How do you differentiate x^{1/x} using the power rule and chain rule?
  • Thread starter Thread starter madmike159
    Differentiation
madmike159
I was looking at results of different numbers in the equation \sqrt[x]{x} and found out that the biggest result came when it was \sqrt[e]{e}. I know this can be re-written as x^{1/x} and that the gradient would be 0 at x = e. How would you differentiate y = x^{1/x}, I can't seem to do it using any of the laws I know.
Find a function f(x) that let's you rewrite y=x^{1/x} in the form y=\exp(f(x)).
I don't see how that works but I'll give it a go.
use the power rule
[u^v]'=v*[u^(v-1)]*u'+[u^v]*[log(u)]*v'
Rather than committing the power rule to memory, I find it much easier to remember a couple simple facts which happen to be of use in a lot of other places,
  1. \frac{d}{dx}\left(e^{f(x)}\right) = e^{f(x)}\,f'(x)
  2. f(x) = e^{\ln f(x)}\;\Rightarrow\;u(x)^{v(x)} = e^{v(x)\,\ln u(x)}
and thus
<br /> \aligned<br /> \frac{d}{dx}\left(u(x)^{v(x)}\right)<br /> &amp;= \frac{d}{dx}\left(e^{v(x)\,\ln u(x)}\right) \\<br /> &amp;= e^{v(x)\,\ln u(x)}\frac d {dx}\left(v(x)\,\ln u(x)\right) \\<br /> &amp;= u(x)^{v(x)}\left(v&#039;(x)\,\ln u(x) + \frac{v(x)\,u&#039;(x)}{u(x)}\right)
Equivalently, if y= x1/x, then ln(y)= (1/x)ln(x). Use "implicit differentiation".
or just use it on
y^x=x
How is a less general rule more useful?
The power rule is easy to recall since it follows from other rules
first remember the right hand side
[u^v]'
next use the chain rule (C is a constant)
[u^v]'=[u^C]'|C=v+[C^v]'|C=u
now recall
[x^C]'=C*[x^(C-1)]
or using the chain rule
[u^C]'=C*[u^(C-1)]*u'
and
[C^x]'=[C^x]*log(C)
[C^v]'=[C^v]*log(C)*v'
inserting these into
yeilds
[u^v]'=C*[u^(C-1)]*u'|C=v+[C^v]'+[C^v]*log(C)*v'|C=u
[u^v]'=v*[u^(v-1)]*u'+[u^v]*log(u)*v'
