Tighter bounds on cosmo parameters (Chandra Cluster Cosmology Project)
In summary, the Chandra Cluster Cosmology Project III has provided new, robust evidence for the existence of dark energy through the observation of galaxy clusters. By counting the number of clusters at different masses and redshifts, they were able to constrain the dark energy fraction and equation of state, and improve upon previous estimates when combined with other cosmological measurements. This suggests a slightly higher dark energy fraction and may lead to a revision of some cosmological parameters. This discovery has been picked up by popular science media, further confirming the significance of this research.
marcus
Dearly Missed
24,775
792
http://arxiv.org/abs/0812.2720
Chandra Cluster Cosmology Project III: Cosmological Parameter Constraints
A.Vikhlinin, A.V.Kravtsov, R.A.Burenin, H.Ebeling, W.R.Forman, A.Hornstrup, C.Jones, S.S.Murray, D.Nagai, H.Quintana, A.Voevodkin
ApJ, in press: Feb 10, 2009 issue
(Submitted on 15 Dec 2008)
"Chandra observations of large samples of galaxy clusters detected in X-rays by ROSAT provide a new, robust determination of the cluster mass functions at low and high redshifts. Statistical and systematic errors are now sufficiently small, and the redshift leverage sufficiently large for the mass function evolution to be used as a useful growth of structure based dark energy probe. In this paper, we present cosmological parameter constraints obtained from Chandra observations of 36 clusters with <z>=0.55 derived from 400deg2 ROSAT serendipitous survey and 49 brightest z=~0.05 clusters detected in the All-Sky Survey. Evolution of the mass function between these redshifts requires OmegaLambda>0 with a ~5 sigma significance, and constrains the dark energy equation of state parameter to w0=-1.14+-0.21, assuming constant w and flat universe. Cluster information also significantly improves constraints when combined with other methods. Fitting our cluster data jointly with the latest supernovae, WMAP, and baryonic acoustic oscillations measurements, we obtain w0=-0.991+-0.045 (stat) +-0.039 (sys), a factor of 1.5 reduction in statistical uncertainties, and nearly a factor of 2 improvement in systematics compared to constraints that can be obtained without clusters. The joint analysis of these four datasets puts a conservative upper limit on the masses of light neutrinos, Sum mnu<0.33 eV at 95% CL. We also present updated measurements of OmegaM*h and sigma8 from the low-redshift cluster mass function."
Sean Carroll has a good post on this at Cosmic Variance. The data plots he shows in a couple of figures tell the story clearly.
The dark energy fraction is a key cosmological parameter and this gives new way to constrain it, another way to measure.
http://blogs.discovermagazine.com/cosmicvariance/2008/12/16/dark-energy-no-longer-a-surprise/
The third figure that Carroll shows (taken from the paper cited above) is a good illustration of how observational cosmology works. It shows overlapping confidence ovals constraining two important cosmological model parameters---OmegaLambda the dark energy fraction, and w the dark energy equation of state---using various batches of data.
The new data is the distribution of clusters by mass, in two redshift ranges (roughly speaking near range and medium range).
Earlier data are from measurements of
SN supernovae
BAO baryon acoustic oscillations
WMAP cosmic microwave background
In the paper they use OmegaX for the dark energy fraction, which is less common notation but sometimes easier to write.
Here is Carroll's explanation:
==quote==
Alexey Vikhlinin and collaborators have used observations from the Chandra X-ray satellite to uncover new evidence for dark energy. ... In particular, they simply count the number of galaxy clusters with various masses at various redshifts, and compare with the predictions of models with and without dark energy. If there were no dark energy, matter would keep clustering on larger and larger scales as the universe expanded, making new clusters all the way. But if dark energy eventually takes over, the creation of new clusters begins to turn off, as the dark energy provides an extra push of expansion beneath the feet of the particles that would like to cluster together, preventing them from doing so.
==endquote==
As figures 1 and 2 show, there are fewer massive clusters than would be predicted in the absence of accelerated expansion (if Lambda were zero---if dark energy had not kicked in a few billion years ago)
The effect of the cosmological constant, or dark energy, has apparently been to disperse galaxies which would otherwise have gathered into clusters---making for fewer of the more massive clusters.
Space news on Phys.org
Carroll mentions that it may be time to slightly revise the estimates of the basic cosmo parameters that we are always using---that for example you plug into cosmo calculators.
For several years we have been using OmegaLambda = 0.73, and OmegaMatter = 0.27. And also putting Hubble ratio equal to 71 (i.e. 71 km/s per megaparsec).
Those are the numbers .27, .73, 71 that you get automatically as default case in Wright's calculator.
It looks more likely now that we should be using 0.26, 0.74, and 71. The darkenergy fraction seems like it might be just a wee bit bigger.
This will slightly change our customary best estimates of the expansion age and a few other things. Not significantly, because these are all still rough estimates, but still worth noticing.
The new expansion age will be 13.8 billion years (instead of 13.7).
The present distance to the matter whose earlier glow we see as CMB is 46 billion ly.
The distance then, when it emitted the CMB light, was 42 million ly.
The CMB light has been traveling 13.8 billion years---only 380,000 years less than the whole expansion age.
You can get these numbers from Ned Wright's calculator just by changing his 0.73 to 0.74 and his 0.27 to 0.26---keeping his 71 the same---and plugging in redshift z = 1090
Related to Tighter bounds on cosmo parameters (Chandra Cluster Cosmology Project)
1. What is the purpose of the Chandra Cluster Cosmology Project?
The Chandra Cluster Cosmology Project aims to improve our understanding of the universe by studying galaxy clusters and their properties. Specifically, it focuses on using data from the Chandra X-ray Observatory to constrain cosmological parameters and test the standard model of cosmology.
2. How does the Chandra Cluster Cosmology Project constrain cosmological parameters?
The project uses X-ray observations of galaxy clusters to measure the cluster's mass, which is then used to calculate the overall matter density of the universe. This, along with other observations such as the cosmic microwave background, can be used to constrain cosmological parameters such as the matter density, dark energy density, and Hubble constant.
3. What are the main findings of the Chandra Cluster Cosmology Project?
The project has found tighter constraints on cosmological parameters, such as the matter density and dark energy density, than previous studies. It has also provided evidence for the existence of dark energy and the accelerated expansion of the universe. Additionally, the project has helped improve our understanding of the formation and evolution of galaxy clusters.
4. How does the Chandra Cluster Cosmology Project contribute to our overall understanding of the universe?
The project's findings help to refine the standard model of cosmology and improve our understanding of the fundamental properties of the universe, such as its age, composition, and expansion rate. This information is essential for studying the evolution of the universe and answering fundamental questions about its origins and future.
5. What are the implications of the Chandra Cluster Cosmology Project's results?
The project's results have significant implications for cosmology and astrophysics. They provide evidence for the existence of dark energy and the accelerated expansion of the universe, which has implications for our understanding of gravity and the fate of the universe. The project's findings also help to inform future research and observations in the field of cosmology.
