Help Solving Equation with Matlab - Get Expert Advice Now!
  • MATLAB
  • Thread starter xuej1112
In summary, this conversation discusses the process of solving a mathematical equation using Matlab. The individual is seeking help with the boundary conditions and someone provides a code for solving the equation. The conversation also includes some additional information and code for calculating the values of the equation.
xuej1112
I am working for a week to solve this equation by matlab,but I am lose.I don't know how to process the boundary condition.
who can tell me some code for solving the equation like this?
View attachment Microsoft Word (2).doc
Thanks a million !
[tex]B_j^0 = 1 \qquad \hbox{(initial condition)},[/tex]
[tex]\frac{B_0^{i+1}-B_0^i}{k}+a\frac{B_1^i - B_0^i}{h} = 0 \qquad \hbox{(left boundary)},[/tex]
[tex]\frac{B_{n+1}^i-B_n^i}{h}=0 \qquad \hbox{(right boundary).[/tex]
yes, I know these are the boundary conditions.I mean that I don't know how to express them in the MATLAB program .
but thanks for your reply.
You'll have to specify them in the first time step, then change them according to the evolution of your program. That means modifying them after each step is calculated. Let [itex]u^i[/itex] be the vector of [itex]B_j^i[/itex] entries (j=1,...n), then
Code:
r = 0:h:r*
u = ones(n+1,1) % Initial condition
% Begin time steps
for i=1:m
    u(1,1) = u(1,1) - (a*k/h)*(u(2,1)-u(1,1)); % Left boundary condition
    u(2:n,1) = Matrix*u(2:n,1); % Matrix form of the PDE
    u(n+1,1) = u(n,1); % Right boundary condition
    v(:,i) = u(:,1); % This will create a matrix with the value of u^i in each column
end
Thank you so much! you a so kind!
I wrote some code this afternoon.but i think there is some thing wrong
r is the longitudinal coordinates, t is the x-coordinate:
dr = 0.01; %each depth step
Nr = 100; % Choose the number of depth steps
Nt = 40; % Choose the number of time steps
dt = (10*365*24*60*60)/Nt; %Length of each time step in seconds
T = zeros(Nr+1,Nt+1); %Create temperature matrix with Nz+1 rows, and Nt+1 columns
time = [0:120/Nt:120]; %120 months in 10 years
T(:,1) = 1; %Set initial condition
maxiter = 500
for iter = 1:maxiter
%Tlast = T; %Save the last guess
%T(:,1) = Tlast(:,end); %Initialize the temp at t=0 to the last temp
for i=2:Nt+1
T(1,i)=(1+dt/dr)*T(1,i-1)-(dt/dr)*T(2,i-1);
for j=2:Nr
depth_2D = (1/(2*dr^2)*dr*(j-1)+(1-dr*(j-1))/(2*dr))*T(j-1,i-1)-(1/(dr^2)*dr*(j-1)+dr*(j-1))*T(j,i-1)+(1/(2*dr^2)*dr*(j-1)+(1-dr*(j-1))/(2*dr))*T(j+1,i-1);
T(j,i) = depth_2D*dt + T(j,i-1);
T(end,i) = T(end-1,i);
end
end
end
As I told you before, the convenient way to do it is to express the system of equations in matrix form, i.e
[tex] B_j^{i+1} = \frac{\sigma_j k}{h} B_{j-1}^i + \left(1-\frac{2 \sigma_j k}{h^2}-\frac{\mu_j k}{h}-r_j\right)B_j^i + \left(\frac{\sigma_j k}{h^2}+\frac{\mu_j k}{h}\right)B_{j+1}^i,[/tex]
or in matrix form, let [itex]B^i = (B_2^i,B_3^i,...,B_j^i,...,B_n^i)^T[/itex]
[tex]B^0 = (1,1,...)^T, \qquad i = 0[/tex]
[tex]B_0^{i+1} = B_0^i+\frac{ak}{h} \bigl(B_1^i-B_0^i\bigr),\qquad j=0,\, i=1,...,m[/tex]
[tex]B_1^{i+1} = \alpha_1 B_0^i + \beta_1 B_1^i + \gamma_1 B_2^i, \qquad j=1,\, i=1,...,m[/tex]
[tex]B^{i+1} = \left( \begin{array}{cccccc} \alpha_2 & \beta_2 & \gamma_2 & 0 & 0 & \cdots \\ 0 & \alpha_3 & \beta_3 & \gamma_3 & 0 & \cdots \\ 0 & 0 & \alpha_4 & \beta_4 & \gamma_4 & \cdots \\ \vdots & & & & & \end{array}\right) B^i = \Lambda B^i,[/tex]
[tex] B_{n+1}^i = B_n^i,[/tex]
where
[tex]\alpha_j = \frac{\sigma_j k}{h},\,\beta_j = 1-\frac{2 \sigma_j k}{h^2}-\frac{\mu_j k}{h}-r_j,\,\gamma_j = \frac{\sigma_j k}{h^2}+\frac{\mu_j k}{h}.[/tex]
Now, the code should look like this:
Code:
u = ones(1,n) ; % Initial condition
MatrixLambda = something % Definition of Lambda.
for i=1:m
    u(1,1) = u(1,1) - (a*k/h)*(u(2,1)-u(1,1)); % Left boundary (j = 0)
    u(2,1) = a_1 u(1,1) + b_1 u(2,1) + c_1 u(3,1) % j = 1
    u(3:n,1) = MatrixLambda*u(3:n,1); % j = 2, ..., n
    V(:,i) = u(1:n+1,1); % Matrix V with the values of u^i in each column
end
To generate the matrix [itex]\Lambda[/itex], I recommend you to check the Matlab function diag.
Code:
help diag
Puff! Hope this helps.
thank u so mush!but I think my difference method is implicit difference that is:
[tex] B_j^i = \frac{\sigma_j k}{h} B_{j-1}^{i+1} + \left(1-\frac{2 \sigma_j k}{h^2}-\frac{\mu_j k}{h}-r_j\right)B_j^{i+1} + \left(\frac{\sigma_j k}{h^2}+\frac{\mu_j k}{h}\right)B_{j+1}^{i+1},[/tex]
so:
[tex]B^i = \left( \begin{array}{cccccc} \alpha_2 & \beta_2 & \gamma_2 & 0 & 0 & \cdots \\ 0 & \alpha_3 & \beta_3 & \gamma_3 & 0 & \cdots \\ 0 & 0 & \alpha_4 & \beta_4 & \gamma_4 & \cdots \\ \vdots & & & & & \end{array}\right) B^{i+1} = \Lambda B^{i+1},[/tex]
maybe this is a equation system
Why are you evaluating the PDE in [itex]t_{i+1}[/itex]?
because I use the implicit difference method.It is steady.So,maybe this is a equation system.
Why are you going backwards if you can go forward?
Thank you so much.
by the way,could I find the analyze solution of this equation by matlab?
What exactly do you mean?
You want plots and stuff?
I did sort of the same thing for my undergraduate thesis, but my pde was nonlinear, so I had to use the Crank-Nicholson scheme (basically the same thing you did), that's why I was able to help :).
thank you man! I am just back from norway.
I tried the code you give me,but it is not work.
The following is the code,could you help me to check it?
>>dr = 0.005;
Nr = 20;
dt = 0.1;
Nt = 20;
a=0.2339*0.0189;
b=0.2339;
delta=sqrt(0.0073);
u=zeros(Nr+1,Nt+1);
u(1,:)=1;
for j=3:Nr
alpha=(1/2)*delta^2*dr*(j-1);
mu=a-b*dr*(j-1);
rho=dt/(dr)^2;
A=diag((1-2*rho*alpha-(dt/dr)*mu-dt*dr*(j-1))*ones(Nr-2,1))-diag((rho*alpha+(dt/dr)*mu)*ones(Nr-3,1),1)-diag((rho*alpha)*ones(Nr-3,1),-1);
end
MatrixLambda = A; % Definition of Lambda.
for i=1:Nt
u(1,1) = u(1,1) - (a*dt/dr)*(u(2,1)-u(1,1)); % Left boundary (j = 0)
u(2,1) = rho*(1/2)*delta^2*dr*1* u(1,1) + 1-2*rho*(1/2)*delta^2*dr*1-(dt/dr)*(a-b*dr*1)-dt*dr*1* u(2,1) + rho*(1/2)*delta^2*dr*1+(dt/dr)*(a-b*dr*1)* u(3,1); % j = 1
u(3:Nr,1) = MatrixLambda*u(3:Nr,1); % j = 2, ..., n
u(Nr+1,1) = u(Nr,1); % Right boundary
V(:,i) = u(1:Nr+1,1); % Matrix V with the values of u^i in each column
end
FAQ: Help Solving Equation with Matlab - Get Expert Advice Now!
1. What is Matlab?
Matlab is a programming language and numerical computing environment used for scientific and technical computing. It allows for data analysis, visualization, and algorithm development, making it a powerful tool for solving complex equations.
2. How can I get help with solving equations using Matlab?
There are several options for getting help with solving equations using Matlab. You can consult Matlab's official documentation, participate in online forums, or seek the assistance of an expert in the field.
3. Can Matlab solve any type of equation?
Matlab is capable of solving a wide range of equations, including linear equations, differential equations, and systems of equations. However, it may not be the most efficient tool for solving certain types of equations, such as symbolic equations or non-linear equations.
4. Do I need to have programming experience to use Matlab for solving equations?
No, you don't necessarily need programming experience to use Matlab for solving equations. However, some knowledge of programming concepts and syntax will be helpful in understanding and utilizing Matlab's capabilities to their fullest extent.
5. How can I improve my skills in solving equations with Matlab?
The best way to improve your skills in solving equations with Matlab is through practice and experimentation. Familiarize yourself with the basic syntax and functions, and then challenge yourself with more complex equations. You can also take online courses or tutorials to learn from experienced users.
