Energy balance from mechanical to electrical energy
In summary, the conversation discusses the equation of energy balance for a system involving a mass, flywheel, and DC motor. The equation takes into account the moment of inertia of the flywheel, angular velocity, and work done to overcome friction. The question is posed of what the equation would look like if a DC motor were attached to the flywheel to convert rotational energy to electrical energy. The formula for electrical energy is also mentioned. The objective is to minimize the final velocity of the mass to maximize the total electric energy. The conversation ends with a question about the energy balance equation in electric machines.
PhiliosKassin
A mass is winded via string aroung a flywheel and allowed to fall a specific height before detachement. The flywheel is connected to a small DC motor via gears and starts generating electricity once the mass is allowed to fall..
Now without the DC motor ( generator) the equation of energy balance is:
mgh = (0.5mv^2+ (0.5Iω^2) + ( 0.5Iω^2 x (n1/n2)
where I is the moment of inertia of flywheel and ω is the angular velocity ( which should be equal to the angular max velocity at point of mass detachment)
n1 = number of revs of flywheel before detachement of mass
n2 = number of revs of flywheel after detachement
the third term in the equation is the work done to overcome friction.
Now the question is :
What form is the equation going to have when a DC motor is attached to the flywheel to be allowed to transform rotational energy to electrical? mgh = ?
the electrical energy is in the form of UIt
It seems that one has to assume the friction is independent of the load.
Let n3 = number of revs of flywheel after detachment, and E = electrical energy.
I think it is not hard to see
E = (0.5Iω^2)(n2-n3)/n2
Is that what you are after?
Suppose the height of initial release of the mass minus the height of detachment is h. Then if the mass falls freely (without flywheel), the total kinetic energy of the mass is mgh = (1/2)mv2. But in the case where it is attached to the flywheel, its final velocity at point of detachment is v1. So its energy at release is now (1/2)mv12. So the missing energy is (1/2)m[v2 - v12]. This was all transferred to the flywheel.
If the flywheel were frictionless and the generator perfect, all the flywheel energy would be converted to electric power. All inertial energy remaining in the flywheel after release of the mass would also be converted to electric power. To maximize the total electric energy, the objective then is to make the final velocity of the mass v1 as small as possible. If the flywheel were massive and v1 were small, then the electrical energy would be nearly mgh. If mgh were expressed in joules, then mgh/3600 would be the energy in watt-hours, or in volt amp hours.
pls what is the energy balance equation in electric machines?
, where U is the voltage, I is the current, and t is the time. Therefore, the equation would be:
mgh = (0.5mv^2 + 0.5Iω^2 + 0.5Iω^2 x (n1/n2)) + UIt
This equation takes into account the mechanical energy of the falling mass (mgh), the kinetic energy of the flywheel (0.5mv^2), the rotational energy of the flywheel (0.5Iω^2), the work done to overcome friction (0.5Iω^2 x (n1/n2)), and the electrical energy generated by the DC motor (UIt). The addition of the DC motor allows for the transformation of mechanical energy into electrical energy, which can then be used for various purposes. This highlights the principle of energy conservation, where energy cannot be created or destroyed, but can only be transformed from one form to another.
FAQ: Energy balance from mechanical to electrical energy
What is energy balance?
Energy balance refers to the concept of the conservation of energy, which states that energy cannot be created or destroyed, only transformed from one form to another. In the context of mechanical to electrical energy, it refers to the balance between the amount of mechanical energy put into a system and the resulting electrical energy output.
How is mechanical energy converted to electrical energy?
Mechanical energy can be converted to electrical energy through the use of a generator. This device uses the principles of electromagnetic induction to convert the rotational motion of a turbine or other mechanical source into electrical energy.
What factors affect the efficiency of energy conversion?
The efficiency of energy conversion from mechanical to electrical energy can be affected by a variety of factors, including the type of generator used, the speed and force of the mechanical source, and any resistance or friction in the system. Additionally, the materials and design of the generator can also impact its efficiency.
Can energy be lost during the conversion process?
While energy cannot be created or destroyed, some energy may be lost during the conversion process due to factors such as friction, heat, and resistance. This loss of energy may result in a lower overall efficiency of the conversion process.
How is energy balance important in sustainable energy production?
Energy balance is crucial in sustainable energy production as it helps ensure that the amount of energy put into a system is equal to the amount of energy output. This balance is necessary to maximize the efficiency of energy conversion and minimize waste, which is vital in promoting sustainable energy practices.
