What is Feynman's excess radius for a black hole?
In summary, Feynman's argument for the radius excess for Schwarzschild black holes is incorrect. He is considering a sphere with a larger radius than the Schwarzschild radius, which changes the result.
heinz
63
In his lectures, Feynman writes on page 42-6 that the radius excess due to space-time curvature is GM/3c^2.
How does this work out for a Schwarzschild black hole? In this case, the predicted radius should be Rp= 2GM/c^2. The observed radius should probably be 0. But the difference is not what Feynman states. What is wrong here?
Hz
of Volume II
In typical Feynman fashion, he left out quite a bit. Feynman is not treating black holes, he is considering constant density spheres that are much larger than their Schwarzschild radii.
If [itex]A[/itex] is the surface area of the sphere, then [itex]R[/itex], the value of the Schwarzschild r-coordinate at the surface, is defined by [itex]A = 4 \pi R^2[/itex].
Now, dig a small tunnel from the surface to the centre of the sphere, and drop a tape measure down the tunnel. If the tape measure shows that the distance from center to surface is [itex]L[/itex], then (Feynman's sign is wrong)
[tex]L - R = \frac{GM}{3c^2}.[/tex]
I have had sme fun verifying this.
The metric inside a constant density sphere is given by
[tex]
ds^{2}=A\left( r\right) dt^{2}-\frac{dr^{2}}{1-\frac{2GM}{c^{2}R^{3}}r^{2}}-r^{2}\left( d\theta ^{2}+\sin ^{2}\theta d\phi ^{2}\right),
[/tex]
where [itex]A\left( r\right)[/itex] is a (somewhat complicated) known function that doesn't come into play in this situation.
Proper (tape measure) distance is calculated at "instant in time", and the tunnel is purely radial, so angles are constant, i.e., [itex]0 = dt = d \theta = d \phi[/itex]. Using this in the metric
[tex]
dl^2 = \frac{dr^{2}}{1-\frac{2GM}{c^{2}R^{3}}r^{2}}
[/tex]
for the proper distance [itex]l[/itex]. Integrating this from centre to surface gives
[tex]
L = \int_{0}^{R}\frac{dr}{\sqrt{1-\frac{2GM}{c^{2}R^{3}}r^{2}}}.
[/tex]
Making the substitution
[tex]
u = \sqrt{\frac{2GM}{c^{2}R^{3}}}r
[/tex]
in the integral gives
[tex]
L = \sqrt{\frac{c^{2}R^{3}}{2GM}}\arcsin \sqrt{\frac{2GM}{c^{2}R}}.
[/tex]
Now, if [itex]R[/itex] is larger than the Schwarzschild radius, then the argument of the [itex]\arcsin[/itex] is fairly small, so keep only the first two terms of a power series expansion of the [itex]\arcsin[/itex] term, giving
[tex]
L = R \left(1 + \frac{GM}{3c^{2}R} \right).
[/tex]
Thank you! Is there some way that Feynman's argument can be used for black holes?
Or can it be changed so that it is also valid for black holes?
Hz
FAQ: What is Feynman's excess radius for a black hole?
Feynman's excess radius for a black hole is a theoretical concept proposed by physicist Richard Feynman to describe the deviation of a black hole's event horizon from its calculated Schwarzschild radius. It is an indication of the dynamic nature of black holes and the effects of quantum mechanics on their behavior.
How is Feynman's excess radius calculated?
Feynman's excess radius is calculated by subtracting the black hole's actual event horizon radius from its calculated Schwarzschild radius. This can be done using the formula: excess radius = event horizon radius - Schwarzschild radius. The resulting value represents the deviation of the black hole's event horizon due to quantum effects.
Why is Feynman's excess radius important?
Feynman's excess radius is important because it helps us understand the behavior of black holes at a quantum level. It also highlights the limitations of the classical theory of general relativity in predicting the behavior of black holes. By considering the effects of quantum mechanics, we can gain a deeper understanding of the fundamental nature of these mysterious objects.
What is the significance of Feynman's excess radius in astrophysics?
In astrophysics, Feynman's excess radius is significant because it allows us to account for the quantum effects on black hole behavior when making calculations and predictions. It also provides a framework for studying the behavior of black holes in a more accurate and comprehensive manner, which can lead to new insights and discoveries in the field.
Can Feynman's excess radius be observed or measured?
Currently, Feynman's excess radius cannot be directly observed or measured. However, its effects on the behavior of black holes can be indirectly observed through various astrophysical phenomena, such as gravitational lensing and Hawking radiation. With advancements in technology and our understanding of black holes, it may be possible to directly measure Feynman's excess radius in the future.
