Calculating Pressure at the Bottom of a Tank Using Density and Volume
  • Thread starter Thread starter talaroue
    Pressure
To find the volume of water with the same mass as 8.58 m³ of ethyl alcohol, the calculation yields approximately 6.7782 m³. The pressure at the bottom of a cubic tank filled with this volume of water can be calculated using the formula Pb = Pa + density * g * h, where h is derived from the cube root of the volume. Atmospheric pressure (Pa) should be included in the calculations, typically taken as 101,300 Pa. The pressure calculation using the density of water and the height derived from the volume should yield the correct pressure in Pascals. Accurate unit conversion and consideration of atmospheric pressure are essential for correct results.
talaroue
What volume of water has the same mass as 8.58 m3 of ethyl alcohol?
If this volume of water is in a cubic tank, what is the pressure at the bottom?
denisty= m/v
Pb=Pa+density*g*h
I found the first part by setting denisty=m/v solving for m=Vrho. Then plugged that in for water in the same equation and got 6.7782 m^3. For the second part though, I thought I could use Pb=Pa+density*g*h. and the height i found by taking the 6.7782^(1/3). But would the Pa be zero since its at the bottom if not what do I use for the Pa?
Atmospheric pressure.
denisty= m/v
Pb=Pa+density*g*h
Well if the mass is the same, what is the pressure of ethyl alcohol at a depth of (8.53)1/3 ?
pressure = F/A...F/8.53^2/3...and the force is equal to mg?
I don't understand this step at all. So it wants the pressure at the bottom of the tank of water. Since its a cube you can find out that the sides are 1.89x1.89x1.89. since its at the bottom that gives the height 1.89, density of 1000, and gravity is 9.8. So that gives yous Pb=Pa+19404 correct?
But then Pa=Fa/A. The area is 1.89*1.89, but then is the force just mg?
What's wrong with
P = ρ*g*h
where ρ in this case is the density of ethyl alcohol.
That woudl me that...
P=790kg/m^3*9.8 m/s^2*2.04 m
P=15818.65341 Pa, which is wrong according to the program.
I'd think that is a bit too much precision.
another thing if the question is asking about water why would i be using the density of ethyl alcohol?
OK. Use water of a different dimension cube.
I think I was just cutting out the middleman.
Ooops. I wasn't I forgot about the cube root of the dimension. Sorry. Not a short cut at all.
so use the volume of water to find the dimension? and then use density of water to find out the pressure?
I tried what you gave me and i rounded to the tenth and it still didn't work.
You're right. I corrected myself. I forgot that the dimension is cube rooted not linear.
So your method of
P = ρgh
using water and the 1.8888 depth is the way to go.
I did and it came up wrong this is in Pascals right?
Well of course check your units. Do they want the answer as Pa or kPa?
It doesn't specifiy which one the want but we when work out this problem the way we did we get N/m^2 which is Pa.
A 1.03 m diameter vat of liquid is 5.47 m deep. The pressure at the bottom of the vat is 1.79 atm. What is the mass of the liquid in the vat?
Pb=density*gravity*height
V*Pb/density*g*h
density can be put in m/v and Pb can be turned to Pa. then just solve for the mass right? Is there something wrong with the way I am rearranging this equation for both of these problems?
That's correct. You should get something like 18,510 Pa = 1.8888*1000*9.8
V*Pb/density*g*h
In this one you know the depth and gravity and pressure in atm that you convert to Pa, then solve directly for ρ don't you and then figure the mass from there?
You can save a step by noting that it is a column so ...
F = m*g = P*A
So m = P * A / g
where A is the area of the bottom.
That anwser isn't coming out right. and neither is this one... Why does it seem i am doing all the work right but the anwser is wrong?
still having a bit of a problem
Show how you are calculating it.
V*Pb/density*g*h
What about atmospheric pressure?
I attached it
EDIT: that answer i came up with is wrong
P(below)= P(above)+density*gh
P(above) would that be considered atmospheric pressure?
Am i wrong in assuming that volume is of cylinder?
That's what I would assume.
Sorry I confused things earlier by dropping the atmospheric pressure. It is needed here for a static liquid.
How would I calculate that? Force=Pressure/Area
No worries, you have helpped me a lot! I apperiate it.
