Setting hbar = c = 1 how can you just do that?
  • Thread starter AxiomOfChoice
In summary: Oops, dropped a 4pi somewhere. When I'm getting a result... that's in coulombs. Oops, dropped a 4pi somewhere.In summary, the conversation discusses the concept of using a system of units where multiple fundamental constants, such as c and \hbar, are set to a numerical value of one. This can be achieved by choosing a unit of time and using it to determine units of length and mass, which then replace the traditional SI units of meter, kilogram, and second. This concept is known as Planck units or natural units. It is also mentioned that other fundamental quantities, such as electrical charge, can be included to create a unit system in
AxiomOfChoice
533
I can sort of understand working in a system of units where, say, either [itex]c[/itex] or [itex]\hbar[/itex] takes a numerical value of one. But I read a paper today where BOTH [itex]c[/itex] AND [itex]\hbar[/itex] were set to be 1. I confess I haven't thought about it very carefully...but could someone please help me understand how you can get by with that?
Basically, the way to come up with a system like that is to pick a unit of time, multiply by the speed of light to get a unit of length, and then just pick a unit of mass such that [tex]\hbar[/tex] is equal to the length unit squared times the unit of mass divided by the unit of time. These units of length, mass, and time replace the meter, kilogram, and second from SI.
In fact, I'll do you one better: imagine a system of units where [tex]c[/tex], [tex]\hbar[/tex], and [tex]G[/tex] (Newton's gravitational constant) are all equal to one! There actually is such a system of units, called Planck units or natural units. The fundamental quantities are the Planck length:
[tex]l_P = \sqrt\frac{\hbar G}{c^3} = 1.616\times 10^{-35}\ \mathrm{m}[/tex]
the Planck mass:
[tex]m_P = \sqrt\frac{\hbar c}{G} = 2.176\times 10^{-8}\ \mathrm{kg}[/tex]
and the Planck time:
[tex]t_P = \sqrt\frac{\hbar G}{c^5} = 5.391\times 10^{-44}\ \mathrm{s}[/tex]
Then the fundamental constants are
[tex]\hbar = \frac{l_P^2 m_P}{t_P}[/tex]
[tex]c = \frac{l_P}{t_P}[/tex]
[tex]G = \frac{l_P^3}{m_P t_P^2}[/tex]
If you're familiar with linear algebra, you can imagine units as vectors. Call the meter (1, 0, 0), the kilogram (0, 1, 0), and the second (0, 0, 1), and say that adding these vectors corresponds to multiplying units. Then you'll recognize that the units of the three constants [tex]\hbar[/tex], [tex]c[/tex], and [tex]G[/tex] form a basis of this "unit space," and that means you can use them to create a unit system in which the values of all three are equal to one. If you had three different constants which also spanned the "unit space," you could make a unit system out of those other constants as well.
That's one of the best explanations I've ever read. Thanks very much for your help!
Am I to infer from this discussion that the chances of finding a system of units in which *4* fundamental constants have a numerical value of 1 would be well-nigh impossible?
Depends on how mean I feel in my next publication.
This means also that e0u0 = 1. Perhaps the only thing that cannot be reset is the fine structure constant. In grad school, I relied on the multiplicative constants to help me keep track of units in my calculations. C'est la vie.
I seem to recall a story that Feynman routinely set h-bar to one in his calculations. Then if his final answer was off by twenty-seven orders of magnitude, he knew he was right. :smile:
Likes davidbenari
Fine structure constant is a unitless number, so it has the same value regardless of what units you choose. Anything else that's unitless is going to be the same in all unit systems.
Cool, thanks ;-)
As far as finding a system in which 4 fundamental constants have a value of 1... once you set hbar, c, and G to 1, you determine the value of all constants which have units involving only mass, length, and time. (Basically, you fix the 3D vector space of mass, length, and time units) But you could add in another fundamental quantity, for example electrical charge, and develop a unit system based on the Planck units (from my last post) and the elementary charge (a.k.a. magnitude of the electron charge).
You could even take it a step further, and develop a unit system in which the Boltzmann constant is equal to 1 (so you get a 5D vector space of mass, length, time, charge, and temperature)... I'm not sure if there are any others, though. At some point you run out of independent units to work with.
Not setting all that crap to 1 is one of the most difficult things about teaching!
Setting hbar = c = k_boltzmann = elementary charge = 1 is more true to the physics then carrying that crap around. There is only one unit: energy = mass = 1/distance = 1/time. We describe a physical quantity as having dimension N e.g. "these quantities have dimension 2, and these have dimension -2" instead of saying historical names of anthro-units.
On the other hand, setting them not equal to one (or at least writing them down explicitly) is tremendously helpful in figuring out where you've made a mistake in the math. When I'm getting a result that doesn't make sense, probably almost half the time I'm able to identify it quickly by looking for the line where the units are not balanced. When you use natural units you can't do that.
Likes nrqed
Related to Setting hbar = c = 1 how can you just do that?
1. What is the significance of setting hbar and c equal to 1 in a scientific context?
Setting hbar and c equal to 1 is a common practice in theoretical physics and other areas of science. It simplifies calculations by reducing the number of constants and units involved. It also allows for a more elegant and concise representation of certain equations and concepts.
2. How does setting hbar and c equal to 1 affect the units of measurement used in calculations?
When hbar and c are set equal to 1, they essentially become dimensionless quantities. This means that all physical quantities can be expressed in terms of a single unit, typically energy or mass. This simplifies calculations and allows for a more intuitive understanding of the relationships between different physical quantities.
3. Can any equation be rewritten in terms of hbar and c equal to 1?
In theory, yes. However, some equations may lose their physical meaning or become mathematically complex when expressed in terms of hbar and c equal to 1. It is important to carefully consider the implications of this choice before making any calculations.
4. Are there any limitations to setting hbar and c equal to 1?
While it can be a useful mathematical tool, setting hbar and c equal to 1 is not always applicable in all areas of science. In fields such as quantum mechanics and relativity, where these constants play a crucial role, it may not be appropriate to set them equal to 1. Additionally, some equations may lose their physical significance when expressed in this way.
5. Does setting hbar and c equal to 1 change the fundamental laws of physics?
No, setting hbar and c equal to 1 is simply a mathematical convention and does not change the underlying physical laws. It is a useful tool for simplifying calculations and making certain concepts more intuitive, but it does not alter the fundamental principles of science.
