- 2,474
- 2,081
This is in response to the following in another thread:
I'm assuming that Fredrik refers to using the plane of simultaneity of the co-moving inertial observer as a means of assigning coordinates to events in an accelerating frame. This works for Rindler coordinates in the case of uniform acceleration in flat spacetime, but I see no reason why it shouldn't work for arbitrary accelerating observers.
You will have to impose some restrictions on the smoothness of the observer's worldline. ([itex]C^\infty[/itex] would certainly be good enough, in my guess, and probably much worse would do.) And you are guaranteed to get a one-one correspondence between coordinates and events only locally near the observer. (I would guess within a distance of [itex]c^2/a[/itex], the "radius of curvature" of the worldline, where a is the instantaneous proper acceleration; this radius is pretty large for most physically realistic accelerations, e.g. about one light year for 1g. But even beyond that radius, coordinates are still defined, just no longer one-one. That being said, there may nevertheless be some events lying behind an event horizon with no coordinates.) But apart from that I don't see why it shouldn't work, and why you shouldn't regard this as "natural" -- or to be more specific, I don't see why uniform acceleration should be singled out as being different. (I'm using my geometric intuition here, I have no proof.)
I answer it here to avoid diverting that other thread's course.Fredrik said:The problem is that there's no natural way to extend the accelerating coordinate system to points that aren't close on the rocket's world line so that it assigns a time coordinate to events on Earth as well. (There is a choice that can be considered natural when the acceleration is constant, but not when the acceleration is arbitrary).
