Partial derivative as a vector
In summary: R^2, so it has two components. So there are many different ways to represent the same velocity vector. If we use a different trajectory, then the rate of change with time of, say, temperature, will be different.The directional derivative operator can be used on any function, so it is not a function, it is an operator. The "directional" aspect of it is that you can vary the trajectory, and it will give you the rate of change at different points on the trajectory. The "derivative" aspect of it is that it obeys the product rule, so it can be used on products like velocity times temperature or velocity times density.In summary
snoopies622
846
28
How is [tex]\frac{\partial}{\partial t}[/tex] a vector?
The original context of my question is located in post #5 of my most recent and very short-lived thread, “covariant vs. contravariant time component…”, located here
https://www.physicsforums.com/showthread.php?t=261473
and it had to do with Schwarzschild coordinates and the energy of a particle.
I understand that if one takes the partial derivative of every component of a vector, the result is a new vector. But when the original vector isn’t specified, what does it mean?
MTW is confusing on this aspect.
The point is that all the directional derivatives at a point on a manifold constitute a vector space, and that vector space is isomorphic to the tangent space. So we can make an identification between them.
For simplicity, think of a curved 2-surface S sitting in 3-dimensional Euclidean space. To find a tangent to the surface at a point P, you want to find all the tangents to all curves on S passing through P; these tangents will all lie in a plane, and they will form a vector space: the tangent space. One can identify each tangent vector with a directional derivative operator at P.
That's all it is, really. I think MTW confuses the issue by over-stressing the importance of intrinsic vs. extrinsic curvature. Just because the spacetime manifold doesn't have to sit within a higher-dimensional Euclidean space, doesn't mean you can't imagine it does for the sake of understanding.
Just remember that a vector is not an arrow between two points. A vector is an abstract object that lies within a vector space, which is defined by the axioms of addition and scaling.
An intuitive way (not rigourous!) to think of it is: why is a vector a directional derivative? Imagine a room filled with air that is not at a uniform temperature. When you make a trajectory through space as a function of time, the temperature will change as a function of time along your trajectory. In this sense, your velocity is defining a rate of change of temperature. So whenever we have a trajectory through a point, we can use the velocity at that point to define a directional derivative operator (on the temperature, or whatever else is in the air).
Let me see if I am following you correctly so far. Suppose T(x,y,z) is temperature as a function of location.
The gradiant of T is [tex] <\frac {\partial T}{\partial x},\frac {\partial T}{\partial y},\frac {\partial T}{\partial z}>[/tex].
If I move in the room with velocity [tex]V= <\frac {\partial x}{\partial t},\frac {\partial y}{\partial t},\frac{\partial z}{\partial t}>[/tex]
and I then take the dot product of the gradiant (co-)vector and the velocity vector, I get scalar [tex]\frac {dT}{dt}[/tex]-- the rate of temperature change (for me) per unit time. This scalar is the directional derivative, which is not a vector. Am I to identify the velocity vector V as the directional derivative, and to think of it simply as [tex]\frac{\partial}{\partial t}[/tex]?
The space of directional derivative operators is a vector space. It can be identified with the tangent space. Did you read my post?
Hi Ben, I did read your post.
Between
Ben Niehoff said:
..all the directional derivatives at a point on a manifold constitute a vector space..
and
I thought you were using "directional derivative" and "directional derivative operator" interchangably. Do you mean something that acts on a directional derivative, or something that acts on something else to produce a directional derivative?
No, I mean an operator like
[tex]\nabla_{\vec x}[/tex]
that differentiates a [scalar, vector, or tensor] in a specific direction. In particular, the partial derivative operators [itex]\partial / \partial x^i[/itex] constitute the basis of a vector space.
For simplicity, think about just two dimensions. Write
[tex]u = a \frac{\partial}{\partial x} + b \frac{\partial}{\partial y}[/tex]
[tex]v = c \frac{\partial}{\partial x} + d \frac{\partial}{\partial y}[/tex]
And then show that u and v are elements of a vector space.
Oh, so [tex]\frac{\partial}{\partial t}[/tex] is simply another way of representing [tex]e_{t}[/tex], the basis vector for the time direction? Well now that I understand.
Does it then follow that the energy of a particle in a static gravitational field is [tex]e_{t} \cdot \vec{p}[/tex] where [tex]\vec{p}[/tex] is the four-momentum vector, and my original question about whether one should use p0 or p0 becomes unnecessary since [tex]e_{t} \cdot \vec{p} = \omega^{t} \cdot \tilde{p}[/tex] no matter what the coordinate system?
Yes, along those lines. I think of the gradient covector as a later concept than the velocity as a directional derivative operator. I think of rate of change of temperature with time dT/dt, and the velocity [dx/dt,dy/dt].
The temperature T is a number at every point T(x,y). The trajectory assigns a time t, also a number, to points along a path [x(t),y(t)]. On the trajectory, T(x(t),y(t))=T(t) is just a normal function of one variable, so we can define dT/dt as the rate of change of temperature with time along the trajectory.
Then using the chain rule:
dT(x(t),y(t))/dt
=(dT/dx)(dx/dt)+(dT/dy)(dy/dt)
=[(dx/dt)(d/dx)+(dy/dt)(d/dy)]T
This will work not only for temperature, but for any function of space like humidity or density, so we can make this operator which maps any function to a number:
d/dt=[(dx/dt)(d/dx)+(dy/dt)(d/dy)]
Comparing the term in the square brackets with the velocity, it makes sense to call this operator the directional derivative operator in the direction of the velocity.
Many different trajectories can have the same velocity at a point, so instead of depending on one particular trajectory, we can use v to represent the velocity of all trajectories having that velocity at that point:
v=[vx(d/dx)+vy(d/dy)]
Amazingly or not, I haven't decided, the velocity operators at a point form a vector space like Ben Niehoff says. You can add different velocity operators at a point, but you cannot add velocity operators at different points, unless the space is special.
OK, I am going to hazard a guess from George Jones's clues in the thread you referred to.
E=g(d/dt,u)=gab<d/dt,dxa><u,dxb>
In coordinates by definition of basis vectors and dual basis vectors:
<d/dt,dt>=1 for xa=t
<d/dt,dxa>=0 for xa!=t.
So: E=gtb<u,dxb>
For the Schwarzschild metric, gtb=0 except gtt
So: E=gtt<u,dxt>=gttut=ut ... ?
Edit: E=gtt<u,dxt>=gttut=ut ... ?
Interesting. This is forcing me to (finally) work with basis vectors and covectors in a context where there is no background higher-dimensional Euclidean space. For those who might be interested, I first described my problem here https://www.physicsforums.com/showthread.php?t=236974
It seems part of my confusion has been the notation I have been using -- in which Ar represents a component of a vector while er represents an entire vector. I'm not quite finished working it out yet, but so far the results are promising.
Thank you both for your help.
Right, but [itex]\partial / \partial t[/itex] is not normalized, i.e., does not have unit length.
Right! This is because [itex]\partial / \partial t[/itex] is a timelike Killing vector, so this works in the more general case of stationary spacetimes. Usually, [itex]E[/itex] is defined as energy per unit mass, so 4-velocity [itex]u[/itex] is used instead of 4-momentum [itex]p[/itex]. Note that [itex]E[/itex] is a scalar that has the same value in all coordinate systems, and that happens in the particular case of Schwarzschild coordinates to be equal to [itex]u_0[/itex].
atty said:
OK, I am going to hazard a guess from George Jones's clues in the thread you referred to ..
Right! Typically, physicists wouldn't use letters for particular values of indices. Let me reproduce what you wrote this using slightly different notation.
Set
[tex]\left\{ e_0 = \frac{\partial}{\partial t} , e_1 = \frac{\partial}{\partial r} , e_2 = \frac{\partial}{\partial \theta} , e_3 = \frac{\partial}{\partial \phi} \right\}.[/tex]
Slightly non-standard notation has been used in that [itex]\left\{ e_\mu \right\}[/itex] is not an orthonormal basis. Now,
[tex]
\begin{equation*}
\begin{split}
E &= g \left( e_0 , u \right) \\
&= g \left( e_0 , u^\mu e_\mu \right) \\
&= u^\mu g \left( e_0 ,e_\mu \right) \\
&= u^\mu g_{0 \mu} \\
&= u_0.
\end{equation*}
\end{split}
[/tex]
I thought the unit-length basis vectors were represented by putting a little circumflex over the coordinate symbol, as in [tex]e_{\hat{\theta}}[/tex] instead of [tex]e_{\theta}[/tex]. Is this not the convention, or do I misunderstand you?
Related to Partial derivative as a vector
1. What is a partial derivative as a vector?
A partial derivative as a vector is a mathematical concept used in multivariate calculus to represent the rate of change of a function with respect to multiple variables. It is expressed as a vector, with each component representing the partial derivative of the function with respect to a specific variable.
2. How is a partial derivative as a vector calculated?
A partial derivative as a vector is calculated by taking the partial derivatives of the function with respect to each variable and combining them into a vector. This can be done using the gradient operator, which takes the partial derivatives in each direction.
3. What is the significance of a partial derivative as a vector?
A partial derivative as a vector is significant because it gives information about the direction and magnitude of the rate of change of a function in multiple dimensions. This can be useful in fields such as physics, engineering, and economics.
4. Can a partial derivative as a vector be negative?
Yes, a partial derivative as a vector can be negative. The sign of the vector component indicates the direction of change, with a negative value indicating a decrease in the function and a positive value indicating an increase.
5. How is a partial derivative as a vector used in real-world applications?
A partial derivative as a vector has many real-world applications, such as in optimization problems, where it can be used to find the direction of steepest ascent or descent. It is also used in fields like economics to model changes in production and demand, and in physics to calculate forces and motion in multiple dimensions.
