sunniexdayzz
- 13
Part A:
A 5.73 kg mass is attached to a light cord, which is wound around a pulley. The pulley is a uniform solid cylinder of radius 9.14 cm and mass 1.26 kg. The acceleration of gravity is 9.8 m/s2 . What is the resultant net torque on the system about the center of the wheel? Answer in units of kg m2/s2.
Part B:
When the falling mass has a speed of 5.92m/s, the pulley has an angular velocity of v/r. Determine the total angular momentum of the system about the center of the wheel. Answer in units of kgm2/s.
Part C:
Using the fact that τ = dL/dt and your result from the previous part, calculate the acceleration of the falling mass. Answer in units of m/s2.
(L is the angular momentum)
Please show me the steps and explain everything!
Thank you!
I=1/2mr^2
a=[tex]\alpha[/tex]*r
[tex]\sum\tau[/tex]=I[tex]\alpha[/tex]
I found the sum of the forces for each body (the pulley and the hanging mass) and then i found the torque to be the radius x tension in cord. then i tried to solve for [tex]\tau[/tex] but my answer is wrong .. the final equation i got is
torque = .5m(pulley)*r(m(hanging)*g/(.5m(pulley)+m(box))
i don't even know where to start with the other two because i don't have the first part
PLEASE HELP!
