Solved: Showing Dirac Lagrangian Commutes at Spacelike Separated Points
  • Thread starter Thread starter jdstokes
The discussion addresses the commutation of the charge current density operator for the Dirac Lagrangian at spacelike separated points, specifically showing that [s^\mu(x), s^\nu(y)] = 0 when (x-y)^2 < 0. The participants explore the implications of microcausality, noting that the anticommutation relation {ψ(x), ψ̄(y)} = 0 is crucial. A detailed evaluation of the commutator reveals discrepancies in the expansion of terms, leading to confusion about the nature of the current as matrices versus complex numbers. Ultimately, it is confirmed that the commutation relation [j^{\mu}, j^{\nu}] = 0 holds true. The resolution highlights the importance of correctly interpreting the mathematical structure involved.
jdstokes
[SOLVED] Mandl and Shaw 4.3
The question is to show that the charge current density operator s^\mu = - ec \bar{\psi}\gamma^\mu\psi for the Dirac Lagrangian commutes at spacelike separated points. Ie
[s^\mu(x),s^\nu(y)] = 0 for (x-y)^2 &lt; 0.
By microcauality we have \{ \psi(x), \bar{\psi}(y) \} = 0.
The commutator is
e^2c^2( \bar{\psi}(x)\gamma^\mu\psi (x) \bar{\psi}(y)\gamma^\nu\psi(y)-\bar{\psi}(y)\gamma^\nu\psi(y) \bar{\psi}(x)\gamma^\mu\psi (x) )
I tried to evaluate this in index notation. The first term is
\left(\bar{\psi}(x)\gamma^\mu\psi (x) \bar{\psi}(y)\gamma^\nu\psi(y)\right)_{\alpha\beta} = \left(\bar{\psi}(x)\gamma^\mu\psi (x) \right)_{\alpha\epsilon}\left( \bar{\psi}(y)\gamma^\nu\psi(y)\right)_{\epsilon\beta} = \bar{\psi}_\alpha (x) (\gamma^\mu)_{\epsilon\gamma} \psi_\gamma (x) \bar{\psi}_\epsilon (y)(\gamma^\nu)_{\beta\delta}\psi_\delta(y)
=\bar{\psi}_\alpha(x) \psi_\gamma (x) \bar{\psi}_\epsilon(y)\psi_\delta (y)(\gamma^\mu)_{\epsilon\gamma} (\gamma^\nu)_{\beta\delta}.
Minus the second term is
\left(\bar{\psi}(y)\gamma^\nu\psi (y) \bar{\psi}(x)\gamma^\mu\psi(x)\right)_{\alpha\beta}.
If I simply expand this as \left(\bar{\psi}(y)\gamma^\nu\psi (y)\right)_{\alpha\epsilon}\left( \bar{\psi}(x)\gamma^\mu\psi(x)\right)_{\epsilon\beta} I get a different answer to the first term. What I would like to do is to equate this to
\left(\bar{\psi}(y)\gamma^\nu\psi (y)\right)_{\epsilon\beta}\left( \bar{\psi}(x)\gamma^\mu\psi(x)\right)_{\alpha\epsilon} and then use the anti-commutation relations to show this is the same as the first term.
If A and B are Hermitian and so is AB then (AB)_{\alpha\beta} = (AB)^\ast_{\beta\alpha} = a_{\beta\epsilon}^\ast b_{\epsilon\alpha}^\ast = a_{\epsilon\beta}b_{\alpha\epsilon}. But in my case the product of the two matrices is not Hermitian so I can't do that.
Turned out to be something totally stupid. I was interpreting the current as quadruple of matrices when it is in fact a quadruple of complex numbers.
Ok,
[j^{\mu}, j^{\nu}] =0
where j^{\mu} =\overline{\psi}(x)\gamma^{\mu}\psi (x)
Is this true?
  • · Replies 25 ·
  • · Replies 0 ·
