Derivation of Yukawa potential: quandry
In summary, the derivation in Peskin and Schroeder (equation 4.126, p.122) involves deriving the position-space Yukawa potential by Fourier-transforming the Feynman amplitude for a process. The simplifications from the first to the second line of the equation are not clear, specifically the term \frac{e^{iqr}-e^{-iqr}}{iqr}. To help understand this term, one can use the relationship \bold{q}\cdot\bold{r} = qrcos(\theta ) and integrate over q, \theta, and \phi from 0 to infinity, 0 to pi, and 0 to 2pi respectively. Any further clarification on this term
A/4
56
Can someone provide some help with a derivation in Peskin and Schroeder (equation 4.126, p.122):
[tex]
V(\bold{x}) = \int \frac{d^3q}{(2\pi)^3} \frac{-g^2}{|\bold{q}|^2+m^2}e^{i\bold{q}\cdot\bold{r}}
[/tex]
[tex]
= \frac{-g^2}{4\pi^2}\int_0^\infty dq\; q^2\; \frac{e^{iqr}-e^{-iqr}}{iqr}} \frac{1}{q^2+m^2}
[/tex]
They derive the position-space Yukawa potential by Fourier-transforming the Feynman amplitude for the process. Perhaps I'm just being obtuse, but the simplifications from the first to the second line of the equation (once they've done the angular integration) don't seem clear to me.
In particular, what is the justification for this term: [tex]\frac{e^{iqr}-e^{-iqr}}{iqr}}[/tex]
Any help would be appreciated.
Use [tex] \bold{q}\cdot\bold{r} = qrcos(\theta ) [/tex]
[tex] d^3q = q^2sin(\theta ) d\phi dq [/tex]
[tex] q \text{ from } 0 \text{ to} +\infty [/tex]
[tex] \theta \text{ from } 0 \text{ to}\pi [/tex]
[tex] \phi \text{ from } 0 \text{ to}2\pi [/tex]
Thank you.
The term \frac{e^{iqr}-e^{-iqr}}{iqr} is known as the Fourier transform of a delta function. In order to understand this, we need to first look at the definition of a delta function. The delta function, denoted as \delta(x), is a mathematical function that has the property of being zero everywhere except at x=0, where it is infinite. Its integral over any interval containing x=0 is equal to 1. Mathematically, we can write this as:
\int_{-\infty}^{\infty} \delta(x) dx = 1
Now, let's consider the Fourier transform of this delta function. The Fourier transform of a function f(x) is given by:
\tilde{f}(k) = \int_{-\infty}^{\infty} f(x) e^{-ikx} dx
Using the properties of the delta function, we can write the Fourier transform of the delta function as:
\tilde{\delta}(k) = \int_{-\infty}^{\infty} \delta(x) e^{-ikx} dx = 1
This means that the Fourier transform of the delta function is a constant function with value 1. Now, coming back to our original equation, we can see that the term \frac{e^{iqr}-e^{-iqr}}{iqr} is essentially the Fourier transform of a delta function at x=q. This is why it appears in the derivation of the Yukawa potential.
I hope this helps clarify the derivation for you. If you have any further questions, please feel free to ask.
Related to Derivation of Yukawa potential: quandry
1. What is the Yukawa potential and why is it important?
The Yukawa potential is a mathematical model that describes the interaction between two particles due to the exchange of a virtual particle. It is important because it helps to explain the forces between subatomic particles and is used in various fields of theoretical physics, such as quantum mechanics and particle physics.
2. How is the Yukawa potential derived?
The Yukawa potential is derived using the principles of quantum field theory and the concept of virtual particles. It involves calculating the probability amplitude for a particle to travel from one point to another, taking into account the exchange of virtual particles between the two points.
3. What is the quandary in the derivation of the Yukawa potential?
The quandary in the derivation of the Yukawa potential lies in the fact that virtual particles have infinite energy and therefore cannot exist in reality. This leads to mathematical inconsistencies in the calculations, which need to be addressed in order to obtain a physically meaningful result.
4. How is the quandary resolved in the derivation of the Yukawa potential?
To resolve the quandary in the derivation of the Yukawa potential, a technique called renormalization is used. This involves adjusting the parameters in the equations to account for the infinite energy of virtual particles, resulting in finite and physically meaningful values for the potential.
5. What are some applications of the Yukawa potential?
The Yukawa potential has several applications in physics, including the explanation of the strong nuclear force between nucleons, the prediction of the existence of the Higgs boson, and the study of the behavior of particles in high-energy collisions. It is also used in cosmology to model the interactions between particles in the early universe.
  • Quantum Physics
  • Calculus
