Sticky for beginners to draw a spacetime diagram
In summary, the Lorentz transformation allows us to apply the same equations for position and time in different frames of reference, as shown by the equations for events 1 and 2 occurring in frame S and their transformed values in frame S'. This transformation is linear and can be used to draw spacetime diagrams, where position is on the horizontal axis and time is on the vertical axis. This can be helpful in understanding the concept of lines of simultaneity, which differ for observers moving at different velocities. This information can be found in the Physics Forums FAQ.
granpa
2,268
jtbell said:
Let events 1 and 2 occur at [itex](x_1, t_1)[/itex] and [itex](x_2, t_2)[/itex] in frame S. In frame S' they occur at
[tex]x_1^{\prime} = \gamma (x_1 - v t_1)[/tex]
[tex]t_1^{\prime} = \gamma (t_1 - v x_1 / c^2)[/tex]
[tex]x_2^{\prime} = \gamma (x_2 - v t_2)[/tex]
[tex]t_2^{\prime} = \gamma (t_2 - v x_2 / c^2)[/tex]
Subtracting pairs of equations gives
[tex]\Delta x^{\prime} = x_2^{\prime} - x_1^{\prime} = \gamma ((x_2 - x_1) - v (t_2 - t_1)) = \gamma (\Delta x - v \Delta t)[/tex]
[tex]\Delta t^{\prime} = t_2^{\prime} - t_1^{\prime} = \gamma ((t_2 - t_1) - v (x_2 - x_1) / c^2) = \gamma (\Delta t - v \Delta x / c^2)[/tex]
That is, the Lorentz transformation applies to [itex]\Delta x[/itex] and [itex]\Delta t[/itex] just as it does to x and t, because the transformation is linear.
I'm always sending beginners to that post and it often answers their question.
maybe we should have a sticky listing these equations.
maybe throw in something about how to draw a spacetime diagram too. and a note about the lines of simultaneity being different for observers moving at different velocities (which as what beginners always have trouble with). anyone know of any good posts for that?edit:I see there is already a FAQ. maybe the post above should be included in it.
https://www.physicsforums.com/showthread.php?t=104715
Good idea. Most students are familiar with plotting a diagram with position on the vertical axis and time on the horizontal axis. A spacetime diagram is nothing more than that but for historical reasons the axes are reversed so that position is on the horizontal axis and time is on the vertical axis. The Lorentz transform is then just a way of changing those diagrams from one frame to another.
FAQ: Sticky for beginners to draw a spacetime diagram
What is a spacetime diagram?
A spacetime diagram is a visual representation of the relationship between time and space in a given scenario. It is used in physics to better understand the concept of spacetime, where time and space are interconnected and cannot be separated.
Why is it important to learn how to draw a spacetime diagram?
Drawing a spacetime diagram can help in understanding various concepts in physics, such as relativity, time dilation, and the geometry of spacetime. It allows for a visual representation of complex ideas and can aid in problem-solving and analysis.
What are the basic elements of a spacetime diagram?
A spacetime diagram typically consists of a vertical axis representing time and a horizontal axis representing space. The slope of a line on the diagram represents the speed of an object, and the curvature of the line indicates acceleration.
How do I draw a spacetime diagram?
To draw a spacetime diagram, start by labeling the vertical axis as time and the horizontal axis as space. Then, plot the position of an object at different points in time, connecting the points with a line. Use the slope and curvature of the line to represent the object's speed and acceleration, respectively.
Are there any common mistakes to avoid when drawing a spacetime diagram?
One common mistake is to use equal intervals on both the time and space axes. This can lead to inaccuracies in the diagram, as time and space do not have the same units. It is also important to consider the reference frame and the speed of light when drawing a spacetime diagram.
