Empty lattice energy bands (Kittel, problem 7.2)
FranzIn summary, the conversation discusses problem 2 of chapter 7 in Kittel's "Introduction to Solid State Physics." The student is required to sketch the free electron energy bands in the empty lattice approximation and in the reduced zone scheme, for a fcc lattice in the [111] direction. The equations and attempt at a solution are provided, with a focus on the difference between simple cubic and fcc lattices in the [111] direction. Further discussion is had on the allowed reciprocal lattice vectors and their effects on the band structure. The conclusion is that some bands may be present in a simple cubic lattice but not in a fcc lattice, as shown in a plotted graph. However, there is a factor of
Franz101010
"empty lattice" energy bands (Kittel, problem 7.2)
This is problem 2 of chapter 7 in Kittel's "Introduction to Solid State Physics".
empty lattice approximation and in the reduced zone scheme, for a fcc lattice,
It is the equation at page 189 of Kittel's book. Basically what one has to do is
to express the free electron energy as
e(kx,ky,kz) = \hbar / 2 m (k+G)2
where G is a reciprocal vector and k lies in the first Brillouin Zone.
A similar problem is treated explicitly for a simple cubic crystal in the [100] direction at
pages 189-190. The resulting bands are plotted in fig. 8.
The problem does not look very hard. Since the desired direction is [111] one gets
kx= ky = kz = k. The range of k is the interval [-\pi/a, pi/a] as in fig 8, since the boundary
of the first BZ in the direction [111] is [pi/a pi/a pi/a]
I have attempted a solution, and ended up with the same as in this "[URL
handout[/URL] I have found on the web.
So far so good... I guess...
What really puzzles me is the "fcc" ingredient. Is this solution really specific to a fcc lattice??
It seems to me that one would get exactly the same result for a simple cubic lattice.
Perhaps it is not very surprising that an "empty lattice approximation" does not depend on the lattice geometry, but I find Kittel's choice quite confusing. Even more so because just below the table at page 189 Kittel suggests to carry out the calculation for a simple cubic lattice...
Of all the possible direction kittel chooses the one where the bands look the same for sc and fcc lattices (and probably for bcc as well). And it seems to me that he does not emphasize this...
Am I missing something? Is my idea (that the band structure is lattice independent in the [111] direction) wrong? It seems to me that the band wrapping would be different for fcc and sc lattices in the [100] direction...
Thanks a lot for any insight
Franz
I gave some more thinking about this problem, and I realized that there's a further
difference between sc and fcc lattices, other than the BZs.
The difference is in the allowed reciprocal lattice vectors (of course...).
The reciprocal lattice of a sc lattice is another sc lattice.
A possible basis is (in units of 2 \pi/a, where a is the lattice constant)
(1) [1 0 0], [0 1 0], [0 0 1]
The reciprocal lattice for a fcc lattice is a bcc lattice, and a possible basis is
(2) [1 1 -1], [1 -1 1], [1 1 -1]
Now the G's in the above equation must be combinations of vectors
in the basis (with integer coefficients). Of course (2) can be obtained from (1),
but the converse is not true.
Hence, in my opinion, the bands corresponding to the vectors in (1) appear
only in the sc band structure.
If I'm not taking a blunder, the band structure in this http://www.colorado.edu/physics/phys7440/phys7440_sp03/HOMEWORK/Homework/S6.htm" is not for a fcc lattice, but for a sc lattice.
The band structure for the fcc lattice is obtained by removing the bands from 2 to 6
(I count them from bottom up, on the left side of the last figure in the handout).
Could someone comment on this? Thanks a lot
Franz
I think my previous comment can be made clearer easily.
In doing this I take advantage of the very cool tex feature I've just discovered :!), and
correct some typos I've made.
So the main equation is
[tex]\epsilon = \frac{\hbar^2}{2 m} ({\mathbf k}+{\mathbf G})^2[/tex]
where G is an allowed reciprocal lattice vector and k is in the first BZ. According to the above discussion this means that
[tex]{\mathbf k} = \frac{2 \pi}{a} x [1,1,1],\qquad\qquad |x| \leq \frac{1}{2} [/tex]
The reciprocal lattice basis is formed (e.g.) by the three vectors
[tex]{\mathbf g}_1 = \frac{2 \pi}{a} [1,1,-1],\qquad
{\mathbf g}_2 = \frac{2 \pi}{a} [1,-1,1],\qquad
{\mathbf g}_3 = \frac{2 \pi}{a} [-1,1,1][/tex]
so that a generic reciprocal lattice vector is
[tex]{\mathbf G} = p\, {\mathbf g}_1+q\, {\mathbf g}_2 +r\, {\mathbf g}_3 =
\frac{2 \pi}{a} [p+q-r,p-q+r,-p+q+r],\qquad\qquad p,q,r \in {\mathbb Z}\qquad (*) [/tex]
whence
[tex]\epsilon= \frac{\hbar^2 \pi}{m a} \left[
(x+p+q-r)^2+(x+p-q+r)^2+(x-p+q+r)^2
\right]
[/tex]
Using the last equation for drawing the bands gives the attached result Kittel_7_2.jpg, where the numbers in the legend are not the normalized components of G , but the above p, q and r. The components of G in units of [tex]2 \pi/a[/tex] are easily found by using Eq. (*). For instance
[p q r] ---> [Gx Gy Gz]
[0 0 0] ---> [0 0 0]
[1 0 0] ---> [1 1 -1]
[1 1 0] ---> [2 0 0]
[1 -1 0] ---> [0 2 -2]
If I'm not forgetting anything, this is in agreement with what I have argued in my previous post: reciprocal vectors such as
[tex]{\mathbf G} = \frac{2 \pi}{a} [1 0 0][/tex]
are not allowed in a fcc lattice, but only in a sc lattice. Hence some bands which are present in the latter are missing from the former.
It problably doesn't matter since this thread is several months old, but anyway, the plot posted above is incorrect, all values should be multiplied by 4/3. Franz101010 did not normalize the energies correctly. See the attached mathematica notebook.
  • kittel72.nb
Nathan12343,
thanks for replying to my old post. I have not had time to look at your mathematica notebook yet, but I guess you're right about normalization. I'll peruse it asap.
Anyway if I get it right it is an overall factor, so it does not really matter for the original question. I do not recall what I was meaning by "normalized" in the plot I've attached, but probably you're right and I've got some factor wrong.
Thanks again
Franz
Kittel wants everything in units of the maximum energy of the lowest energy band, which happens to be 3/4 modulo a bunch of constants.
You're definitely right about this, I've read the text of problem 2 again. Kittel suggests the normalization convention you mention, I've adopted a different one.
But, again, that seems to me a definitely minor point, since the normalization factor is to some extent arbitrary.
My question was of a different nature. Today I wanted to take a look at your notebook, but it's still pending approvation. I'm curious to see whether you ended up with the same band structure as me (modulo a 4/3 coefficient, of course :wink:).
Cheers
F
FAQ: Empty lattice energy bands (Kittel, problem 7.2)
1. What is an empty lattice energy band?
An empty lattice energy band refers to the energy levels within a solid material that are unoccupied by any electrons. These energy levels form a continuous band of allowed energy states within the material, and are often represented as a curve on a graph.
2. How is the concept of empty lattice energy bands relevant to the study of materials?
The concept of empty lattice energy bands is crucial in understanding the electronic properties of materials. The band structure of a material determines its electrical conductivity, optical properties, and other important characteristics. By studying the empty lattice energy bands, scientists can gain insight into the behavior of a material and how it may be used in various applications.
3. What is the difference between a completely filled and an empty lattice energy band?
A completely filled lattice energy band means that all of the energy levels within the band are occupied by electrons, while an empty lattice energy band has no electrons present. This difference in occupancy affects the electronic properties of the material, as a completely filled band may behave as an insulator while an empty band may behave as a conductor.
4. How is Kittel's problem 7.2 related to empty lattice energy bands?
Kittel's problem 7.2 is a theoretical problem that deals with the energy levels and band structure of a one-dimensional crystal. It specifically focuses on the behavior of an empty lattice energy band and how it is affected by various parameters such as lattice spacing and electron energy. Solving this problem can provide a deeper understanding of empty lattice energy bands and their role in the electronic properties of materials.
5. What are some real-life examples of materials with empty lattice energy bands?
Some examples of materials with empty lattice energy bands include metals, semiconductors, and insulators. In metals, the conduction band is partially filled with electrons, leaving some energy levels empty. In semiconductors, the band gap between the valence and conduction bands creates empty energy levels. In insulators, there is a large band gap, resulting in a completely empty conduction band.
