R=6.37X10^6G*M/(R+366.1X10^3)=gGravity Force on 1.09 kg Sphere in Space Shuttle
  • Thread starter Thread starter talaroue
    Gravity Theory
To calculate the gravitational force on a 1.09 kg sphere inside the space shuttle orbiting 366.1 km above Earth, the relevant formula is F = G*M*m/r^2, where G is the gravitational constant, M is Earth's mass, m is the sphere's mass, and r is the distance from the Earth's center. The distance r is the sum of Earth's radius and the shuttle's altitude. The discussion emphasizes understanding the relationship between gravitational potential energy and force, suggesting that using potential energy equations can simplify the process. Participants confirm that using the gravitational force formula directly is valid and that the initial approach may have been overly complicated. The correct application of these principles will yield the gravitational force acting on the sphere.
talaroue
The space shuttle orbits 366.1 km above the surface of the earth. What is the gravitational force on a 1.09 kg sphere inside the space shuttle?
U=Gm1m2/Re
U=-W
W=m(freefall)
I am starting to understand the theory behind gravity now, am I setting this problem up correctly? I am making U=-W and then solving for the free fall so I come up with ...
G*M/(radius of earth+ distance of how far it is from earth)=g
G=6.67X10^-11
M=5.98X10^24
What is the formula of the gravitational force between two objects?
I assume that by W you mean work (e.g. work done against the gravitational force to lift the sphere from the center of the Earth to its current position). In that case, W is not given by m, but by m g h where h = radius of Earth + distance above the surface. It is probably easier, however, to go from the potential energy directly to the force through F = - U', where U denotes differentiation with respect to the distance, giving
F = G M m / r^2
where M, m are the mass of the Earth and sphere and r is the distance between the sphere and the center of the Earth (= radius of Earth + distance above the surface).
You can also use the first two formulas you gave complemented with W = m g r as I explained above to derive an expression for g first, and then use F = m g for the gravitational force. That will give you the same result.
So all I have to do is ues F=G*M*m/r^2...? Was I just over thinking things?
Where F is the gravitational force?
Yep.
14K
