Race cars - Torque vs Hp - The Undiscovered Country (for many)
In summary: Yes, but to make your comparison (the graph later) you have to ignore any mechanical advantage. The correct comparison for what you want is chassis dyno info (it makes no difference really from your engine graph, but it seems silly to discuss forces at the tire with flywheel data), which is done in a 1:1 gear ratio.Many different types of race cars have all sorts of engines. some with high torque and some with low torque, even some of those might have equal HP output. Since HP is a rate of doing work, a rate of change of kinetic energy, if a two cars were to be compared and both had the same HP, yet one had half the torque output, if their HP curve
zanick
383
23
We have some unbelievable discussions regarding the acceleration of race cars.
At first glance, many just look at what they remember, F=ma and go on long rants regarding engines that have high levels of torque. However, even when you rearrange the term to a=F/m, its still a Force at the tires that causes acceleration, not at the engine before the gear box.
Many different types of race cars have all sorts of engines. some with high torque and some with low torque, even some of those might have equal HP output. Since HP is a rate of doing work, a rate of change of kinetic energy, if a two cars were to be compared and both had the same HP, yet one had half the torque output, if their HP curve shapes were the same, the rate of acceleration at any vehicle speed would be the same. Correct?
This rate of acceleration is proportional to Power at any vehicle speed. (all other things being equal, such as the car's weight, speed)
Acceleration=Power/(mass x velocity)
Can you guys here enlighten the folks in the racing community regarding equations for acceleration of a race car and the relationship of their engines torque output to the torque and force found a the wheels to accelerate it at any vehicle speed, anywhere on the track.
I posted a set of engine HP/torque curves that showed that even with lower engine torque values, one engine can produce more rear wheel torque and force at any speed, because its HP curve was boader. Not the rule, but the exception that a good percentage of the racing community cannot accept.
Here is the graph that was posted based on the original question, "What would be better on the race track if the two engines in question, both had the same HP but one had more torque than the other. " From the data provided from this person posing the question, I put it in a graph and looked like as follows:
There is a reason I don't participate in these types of discussions on the automotive forums that I used to, or still do frequent. It's a waste of time. The people who understand have no interest in participating. The ones who are uneducated and believe the answers can be found in a handful of numbers are drawn like moths to a flame, and for the most part will resist anything different.
You demonstrate later in your post that you know peak numbers don't mean much, so why do you allow yourself to use peak numbers to describe entire curves here? This mistake is the same one that you are arguing against with your car buddies.
What you would be concerned with as far as HP curves for equal acceleration would be the area under the curves being equivalent. This could be done either by having the exact same curve shifted along the rpm axis (accounting for differences in peak torque), or with a different curve that has the same area below it (allowing for more narrow or broad rpm ranges).
I understand what you mean, but again your wording is poor. The difference in torque at the flywheel and the wheels (in 1:1 ratio) is simply a difference of drivetrain losses and will not change. HP is a function of torque and rpm and therefore you can supplement lower torque with higher rpms. Again, the important thing will be area under the curve.
That's all I have at 4:30 AM :zzz: . I'm trying not to be overly critial of your post because you recognized an important concept about the curves whereas most never will. Try not to concern yourself with what others on the internet don't/can't understand.
All you really need to do with engine torque is multiply it by the gear ratio to get the torque at the wheels, then divide by wheel diameter to get the force.
Thanks for the response. Actually, I could have been more clear. the curve I posted was set from the guidlines of one of the posters on that discussion. IT IS REAR WHEEL HP AND TORQUE values. It would open an entire set of variables if we start talking gear box efficiencies, etc. I used the peak torque and HP, because those were the only requirements, making it easy for me to debunk the idea that engine torque matters at all as a judging value. am I correct in saying that the HP at any vehicle speed will determine the rear wheel torque and thus forces if the tires are the same diameter? I think so and its been the the foundation of the argument. In otherwords, it doesn't really matter what the engine torque peak or value is, if the HP is the same at any vehicle speed. (meaning the shape of the HP curve is the same for both) then, both vehicles will acceleratae at the same rate at any vehicle speed.
I used the flywheel data, as measured at the rear wheels by a dyno. we have to assume that the gear rations of the comparison for the two engines of equal HP, will be adjusted to have the same final vehicle speed at each maximum rpm point on the engine, AND the same % rpm drop for each shift, to keep the argument centered around what the accelerative potential is of the two engines.
sure, we need to look at the optimal use of HP to create the maximum amount of HP available to the rear wheels, using gear box ratios. I don't think this is done by looking at the area under the curve, because wouldn't the time spent at the different HP levels be more accurate? So, I start thinking in terms of "HP-seconds", unit measures of work, because at the higher rpm levels, near maximum engine speeds, the acceleration rates will be less and more time will be spent at those levels. I know the concepts are simple, but the application is relatively complex, correct. you have variable power on the curve, non-constant jerk, (is that a term?) and a host of other variables we are not even talking about regarding the acceleration of a vehicle on a race track.
Getting back to your last paragraph about my wording. maybe i wasnt making my point well enough. my point was that the engine power determines rear wheel torque as it is multiplied through the gear box at any vehicle speed. sure engine torque will be multiplied through the gear box to get rear wheel torque based on the reduction ratios for a given speed. So, as an example, if both cars are at max hp, the rear wheel torque will be the same, even if the engine torque is 1/2 for one vs the other. (because the rpm are traded off for gear reduction). of course it is consistant with the equation, Acceleration = power/(Mass x velocity) where the power determines the acceleration rate at any vehicle speed, not the engine torque numerical value.
Thanks for the replies
Mk
Yeah, I think they all get this, but some how can't get their arms around the power being the driving factor. The main point here is that torque is a factor of power. power determines what torque you are going to have available at any vehicle speed. Seems most get it backward, after all power is the rate of doing work. heck, force is just a factor of work.
What is the formula for acceleration of a mass over a speed range based on power?
since power is the rate of change of kinetic energy, Is there a formula that ties the two together in one neat equation?
Thanks,
Power in watts = torque (in Newton-meters) times RPM x 2 pi/60
power in HP = power in watts/746
So a torque of 300 Newton meters at 6000 RPM is 188,500 watts or 253 HP. Getting the right torque to the wheels is selecting the right gearbox ratios.
If torque is in pound feet, multiply by 1.356 to get Newton meters:
So a torque of 300 pound feet is 407 Newton meters
407 Newton meters x 6000 RPM x 2 pi/60 = 255,700 watts = 343 HP
Im not sure what your point is below. You just gave he difference in power output using the same rpm but different amounts of torque (i.e 300ft-lbs is different than 300NM)
The point of all this is that with the same power output, the rear wheel torque at any speed on the road will be the same. true? Power dictates power to the rear wheels at any vehicle speed. Obviously, engine torque is going to change inversely with RPM needed to acheieve the same vehicle speed, if both cars have the same power output at any same vehicle speed.
For example, if we have a total gear ratio of 8:1 for a high torque engine (most first gears of most cars) and have the same size diameter tires, at 300hp, and 300ftlbs of torque at 4000rpm, i would have 2,400ft-lbs of torque at the tires. A same hp 300hp car with 150ft-lbs of engine torque and 8000rpm would have 2,400ftlbs of torque because it would be running a 16:1 gear ratio in that same gear. All other gears would follow suit, because the RPM drop % would be the same (very common) and the HP curve shape is the same.
In some cases, the curve might be more optimal if broader for a lower torque engine, so it would have more accelerative forces at any vehicle speed. this is the crux of the argument
I'm trying to show those with a little less basic physics 101 knowedge than I have :), how acceleration is determined by HP available, not engine torque at any same speed.
With distilling out a couple of Newtonian identities, a=F/M and P=Fv, I use a=p/(mv) to show that acceleration is proportional to power at any same vehicle speed. (and same car ).
This isn't going over well with folks that think and say "Torque gets you out of turns and hp gets you down the straight". :)
Thanks for the comments!
You are confusing and misusing terms, as I tried to be polite about in my first post. HP is a function of torque and rpm, period. There is no way for two equivalent HP values at different rpms to have the same torque. If you are considering your graphs to be at the wheels, then you already know exacty what the torque is at the wheels.
I know what you are trying to say, but you are doing a poor job of it and as is it is technically incorrect. I was trying not to focus on that, as it is not what is really important at this point.
Dont worry, I am conferring with you guys because I want it to be technically correct. so, I appreciate the input. If you read what i wrote again, you can see that I said that two cars with equal Hp, one having more "Engine" torque than the other, will still produce the same rear wheel torque or rear wheel Force (as measured after the gear reductions) at the same vehicle speed. (since we use 24" diameter tires, the force would be equal to the torque found at the rear wheel input shaft :) )
Maybe its confusing because there are two types of rear wheel torque. Rear wheel torque that is calcuated by the dyno, relating to flywheel torque, and the rear wheel torque that is responsible for the rear wheel force on the pavment. I'm trying to be clear with the two, and is why I say, "Rear wheel torque, as multiplied through the gear box", when I am speaking about the end force that is developed at any same engine HP level. So, when I say, "Engine HP determines rear wheel torque" I'm saying that Engine HP detrermines Rear wheel Forces at any vehicle speed.
Again, the terms are:
Engine HP= obvious
flywheel HP= obvious
Rear wheel Hp= that which is measured at the dyno
Rear wheel torque= that is which is measured at the dyno,but relates to torque at the flywheel as measured and calculated at the rear wheels using engine RPM
Rear wheel torque/force= that which is found at the rear wheels as acting on the pavement. This value is engine torque multiplied by gear ratios at any given vehicle speed. Maybe this should be called "Wheel Force" and forget about torque as it can be confused with rear wheel torque that the dyno calculates.
So, with your first objection, I'm talking about the same HP of two engines making the same rear wheel torque. (the 2,400ft-lbs value) made up from either 300ft-lbs at the engine at 4000rpm or the 150ft-lbs made by the other engine at 8,000rpm. Both engines have the same HP output at that vehicles same speed, and thus will have the same rear wheel forces acting on the pavement.
If there is a better way to explain this, I surely would like to hear it. Its all in an effort to show that power of the engine determines acceleration at any same vehicle speed.
Is ok, I have a thick skin. I want to be techically correct and explain it in a way that is not confusing.
Thanks
Going back to your first post:
From the equation that relates torque and horsepower, getting half the torque at the same horsepower requires double the rpm. You tell me - does a car that requires double the rpm to generate the same horsepower accelerate slower or faster?
Or perhaps more telling: if these two cars get the same horsepower, torque, and acceleration at a given speed (their hp to the wheels is the same) and to do that, one has to operate at twice the rpm, what does that tell us about the horsepower at the engine?
And unless one car redlines at twice the rpm as the other, what does that tell us about their max hp and max speed?
WE need Mike in here.
With regard to one of your questions in the OP.
The one with more torque, torque adds drivability to an engine. Thats an easy question to answer.
But what if the question was "What would be better on the race track a turbo 4pot 500HP with 200Nm (avg) torque, or somewithing like a v8 with 450HP and 350Nm (avg) torque (these are figures I just plucked out of the air)"
The answer would depend on, what's the track, what's the gearing of both cars, how good is the driver etc etcetc. In this case its not as simple as the first, as the car with more torque would accelerate harder in any given gear lower down, but has less ultimate grunt, the engine would feel 'torquey'. Its also importent to remember that the higher torque gives an 80% max power reading across a wider rev range, increasing drivability.
With the other engine, all the power and acceleration comes at he top end. However this isn't as bad as it seems for acceleration as some of this low down loss can be eiminated with clever selection of gears.
So what would you want here. If the track had long open straights, and relatively few slow corner to fast straight, you'd be better with the HP of the turbo 4pot. If the track had lots of slow corners mid length strights you'd want the extra torque of the v8 for inital acceleration.
I'll try to find a nice link that explains this better.
In the way you're asking about this, it doesn't really matter. Assume that the horsepower versus RPM curves look the same, with the only difference being the rpm scale at the bottom of the chart. Say the chart for the higher torque engine shows rpm from 0 to 5000 rpm, spaced 1000 rpm per inch across, while the one for the lower torque engine shows rpm from 0 to 10000 rpm, spaced 2000 rpm per inch across. If the curves appear to be the same, then the performance will be the same. If you then overlay these charts with torque versus rpm, then the first torque curve will be twice as high as the second torque curve, but as you stated, the actual torque curve doesn't matter, it's the power curve.
The shape of the torque curve matters, but this would show up in the power versus rpm curve.
Eh... Jeff that's not really comprehensive.
Are you saying if the power curves look the same it'll go the same?
Edit: also people don't take into account the fact that its the gearbox that's the critial factor of how the engine power gets put down. All people seem to talk about is single value readings, this is a horrible way of determining performance.
I don't agree, but the difference might be in the testing...
Yes, assuming one can top out at a much higher rpm than the other.
But what is being tested to get that curve? Are we talking about a car sitting on a dyno in first gear? Do they usually go through all the gears? Or is this just the engine output curve?
-If it is the engine output curve, then the one that operates at lower rpm has lower drive losses and performs better when installed in a car.
-If this is a dyno run in 1st gear and the curves produced are identical except for the engine rpm scale at the bottom, drive losses decrease as you go through the gears, so the car that operates at higher engine rpm accelerates faster...and generates more horsepower at the wheels than the other engine, as both accelerate.
As with a lot of questions, most of the problem here is with the question being not specific enough. If you make the question specific, the answers are pretty straightforward - these are relatively simple issues.
Normally you'd do a dyno test (all the ones I've done) with as close to 1:1 drive through the gearbox as possible (usually 4th gear). Yes I know about the final drive at the diff, I don't really know why, i'd guess its so it doesn't rev up to the limiter too quickly.
The reason the gear closest to 1:1 ratio (usually 4th gear) is chosen, is that normally the drivetrain losses are less in that gear than other gears.
Going back to my point about power versus rpm curves, assume that the dyno power curves (force versus speed) are the same. The car with the lower torque, double the rpm engine, would have a final drive ratio with twice the reduction factor.
I think the real issue here is the shape of the power or torque versus rpm curve. Generally more power can be acheived with a peakier curve, at the sacrifice of a smaller rpm range where that high power is acheived. The spacing between gear ratios and shift speed are factors in how narrow the powerband can be. Formula 1 cars have 7 closely spaced gears, with computerized shifts that take 30ms to 50ms, so a fairly narrow power band can be used. A race car with fewer gears and a larger spacing between gear ratios will need a wider power band. Nascar race cars are only allowed 4 gears for example, and they run at a few road courses, like Infineon, each season. In race classes where computerized shifting isn't allowed, shift times become significant, and translate into fewer and wider spaced gearing.
On a side note, with improvments in metal alloys and engine design, piston speeds in sport vehicle engines have increased to result in more power, especially motorcycles. The Corvette Z06 has a 7 liter (427.6 in^3) engine that redlines a bit over 7000 rpm, to provide a minimum (SAE) of 505 hp at the flywheel, translating into 440 hp a the rear wheels (the average is more like 450 rwhp). Note the Z06 engine is liter than the turbocharged Porsche 911 3.6 liter engine (480 hp for turbo 911, 530hp for the GT2), and gets better gas mileage.
In the case of motorcycles, a 1 liter road racer replica will have about the same 1/4 mile performance as a 1.3 liter superbike (Hayabusa), but the 1.3 liter bike gets 80% of peak torque for the upper 2/3rds of it's rpm range, while the 1.0 liter bike gets 80% of peak torque only in the upper 1/3rd of it's rpm range, half the powerband width. When crusing on a freeway at around 65mph, in top gear (6th), the liter bike won't be able to accelerate as fast as the superbike (1.3 liter engine) without downshifting to get the rpms up. In the case of Suzuki, the 1 liter engine redlines at 14,000 rpm, while the 1.3 liter engine at 11,000 rpm.
Hmm thinking about it, that's obvious really as the 4th gear locks the input and output shafts. Bit of a brain fade moment :P
Not in the case of a manual transmission. It's just another pair of gears, in this case equally sized gears that generally have a bit less power loss than the other gear combinations. Motorcycles transmissions never bother with this, losses with a tranny and chain drive are about 8%.
Strength of the gears is a factor in determining gear ratios. The bigger the difference in gear size, the less contact (fewer gear teeth engaged) between gears. To compensate the gear widths are varied. Back in the 70's and 80's rear end ratios were less than 3.00, and first gear ratio over 3.00, but since the 1990's, this was swapped to reduce gear width in the trannies of the higher powered cars (Z06, Viper) to allow more gears (6 instead of 4) and to be able to handle more engine torque. Using the C6 Z06 as an example, 1st gear ratio is 2.66, while the rear end ratio is 3.42.
In MT it locks the shaft. The layshaft isn't used so it has to.
EDIT: most the gearboxes I've seen have run direct drive as its better then running a ratio of 1:1
I forgot that some MT's still lock the shaft. I doubt racing cars transmissions do this though. I don't think the Tremec T56 or T6060 do this either.
Yeah, i'll admit I don't know a super amount about racing boxes. Its been a while since I've done anything with transmissions.
Getting slightly back on topic. I'm glad this thread has swung around to what really matters for acceleration. The gear ratios! Yes peak torque and peak horsepower figures are great for willy waving in the paddock, but careful selection of gear ratios and usefulness of the powerband is king.
Sorry about that, I left out that detail. Yes, the rpm would obviosly have to be a variable. we would be trading rpm at any vehicle speed, for lower torque, and the gear ratio would be proportionally changed as well.
mk
russ_watters said:
Going back to your first post: From the equation that relates torque and horsepower, getting half the torque at the same horsepower requires double the rpm. You tell me - does a car that requires double the rpm to generate the same horsepower accelerate slower or faster?
Actually, that's why I came to you guys.
First of all, the hp curves would be the same shape. even though one had a 8000rpm redline vs the other at 6000rpm, the HP curves being the same shape, would create the same exact rear wheel forces at any speed on the track. coming off a turn, down a straight , anywhere. This is because the HP curve is the same shape. Think of the gear ratios as the same speeds in each gear. (e.g. 50mph 1st, 80mph 2nd, 120mph 3rd, etc)
this way, the gear spacing is the same and the only difference is the numerical torque values at the engine. at the rear wheels, since HP is determining the rear wheel force at any vehicle speed, the torque or force would be the same.
what I am asking is how do we explain this so it is easy to understand and fight the perception that the greater engine torque will be "stronger" off a turn, or the higher rpm engine is better down the straight. :)
Thanks
Mark
I think you got it, exactly right. Now if I can get the terminology down, it might be better to explain. One of the things I struggle with is the comparing of different HP curves. if the HP curves have the same area under the curve (integration), it doent mean it will move the mass at the same acceleration rate at a given speed. Its a matter of what I call, Hp-seconds, or watt-seconds. obviously, its better to have the higher hp at the top of the HP curve at the higher speeds, because more time is spent there in accelerating over the operational speed range in each gear.
Mark
I don't get your last statement, why would we want to fight the perception of toruqe being better off the turn and power down the straight when that is correct?
You are saying the curves look the same but one goes to a higher RPM and produces the same power then by definition they don't look the same.
You don't integrate the HP curve, that would be pointless. For the work acutally done you'd integrate the torque curve.
I think he is and he is right. But, I will say the gear box is important, but we are assuming same gear spacing and same MPH speed in each gear. even if they were not the same speed in each gear, the differences are subtle and are trade offs. IN fact, any change might favor one track, while being not optimal on an other. Gear boxes don't create hp, they just optimize the HP available for a given speed range.
mk
mk
All of your statemnts so far have been riddled with things that are contradictive and incredibly confusing.
If you set the gear ratios the same, and you have more torque with one engine you will get a higher mph for that given gear.
As Jeff said, dynos are done in a few of the top gears to avoid wheel spin. usually, 3rd or 4th gear. This just gives the rear wheel HP and calculated engine torque values. Now, if ths same car had a different engine and transmission installed and it did the same test, in its 4th gear, but the ratio was higher due to the proportionally higher rpm, due to the lower engine torque, the power would be the same, and the acceleration of the vehicle would be the same. I wouldn't expect the effeciency to be less in lower gears. if there was a difference, it would be canceled out by the fact that the initial dyno runs used proportionally different total ratios, even if it was 1:1 in the gear box, the final drive is likely 2-4:1 additioally.
What we are looking for is the correct terminology to explain to folks that still confuse engine torque with rear wheel forces and torque though the gear box.
We know that Acceleration = Power/(mass x velocity), so acceleration is proportional to power at any vehicle speed. This also indicates that power will also determine rear wheel torque , or longitudinal force at any speed as well. How do we say this?
mk
russ_watters said:
I don't agree, but the difference might be in the testing... Yes, assuming one can top out at a much higher rpm than the other.
This is getting slightly out of hand with multiple different replys going on at the same time, and I think we need to go back to square one. Can you restate the question you want answered. Preferably in 2 scentences or less.
And what do you think a dyno acutally measures? The variables.
well, certainly it matters what the HP curve looks like, but the torque curve, (if we are talking about different engines, like 4 bangers vs z06 vet 7 liters and 6 bangers.) is not usefull for a couple of reasons. First, its not even an indication of performance, as most of the time, the operational range of an engine will be between 4500rpm and 6500rpm for a V8. at 5250rpm, the torque is heading down anyway, and discounts all the "flat torque curve talk". in fact, the porsche GT3 has the peakiest HP curve you would ever see, but the torque is a flat 275 from down low almost until the top rpm :).
I have two engines that have the same hp, one with 65ft-lbs more than the other. their HP curves are close, but the lower torque , higher rpm engine has a more broad HP curve. It actually would put down more rear wheel forces at ANY vehicle speed, anywhere on any track. How do we convey this to the "torqueez" out there? they still think in that case, the higher torque engine has more "grunt" off turns, yet on the dyno runs, the curves show that even at the lower rpm, the lower torque engine has more HP or at least the same.
How do we say, "HP determines rear wheel torque at any vehicle speed"?
also when looking at different shapped HP curves, how do we talk about the differences in time spent at the different segmements of speed in any individual gear? watt-seconds? HP-seconds? what makes the most sense?
Thanks,
Mark
  • #31
I said same MPH range in each comparable gear. (each gear might be a 27% rpm drop for each shift ) This means the actual ratio will be in proportion to the increased or lower rpm levels to reach that same MPH range in each gear.
mk
  • #32
Well, I think we are getting somewhere now. yes, the curves "shape" look the same (same shape over the rpm range used)
why do folks always talk about area under the HP curve (which is integration of the curve, correct?)
It seems that intgrating the torque curve would be pointless, as at the engine, without knowing final drive ratios, you would end up with nothing useful, correct? However, if you could integrate the torque curve at the rear wheels , AFTER the gear ratios, so you could get value of work done, correct? I would think that the HP curve integration would give an average power, and if you have time tied to it, (something like watt-seconds) you could get an idea of work done that way as well. This is the part that is causing the most confustion.
Thanks,
Mark
  • #33
It acutally seems we're getting nowhere. You seem obsessed about the shape of the HP curve. What governs the shape of the hp curve.
What does a dyno measure?
  • #34
Sorry, didnt see this post until I had answered the others.
the dyno measures the rate of change of kinetic energy. (by knowing the change of speed of the drum and the weight and size of the drum). without a spark (rpm) signal of the engine, the output is only power vs MPH. I suppose it could produce rear wheel forces, but it doesn't output that. the engine rpm could be 3000 to 6000rpm or 6000rpm to 12,000rpm. once you have a spark signal, the dyno then outputs an engine torque value.
The question is how to we describe engine power determining rear wheel torque, as found at the rear tires at any vehicle speed.?
When comparing two equal HP engines, but one has more torque than the other, it can depend on the shape of the HP curve in determining which one will develope more accelerative forces at the driving tires. I am asking what is the proper way to describe this reality?
why wouldn't the area under the HP curve or getting a HP-seconds, or watt-seconds value to determine which Hp curve is more optimal for acceleration based on different shapes.
Thanks for being patient and helping out here.
Mark
  • #35
We're going to have to deal with this one question at a time I'm having trouble following many mish mashed questions at one. Sorry to be a bit pedantic about this, but following your reasoning is very difficult.
You haven't clearly stated what the dyno measures. Does it measure the torque or horsepower that the engine puts out?
