Can somene tell if I have started this right please.
  • Thread starter ptex
In summary, you are trying to find the explicit formuala for a recursive sequence, but are having trouble understanding what is confusing you. You may want to study algebra more to improve your understanding of these equations.
ptex
42
I need to find the explicit formuala for this recursive sequence.
Code:
a[sub]1[/sub] = 3
a[sub]2[/sub] = 7
a[sub]n[/sub] = 7a[sub]n-1[/sub] - 10a[sub]n-2[/sub]
a[sub]n[/sub] - 7a[sub]n-1[/sub] + 10a[sub]n-2[/sub] = 0
t[sup]n[/sup] - 7k[sup]n-1[/sup] + 10t[sup]n-2[/sup] = 0
t[sup]2[/sup] - 7t + 10 = 0
(t - 2)(t - 5)
(t = 2)(t = 5) :confused:
if that is right I can move on.
Move on. :smile:
Thank you I will go ahead and stop if I have more questions I will stop. Ok?
Is this the formula?
Code:
a[sub]n[/sub] = 8/5(2)[sup]n[/sup] - 1/15(5)[sup]n[/sup]
No. Probably just a mistake someplace in your algebra.
You know, you can check your solution by using the recurrence to determine the value of a3 and comparing that to the value generated by your formula.
To find B;
Code:
2(4A + 25B = 7) = 8A + 50B = 14
4(2A + 5B =  3) = 8A + 20B = 12
30B = 2
B = 1/15
To find A;
Code:
2A + 5B = 3
2A + 1/5B = 3
10A + 1 = 15
10A = 16
A = 16/10
A = 8/5
A = 8/5 B= 1/15
> 2A + 5B = 3
> 2A + 1/5B = 3 ...what is this? How did 5B become 1/5 B? You already know B. Plug it into the first eqn & solve for A.
B = 15 and A = 16?
No.
This was correct:
30B = 2
B = 1/15
Now use this equation to find A :
2A + 5B = 3
I think
Code:
a[sub]3[/sub] = 19
You think?
You're supposed to know. :wink:
Is A=1/2 if so
Code:
the formula would be a[sub]n[/sub] = 1/2(2[sup]n[/sup]) - 1/15(5[sup]n[/sup])
I don't understand what is confusing you.
You have already solved the simultaneous equations:
30B = 2
B = 1/15
so you know that B=1/15.
So now take one of your original equations (either one) and solve for A. Show me what you're doing, step by step.
woops
Code:
2A + 5B = 3
2A + 5(1/15) = 3
2A + 1 /3 = 3
2A = 3 1/3
A = 3 1/3 / 2
A = 5/3
[tex]B =\frac{1}{15}[/tex]
2a + 5b = 3
2a + 5(1/15) = 3
2a + 1 /3 = 3
2a = 3 1/3
A = 3 1/3 / 2
A = 5/3
2a + 5b = 3
2a + 5(1/15) = 3
2a + 1 /3 = 3
2a = 3 1/3 <<<<check this again
A = 3 1/3 / 2
A = 5/3
2a + 5b = 3
2a + 5(1/15) = 3
2a + 1 /3 = 3
2a = 10/3
A = 10/3 / 2
A = 5/3
2a + 5b = 3
2a + 5(1/15) = 3
2a + 1 /3 = 3
...- 1/3 = -1/3
2a = 8/3
A = 4/3
Thank you
the 1/3 turns negitive? then ?
The 1/3 doesn't turn negative. You subtract 1/3 from both sides of the equation. Then you divide both sides of the equation by 2. Then the equation is solved. A = 4/3.
So, you've never studied algebra and yet you are interested in solving linear homogeneous recurrence relations with constant coefficients. Very interesting.
The last time I took algebra was 10 years ago. This class Discrete Mathematics is a requirerment for my degree (all I want to do is write code). Yeah I know its a long time to get a degree but I have a bit of a skiing career so I can't go to school during the winter. Anyway thank you very much now I must move on to the second problem and try to recall algebra which by the seems more defficult then some of this stuff.
FAQ: Can somene tell if I have started this right please.
Can someone really tell if I have started this right?
It depends on what you are referring to as "this". If you are asking if someone can tell if you have started a project or task correctly, then it is possible for someone to assess and offer feedback or advice. However, if you are asking if someone can tell if you have started something in your personal life "right", then that is subjective and only you can determine what is right for yourself.
Is there a specific method or formula to determine if I have started something correctly?
It depends on the context. In scientific research, there are often specific methods and protocols to follow in order to ensure that the results are valid and reliable. However, in other areas of life, there may not be a set formula and it may be more subjective.
Can I tell if I have started something correctly without outside validation?
It depends on the situation. In some cases, it may be possible to assess your progress and determine if you are on the right track without external validation. However, in other cases, it may be helpful to seek feedback or advice from others in order to ensure that you are on the right path.
How long should I wait before determining if I have started something correctly?
This is highly dependent on the specific situation. In some cases, you may be able to tell relatively quickly if you have started something correctly, while in other cases, it may take more time and data to determine if you are on the right track.
What should I do if I am uncertain if I have started something correctly?
If you are unsure if you have started something correctly, it may be helpful to seek out the advice or guidance of someone who is more knowledgeable or experienced in the subject matter. They may be able to offer insights or suggestions to help you determine if you are on the right track.
