Does every observable commute with the hamiltonian?
In summary, the conversation discusses the commutativity of observables with the Hamiltonian in quantum mechanics. It is mentioned that usually operators q and p do not commute with H, and only conserved quantities or observables that are Casimirs of a group G will commute with H. It is also noted that there is no observable that will necessarily commute with all other observables or with the Hamiltonian in general. The conversation also briefly mentions the application of group theory in physics and references some books on the topic.
CPL.Luke
441
I would guess that they would as every observable is a function of the q's and p's and as those commute with the hamiltonian I couldn't imagine an observable that wouldn't commute, however are there any other cases where an observable won't commute with the hamiltonian?
Usually operators q_i and p_i don't commute with the H.
q and p don't commute with each other, so if the hamiltonian is composed of both q's and p's then neither q or p will commute with H.
I think only conserved quantity/observable commute with hamiltonian.
If you write down an Hamiltonian that as a q dependence, i.e. a particle in a central potential, let's say, you can already see that it is never going to commute with an operator such as p. As has been mentioned already, H can consist of both p and q. Unless you have an operator that does nothing, then an operator most usually do not commute with the Hamiltonian. Only in special cases, such a a free particle, would H commute with p.
Zz.
hmm thtat poses a problem as it would necessarily imply that there existed an uncertainty relation between H and q,p which I have not heard of, and it would mean that you could not have simultaneous eigenvalues of the energy and momentum or position.
If you look at the one-dimensional infinite square well, to take a simple example, it's clear that the energy eigenstates are not states of definite position or definite momentum! (the particle in an energy eigenstate is not located at a specific position nor does it have a specific momentum). In other words, the energy eigenstates are not Dirac delta functions in real space nor in momentum space.
If an observable does not commute with H it means that if you measure that observable at one time and then wait a while and measure it again, you are not guaranteed to obtain again the same value. The time evolution of the system (governed by H) will mix in states of different eigenvalues for that observable.
By contrast, L_z commutes with the Hamiltonian of a spherically symmetric potential. So if you measure the L_z of a a hydrogen atom, say, you are assured that it will stay it the eigenstate corresponding to the eigenvalue you obtained.
yeah I just got my pencil and paper out and computed the commutator, your right, the commutator of H,P is i (partial v, x) (in the position representation)
so if the partial of v with respect to x is zero then you can have a simultaneous eignevalue of p and H but this wouldn't hold generally.
I wonder is there any observable then that could be constructed such that it would commute with all others?
Usually in physics the interesting observables that commute with H are the casimirs of some group G (Galileo/Poincarè, etc).
If some observable commute with H, u get that it is a constant of motion.
Certainly there are many obs. that are not so, i.e. q_i and p_i of every singular particule if we are dealing with many body problems.
Lz is not always a constant of motion, it depends on the potential.
If we explicity broke translational invariance also Ptot is not anymore a const!
regards
marco
interesting, do you know of any books that cover this in more detail? I'm taking a course in group theory and quantum mechnics now, however the only thing we really covered for finite groups were degeneracies in various symmetry enviroments.
I think that a "bible" for application of group theory in physics is Cornwell... and also tha Hamermesh is a good one...
i did like to have a look on the oldest ones also, weyl and friends :)
regards
marco
Wigner showed in 1939 that in relativistic physics, physical states were classified according to their mass and spin (or helicity for massless particles). It was an amazing application of group theory!
Buit this is getting a bit far from your initial question on nonrelativistic qm. There is no observable that will necessarily commute with all th eother observables or with the Hamiltonian, in general.
I agree with u :
On Unitary Representations of the Inhomogeneous Lorentz Group
E. Wigner
The Annals of Mathematics, 2nd Ser., Vol. 40, No. 1. (Jan., 1939), pp. 149-204.
regards
marco
Related to Does every observable commute with the hamiltonian?
1. What is meant by "commuting with the Hamiltonian"?
Commuting with the Hamiltonian refers to the property of an observable in quantum mechanics where its value remains constant over time. In other words, the observable and the Hamiltonian operator can be measured simultaneously without affecting each other.
2. Why is it important for observables to commute with the Hamiltonian?
The commutation of observables with the Hamiltonian is important because it allows for the simultaneous measurement of these properties without altering their values. This property is crucial in quantum mechanics as it helps us to accurately predict the behavior of a system over time.
3. Is it always true that every observable commutes with the Hamiltonian?
No, it is not always true that every observable commutes with the Hamiltonian. This property depends on the specific system and the observables being measured. In some cases, observables may not commute with the Hamiltonian, leading to uncertainty in their values.
4. What are the consequences if an observable does not commute with the Hamiltonian?
If an observable does not commute with the Hamiltonian, it means that the values of these properties cannot be measured simultaneously without affecting each other. This leads to uncertainty in the values of the observables and can make it difficult to accurately predict the behavior of a system.
5. How do we determine if an observable commutes with the Hamiltonian?
We can determine if an observable commutes with the Hamiltonian by using the commutator, which is a mathematical operation that measures how much two operators, such as the observable and the Hamiltonian, do not commute. If the commutator is equal to zero, then the observable and the Hamiltonian commute.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
