How to Get ASME Certification for Heat Exchangers?
To obtain ASME certification for shell and tube heat exchangers, a company must secure a "U" stamp, which involves acquiring specific code books, completing required forms, and paying associated fees. The heat exchangers must be welded by an ASME-certified welder, and an Authorized Inspection Agency is necessary for code inspection, which typically includes a physical pressure test and design review. It is recommended to work with a designer or fabricator that is already certified to avoid unnecessary costs and complications. Companies like ABS Consulting offer authorized inspection services and can assist in the certification process. Engaging with specialized manufacturers can streamline compliance with ASME standards.
famine
Hi All
I'm looking into getting some shell and tube heat exchangers ASME certified for my company and was wondering if anyone could help me with the process. I know that we are trying to get a "U" stamp and need to get the code books that are required. There is also a few forms that we have to fill out and fees to be paid. I'm also aware that the heat exchangers will have to be welded by a ASME welder. I'm a little confused on the "Authorized Inspection Agency" that provides the code inspection, I'm assuming that this would be a physical pressure test and a reveiw of the design but I don't have any idea where we could get this done or how much the cost would be. Any information on the process, or facilities in the midwest that can do the testing would be appreciated.
Thanks
famine said:
Hi All
Thanks
If you're looking for just a vessel pressure test certification then try to Google "hydrostatic pressure testing services" or something along those lines.
CS
The designer/fabricator you select should certify the vessel. A certification stamp goes to a company not an individual. The Inspector that certifies the vessel for the company goes through a specific licensing process. If this is recertification of an existing vessel, ASME VIII BPV has specific guidance on the process. . . There is a company in Richardson TX pressure Sciences Inc that maymeet your specific needs.
Wes
Hi famine, welcome to the board. As bwhartley mentions:
The certificate (ie: U stamp) is given out by the National Board to a company certified to build pressure vessels per ASME Section VIII, div 1 or 2, BPV code. If your company isn't in the business of designing and building pressure vessels to the code, it's not worth your company's time and money to try and get certified. Purchase the heat exchangers directly from a manufacturer that specializes in design and mfg per the code. You can find lots of companies that can meet your needs through ThomasNet for example:
http://www.thomasnet.com/nsearch.ht...+ASME+Code&heading=26625004&navsec=prodsearch
PS: Welcome to the board Wes. :smile:
famine said:
Hi All
Thanks
We ABS Consulting is accredited by the American Society of Mechanical Engineers (ASME) as an Authorized Inspection Agency (AIA). ABS Consulting provides authorized inspection services for manufacturers of Pressure Vessel & Heat Exchanger for more information mail to absgpatel@gmail.com
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
9K
11K
