Negative time Minkowski metric
In summary, the sign on the time component being opposite those of the spatial components of the Minkowski metric means that the speed of light is the same for all inertial observers. This can be seen in the scalar product equation, which is computed using the metric. The different signs also indicate that coordinate time is not the same as the spatial dimensions, and can be thought of as a "special dimension" or proper time. This leads to a hyperbolic rather than Euclidean metric space for space-time. Additionally, there are three categories of paths and vectors in this space: space-, light-, and time-like. While it may be difficult to grasp, space-propertime is a complimentary tool to Minkowski space-time and can be
tickle_monste
69
What does it mean physically that the sign on the time component is opposite those of the spatial components of the Minkowski metric?
It means that the speed of light is the same for all inertial observers.
For the x frame: x2=c2t2
For the x' frame: x'2=c2t'2
So: x2-c2t2=x'2-c2t'2 , which is the scalar product, which is computed using the metric.
I cheated, but it's a good cheat.
In other words, in order for the space-time interval to be invariant under Lorentz transformations the time component simply has to have an opposite sign compared to the spatial components. And yes, it also preserves the constancy of the speed of light.
If you don't like minus signs, you can rearrange the equation so it contains none. This doesn't change the meaning of the formula, but maybe the geometrical interpretation.
Different signs of the time and space components mean that coordinate time is not a dimension just like the space dimensions but a bit different. If you don't like "special dimensions" you can regard proper time [tex]\tau[/tex] as the temporal dimension, and the coordinate time [tex]t[/tex] as the space-time interval. Then you have no minus signs:
[tex]dt^2=d\tau^2+dx^2+dy^2+dz^2[/tex]
But this is not Minkowski space time anymore.
The problem is, that differential equation doesn't actually define a coordinate τ.
These equations would:
[tex]t=\sqrt{T^2 + X^2}[/tex]
[tex]x = X[/tex]​
where (t,x) are standard Minkowski coordinates (let's ignore 2 dimensions) and (T,X) are new coordinates we want to define.
From which
[tex]dt = \frac{TdT + XdX}{\sqrt{T^2 + X^2}}[/tex]
[tex]dx = dX[/tex]
[tex]d\tau^2 = dt^2 - dx^2 = \frac{T^2(dT^2 - dX^2) + 2TXdTdX}{T^2 + X^2}[/tex]​
In this coordinate system, proper time is defined by the last equation above, not by τ = T.
The point of all this is, this is a valid coordinate system to use (although valid only in the region |x| ≤ |t|), but it's technically incorrect to describe T as "proper time". It coincides with proper time only along straight worldlines through the origin.
You can also say that it means that space-time is a hyperbolic rather than euclidean metric space. The statement that different observers have different notions of space and time measurements, with an invariant speed of light, can be described by saying that paths of observers are in a hyperbolic space. This also means that there is a natural partition for paths and vectors into three categories: space-, light- and time-like.
[tex]x = X[/tex]​
I think you demand a 1:1 mapping between [tex](x,t)[/tex] and [tex](X,T)[/tex] here. But there is no such corespndence between [tex](x,t)[/tex] and [tex](x,\tau)[/tex]. An event in Minkowski space-time, doesn't have a corresponding single point in space-propertime. In Minkowski space-time you see that two objects meet at [tex](x,t)[/tex] when their worldlines cross there. In space-propertime[tex](x,\tau)[/tex] you see they meet if they are at the same [tex](x)[/tex] (but eventually different [tex](\tau)[/tex]) after traversing worldlines of the same length:
[tex]dt=\int \sqrt{dx^2 + d\tau^2}[/tex]
A.T. said:
I think you demand a 1:1 mapping between [tex](x,t)[/tex] and [tex](X,T)[/tex] here. But there is no such correspondence between [tex](x,t)[/tex] and [tex](x,\tau)[/tex]. An event in Minkowski space-time, doesn't have a corresponding single point in space-propertime. In Minkowski space-time you see that two objects meet at [tex](x,t)[/tex] when their worldlines cross there. In space-propertime[tex](x,\tau)[/tex] you see they meet if they are at the same [tex](x)[/tex] (but eventually different [tex](\tau)[/tex]) after traversing worldlines of the same length:
Fair enough, but that does mean that "space-propertime" is a very limited concept and pretty difficult to grasp. You can plot a single worldline in space-propertime, but an isolated "point", not lying on any worldline, has no meaning, and if you plot more than one worldline on the same graph it's going to get pretty confusing, as the intersection of two lines has no physical significance, and a single event in spacetime could be mapped to multiple distinct points in space-propertime on different worldlines.
OK, but does this hold true?
[tex]d\tau^2+dx^2+dy^2+dz^2 = d\tau'^2+dx'^2+dy'^2+dz'^2[/tex]
It is actually just like normal Euclidian space with dimensions of the same kind, where everything 'moves' at the same rate. For layman it is not more difficult to grasp, than the pseudo-Euclidian Minkowski space-time. I see it as complimentary tool.
It depends what you want to show. You can visualize different propertimes for two worldlines very well directly in a space-propertime graph. Like the usual twins for example. And you still see the coordiante time in the diagram, as the length of the world lines.
Just like in a purely spatial graph, where the intersection of two paths doesn't imply a meeting point. That was exactly the point, that propertime is just like a 4-th space dimension.
If you mean two different frames of reference observing the same object: no
If you mean two different objects observed in the same frame of reference: yes
Related to Negative time Minkowski metric
1. What is the Minkowski metric?
The Minkowski metric is a mathematical tool used in the study of spacetime, which combines the concepts of space and time into a single four-dimensional continuum. It is named after the physicist Hermann Minkowski and is a fundamental concept in Einstein's theory of relativity.
2. How is negative time incorporated into the Minkowski metric?
Negative time is incorporated into the Minkowski metric through the use of imaginary numbers. In the Minkowski metric, time is considered to be a fourth dimension, and the use of imaginary numbers allows for the concept of negative time to be included in calculations.
3. What are the implications of negative time in the Minkowski metric?
The implications of negative time in the Minkowski metric are still being studied and debated. Some theories suggest that it could lead to the possibility of time travel, while others propose alternative explanations for the use of negative time in the metric.
4. How is the Minkowski metric used in physics?
The Minkowski metric is used in various areas of physics, including special relativity, general relativity, and quantum field theory. It is a crucial tool for calculating the effects of time and space on particles and objects.
5. Is the idea of negative time in the Minkowski metric accepted by the scientific community?
The concept of negative time in the Minkowski metric is still a topic of debate and research in the scientific community. While some theories and experiments support its existence, others propose alternative explanations for the use of imaginary numbers in the metric. Further research and experimentation are needed to fully understand the implications of negative time in the Minkowski metric.
