Some question from the oxford entrance test
  • Thread starter i25959341
  • Tags
    Test
In summary, the black box will measure current when the battery is connected in different ways, but there is no current when the battery is connected with ¡ to B and + to C.
i25959341
14. You should already be familiar with the mathematical treatment of an
ideal pendulum, in which the pendulum bob is modeled as a point
mass on the end of a rigid rod of negligible mass. In this problem you
will consider the behaviour of more complex types of pendulum. You
will be given all the information you need in the sections below.
For a general pendulum of any shape and size the period P is given by
p= 2*pie*root(I/gM(LCM))
where g is the acceleration due to gravity, M is the total mass of the
pendulum, LCM is the effective length of the pendulum, defined as the
distance from the pivot to the centre of mass, and I is the moment of
inertia around the pivot point. For a point mass m fixed at a distance
r from the pivot I = mr^2, while for a uniform rod of mass m and length
r attached to the pivot at one end I = 1/3mr^2
. For more complex objects
the total moment of inertia can be calculated by adding together values
for the component parts.
(c) Now consider the case of a real pendulum, with a bob of mass
Mb (which you may treat as a point mass) attached to the pivot
using a uniform rod of mass Mr and length L, and find the period
in this case. Show that the result for a real pendulum reduces to
the results for an ideal pendulum and a rod pendulum by taking
appropriate limits.
What have you tried? You are given the equation for the period of the real pendulum...all you need to do is determine LCM and I. What happens to p as Mr approaches zero?
okokok thank you dat s the direction i was thinking but i don't kno whether it s the right one
(d) Most substances expand with increasing temperature, and so a
metal rod will expand in length by a fraction ®dT if the tem-
perature is changed by dT, where ® is called the coe±cient of
linear thermal expansion. Consider the effect of this expansion
on a pendulum clock with a pendulum made from brass, with
® = 19 £ 10¡6 K¡1. What temperature change can this clock
tolerate if it is to remain accurate to 1 second in 24 hours? [5]
do u just try to separate p and dp and stuff??
wat is the question saying wen it is asking u to take appriopriate limit??
For the ideal pendulum, Mr=0 so the "appropriate limit is the limit as Mr approaches zero.
the period p will be a function of the length of the pendulum and the length of the pendulum will be a function of temperature...therefor p is a function of temperature... if the temperature change is [itex]\Delta T=T_2-T_1[/itex] what is the change in period [itex]\Delta p = p(T_2)-p(T_1)[/itex]? If the pendulum is accurate to within 1 second in 24 hours, then [itex]\Delta p \leq \frac{1s}{24h}[/itex] and you can solve for [itex]\Delta T[/itex].
thabk you
24. A black box has three electrical connections labelled A, B, and C,
arranged in a triangle as shown below.
A
b c
The box contains three components: a resistor, a small capacitor and a
diode. You know that one component is connected between each pair
of terminals, but you cannot see exactly how they are arranged. You
make the following observations with a 9V battery connected in series
with an ammeter
² When the battery is connected with + to A and ¡ to B a current
of 3mA °ows
² When the battery is connected with + to B and ¡ to C a very
large current °ows
² When the battery is connected with + to C and ¡ to A no current
is measured
² When the battery is connected with ¡ to B and + to C no current
is measured
Will you be tested on "ure" grammar?
OK so I got to √L2 - √L1 ≤ 5.825 x 10^-6
How do I get ΔL from there?
You got Δ√L haven't you?
Yeah, but how can I get ∂T from ∆√L ?
You are looking for the maximum change in length allowed aren't you? So if you have the square root of the change in length allowed..
I'm sorry, I still don't understand, if I had √∆L then I could do it, but that's not equal to ∆√L is it?
Related to Some question from the oxford entrance test
1. What is the format of the Oxford entrance test?
The Oxford entrance test typically consists of multiple-choice questions, short answer questions, and essay questions. The specific format may vary depending on the subject being tested.
2. How long is the Oxford entrance test?
The length of the Oxford entrance test can vary depending on the subject being tested. On average, it takes about 2-3 hours to complete.
3. What topics are covered in the Oxford entrance test?
The topics covered in the Oxford entrance test will depend on the subject being tested. Generally, the test will cover a wide range of subjects within the chosen field, including foundational concepts, theories, and applications.
4. Is there a specific study guide for the Oxford entrance test?
Yes, there are study guides available for the Oxford entrance test. These can be found online or through the official website of the university. However, it is important to note that the test is designed to evaluate critical thinking and problem-solving skills, so simply memorizing information may not be sufficient.
5. How can I prepare for the Oxford entrance test?
To prepare for the Oxford entrance test, it is important to have a solid understanding of the subject being tested and to practice critical thinking and problem-solving skills. Reviewing past exams and seeking guidance from mentors or tutors can also be helpful. It is recommended to start preparing well in advance to allow for sufficient time to cover all necessary material.
