What Defines a Null Coordinate in Spacetime Metrics?
  • Thread starter DrGreg
  • Tags
    Coordinate
In summary: Euclidean space... which is why it's called the Laplacian).In summary, coordinates that are described as "null coordinates" are those for which the 1-form has zero norm, meaning that the hypersurface of constant coordinate has a null tangent vector at every point. This can be determined by solving for the vector components and finding the corresponding covariant vector. The inverse metric can also be used to classify coordinates as timelike, spacelike, or null. The d'Alembertian operator is used in arbitrary coordinate systems in GR to account for the strong equivalence principle. The Laplacian and d'Alembertian are two different operators with different meanings and should not be confused.
DrGreg
2,084
Coordinates are sometimes described as "null coordinates". An example in SR is the coordinate [itex]u = x - ct[/itex]. Another example is one of the coordinates in the Eddington-Finkelstein metric. But I've never seen an explicit rigorous definition of a null coordinate. The defining property seems to be that any hypersurface of constant coordinate should possesses a null tangent vector at every event within it.
My first thought was to say that [itex]x^0[/itex] is a null coordinate if the tangent vector [itex](dx^0, 0, 0, 0)[/itex] is null. But it didn't take long, considering the above examples, to realize this was wrong. Should I, instead, be considering the cotangent covector [itex](dx_0, 0, 0, 0)[/itex]? If I haven't made a mistake in my maths, this seems to work for the examples above, but I can't convince myself it will always work.
And then what about "timelike" coords and "spacelike" coords? Can they be defined in a similar way?
If I have an explicit equation for a metric, e.g.
[tex]ds^2 = -\left(1-\frac{2M}{r} \right) du^2 - 2 du dr + r^2 \left(d\theta^2 + \sin^2 \theta\, d\phi^2 \right) [/tex]​
is there a quick way of inspecting this to classify each of the four coordinates as timelike, spacelike, or null?
Likes edgarpgovea
You are correct. A null coordinate [tex]f[/tex] is one for which the 1-form [tex]df[/tex] has zero norm. In other words, the hypersurface of constant [tex]f[/tex] posesses a null "normal 1-form". The 1-form is what you might call a covariant vector. Thus [tex]df[/tex] has components [tex] (\tfrac{\partial f}{\partial x^0}, \tfrac{\partial f}{\partial x^1}, \tfrac{\partial f}{\partial x^1}, ...)[/tex]
To quickly classify coordinates, one usually does it by inspection. Otherwise, of course, you could first diagonalize the metric and work from there.
The rough 'n' ready way of finding null/spacelike/timelike vectors is simply to look at tangent vectors to curves that are perpendicular to the hypersurface. Hence, you want to solve, say,
[tex]0 = ds^2 = -\left(1-\frac{2M}{r} \right) \frac{du}{d\lambda}^2 - 2 \frac{du}{d\lambda} \frac{dr}{d\lambda}[/tex],
hence
[tex]-\left(1-\frac{2M}{r} \right) \frac{du}{d\lambda} - 2 \frac{dr}{d\lambda} = 0[/tex]
fits the bill.
So take the vector to be
[tex]\vec{v} = (-2, \left(1-\frac{2M}{r} \right) , 0, 0)[/tex]
and find the corresponding covariant vector [tex]v_\alpha[/tex].
I suspect that it'll have components [tex]v_\alpha = (?, 0, 0, 0)[/tex] since [tex]u[/tex] looks to me like a null coordinate.
** The only caveat of course is that null vectors are orthogonal to other null vectors. But looking back at the problem, it is obvious that the 1-form [tex]du[/tex] is null, while the 1-form [tex]dr[/tex] is spacelike. I tried to motivate my explanation without actually making use of the geometrical interpretation of a 1-form, which is difficult. I therefore invite you to read up on vectors and 1-forms in differential geometry.
Likes edgarpgovea
Thanks very much. Your reply was very helpful and gave me the right terminology to search further. I dug out my quarter-read copy of Roger Penrose's Road to Reality and was able to make some sense out of 1-forms from that. Though I've always known the coordinate definition of a covector as [itex]v_a = g_{ab} v^b[/itex], I've never had much geometrical insight into what this meant, and now I understand better.
In the case of an "almost diagonal" metric like the one I quoted, it's not very difficult to calculate the "inverse metric" [itex]g^{ab}[/itex] and then you can just read off the diagonal entries to determine timelike/null/spacelike coordinates.
I'm assuming that the definition of (locally) timelike/null/spacelike works for any scalar field [itex]f[/itex], not just a "coordinate".
After reading all this, it occurred to me that the "dual" of the usual metric "definition" of [itex]ds^2 = g_{ab} dx^a dx^b[/itex] must be the operator
[tex]g^{ab}\frac{\partial}{\partial x^a} \frac{\partial}{\partial x^b}[/tex]​
which, if we had a Euclidean metric, I would call the Laplacian [itex]\nabla^2[/itex] or [itex]\triangle[/itex]. Wikipedia calls this the d'Alembertian in the case of (flat) Minkowski space but makes no mention of any other metric. Is that terminology used in GR?
Likes edgarpgovea
The Laplacian is different from the d'Alembertian since the later contains a temporal term. For details please see - http://en.wikibooks.org/wiki/Electrodynamics/Four-Vectors#The_d.27Alembertian
The operator you posted is the d'Alembertian in an arbitrary coordinate system and thus holds in GR. The metric in that expression, g, represents an arbitrary metric. This is easily seen from the strong equivalence principle which requires replacing the Minkowski metric with an arbitrary metric in arbitrary (but physically meaningful) coordinate system.
Pete
Likes edgarpgovea
Hold your horses!
The inverse metric is the (2,0) tensor
[tex]
g^{ab} \frac{\partial}{\partial x^a} \otimes \frac{\partial}{\partial x^b}
[/tex],
meaning that the action on two 1-forms [tex]\tilde{\mu}[/tex] and [tex]\tilde{\nu}[/tex] is
[tex]
g^{ab} \frac{\partial}{\partial x^a} \otimes \frac{\partial}{\partial x^b} (\tilde{\mu},\tilde{\nu}) = g^{ab} \frac{\partial}{\partial x^a} \otimes \frac{\partial}{\partial x^b} (\tilde{\mu},\tilde{\nu}) = g^{ab} \left\langle \frac{\partial}{\partial x^a}, \tilde{\mu} \right\rangle \left\langle \frac{\partial}{\partial x^b}, \tilde{\nu} \right\rangle = g^{ab} \mu_a \nu_b
[/tex].
Unfortunately this is one place where the [tex]\otimes[/tex] is kind of important, because otherwise the thing you wrote down *looks* like a Laplacian (d'Alembertian, doesn't really matter... call it the Laplace-Beltrami if you will).
The Laplacian is an altogether different beast, namely [tex]\nabla_a \nabla^a f = \frac{1}{\sqrt{|g|}} \partial_a \left ( \sqrt{|g|}\, \partial^a f\right)[/tex].
Thus
[tex]g^{ab} \frac{\partial^2 f}{\partial x^a \partial x^b}[/tex] is not a coordinate invariant expression and means something altogether different (and happens to be meaningless)
Cheers
Likes edgarpgovea
lbrits said:
Hold your horses!
[tex]
[/tex],
[tex]
[/tex].
Thus
Cheers
Fair enough. I don't entirely follow every detail of your reply, but don't worry, I don't want you to elaborate. I'm aware that there are different ways of differentiating in GR and I'll get to grips with the technicalities of that later.
The point of my supplementary question was this: usually when the components of a specific metric are to be specified, it's conventional to write the equation [itex]ds^2 = g_{ab} dx^a dx^b[/itex] instead of the 4 × 4 matrix [itex]g_{ab}[/itex]. Is there a convenient equation you could use instead of the 4 × 4 matrix [itex]g^{ab}[/itex]? And if there is, does anyone actually use it in practice?
Likes edgarpgovea
I'll try to elaborate without elaborating =) The answer is yes, and it is written
[tex] g^{ab} \frac{\partial}{\partial x^a} \otimes \frac{\partial}{\partial x^b} [/tex]
The point is, though, that this isn't actually a differential operator. It is a tensor formed out of the tensor product of basis vectors. In differential geometry, upon which GR is based, there is a natural one-to-one correspondence between (contravariant) vectors and directional derivatives. Similarly, there is a natural one-to-one correspondence between (covariant) vectors ([tex]dx[/tex] and the like) and gradients.
If you'd like, I could write the inverse metric as [itex] g^{ab} \vec{e}_a \otimes \vec{e}_b [/itex]. In matrix notation, you might want to write this as
[tex]g^{-1} = \sum_{ab}(g^{-1})^{ab} \vec{e}_a {\vec{e}_b}^{\,T}[/tex],
where you might want to write [tex]\vec{e}_1 = (1,0,0,0)[/tex], etc.
I don't know if any of this has helped you. Does anyone actually do this in practice? Sometimes. Most of the time you work with [tex]g_{ab}[/tex] and just compute [tex]g^{ab}[/tex] as needed. I think the best path is to understand this admittedly cumbersome notation and the notion of vectors and 1-forms first, and then when you're more comfortable with what tensors do, to just use index notation. The metric is sort of the exception because you usually want to communicate it's components, and writing it in the form [tex]ds^2 = ...[/tex] is efficient.
Likes edgarpgovea
My question about null-time-space coordinates:
are there any restriction about the distribution of coordinates?
I mean it is possible to use four null-coordinates to describe a spacetime
or two time- and two space-coordinates for example?
FAQ: What Defines a Null Coordinate in Spacetime Metrics?
What is a null coordinate?
A null coordinate is a coordinate that has a value of zero. In mathematics and physics, it is commonly used to represent a point or location where there is no change or movement in a particular direction.
How is a null coordinate different from a zero coordinate?
A null coordinate and a zero coordinate are often used interchangeably, but they have subtle differences. A null coordinate represents a point of no change in a particular direction, while a zero coordinate simply has a value of zero without any specific meaning attached to it.
What is the significance of a null coordinate in mathematical equations?
A null coordinate is often used as a reference point or origin in mathematical equations. It can also help simplify calculations and represent a starting point for a particular problem.
Can a null coordinate have a negative value?
Yes, a null coordinate can have a negative value, depending on the coordinate system being used. In some cases, a negative null coordinate may represent a point moving in the opposite direction of a positive null coordinate.
How is a null coordinate used in physics?
In physics, a null coordinate is often used in concepts such as the theory of relativity, where it represents a point in space-time where there is no change or movement. It is also used in vector calculus to define a starting point for calculations.
