How many string theories with more than one supersymmetry?
In summary, the conversation discusses the existence of different types of string theories and their corresponding dimensions and supersymmetries. It mentions that in 10 dimensions, there can be theories with 2, 1, or 0 supersymmetries, while in 4 dimensions, there can be theories with 0 to 8 supersymmetries. However, phenomenologically, only theories with 1 or 0 supersymmetries are relevant due to the presence of chiral fermions. The conversation also brings up the concept of world-sheet supersymmetry and its relation to spacetime supersymmetry. Other topics discussed include the ambiguity in defining dimensions and the use of F-theory as a mathematical tool to
MTd2
25
With one, we have 5, what about more than one? What are they? What are the importance of these, phenomenologicaly saying?
This is an ambiguous question, the answer depends on the dimension. in 10d there are theories with 2,1 and 0 supersymmetries. That's all what can exist due to Nahm's classification of supersymmetries. In four dimensions one can have everything vom 0 to 8 supersymmetries (well, N=7 is equivalent to N=8).
Phenomenologically, only theories with N=1 and 0 can be relevant because only for those the theory can have chiral fermions.
This is not ambiguous, I just didn't put it well, sorry. I mean string theory by a sigma model whose worldsheet has no conformal anomaly.With 1 supersymmetry, there are 5 theories, all of them shows that 10 dimension is a condition needed to cencel the anomaly. What if that sigma model, instead of 1 supersymmetry, had 2 or more? How many anomaly-free free would one get for each case? How many dimensions each one of them would have?
Ahh you mean world-sheet supersymmetries. Well there is still something not quite accurate in what you are saying, namely one can have world sheet susy in the right- and leftmoving sectors independently and thus there are various combinations possible. So the two type-II strings have (N_L,N_R)=(1,1) susies and the two heterotic strings have (1,0) (or (0,1), which is of course equivalent). Then there is also the open type-I string, which has N=1 supersymmetry.
Moreover, which is something that is not often mentioned, there are various theories in 10d which are not supersymmetric in space-time, but only on the world-sheet, those come again in type-II and heterotic versions.
What you are asking for are theories with more world sheet supersymmetries, yes they do exist, most famous is the so-called N=2 string for which the supersymmetries as written above are doubled. Its critical dimension is four, but this does not refer to Minkowski spacetime with signature (time,space)=(-,+++) but to a spacetime with signature (--,++); you may call that a two-time theory if you like... So the theory is physically not very relevant but has some nice mathematical properties which is why it was studied. Then there are N=4 strings, I think, but I can't recall out of my mind any of their properties.
Be aware that these considerations are based on the world-sheet, which is not a fundamental concept but rather, by its very definition, a concept of perturbation theory. Thus non-perturbative relationships between those various strings are not visible in this framework; and the 11-dimensional membrane theory and the 12-dim F-theory are not describable in this language at all. So questions concerning the nature of string theory should not be formulated in this language in the first place.
Also, the concept of dimensions can be quite misleading. For example, in the heterotic string the "non-supersymmetric chiral half" (ie, the "0" in (N_L,N_R)=(1,0)) formally corresponds to the bosonic string which has critical central charge c equal to 26. So for the heterotic string the critical central charges are formally (c_L,c_R)=(15,26), but this does not mean that there are 26 spacetime dimensions somewhere in the theory. A better viewpoint is that the central charges simply label internal degrees of freedom of the string, which may or may not have an interpretation in terms of compactified dimensions.
Sounds like what I see sometimes when I see Berkovitz talking about twistor strings. I see everywhere N=2 and (--++) signature. Anyway, couldn't one rotate (2,0) to (1,1)?
But you have to to start counting dimensions somewhere, right? So the 10d strings spacetime is fundamental in this aspect. Also, isn't F-Theory a mathematical device to understand Type II strings?
Well formally one can rotate the backround metric in the effective theory but then the theory is, I guess, not consistent any more. The theory in (--,++) is very special, has very few degrees of freedom, is integrable, etc, and probably not many of these special properties would survive this "wick" rotation. There is no reason why they should.
Actually, counting dimensions in this way has, in my opinion, historically created much confusion. It sounds like as if the 10d theories would be more "fundamental", and all the lower dimensional theories are "compactified". But it is well known that many, say 4d, theories are not compactifications in the sense that there is no 10d lorentz symmetry restored no matter how high we go up in energy. There is, in fact, no absolute notion of compact dimensions, and an example is the heterotic string alluded to above.
Another is AdS/CFT duality...is it just 4d N=4 Yang-Mills theory, or is it compactified 10d type-II strings? Either description is good in its own regime of validity. More generally it seems that almost any strongly coupled 4d theory has some higher dimensional holographic properties. Non-perturbative quantum effects in the 4d theory can be described in terms of classical background gemetry of some compactified higher dimensional dual gravity or string theory. Coordinates of some higher dimensions turn into coupling constants in the 4d theory in this way.
So there is in general no unambiguous notion of compactified dimensions to start with; sometimes they simply play the role of internal degrees of freedom (and sometimes they enocde, and in a sense emerge from, non-perturbative effects). All what matters that the Virasoro central charge is cancelled, and this requires a certain amount and structure of extra internal degrees of freedom. Whether these extra degrees of freedom have an interpretation in terms of higher dimensions or not, does not matter at all; see the "extra" 16 dimensions of the heterotic string that can be rewritten in terms of 2d fermions for which the extra-dimensional interpretation disappears. All what counts is that they provide the E8xE8 Kac-Moody symmetry which must be there for consistency.
Unfortunately, historically, too much emphasis was put on literal compactifications of the 10d theories and so many people get preoccupied with misleading questions; I have seen here threads discussing what the meaning of those extra dimensions is and so on. Well, again, they just provide internal degrees of freedom, using the KK idea that compactified momenta are nothing but charges. I would even go as far and provocatively say that only in special circumstances those internal degrees of freedom also happen to be interpretable in terms of compactifications of higher dimensional theories.
As for F-theory, yes, this is another example of theory where extra dimensions (at least formally) emerge from non-pertubative dynamics, here the type IIB strings. Everybody is free to choose her viewpoint, namely either whether these extra dimensions are "real" and are tied to some hypothetical F-theory, or whether these extra dimensions are simply the coupling constants of the type IIB string which miraculously behave like a torus; it does not matter. At any rate, my point was that these non-pertubatve considerations cannot be captured by world-sheet considerations, so those are not fundamental.
So you asked.. "But you have to to start counting dimensions somewhere, right?" I hope to have argued that this is not necessarily a good question to ask. Probably you have meant: "what is the most fundamental string (or whatever) theory"? But as said, this may also not be a good question.
But is that Berkovitz Twistor Theory? Also, when I said rotate, I didn't refer to rotate the metric, but rotate the chiralities, if that makes any sense. For example, like Left would be the x-axis and Right the y-axis. So, (2,0) or (1,1) would be a kind of coordinate.
"All what matters that the Virasoro central charge is cancelled, and this requires a certain amount and structure of extra internal degrees of freedom."
That means string theory is a theory in without ghosts in surfaces?
Rotating chiralities doesn't make sense IMHO. Chiralities involve differerent (spinor) representations and (perhaps apart from SO(8) triality) changing reps relative to each other does change phyiscs.
Not sure whether I understand the question. The point is that in perturbative string constructions based on CFT, the relevant ghost central charge must be canceled by something; one may choose spacetime coordinates all the way up, so this then gives strings in d=26 or d=10, but one may also choose a subset, say 4, spacetime coordinates. The missing central charge must then be compensated by something else, and in fact any suitable CFT can be used. The degrees of freedom arising from that are then by definition internal and not space-time degrees of freedom. Sometimes but not always these extra degrees of freedom look like compactified coordinates of some higher dimensional spacetime, and then it is often useful to visualize them in terms of higher dimensions.
Alright. But I was thinking just it the world sheet, like, operators that exchanged the chirality of supercharges, so that the count of supercharges could go left right.
suprised said:
Sometimes but *not always* these extra degrees of freedom look like compactified coordinates of some higher dimensional spacetime, and then it is often useful to visualize them in terms of higher dimensions.
Not always, how?
MTd2 said:
Not always, how?
There is no reason why the "internal" part of the CFT would correspond to a compactifaction of a higher dimensional theory on some manifold. There are lots of "non-geometric" compactifications. A geometrical interpretation is sometimes/often(?) possible but this is not important. And this is in fact often even ambiguous... due to dualities, one and the same theory can have different interpretations, namely as different world sheet theories compactified on different manifolds (like type-II strings on K3 being equivalent to heterotic ones on T4). This shows that there is in general no absolute meaning of a compactification manifold.
I am just saying this because often people are too closely tied to notions like compactification manifold, dimension, D-brane etc. All these are just different parametrizations and approximations of one and the same, probably unique, largely unknown theory one may call M-theory.
I see, so the different string theories are like generalized Fourier transforms. In the usual Quantum Mechanics, you just transform between momentum and position, in string theory you transform between several different types of basis, which are the different string theories. Right?
Besides that, is there anything that forbids an operator on the worldsheet that exchange chiralities?
Vaguely yes. Some of the dualities act like a Fourier transformation, for example between momentum and string winding states, or between electric and magnetic degrees of freedom.
Hm.. probably not. But such an operation will in general change the physical theory, and the question is what properties survive it.
However sometimes the theory stays invariant and then this operation can be very interesting. For example, flipping relative chiralities map the type IIA and type IIB strings into each other, which are a priori completely different theories. However, if one theory (say Type IIA) is compactified on a Calabi-Yau space and is transformed into the other (ie, type IIB), then the theory stays invariant provided the Calabi-Yau is replaced by a specific other one (the "mirror dual"). This has extremely non-trivial mathematical consequences.
What is missing to define an M-Theory nowadays?
hmm this is a hard one... one just knows various approximations to it, in various corners of its moduli space. The feat would be to formulate something that gives rise to all those field, string and membrane theories when expanded around the relevant regions of the vacuum parameter space, in terms of the appropriate degrees of freedom. Clearly almost everyone can say a lot of vague and naive things about this, but to come up with something concrete still seems very hard.
Would you mind citing some things that are known not to be reproduced "when expanded around the relevant regions of the vacuum parameter space" ?
Well for example sick QFT with gauge anomalies.
Isn't that a good thing? Why should M-Theory include them?
Yes it is a good thing... M-Theory supposedly is the mother of all consistent theories...and if I may say something provocative, IMHO it is defined by this property.
OK, then. I thought you said that there were consistent theories that were not reproduced "when expanded around the relevant regions of the vacuum parameter space". Hmm, but what I actually mean, if it is that they can be reproduced right now? If there is any, can you tell me which one is?
.. don't understand the question...;-(
Well, you know that the final form of m-theory is not known. How can you that something is missing?
Well we know it has such a high degree of consistency, so it is pretty clear that grossly inconsistent theories won't come out. But more to the point and more difficult to answer is whether there is a swampland of apparently consistent field theories that cannot come out. For example, can a gauge theory with gauge group SU(10^10) come out or not? Or is there something in the coupling to gravity that forbids this?
Indeed we are far from knowing what M-theory is, even from properly defining it. All we know is a bunch of perturbative limits, and that we can go between some of them.
Well, so M-Theory is a gut feeling?
What do you think of E8 Gauge theory? (the one in 12 dimensions, not the Garrett Lisi's).
Well it is a bit more than that, you can't press complicated matters in such a simple buzzword ;-)
Which E8 gauge theory in 12d? I never heard of it...
This is why I asked for examples! :)
It is a theory from Witten, Diacunescu and Moore.
These are the original articles:
http://www.slac.stanford.edu/spires/find/hep/www?rawcmd=FIND+EPRINT+HEP-TH/0005090
Supersymmetry in this theory is a low energy limi.
Be sure to check its citations!
So, suprised, what did you think of E8 gauge theory? Witten invented it, but there is not that many citations within 12-9 years since it was invented, as it usually happens when he comes up with breakthrougs. Perhaps people are overlooking it? What do you think?
Well I need to re-read more carefully this paper, but upon glancing over it seems that it deals with the gauge theory that lives on the branes which sit at the two endpoints of the interval that defines the "compactification" of 11d M-Theory to the heterotic string. Thats the way how E8xE8 of the heterotic string is produced. The idea is older than that, see papers of Horava and Witten etc, so why should this paper stand out more? The paper mainly deals which mathematical/technical questions of anomalies and other aspects of the M-theory partition function, it is very dense and I cannot tell much more without carefully reading it, but why do you put so much emphasis on that? It has more than 100 citatations so what's the problem with it?
BTW in that paper M-theory means the theory whose low-energy limit is 11d sugra, in what I was writing before I used M-theory in a wider sense (I say this to avoid confusion).
Because it has 12 dimensions, like F-Theory. It is even shown in a later paper that it is dual to it. But the reason that, unlike F-Theory, there is a certain "bulk" which is not supersymmetric, in fact, supersymmetry is a lower energy condition on the 11th dimension border. I read an explanation of this in another paper that explains it. Unfortunantely, I cannot post it here.
Well the previous remarks apply: this E8 gauge therory is just part of another dual description of the heterotic string, here the E8 comes from gauge fields on a brane world-volume, in contrast to the original CFT construction where it arises from free world-sheet bosons or fermions.
That paper mainly deals with K-theorerical aspects if this construction, which are conceptionally interesting for the mathematically inclined physicist, but may be not so interesting for a more general audience. In fact the role of K-theory in string physics is somewhat overrated and doesn't play an important role beyond cohomology, so I would advise anybody not to waste time by studying papers on K-theory, unless she really wants to understand subtleties in defining D-brane charges and similar.
  • #31
It was later argued that K-Theory is not enough, you have to consider elliptic-cohomology, which is one step further in complexity, since it deals with curves on a torus, or lattice. According to what I sent you, K-theory cannot classify 3-form fields with torsion.
And if I don't classify what the fields are, how can I find what is m-theory?
  • #32
Well I have seen claims but right now I don't know of any concrete use of elliptic cohomology in M-theory. It sounds more like a wish list for math concepts to be applied somewhere in physics (and yes, there are plenty). I studied a few papers of Sati et al but really couldn't get anywhere.
I know somewhat better the K-theory story in relation to D-branes, and you could say the same thing: how could one possibly understand D-branes without K-theory? However indeed K-theory doesn't play an important role beyond cohomology. In other words, cohomology is about RR-charges of branes and open strings (which are certainly important) but essentially what K-theroy adds for physicists is torsion pieces to charges, for example Z_2 factors (concretely, this boils down for example that certain orientifold planes are labelled by some extra signs, +/-). This by itself isn't just particularly important.
My suspicion is that many people believe that K-theory must be important because some renowned people worked on it and it sounds cool. But in all the many years since it has been introduced in physics, I wouldn't know about any single truly important application. In fact K-theory is just the poor man's version of derived categories, and this is a much better way to understand brane-antibrane annihilation, tachyon condensation and so on. For example, all D0 branes are equal in K-theory, which just knows about their total charge; but in the category also the location of the D0 branes play a role, and so can distinguish if two D0 branes sit on different places or are on top of each other (and can bind or whatever).
So while all of this seems interesting in one way or other, and certainly is of some conceptional relevance, I would think that there are some more down-to-earth things to study which would be more worthwhile to study!
  • #33
suprised said:
Well I have seen claims but right now I don't know of any concrete use of elliptic cohomology in M-theory. It sounds more like a wish list for math concepts to be applied somewhere in physics (and yes, there are plenty). I studied a few papers of Sati *et al* but really couldn't get anywhere.
But, have you been following "et al"? One of those is Urs Schreiber! That's why a large number of n-category cafe posts is about this. I guess that's why I came across this kind of thing.
But what kind of down to Earth thing do you mean?
  • Beyond the Standard Models
11K
