The diffraction limit of the Hubble ST
In summary, the Hubble Space Telescope can observe a range of wavelenghts, but the diffraction limit is calculated using a particular wavelength of 500 nm. The justification for this is that it coincides with the irradience, sensitivity, and middle wavelength of the visible spectrum.
TheMan112
43
I'm trying to calculate the diffraction limit/angular resolution for the Hubble Space Telescope. I know this can be found using the formula:
[tex]\theta = 1.22 \frac{\lambda}{D}[/tex]
Where [tex]\lambda[/tex] is the wavelength of the light being observed and [tex]D[/tex] is the diameter of the objective lens (2.5 m on Hubble).
Now since Hubble is able to observe a wade range of wavelenghts from the ultraviolet to the visible to the infrared spectrum I would describe the diffraction limit as an interval depeding on this range of wavelenghts.
However, in all examples I've been able to find, even http://www.nasa.gov/missions/highlights/webcasts/shuttle/sts109/hubble-qa.html" , the diffraction limit of optical telescopes is calculated using a single wavelength of 500 nm (~cyan). What's the justification for using this particular wavelength for Hubble (and other optical telescopes).
500 nm coincides with:
1. The irradience top of sunlight (and thus any G-type star). See: http://en.wikipedia.org/wiki/File:EffectiveTemperature_300dpi_e.png
2. The sensitivity top of the human eye.
3. The approximate middle wavelength of the visible spectrum.
However (respectively):
1. G-type stars aren't all that common, comprising only 7.6% of all stars, thus the usage is limited and this point cannot be applied to all visible starlight.
2. The HST employs CCD sensors and not direct human observation, thus point 2 is irrelevant.
3. This is the only point that seems relevant. However the HST would theoretically achieve greater angular resolution by using say the 380-450 nm range.
So what's the point of using 500 nm when calculating the diffraction limit?
For optics you tradiationaly use the Sodium D line (532nm) because before lasers it was the easiest bright monochromatic source.
The diffraction limit of the HST is different at each wavelength, the optics aren't necessarily diffraction limited at all wavelengths or the detectors have enough resolution to sample the diffraction limit.
Yeah, it apprears the detectors on WFPC2 can resolve down to 0.04 arcsec, given that lamda = 500 nm we get an angular resolution for the telescope itself at roughly 0.05 arcsec. The other camera appears to have much worse resolutions. Thanks!
Related to The diffraction limit of the Hubble ST
1. What is the diffraction limit of the Hubble Space Telescope?
The diffraction limit of the Hubble Space Telescope refers to the smallest details that the telescope can distinguish in an image. It is determined by the telescope's aperture and the wavelength of light being observed.
2. How does the diffraction limit affect the quality of images taken by the Hubble ST?
The diffraction limit impacts the sharpness and resolution of images taken by the Hubble ST. If the telescope's resolution is limited, it will not be able to capture fine details in an image, resulting in a lower quality image.
3. Can the diffraction limit be improved upon for the Hubble ST?
The diffraction limit is a fundamental limit based on the telescope's design and cannot be improved upon. However, advancements in technology and image processing techniques can sometimes help to enhance images taken by the Hubble ST.
4. How does the diffraction limit of the Hubble ST compare to other telescopes?
The Hubble ST has a smaller aperture than some ground-based telescopes, meaning its diffraction limit is slightly larger. However, the Hubble ST's location in space allows it to capture images with significantly less distortion and interference from Earth's atmosphere.
5. How does the diffraction limit of the Hubble ST affect its ability to observe distant objects?
The diffraction limit of the Hubble ST can limit its ability to observe very small, distant objects. However, the telescope's high resolution and sensitivity still allow it to capture incredibly detailed images of objects in the distant universe that would be impossible to see with ground-based telescopes.
