jonmtkisco
- 532
- 1
Please excuse me for what is possibly a meaningless or misinformed question about the motivations behind GR.
John Wheeler famously said: "matter tells Spacetime how to curve, and Spacetime tells matter how to move." I interpret this school of thought to reflect a conjecture that Spacetime is not simply a mathematically convenient tool for calculating and graphing the effects of relativity; it also is the actual physical mechanism by which gravity operates. That is, gravity actually changes the physical geometry of local space and time.
I understand that this school of thought originally was motivated to provide an explanation for aspects of the Equivalence Principle which in the absence of that definition were considered to be coincidental or mysterious. For example this definition of the Strong Equivalence Principle: "The gravitational motion of a small test body depends only on its initial position in spacetime and velocity, and not on its constitution." My question is, why should we be at all puzzled that gravitational motion is independent of the constitution of the test body?
If gravity is thought of as a plain-vanilla force, rather than as a creator of "spacetime curvature", the SEP is not only intuitively obvious, but any behavior other than the SEP would be inexplicable.
Any massive test body is comprised of atoms, and the vast majority of the mass of atoms is comprised of hadrons (protons and neutrons). So to simplify this discussion I'll just ignore the mass of electrons and assume that all hadrons have the same mass. When a "force" such as gravity acts on a hadron, Newton tells us that F=Ma, so any given force potential causes a single hadron of mass=1 (in a hadron-based mass scale) to accelerate toward the source at a specified acceleration rate (let's say a=1 in our scale). The hadron's inertia is what resists the force of gravity and it is what that force must overcome in order to accelerate an M=1 hadron at a=1. If our test mast contains 1M hadrons, then the same force of gravity as before will separately and equally pull on each hadron, causing each hadron to accelerate at a=1 and, indirectly, causing the test particle as a whole to accelerate at a=1. Gravity is an inexhaustible source of force, in the sense that it can pull on an unlimited number of hadrons at once (subject to physical space limitations) without diminishing the force it applies to each individual hadron.
By this elementary reasoning it would defy common sense to expect a more massive object to accelerate faster than a less massive object. Linking individual hadrons together (chemically) does not cause any (significant) change in their individual inertias. It would be bizarre indeed if linking hadrons together caused them to each become more (or less) susceptible to gravitational force than the same number of hadrons that are unlinked.
As I said, all of this seems entirely obvious and elementary. So I don't understand why so many great minds have spent so much time marveling about it. I am missing something.
Of course GR makes slightly different predictions about the effects of gravitational force than Newton does. Plotting gravity on a 4-axis spacetime diagram makes these differences seem easily explainable as geodesics through a physically curved local spacetime. But why can't an old-fashioned "force" have complexities in its effects, without mandating that we adopt spacetime curvature as the physical mechanism?
Jon
Jon
