Understanding the Role of Space as the Background for Light and Gravity"
  • Thread starter wolram
In summary, the concept of background can have different meanings in physics, but it is often used to refer to an assumed fixed metric geometry on a continuum. This is a key issue in physics, as some theories start with a completely floppy continuum while others assume a fixed metric and add on to it. The nature of this background and the vacuum of empty space is still not fully understood, but new developments in physics, such as those expected from the Large Hadron Collider, may shed more light on it.
wolram
Dearly Missed
4,446
558
This may be nieve but i have not found an explanation yet, i guess the background is the medium needed for light to travel by and for gravity to permeate, but as aether theories have been ruled out this leaves only space it's self as the background AFAIK.
In this case for some theories space must have been the first (thing) to exist?
Space news on Phys.org
The word has no one unique meaning. When people talk about background they mean different things and you have to study the context to tell what they mean.
What many people mean by it is an assumed background metric geometry. A continuum---a set of points representing space or spacetime can be either stiff or floppy. What gives a continuum a rigid shape is having a metric or distance function defined on it. Then you can measure angles and triangles and areas and volumes etc. If there is a fixed metric on a continuum you can do geometry on it.
If a continuum has no metric then it is shapeless and floppy and stretchy. You can't do geometry.
There is a BIG ISSUE in physics which is when you build a model of space or of spacetime should you
1. start with a completely floppy continuum and not assume any fixed metric at all, at the beginning. No preconceptions, just distribute some matter in your continuum and see what kind of metric evolves. (this is how General Relativity does it) Or should you
2. start with a continuum already equipped with a fixed metric----typically representing a flat zero-curvature vanilla geometry---and then add stuff bit by bit and allow slight modifications, like ripples on a basically flat pond surface.
So in the context of that ongoing argument, background is shorthand for background metric assumed at the start, in constructing a model. 1915 General Relativity manages to not need a background metric, so it is independent of background geometry.
I think you are asking about something else. You say you guess "the background is the medium needed for light to travel by and for gravity to permeate" and that is certainly one possible defintion but I never heard anyone use the word background to mean that. However one says it, asking what it is is a good question. You could use a different word so as to reduce the risk of confusion.
You could say "empty space" or "vacuum" or maybe continuum. whatever light travels thru and is shaped by the gravitational field.
Calling it background would also seem like a good idea if it were not for the risk of getting mixed up in a loud discussion of something entirely different---where people mean something else by it.
Frank Wilczek has a new book (The Lightness of Being) which is entirely about the modern physics understanding of the vacuum. He never once calls it "background", though. He has various things he calls it. Sometimes he says "the entity we call empty space".
His point is that we call it empty space but we probably shouldn't think of it as empty.
I conclude from reading the book, and everything else I've seen on the subject, that we don't know. We don't know what is the [whatever light travels thru and is shaped by gravity]. We don't know what the background is (if you insist on calling it that).
We don't know the best way to think about empty space. What Wilczek says in the book is that HE sees ways in which the LHC results will help greatly to grasp empty space better. He explains how, for him, knowing how many Higgs-like particles there are and what their properties are will help figure out how empty space works.
He explains how seeing some supersymmetry would be a big help in comprehending the vacuum.
The book points out that there are immediate questions. Some things that are known about empty space---he refers to layers of knowledge. He says we know some layers but there are further layers about which he is itching with curiosity. He makes lists and some items have question marks beside them. It is in some ways it is an impatient book. He is very eager to get some LHC results.
He doesn't talk about the Big Bang, or string theory, his focus is on ordinary empty space and he takes a kind of bottom-up approach to it (based on those experiments done in the past at earlier colliders and those he expects to be done in the future.)
Thanks Marcus,
How would one perform geometry in a pointless, non particle inhabited contium?
(Marcus)
The ingredients of GR are
i) A blank manifold
ii) the gravitational and matter fields
There is no reason why the physical fields should be localized over the spacetime manifold one way or another as long as they are located with respect to one another in the same way!
So matter is located with respect to the gravitational field only but not with respect to some given apriori fixed background container.
In a review of rovelli's book I write another expalination of background independence - I hope this will be illuminating.
regards
ian
I te review rovelli's book I go by the name of ian beynon - I also contributed to background independence section of LQG of wikipedia.
I think you may be asking about the mathematical foundations of GR. A blank manifold is still a countinuum of points even though theer is no metric to define distances. Differential geometry has been developed for metric-free manifolds. An important concept is the Lie derivative which I talk about in wiki. Hope this helps
regards
ian
I the review rovelli's book I go by the name of ian beynon - I also contributed to background independence section of LQG of wikipedia.
I think you may be asking about the mathematical foundations of GR:
A blank manifold is still a countinuum of points even though there is no metric to define distances. Differential geometry has been developed for metric-free manifolds. An important concept is the Lie derivative which I talk about in wiki. Hope this helps
regards
ian
Background Independent Framework
Link:
http://en.wikipedia.org/wiki/Background_independence"
FAQ: Understanding the Role of Space as the Background for Light and Gravity"
1. What is the relationship between space and light?
The relationship between space and light is that space is the medium through which light travels. Light is a form of electromagnetic radiation that moves through space at a constant speed. Without space, light would have no medium to travel through and would not be able to reach us.
2. How does space affect the behavior of light?
Space affects the behavior of light in several ways. First, the curvature of space, caused by massive objects such as stars and planets, can bend the path of light, resulting in phenomena like gravitational lensing. Additionally, the expansion of space can cause light to shift towards longer wavelengths, known as redshift, which is a key piece of evidence for the theory of the Big Bang.
3. What is the role of space in the theory of gravity?
Space plays a crucial role in the theory of gravity, as described by Einstein's theory of general relativity. According to this theory, the presence of mass and energy warps the fabric of space, creating a gravitational field. This field then influences the motion of objects, causing them to move towards each other.
4. How does the understanding of space impact our understanding of the universe?
Our understanding of space is fundamental to our understanding of the universe. The properties of space, such as its curvature and expansion, have a direct impact on the behavior of matter and energy in the universe. By studying space, we can gain insights into the origins and evolution of the universe.
5. What are some current research areas related to understanding the role of space in light and gravity?
Some current research areas related to understanding the role of space in light and gravity include studying the effects of dark matter and dark energy on the expansion of space, investigating the properties of black holes and their impact on the surrounding space, and using gravitational wave detectors to study the warping of space caused by massive objects. Additionally, scientists are continuously exploring ways to further refine our understanding of space and its relationship to light and gravity through experiments and observations.
