Color currents in classical QCD
In summary, I've been playing around with the QCD Lagrangian and trying to interpret the resulting equations. I found that the equations are in the adjoint representation and not the fundamental one, which is why they are nonlinear and describe the gluon fields instead of quarks. However, I encountered a problem where setting 6 of the 8 gluon fields to zero would result in all nonlinear terms in the equations being zero as well. This is not allowed due to gauge invariance, as the equations should be SU(3) invariant. This could mean that the solutions where only 3 of the 8 gluon fields are non-zero are not physically meaningful.
Ben Niehoff
171
I've been playing around with the QCD Lagrangian to get a better understanding of how it works. I can derive some classical, Maxwell-like equations; the inhomogenous ones are
[tex]\nabla \cdot \vec E^a = -gf^{a}_{bc} \vec A^b \cdot \vec E^c + \rho^a[/tex]
[tex]\nabla \times \vec B^a - \frac{\partial}{\partial t} \vec E^a = \vec J^a + gf^a_{bc} (\Phi^b \vec E^c - \vec A^b \times \vec B^c)[/tex]
The problem is that I'm not quite sure how to interpret these equations. The (gluon) color indices {a, b, c} run from 1 to 8. But there are three kinds of color charge. So how do I interpret the sources [itex]\rho^a[/itex] and [itex]\vec J^a[/itex]?
One thing I attempted was to multiply both equations by the generators [itex]T^a_{ij}[/itex]. This eliminates the gluon color indices {a, b, c} in favor of the quark color indices ij (which then run from 1 to 3). But now there are two indices on everything! One for a color and one for an anti-color. Again, I can't quite figure out how to interpret what it means.
Hmm...no answers. Maybe I didn't explain the question enough. The problem is that these equations are in the adjoint representation, but the quarks are in the fundamental representation, and I wasn't sure how to relate them.
I think I've figured it out, though. I have to represent some color-charge distribution as the linear combination of adjoint-color matrices (as functions of position and time) that leave that charge distribution invariant. For example, a red point-charge at point [tex]\vec x'[/tex] would be represented by
[tex]\rho(\vec x) = \left( \frac12 \mathbf \lambda_3 + \frac{\sqrt 3}{2} \mathbf \lambda_8 \right) \delta^{(3)}(\vec x - \vec x')[/tex]
where [itex]\mathbf \lambda_a[/itex] are the Gell-Mann matrices.
To anyone more familiar with this stuff: Does this sound right, or have I gone astray?
Yes, I had it completely wrong. But now I've figured it out! It comes from the definition of the color currents (of course)
[tex]j^{\mu}_a = \bar \psi \gamma^{\mu} \frac12 \lambda_a \psi[/tex]
Then
[tex]\rho_a = j^0_a = \psi^{\dagger} \frac12 \lambda_a \psi = \langle \psi | \; \frac12 \lambda_a \; | \psi \rangle[/tex]
which for red, green, or blue quarks gives
[tex]\rho_R = \frac12 \lambda_3 + \frac1{2\sqrt3} \lambda_8[/tex]
[tex]\rho_G = -\frac12 \lambda_3 + \frac1{2\sqrt3} \lambda_8[/tex]
[tex]\rho_B = -\frac1{\sqrt3} \lambda_8[/tex]
which form an equilateral triangle in [itex](\lambda_3, \lambda_8)[/itex] space. Nifty!
you answered your own questions, so that's good. Let me just point out one more thing: "E" and "B" are not describing quarks, but they're describing the gluon field strength. So that is why these equations are in the adjoint and not the fundamental - there are eight types of gluons, and these equations are describing those eight fields, regardless of the form of the source.
Just a slightly different (wordy) statement of what you wrote down. :wink:
However, I've reached another point of confusion. These equations are nonlinear, but the nonlinear parts depend upon the structure constants. In particular,
[tex]f^a_{38} = 0[/tex]
for all a. So if my quark charges lie in [itex](\lambda_3, \lambda_8)[/itex] space, they will never set up any nonlinear fields! That is, if the vector potentials [itex]\vec A^a[/itex] for a={1, 2, 4, 5, 6, 7} are zero at any time, they are zero for ALL times. The chromoelectric field will behave just as three superimposed Maxwell fields, with completely linear behavior (and hence, no confinement).
There is an equation which rotates the quark charges:
[tex]\frac{dQ^a}{dt} = -g f^a_{bc} Q^b \left( \Phi^c - \vec v \cdot \vec A^c \right)[/tex]
but this too depends on the existence of charges and/or fields that lie outside the [itex](\lambda_3, \lambda_8)[/itex] plane.
So it appears there are no interesting new dynamics unless one assumes pre-existing gluon fields of the remaining 6 types.
Is this true, or is there something I'm missing?
I'm not sure what you are doing exactly, but you need the complete gluon octet to make a self-consistent model. Picking 3 of 8 gluons won't work.
I am using 8 gluon fields. The issue is that it appears that I can set 6 of them to zero without any inconsistency:
1. The nonlinear parts of the Maxwell-like equations I posted are all multiplied by the structure constants [itex]f^a_{bc}[/itex].
2. My color currents, as computed above, all lie in the [itex](\lambda_3, \lambda_8)[/itex] plane in the 8-dimensional gauge space.
3. [itex]f^a_{38} = 0[/itex] for all a in {1, ..., 8}.
4. Therefore, unless I assume pre-existing gluon fields along one of the {1, 2, 4, 5, 6, 7} axes in gauge space, ALL of the nonlinear terms in the equations are identically zero!
In other words, there are solutions where the quarks interact with an ordinary, inverse-square force (but with three kinds of charge, instead of just one), and never display any "interesting" dynamics.
Am I missing something? Is there some principle by which these solutions can be discarded?
Gauge invariance prevents you from doing that. Your equations are not SU(3)_c invariant !
I was hoping it was something like that. But according to Peskin & Schroeder, p. 491, the non-Abelian gauge field is NOT invariant, but transforms as
[tex]F^a_{\mu \nu} \rightarrow F^a_{\mu \nu} - f^a_{bc} \alpha^b F^c_{\mu \nu}[/tex]
It's the Lagrangian which should be invariant.
But maybe there is some subtlety I'm not getting? The quark charges are not gauge-invariant, so maybe I am not allowed to assign them specific values? (Since that would involve fixing an unphysical degree of freedom). Or something like that.
Related to Color currents in classical QCD
1. What are color currents in classical QCD?
Color currents in classical QCD refer to the flow of color charge in quantum chromodynamics, which is a theory that describes the strong force that binds quarks together to form particles such as protons and neutrons. Color charge is a fundamental property of quarks and is responsible for the strong interactions between them.
2. How do color currents affect the behavior of particles in QCD?
Color currents play a crucial role in the behavior of particles in QCD. They determine the strength of the strong force between quarks, which in turn affects the stability and mass of particles. Color currents also play a role in the production and decay of particles, as well as in the formation of color-neutral objects such as hadrons.
3. Can color currents be observed in experiments?
No, color currents cannot be directly observed in experiments. This is because color charge is confined within particles, meaning that individual quarks cannot exist in isolation. However, the effects of color currents can be observed through the behavior of particles in high-energy collisions and other experiments.
4. How do color currents relate to the concept of color confinement?
Color confinement is a fundamental principle of QCD which states that color-charged particles are confined within color-neutral particles. Color currents play a key role in this principle, as they are responsible for the strong force that binds quarks together, resulting in color confinement.
5. Are there any current theories or research on color currents in classical QCD?
Yes, there is ongoing research on color currents in classical QCD, as it is a complex and dynamic area of study. Researchers are exploring various aspects of color currents, such as their role in the structure of hadrons and their behavior at high energies. There are also ongoing efforts to improve our understanding and mathematical description of color currents in QCD.
  • Classical Physics
