Is it possible to make a gamma-ray laser?
  • Thread starter Green Xenon [Radium]
  • Tags
    Laser
In summary, a gamma-ray laser is theoretically possible, but currently not feasible with our current technology. The high energy and short wavelength of gamma rays make it difficult to control and focus them into a coherent beam for use in a laser. Scientists are still researching and experimenting with different methods to overcome these challenges and make a practical gamma-ray laser a reality. Additionally, the potential applications of a gamma-ray laser, such as in medical imaging and nuclear fusion, make it an area of ongoing interest and study.
Hi:
Is it possible to make a free-electron laser that emit coherent gamma
rays? If so, could this laser be used to ignite Hydrogen-Boron fusion?
Thanks,
Radium
Science news on Phys.org
Green Xenon [Radium] wrote:
> Hi:
Since by definition gamma rays are emitted by nuclei I'd say its
impossible. X-rays of the same wavelength however...
Dirk
http://www.transcendence.me.uk/ - Transcendence UK
Remote Viewing classes in London
On 10 Jun, 17:52, "Green Xenon [Radium]" <gluceg...@excite.com> wrote:
> Hi:
Yes it is. A nuclear bomb though is required to pump it. Any
wavelength can theoretically lase. There has in fact been a proposal
to use an X/Gamma ray laser in an ABM system. The theory is all known.
The idea is to point rods towards incoming missiles and then detonate
a nuclear bomb. The material will stay in place just long enough for
the laser pulse.
A free electron laser is I feel impossible as you would need the sort
of magnetic fields you get round black holes.
Whether the laser should be built or not is a political and moral
question. There are you know limits for moral scientific enquiry.- Ian Parker
ive got to admit though it would be cool to see
Technically 'seeing' it would be a bit tricky!
I suppose it would be cool to see it melt your head.
>> Hi:
Then could an X-ray laser be used to initiate HB fusion?
On Jun 10, 9:52=A0am, "Green Xenon [Radium]" <gluceg...@excite.com>
wrote:
> Hi:
> Thanks,
> Radium
A high energy FEL appears theoretically possible and allows a modest
energy. A several MeV energy level is allowed. What happens is a
bunch as the wiggled electron set can not be aligned as a whole
packet, disallowing ultra high energy levels.
A 5 MeV limit effectively exists. Distortion of the bunch causes the
magnetic field to also distort. A focusing is not present in FEL's
because of the difficulty in field gradient versus field x-axis
acceleration. x-axis as the wiggled axis must be a suitably high
displacement and the magnetic field density as a length causes the
field to wiggle as a whole set of accelerator magnets. Meaning the
whole length emitts as a laser, it is not magnet element by element
Bremsstralung.
So the axis free energy as a local effect becomes the stimulated atom
set, in effect, in analogy to a gas laser. FELs are true lasers, but
atomic excitation does not occur.
Axis acceleration versus length magnetic field gradient allows a state
as a wire coil excitation. Excited field coils form the laser in FELs,
not excited gas atoms. A property of the coil allows focusing to
overcome this limitation. An RF waveguided cavity inside the FEL can
allow ultrahigh energy levels. A small linac field will cause a
slight bunching preventing distortion of the wire coil's magnetic
field.
A literal vacuum cavity using suseptable metal becomes the interior of
a good simple wiggler magnet.
>> Hi:
> the laser pulse.
AIUI the US tried to build such a laser and failed.
Too little energy was converted to gamma rays.
Ditto induced gamma emmision from pumped isomers, although any major
success would probably be classified immediately because of its military
implications.
http://en.wikipedia.org/wiki/Induced_gamma_emission
Dirk
I don't think i would really 'see' it melting my head, do you ?
It appears mgb_phys is reacting to the comment about 'seeing' a gamma-ray laser, but I don't believe that is what one meant. I believe one meant that it would be interesting to see/observe the effects of an operating gamma laser, or rather, a concentration of gamma radiation.
Clearly X-ray and gamma rays are 'invisible', i.e. like UV they are outside of the visible spectrum. X-rays and gamma rays are highly penetrating, with the penetration increasing as a function of energy. They are also ionizing since they interact with atomic electrons (photoelectric effect and Compton scattering) and nuclei (electron-positron pair production).
Basically X-rays/gamma rays of wavelengths comparable to atomic lattices can be focused. With shorter wavelengths, they can't be focused but would more likely scatter, and the scattering increases with energy.
Free electron laser are somewhat limited in wavelength/frequency.
The free-electron laser has the widest frequency range of any laser type, and can be widely tunable, currently ranging in wavelength from microwaves, through terahertz radiation and infrared, to the visible spectrum, to ultraviolet, to soft X-rays.
http://en.wikipedia.org/wiki/Free_electron_laser
But - http://www.anl.gov/Media_Center/Frontiers/2002/b2excell.html
Scientists and engineers at Argonne National Laboratory’s Advanced Photon Source (APS) achieved "saturation" of self-amplified spontaneous emission in a mirrorless free-electron laser at a wavelength more than 1,000 times shorter than the previous record. This accomplishment demonstrated that free-electron lasers based on this process may one day provide laser-quality X-ray beams and open exciting new horizons for research in dozens of scientific fields.
The beam of light produced in the experiment had a wavelength of 385 nanometers, placing it in the ultraviolet region of the spectrum. The success of the particular process employed at Argonne is gauged by whether the free-electron laser effect has "saturated," meaning the point at which the maximum power has been yielded by the electron beam and converted to coherent synchrotron radiation. The Argonne device clearly exhibited saturation of the process.
FAQ: Is it possible to make a gamma-ray laser?
Can gamma rays be used to create a laser?
Yes, it is possible to create a gamma-ray laser, also known as a graser. However, the technology is still in its early stages and has not yet been developed for practical use.
How does a gamma-ray laser work?
A gamma-ray laser works by using excited atoms or ions to amplify gamma-ray photons, similar to how a traditional laser uses excited electrons to amplify visible light photons. This amplification process creates a highly concentrated and powerful beam of gamma rays.
What are the potential applications of a gamma-ray laser?
A gamma-ray laser could have a wide range of applications in fields such as medical imaging, nuclear physics, and defense. It could also potentially be used for deep space communications and propulsion.
How difficult is it to create a gamma-ray laser?
The creation of a gamma-ray laser is a complex and challenging process. It requires advanced technology and precise control over the energy levels of atoms or ions. Currently, only a few research facilities have the capabilities to create and study gamma-ray lasers.
Are there any safety concerns with a gamma-ray laser?
Yes, a gamma-ray laser can be hazardous if not properly controlled and shielded. Gamma rays are a form of ionizing radiation, which can be harmful to living organisms in high doses. Scientists working with gamma-ray lasers must follow strict safety protocols to prevent exposure to these hazardous rays.
