch diameter wheel)
tire radius 120x70x17 = 120mm x .70 + 8.5 in = 3.3 in + 8.5 in = 11.8 in
wheel radius = .72 of total radius
Repeating the math as before:
Iw = angular inertial of wheel, treated as a solid disk:
Iw = 1/2 M (.72 R^2) = .26 M R^2
LF - FF = M LA
AA (angular acceleration) = T (torque) / Iw
LA = AA x R (left this out before)
Torque = FF x R
LA = (FF x R^2) / (.26 M x R^2)
LA = FF / (.26 x M)
FF = LA x .26 x M
LF - FF = LA x M
LF - (LA x .26 M) = LA x M
LF = 1.26 x (LA x M)
LA = LF / (1.26 M)
So any weight added to a solid disk would have 1.26 times the effect. 1 lb added to to the spokes would be the same as 1.26 lbs added to a non-moving part of the motorcycle.
For the case of adding weight to the rim of the wheel:
Iw = angular inertial of rim, treated as a thin hoop
Iw = M (.72 R^2) = .52 M R^2
LF - FF = M LA
Torque = FF x R
LA = (FF x R^2) / (.52 M x R^2)
LA = FF / (.52 x M)
FF = LA x .52 x M
LF - FF = LA x M
LF - (LA x .52 M) = LA x M
LF = 1.52 x (LA x M)
LA = LF / (1.52 M)
So any weight added to a hoop with .72R radius would have 1.52 times the effect. 1 lb added to the rim would be the same as 1.52 lbs added to a non-moving part of the motorcycle.
Basically the effect will be 1.00 + the coefficient for angular inertia. Actual radius, doesn't matter, just the relative radius of the spokes, or wheel to the outer radius of the tire (note, that the effective radius is a bit smaller, because the contact patch deforms, but I don't think you need numbers that exact).
In your case, weight added to the spokes has a 1.26 multiplier, and weight added to the rim has a 1.52 multiplier. For the back wheel, the effect is less, because the tire is larger, for a 190/50/17, its 3.75 inches. This reduces wheel radius factor to .69, and weight added to spokes would have a 1.24 multiplier and weight added to rim would have a 1.48 multiplier.
To caculate tire height from a tire size, width / profile / diameter
width is given in mm, profile is a percentage, and diameter doesn't matter
Tire height in inches = width x profile / 2540
Total diameter = diameter + 2 x tire height in inches.
reducing steering effort
This can always be done by reducing the trail. Swap the triple clamp for one that places the fork tubes a bit more forwards and you reduce the trail, but increase the likelyhood of speed wobble (use a steering damper). The first year model of Honda's 900 RR placed the forks too far forward, and the fork tubes were moved back 3/8 of an inch in later models.
A simpler solution is to not add weight to the wheels, as I don't seem the value of cosmetic additions to a racing motorcycle. Another soluton would be to work out so fatigue isn't a factor on the longer races.
Probably we didn't understand each-other. When you write "to push in the same direction" what do you mean? I'm no native-english speaker, I believed you intended that if you want to turn left you steer left, I know very well that, in speed, we have to countersteer.
True, but swapping the triple clamps on a bike is no trivial task (not because it's hard to do...it's quite easy actually) because then you're messing with the factory geometry of the bike, which can lead to very unpredictable results. And even with a steering damper (which any decent race bike has - I use Hyper Pro RSC Activ damper system on this bike in question), there are other stability issues besides just headshake (and the damper won't eliminate all headshake either). So unless the replacement triple clamps come from a company that has done extensive testing with the new geometry AND can provide specific measurements for the other geometry affecting options, messing with that can be dangerous.
When we try to adjust geometry on our bikes we usually do it be raising/lowering the forks within the triple clamps and adjusting the shock to change the rear ride height. The specific wheels (17" vs. 16.5") and types of tires (sidewall height, rim width, and tire width) are also contributing factors.
The problem isn't the addition of weight to wheels, the problem is where to make improvements on a bike given a limited budget. Powdercoating wheels is one example, but a better example would be: I have a limited budget of say $2000 for improvements to my race bike. Would I be better off spending all of it on Marchesini alloy wheels which reduce weight from stock by X%, or would I be better off spending it on a combination of other things, such as Al subframe, Ti bolt kit, etc.
So then my question is, what is the easiest way for me to tell how much more a weight reduction/increase on a rotating mass affects the effort of riding the bike at speed versus the same reduction/increase in static sprung or unsprung mass?
Thanks.
My apologies for being unclear. Here's what I mean:
At speed, let's say coming off a straightaway for a left hand turn, I would first slow down using a combination of the brakes, engine braking (also to get the engine into the right transmission gear to use through the turn, when I get back on the throttle), wind resistance (sitting up and putting my legs out to "catch the wind"). Then, as I approach the turn, but before I enter it, I would "hang" off the left side of the bike. What that means is that with my hands on the handle bars I raise myself up off the seat of the bike by using my legs and the balls of my feet on the footpegs, and then move my buttocks off of the seat in the direction of the intended turn. At this point approximately half of my buttocks are on the seat, and half are hanging off in the direction of the intended turn. My right thigh is up against the right side of the fuel tank, and my left leg is pivoted away from my body with the knee pointed outwards and down. My right arm is extended almost straight across the top/right side of the tank, while my left is bent at the elbow and out a bit.
So what I was saying is that I think you meant that in order to manage the direction of the bike while I am momentarily in this position but before I want the bike to turn aggressively, I exert varying amounts of pressure on the "inside" handlebar (the handlebar on the side of the bike the direction of the turn) and "outside" handlebar (the handlebar on the side of the bike opposite of the turn). I modulate that pressure depending on how much I want the bike to in the direction to which I'm hanging off.
Is that pretty much what you had meant? Again, my apologies for any confusion that I may have caused.
Changing the sprung weight will have virtually no effect on the effort it takes to counter steer a motorcycle, other than raising the center of mass (makes it easier), or lowering the center of mass (makes it harder). The ideal center of mass should be placed to allow a motorcyle to change lean angle (roll axis changes) the quickest, but I'm not sure where this would be.
However, it would seem that body shifting would consume much more energy than any countersteering effort, so I'm not so sure why you are focused on the counter steering effort.
Regarding body shifting, I've seen some extremes where the riders outside thigh is the only thing touching the seat, and the rider's outside foot is just dangling, not even on the peg. This was in an older video (back in the Freddie Spencer / Kevin Schwanz era), so I'm not sure that riders still do this.
Lighter wheels and tires always help, but your probably stuck with the tires, and kinetic energy and gyroscopic effects don't seem like they would be as important as the sprung to unsprung ratio benefit of lighter wheels and/or brakes. However, if you're not racing on rough tracks, then the sprung to unsprung ratio could be another case of diminishing returns.
I would recommend asking questions like this at a motorcycle racing oriented forum.
The people here at this forum can answer techincal stuff, but what you need is good advice from fellow motorcycle racers, or better yet, the guys who design racing motorcycles.
OK, I haven't articulated well the help I'm seeking - my apologies - so let me try again:
Forget about counter-steering. That whole diversion started because someone tried to point out (incorrectly) that the rider pushes on the opposite handlebar, so that whole digression was just to answer that question, as an aside, and several of us posted in response. So let's agree to forget that for the moment.
So forget about what parts of the body the rider uses - let's just consider that whether the pressure exerted is on the bars, or from the body on the chassis of the motorcycle, or by concentrated thought control that consumes calories or whatever, that we're only concerned with the aggregate amount of physical effort (work, however it's measured) required to initiate a direction change of the motorcycle at speed.
That being the case, let's also assume that the higher the speed the more effort required since there is greater rotational inertia to overcome.
So, can we all agree on those things? If so, then the question is:
Non-rotating mass changes will affect performance, but not necessarily steer-in or transition. Rotating mass changes will affect performance similarly to un/sprung weight static mass changes in some respects (e.g. acceleration, braking, etc), but will also affect handling performance in an additional way which is that it will alter rotational inertia, which will alter the amount of aggregate phyiscal effort required on the part of the rider to affect a direction change. If we can all agree on that, then what I want to know is:
How can I easily calculate how much a change in mass to a part that rotates in the direction of travel (e.g., the wheels, the crankshaft, the flywheel, the stator, etc.) will correlate to the amount of aggregate physical effort required by the rider to affect a direction change? It doesn't have to be exact, i.e., it just needs to give me a sense of the amount of difference a change in that item's static mass will make when, at speed, I attempt to deviate the bike from its current direction of motion.
I ask because if I can understand that, for example, a $2000 investment in wheel weight reduction of 10% will result in a .5% reduction in direction change effort for the rider at a a certain speed (for which I can choose a typical track speed, or at all speeds - I don't know, but I don't think that the relationship is linear or directly proportional as speed changes, so I think that I would have to do the calc for a given speed; but that's OK because I could do it for my realistic range of speeds on the track), then I might choose to spend that $2000 on other changes to the bike; however, if that change amounts to a 5% reduction in effort every time the rider (me) wants to change the bike's direction, then I'm more likely to invest that money in the wheels since I get both weight savings (albeit unsprung) and steer-in/transition benefits.
So those last two paragraphs are all I really want to know. The problem with asking on motorcycle forums is that people don't really understand the physics of these issues and therefore answer anecdotally, or based on rumours/marketing to which they've been exposed. Product sites won't share their R&D - again, they'll only share their marketing, such as the Marvic example I provided previously. And in the rare case where I do find something, it's in a form that I need help understanding, such as:
http://home.comcast.net/~rufusxs/Rotational.xls
So I was hoping that you Phys-Wiz's could help a poor grease monkey like me figure out a simple way to do this analysis every time I want to make an investment in my race bikes.
Believe me, if I could find the Repsol Honda MotoGP team's head of R&D's email address, I would ask him :)
Thanks.
Changing the mass of a motorcycle will change the roll inertia of the motorcyle, unless the mass change is done very close to the center of rotation of the motorcyle. Changing mass in the rotating parts will add to the overall mass plus add to gyroscopic resistance to leaning, which is speed sensitive, changing linearly with speed (I couldn't find a website that makes this clear).
Even at zero speed, weight in the wheels is the same as adding weight anywhere, roll axis angular inertia of for each bit of mass of a motorcycle is m r^2, where m is the mass, and r is the distance from the center of rotation of the motorcycle.
I found that bad info at hard racing .com, "1 ounce = 25 lbs of rotating mass on 17 inch rims at 100mph". 1 ounce added to the rim is equal to about 1.5 ounces added to the frame in terms of the effect on acceleration (from the equations I posted earlier).
The biggest gain from a lighter wheel is sprung to unsprung ratio. The next biggest gain is the effect on acceleration, where rim weight has about 1.5 times the effect of frame weight, and spoke weight has about 1.25 times the effect of frame weight. The lowest gain is reduction in steering effort.
A typical wheel has 70% of the diameter of a tire, and the tire, at around 13 lbs (for the front tire) probably weighs more than an aluminium wheel, at around 10 lbs or less, so the wheel only contributes about 40% of the counter-steering resistance. Switching to a 6 lb wheel only reduces the counter-steering effort by about 17%, not a big difference.
THAT"S WHAT I'M TALKING ABOUT! THANK YOU!
Ok, now we're into the type of info that's helpful to me (curiously I missed it on hardracing.com, I must have just overlooked it).
So a follow-up question: Ceramic Bearings. The stock wheel bearings are some kind of steel alloy (probably high-grade stainless). Ceramic Bearings are a popular upgrade, albeit not cheap. Bargain Brand ceramic wheel bearings will run about $400. Now, they're located very close to the axis of the wheel's rotation. Now the primary reasons for using silicone nitride bearings is NOT for reduced rotational inertia, but rather for bearing performance issues such as reduced friction, reduced thermal expansion, better lubricity, reduced rolling resistance, corrosion resistance, durability, less plastic deformation, etc. But I'm wondering how much effect, if any noticeable, they would would have on required steering effort.
The primary reason for weight reduction in crankshafts/flywheels/stators is to reduce rotational inertia, but rather than for the purpose of reduced steering effort, the purpose is to improve engine performance through increased maximum RPM's. So I'm wondering how much that (which is located much closer to the bike's center of rotation) would effect required steering effort?
BTW, thank you very much for your last response - that's extremely helpful to me now in making trade-off decisions when upgrading on a limited budget.
My guess would be that ceramic bearings main benefit would be less play, for better stability, making a bike less prone to getting wobbles. Is there any real world data on rolling resistance in regular bearings versus the ceramic bearings? It woudn't have any detectable effect on steering effort. Aerodynamic drag is more significant than rolling resistance at higher speeds.
The primary reason for weight reduction in crankshafts/flywheels/stators is to reduce rotational inertia, the purpose is to improve engine performance through increased maximum RPM's.
The usual purpose is to allow faster changes in rpm. This allows faster shift times, normally an issue for racing cars, not racing motorcycles. There is some increase in acceleration in the lower gears, but once in 3rd gear or higher, I doubt there's much effect. Regarding lean resistance, it doesn't matter where the crankshaft is located, since it's a gyroscopic resistance. I've seen this mentioned at some web site, but I'm not sure how much of an issue it is. You could test this yourself by comparing lean response at the same speed while in 1st or 2nd gear versus while in 3rd or 4th gear (remember, at the same speed, so the only variable is engine rpms).
Higer engine rpms don't mean higher power unless you have the proper cam and port changes made to support the higher rpms.
Yes, there is real world data, I just don't have it off hand, but I don't think that rolling resistance (as a function of the non-ceramic bearings' material) is one of the main advantages until heat and other factors come into play, and even then, it's probably minimal as compared to aerodynamics, as you point it. However, the benefits come more in the way of durability, reduce weight, less external lubricant required, etc. Everyone in racing generally agrees that ceramic bearings are better than conventional high-grade SS bearings - I was just wondering about the effect on rotational intertia from the steering effort perspective, if any, and as I suspected, it's null.
Yes, quite right, I should have been more specific: things like lighter crankshafts, camshafts, pistons, rods, etc, make for quicker revving engines in addition to higher revving engines. Generally speaking though if the fuel-air system is capable of scaling with the increased RPM's, a system that revs higher will produce more power since necessarily the fuel-air system would be required to be able to supply the system at that level of revs. I think what you're getting at is that if not balanced with fuel-air and timing, the torque (work) will fall off so much at those high rev levels that the higher revs aren't worth it, since HP is a function of work * repitition, and if the amount of work falls off drastically enough then doing it more often isn't worthwhile. However, in practice, the torque doesn't fall off so much that the higher RPM's aren't worth it, thus the quest in MotoGP and F1 for every higher revs, the limits on revs from league safety officials, etc.
But all of that is incidental the 2nd part of my previous question (which you partially answered, in that the crank location doesn't matter, thank you), which is that since the crank is heavy and by far the amongst the fastest moving items, does shaving or otherwise weight-modifying the crank significantly affect lean-resistance? I understand the test you're suggesting, which is clever, but what is the math to determine the effect of say a 1oz weight saving from the crank at a given RPM on lean resistance? Can we derive that from the previous formulas listed, providing that I can produce the crank's dimensions and weight?
Related to Inertia Moment for Racing Motorcycle Wheels
What is the Inertia Moment for Racing Motorcycle Wheels?
The Inertia Moment for Racing Motorcycle Wheels is a measurement of the resistance of a wheel to change its rotational speed. It is a crucial factor in determining the handling and performance of a motorcycle on the track.
How is the Inertia Moment calculated for Racing Motorcycle Wheels?
The Inertia Moment is calculated by multiplying the mass of the wheel by the square of its radius. This measurement is typically expressed in units of kg*m^2.
Why is the Inertia Moment important for Racing Motorcycle Wheels?
The Inertia Moment is important because it affects how quickly a motorcycle can accelerate and decelerate, as well as how easily it can change direction. A lower Inertia Moment means the wheel will respond more quickly to changes in speed and direction, leading to better handling and performance on the track.
How does the Inertia Moment differ for front and rear Racing Motorcycle Wheels?
The Inertia Moment for front and rear wheels can differ due to differences in mass and radius. Generally, the front wheel will have a lower Inertia Moment than the rear wheel, as it is responsible for steering and requires quicker response times.
Can the Inertia Moment be adjusted for Racing Motorcycle Wheels?
Yes, the Inertia Moment can be adjusted by changing the mass and/or radius of the wheel. Adding weight to the outer edge of the wheel or increasing the wheel size can increase the Inertia Moment, while reducing mass or wheel size can decrease it. Racing teams often make these adjustments to optimize the handling and performance of their motorcycles on different tracks and in different conditions.
  • Mechanics
  • Classical Physics
12K
  • Mechanical Engineering
