Showing Surreal Numbers as a Proper Class
In summary: It doesn't violate trichotomy, but it does show that there is not a complete ordered field containing the surreal numbers.
Dragonfall
1,030
How do you show that the surreal numbers form a proper class?
I suspect it goes along the lines of: show that there is proper class of ordinals, and show that for each ordinal one can construct inequivalent surreal numbers, or something.
Since there are 'more' ordinals than cardinals, and there is a proper class of cardinals (if there is a set of cardinals, C, what is the cardinality of the power set of C?), this becomes easy - if I've understood the one thing I read about surreal numbers and some link to ordinals, and that;s a big if.
I don't understand why the surreal numbers don't form a complete ordered field, in which case the real numbers wouldn't be the only complete ordered field. I guess technically if the surreals form a proper class then it wouldn't count, but that's... wrong, somehow.
Never mind, I was reading the Wiki article, and I apparently misunderstood some things.
I don't know what you've read so I can't really comment, but completeness usually requires some notion of a metric - i.e. a mapping into R, the real numbers. So what is the norm of any non-real surreal?
If a metric needs to be real-valued, and if the surreals form a proper class (or indeed a set bigger than reals) then it can't be defined.
But I haven't read anything on the "norm" of surreal numbers; maybe it's defined differently.
It does.
they do - apparently.
Checking the definitions is always a good idea.
I guess that answers the question about complete ordered fields.
(Rehash of my earlier post... only this time, correct)
Ignoring that the surreals form a proper class rather than a set, you'd need to prove that you can't define a metric on them that turns them into a complete ordered field.
One way to see that the surreal numbers are not a complete ordered field is to use the axioms of a complete ordered field to show that they satisfy the archimedean property, which says that there are no infinitesimals other than 0 and no infinities. Since the surreal numbers have non-zero infinitesimals and infinities, they cannot be a complete ordered field.
The easiest way to show the surreals are a proper class is by contradiction. Assume they form a set, then construct a new surreal number not in that set.
(hint... can you find one bigger than everything in that set?)
If X is the set of all surreal numbers, then so is [tex]\{ X|\emptyset\}[/tex]. But this only leads to a contradiction assuming well-foundedness.
Or by trichotomy...
How does it violate trichotomy?
You've asserted:
{X | } is a surreal number
and it's a basic fact of surreal numbers that
{X | } is larger than every member of X
so...
Now that I think of it, I'm pretty sure it's also a theorem that every surreal number is a well-founded set.
Related to Showing Surreal Numbers as a Proper Class
1. What are surreal numbers?
Surreal numbers are a mathematical concept introduced by John Horton Conway in 1976. They can be thought of as a generalization of real numbers, including both finite and infinite numbers.
2. How are surreal numbers different from real numbers?
Surreal numbers differ from real numbers in that they include both finite and infinite numbers, allowing for numbers that are infinitely larger or smaller than any real number. They also have the property of being a proper class, meaning that they cannot be contained in a set.
3. What is a proper class?
A proper class is a collection of objects that is too large to be considered a set. In other words, it is a collection that cannot be contained in a set. In terms of surreal numbers, this means that they cannot be listed or counted in a traditional way, as they are infinite in number.
4. How are surreal numbers represented?
Surreal numbers are typically represented using a decimal-like notation, with the left and right halves of the number separated by a vertical bar. The left and right halves can contain any number of other surreal numbers, including infinite numbers.
5. What applications do surreal numbers have?
Surreal numbers have applications in fields such as game theory, combinatorics, and topology. They can also be used to solve problems in other areas of mathematics, such as calculus and algebra.
