Curved spacetime: embedded or not?
  • Thread starter Thread starter Dmitry67
    Spacetime
The discussion centers on two interpretations of General Relativity (GR): one where spacetime is intrinsically curved without needing higher-dimensional embedding, and another where curved spacetime can be visualized as embedded in higher-dimensional Euclidean space. Participants explore the implications of these interpretations, noting that while embedding can aid visualization, it is not essential for the mathematical framework of GR. The conversation also touches on the complexities of embedding certain topological structures, such as Klein bottles, and the dimensional requirements for such embeddings, with claims that a 4D spacetime can be embedded in a flat spacetime of up to 90 dimensions. Ultimately, the consensus leans towards the view that the intrinsic curvature of spacetime suffices for the predictions of GR without necessitating higher-dimensional embeddings.
Dmitry67
Can we think about 2 different "interpretations" of GR:
1. Without embedding: space is curved, that's all
2. With embedding: curved non-euclidean space can be embedded in higher-demensional euclidean space.
In another words, spacetime is just curved (1), or it is curved is something (2)
Or in another words, curved spacetime in GR can be embedded in euclidean space, but it is just a pure mathematical result (1) or alternatively there might be some physical meaning of that super-space? (2)
Note that some topological solutions, like helf-spehere, is possible in (1) but not in (2)
I'm fairly certain the embedding in a higher-dimensional space is simply for our convenience in visualizing something. I.e it's pretty much impossible to think about the surface of a sphere without actually picturing a sphere embedded in R^3. I don't think any of the equations or derivations from GR require the existence of a higher dimensional space that spacetime be embedded in, at least not any I've encountered so far.
Logunov's RTG is built in the plane Minkowski space-time. The Riemann geometry metric is an effective metric for matter but the gravitational filed equations contain the Minkowski metric and the gravitational field separately, so the physical background is plane (R=0). The gravitational field is then as physical as the other fields. One can say that the curvature of space-time is embedded in the plane space time of the same dimension (3+1) for matter but not for gravitational field.
In GR it is not so. Splitting the entire metric is not possible since R ≠ 0.
2. With embedding: curved non-euclidean space can be embedded in higher-dimensional euclidean space.
If number 2 how many dimensions would we need for the curved space-time we live in?
I bookmarked a thread on this long ago--here it is, post #3 on that thread mentions that the maximum number of dimensions needed for a flat embedding spacetime would be 90, 87 spacelike dimensions and 3 timelike, though that's just an upper limit, so for any given curved spacetime (including the one we live in) the answer could be lower.
This result was probably just derived out of mathematical interest though, there is no need for an embedding spacetime in GR, curvature can be defined "intrinsically" using differential geometry and adding an embedding spacetime shouldn't change any physical predictions about what will be observed within curved 4D spacetime.
I can give you an example where predictions can be different.
Klein bottle
If space is NOT embedded, you can do it.
If space IS embedded, then you will intersect space with itself in attempt to make it.
I can't tell precisely what you mean.
But I think it's relevant to point that:
. any 4-dimensional manifold contains Klein bottles
. Euclidean 3-space does not contain Klein bottles
yes, but is Klein bottle a 'bottle' in 4D space?
In 3D it is not realistic because it can't be made without intersections to itself
In 4D you can build it, but 'water' would be able to escape from it (like a ring is a 'bottle' in 2D but not in 3D)
What does that have to do with anything? :confused: I would have assumed you're just playing a dumb word game, but you sound like you really meant what you said...
I've heard that spacetime can be embedded in an R5 Euclidean space. Is there any truth to this rumor?
Klein bottle
It can't be embedded in 3 dimensions, but in general there's no guarantee that a curved N-dimensional surface (with the curvature at every point defined using differential geometry) can be embedded in a Euclidean space of N+1 dimensions, you may need more dimensions to do it. The proof I mentioned earlier shows that every curved 4D spacetime allowed by GR (which would presumably include spacetimes where space has the topology of a Klein bottle) can be embedded in a flat spacetime of at most 90 dimensions.
Did you see my post #5 above? The proof mentioned there, that every 4D spacetime allowed by GR can be embedded in a flat spacetime of at most 90 dimensions, would be pretty pointless if there was also a proof it could be embedded in a flat spacetime of only 5 dimensions, so I'm pretty confident the rumor is wrong.
Another interesting question: is it possible that these "extra" dimensions can also include additional 26-4, 11-4 or 10-4 dimensions from the superstring theory?
I found something on it. The wiki claims that a pseudo-Riemann manifold can be embedded in an n(n+1)/2 pseudo-Euclidian space. This would be 10 for spacetime.
More, a 4 dimensional Riemann can be embedded in a 5 dimensional manifold of zero Ricci curvature. It's a little unclear whether this includes pseudo-Riemann manifolds.
My numerologist's handbook doesn't come up anything special about the number 90, other than [n(n+1)/2][-1+n(n+1)/2]. Do you know where it comes from?
What wiki page says that? I didn't see a wiki link on that thread.
I don't know how it was derived, the paper the result comes from is Chris Clarke's "On the global isometric embedding of pseudo-Riemannian manifolds" which doesn't seem to be available online (I'm sure I wouldn't understand it even if it was), though I did find this paper on arxiv.org which references Clarke's paper and seems to be discussing similar issues (but again the math is beyond me).
The "[URL article[/URL], is on Campbell's theorem.
thanks, that the one I also came up with in a search.
Interesting. The Wolfram MathWorld page on this says that Campbell's theorem says "Any n-dimensional Riemannian manifold can be locally embedded into an (n+1)-dimensional manifold with Ricci curvature Rab = 0" and that "any n-dimensional pseudo-Riemannian manifold can be locally and isometrically embedded in an n(n+1)/2-dimensional pseudo-Euclidean space" (italics mine)--I wonder about that use of the word "locally", maybe this is different in some way than an embedding of the entire manifold? I also found this paper on arxiv.org which says on p. 5:
He does, however, state that he dislikes the theorem “because it offers no guarantee of continuous dependence on the data and because it disregards causality” (loc. cit., p.1). A possible interpretation of these comments is that the CM theorem does not guarantee a well-posed initial-value problem, or the non-occurrence of singularities. However, the CM theorem does not claim to do either thing. It is a local embedding theorem, and cannot be pushed towards solving other problems which are the domain of (much more difficult) global embeddings.
It does get involved, doesn't it? I can only guess that 'local' embedding is far less stringent.
Then there is the matter of differentiability. Ideally we'd like an embedding that is one-to-one and onto. So how do we embed a spacetime that contains singularities?
Any (3+1 dimensional) spacetime can be embedded in 8 dimensional Euclidean space. (This was mentioned in Jesse's first source.) It's only if you want to embed it in Minkowski space (in a manner which completely determines the metric) that you may need an order of magnitude more dimensions. A local embedding wouldn't really make sense, you'd only need 4 dimensions for that. I'm not aware if there is any useful physics yet that follows from the existence of embeddings?
Thanks for that, cesiumfrog. Jesse's previous reference actually has something to say about this, although these are probably not the sort of embedding you have in mind, such as Kaluza-Klein theory.
  • · Replies 52 ·
  • · Replies 22 ·
  • · Replies 111 ·
