pellman
- 684
- 5
How do we measure a quantum particle's momentum?
pellman said:How do we measure a quantum particle's momentum?
Measurement of momentum is always achieved by measurement of position, so I assume that observation of momentum is not how it IS but how it WAS . After measurement of momentum value p, the state cannot keep on |p>. It is a kind of destructive observation.pellman said:So do all the methods amount to making a position measurement from which we infer the momentum? How does that square with the uncertainty principle?
sweet springs said:Hi.
Regards.
Particle momentum is a measure of the amount of motion a particle has. It is defined as the product of the particle's mass and velocity.
The SI unit for measuring particle momentum is kilogram meters per second (kg*m/s).
In experiments, particle momentum is measured using detectors such as calorimeters or tracking devices. These detectors can measure the energy and direction of the particle, which can then be used to calculate its momentum.
The accuracy of particle momentum measurements can be affected by factors such as energy loss due to collisions with other particles, uncertainty in the detector's measurements, and relativistic effects at high particle speeds.
The conservation of momentum is a fundamental principle in physics that states that the total momentum of a system remains constant unless external forces act on it. This principle is used in experiments to measure particle momentum by analyzing the before and after effects of collisions between particles.
