Loading 2D array files to Fortran variables
In summary, The conversation discusses the issue of opening and storing the contents of data files created by compiling and running a C++ code in Fortran 77 variables. The speaker is having trouble with using the read command to retrieve the values stored in the file, even though the file contains 2003 lines and 53 columns of data. They have tried different formats and have received various iostat values, but the array still contains only zeros. The expert advises checking the format of the data and the compiler being used. The conversation also includes sample data and code for further analysis.
mrz1982
Hi,
I have created data files by compiling and running a c++ code. Now I
need to open and store the contents of these files in Fortran 77
variables. But I am not able to do this. The read command does not
return the values stored in the file.
The files are having some 2003 lines and 53 colomns. The values are in
the form "2.885531e+002" (positive) and "-7.687902e+001" (negative)
with 1 space seperating different values.
Thank you in advance!
/Z
Technology news on Phys.org
Can you show us the code that you tried to use for reading the file?
The entire code is very long, so I will only write the part where the file is opened and read. I have tried many different formats, here is the last format I tried with:
REAL EVg(2003,53)
open(1,file=''test.txt'')
read(1,10,iostat=k) EVg
10 format(53(G7E3,1X))
close(1)
the iostat has returned different values (-1, 0, 115, etc.) for different format cases I have tried. For the case above it returns 0, but the "EVg" array does not contain the array values.
It's been a long time since I had to deal with this sort of thing, but as I recall, the basic principles are these: (1) When the number of values to be input exceeds the number of specifiers in the format statement, the format simply repeats itself. (2) All data in a single input statement is assumed to be on one line, unless the format specifies otherwise.
So I think your program is trying to read the entire array from the first line of the input file. Try adding a slash at the end of the format, which should skip to the next line:
10 format(53(G7E3,1X)/)
This may still give you problems if the file doesn't have a blank space after the last number on each line.
Also, I don't remember a format specifier like "G7E3", but my Fortran experience ended with Fortran 77.
I don't either.
In fact, the enhanced format specifiers (E,F,G) are mostly for displaying pretty output.
For input, an E,F, or G specifier will accept both 123456.78 or 1.1234E6, as shown in the following example code. The input I gave was 1.123456E+012 1.123456e+013 .
The output was printed correctly.
Code:
C test fortran format
      REAL*8 A,B
      READ(5,1)A,B
C   1 FORMAT(2(F13.6,1X))
C   1 FORMAT(2(E13.6,1X))
    1 FORMAT(2(G13.6,1X))
      PRINT *,A,B
      STOP
      END
Do not forget the extra space at the end of the line, it is required.
If you still have problems, post a few lines of your input, using the code option so we see exactly how the data are laid out.
Also, check if the spaces between the data are aligned. The format above expects them to be aligned. If you have a problem with data alignment, write a c-program to read in and write them out aligned. That would be easier to do to figure out how to read it using free-format input.
Thank you for your response!
I should maybe add that I am working in Fortran 77 environment (due to limitations).
The data in the files basically look like:
Code:
+0.000000e+000 -7.281896e+002 -1.791944e+003
+0.000000e+000 -7.856508e+002 -1.824643e+003
-1.325604e+005 -8.411246e+002 -1.856220e+003
this is taken from somewhere in the middle of the file, at another place it looks like:
Code:
-1.045771e+005 +1.047517e+004 -1.180211e+003
-5.662817e+004 +1.152035e+005 -1.173054e+003
+1.187847e+004 +2.266384e+005 -1.165909e+003
as you can see the data are (now) aligned, (as I added '+' in front of positive values) and the extra space at each line end is there. There is also an line termination after the extra space of the last line.
The file reading procedure:
Code:
REAL EVg(2003,53)
10 format(53(E13.6,1X)/)
close(1)
returns k=0 and EVg a matrix of zeros.
Indeed, an error in the format will cause the numbers read into become zeroes.
Using the following code:
Code:
C testREAD fortran format
      REAL*8 EVg(6,3)
      open(1,file='testread.dat')
      DO 5 I=1,6
    5 READ(1,FMT='(3E15.6)',END=15)(EVg(I,J),J=1,3)
   15 close(1)
      DO 20 I=1,6
   20 WRITE(6,FMT='(SP,3(1PE15.6E3))')(EVg(I,J),J=1,3)
      END
and reading the six lines you supplied from a data file, I obtain the following output:
Code:
+0.000000E+000 -7.281896E+002 -1.791944E+003
+0.000000E+000 -7.856508E+002 -1.824643E+003
-1.325604E+005 -8.411246E+002 -1.856220E+003
-1.045771E+005 +1.047517E+004 -1.180211E+003
-5.662817E+004 +1.152035E+005 -1.173054E+003
+1.187847E+004 +2.266384E+005 -1.165909E+003
Hope that helps to solve your problem.
I have now tried with the following (on a somewhat smaller file [2001][12]),
Code:
open(1,file="test.txt")
DO t=1,2001
READ(1,'(12E14.6)',iostat=ios)(EVg(t,x),x=1,12)
ENDDO
close(1)
DO t=1,2001
WRITE(6,FMT='(SP,12(1PE15.6E3))')(EVg(5,x),x=1,12)
ENDDO
The iostat returns -1, if I change the format to
Code:
'12(E14.6,1X)'
as it should be iostat returns 100.
For both formats I still get a EVg to be an array of 0's.
Can there be a problem with the compiler I am using? I am using the "mingw32-make.exe" which runs a "g77 -c -O2 fortran.f" and a "g77 -s -o file.exe dimdef.o newmods.o comtac.o fgnmod.o usernl.o analyt.o devt69.o usrfun.o hopcod.o user10.o tpbig.a dislin.a -luser32 -lgdi32 -lcomdlg32".
I cannot pronounce anything until you show the actual data you are using with 12 numbers on the same line. In Fortran, the size of each field is important. Even an extra space at the end of the line could be significant. The number of lines is not important in this case.
If you could post 4-5 lines of data, then I'll see how the data fits in with the format.
If we don't find anything there, then we may have to worry about the compiler.
Here are 5 lines taken from the middle of the data file:
Code:
+1.670000e-006 +0.000000e+000 -8.540156e+006 -1.585399e+003 -2.243492e+003 -2.763622e+003 -3.142946e+003 -3.299538e+003 -3.304998e+003 -3.342794e+003 -3.706140e+003 -4.368216e+003
+1.680000e-006 -9.375357e+004 -8.037304e+006 -1.612638e+003 -2.255844e+003 -2.763778e+003 -3.130649e+003 -3.279551e+003 -3.282095e+003 -3.319731e+003 -3.677900e+003 -4.360687e+003
+1.690000e-006 -2.859594e+005 -7.588826e+006 -1.639665e+003 -2.269052e+003 -2.765124e+003 -3.119963e+003 -3.261429e+003 -3.261483e+003 -3.300265e+003 -3.655372e+003 -4.347075e+003
+1.700000e-006 -6.289417e+005 -7.239074e+006 -1.666989e+003 -2.283188e+003 -2.767609e+003 -3.110709e+003 -3.244538e+003 -3.242276e+003 -3.283470e+003 -3.638555e+003 -4.326224e+003
+1.710000e-006 -1.137889e+006 -7.009578e+006 -1.694831e+003 -2.298037e+003 -2.770898e+003 -3.102424e+003 -3.228056e+003 -3.223421e+003 -3.268063e+003 -3.626592e+003 -4.298185e+003
It is a space after the last values of every line (the option apperently removes extra space after the last value).
Sorry it took a little more time than I thought would take, but I have remodelled the program to make it a little more general in order to read in a variable number of lines and fields. It seems to read in and write correctly.
You could try with this new version and make adaptations required for your purposes:
Code:
      REAL*8 EVg(5,12)
      CHARACTER *20 READFMT
      CHARACTER *25 WRITEFMT
      NLINES=5
      NFIELDS=12
      WRITE(READFMT,'(1H(I2,5HE15.61H))')NFIELDS
      WRITE(WRITEFMT,'(4H(SP,,I2,12H(1PE15.6E3)) )')NFIELDS
      PRINT *,READFMT,WRITEFMT
C     (12E15.6)           (SP,12(1PE15.6E3))
      OPEN(1,FILE='testread.512',FORM='FORMATTED',IOSTAT=IOS,RECL=181)
      IF(IOS.NE.0) THEN
        PRINT *,'ERROR IOS=',IOS
        STOP
      ENDIF
      DO 5 I=1,NLINES
      READ(1,FMT=READFMT,END=15)(EVg(I,J),J=1,NFIELDS)
    5 CONTINUE
   15 close(1)
      DO 20 I=1,NLINES
      WRITE(6,FMT=WRITEFMT)(EVg(I,J),J=1,NFIELDS)
   20 CONTINUE
C     FORMAT(SP,12(1PE15.6E3))
      STOP
      END
Output:
Code:
+1.670000E-006 +0.000000E+000 -8.540156E+006 -1.585399E+003 -2.243492E+003 -2.763622E+003 -3.142946E+003 -3.299538E+003 -3.304998E+003 -3.342794E+003 -3.706140E+003 -4.368216E+003
+1.680000E-006 -9.375357E+004 -8.037304E+006 -1.612638E+003 -2.255844E+003 -2.763778E+003 -3.130649E+003 -3.279551E+003 -3.282095E+003 -3.319731E+003 -3.677900E+003 -4.360687E+003
+1.690000E-006 -2.859594E+005 -7.588826E+006 -1.639665E+003 -2.269052E+003 -2.765124E+003 -3.119963E+003 -3.261429E+003 -3.261483E+003 -3.300265E+003 -3.655372E+003 -4.347075E+003
+1.700000E-006 -6.289417E+005 -7.239074E+006 -1.666989E+003 -2.283188E+003 -2.767609E+003 -3.110709E+003 -3.244538E+003 -3.242276E+003 -3.283470E+003 -3.638555E+003 -4.326224E+003
+1.710000E-006 -1.137889E+006 -7.009578E+006 -1.694831E+003 -2.298037E+003 -2.770898E+003 -3.102424E+003 -3.228056E+003 -3.223421E+003 -3.268063E+003 -3.626592E+003 -4.298185E+003
Thank you, it is working now. I was stuck with these lines for more than 2 weeks... but now everything is working.
Glad that everything works out, come and visit us often!
Related to Loading 2D array files to Fortran variables
1. How do I load a 2D array file to a Fortran variable?
To load a 2D array file to a Fortran variable, you will need to use the Fortran "READ" statement. This statement allows you to read data from an external file and assign it to a variable. You will need to specify the file name, the variable name, and the dimensions of the array in the READ statement.
2. What is the format of a 2D array file for Fortran?
The format of a 2D array file for Fortran is typically a plain text file with the data organized in rows and columns. The values should be separated by spaces or tabs, and each row should be on a new line. The file should also include a header that specifies the dimensions of the array.
3. Can I load a 2D array of any size to a Fortran variable?
Yes, you can load a 2D array of any size to a Fortran variable as long as you specify the correct dimensions in the READ statement. Keep in mind that larger arrays may require more memory and can affect the performance of your program.
4. How do I handle errors when loading a 2D array file to a Fortran variable?
You can use the "IOSTAT" argument in the READ statement to check for errors while loading the array file. This argument will return a value of 0 if the file is successfully read, or a negative number if there is an error. You can then use an "IF" statement to handle the error accordingly.
5. Are there any other methods for loading 2D array files to Fortran variables?
Yes, there are other methods for loading 2D array files to Fortran variables, such as using the "OPEN" and "CLOSE" statements to open and close the file, or using the "GET" statement to read individual elements from the file. However, the READ statement is the most commonly used method and is recommended for loading larger arrays.
