Four Point Correlation function from Generating Functional
In summary, the conversation discusses a confusion in understanding the absence of a term in equation 9.41 from Section 9.2 of Peskin and Schroeder. The participants define various symbols and equations and discuss the steps they took to reach a solution, ultimately realizing that the missing term is due to the J dependence being eliminated by the last functional derivative.
maverick280857
1,789
Hi everyone,
I'm working through Section 9.2 (Functional Quantization of Scalar Fields) from Peskin and Schroeder. I have trouble understanding the absence of a term in equation 9.41 which I get but the authors do not.
Define [itex]\phi_i \equiv \phi(x_i)[/itex], [itex]J_{x} \equiv J(x)[/itex], [itex]D_{xi} \equiv D_{F}(x-x_i)[/itex] (the Feynman propagator). Repeated subscripts are integrated over implicitly.
Equation 9.41 in the book reads
[tex]\langle 0|T\phi_1\phi_2\phi_3\phi_4|0\rangle = \frac{\delta}{\delta J_1}\frac{\delta}{\delta J_2}\frac{\delta}{\delta J_3}\frac{\delta}{\delta J_4}e^{-\frac{1}{2}J_x D_{xy} J_{y}}[/tex]
[tex]= \frac{\delta}{\delta J_1}\frac{\delta}{\delta J_2}\frac{\delta}{\delta J_3}\left[-J_x D_{x4}\right]e^{-\frac{1}{2}J_x D_{xy} J_{y}}[/tex]
[tex]= \frac{\delta}{\delta J_1}\frac{\delta}{\delta J_2}\left[-D_{34}+J_{x}D_{x4}J_{y}D_{y3}\right]e^{-\frac{1}{2}J_x D_{xy} J_{y}}[/tex]
[tex]= \frac{\delta}{\delta J_1}\left[D_{34}J_{x}D_{x2}+D_{24}J_{y}D_{y3} +J_{x}D_{x4}D_{23}\right]e^{-\frac{1}{2}J_x D_{xy} J_{y}}[/tex]
[tex]= D_{34}D_{12} + D_{24}D_{13} + D_{14}D_{23}[/tex]
where J is set equal to zero after all the 4 functional derivatives have been evaluated.
When I do this by hand, I get (in the second last step), an extra term:
[tex]= \frac{\delta}{\delta J_1}\left[D_{34}J_{x}D_{x2}+D_{24}J_{y}D_{y3} +J_{x}D_{x4}D_{23}-J_x D_{x4} J_{y}D_{y3} J_z D_{z2}\right]e^{-\frac{1}{2}J_x D_{xy} J_{y}}[/tex]
which isn't given in the book. I just follow the prescription of differentiating with proper order and bringing down a -J*D type of term every time the exponent is differentiated. What happened to this term? Please help..
Thanks in advance.
Wait...I think I got it...the terms that are O(J^2) survive the derivatives but go to zero when J is set equal to zero, whereas the O(J) terms are robbed of their J dependence by the last functional derivative. The authors just don't show the steps.
I should've read what I was writing :rolleyes:
Hi there,
Thank you for sharing your question and showing your work. The four-point correlation function is an important tool in quantum field theory, and it's great to see you working through it.
From what I can see, your calculations are correct. The extra term you have identified should indeed be present in the final expression for the four-point correlation function. However, it is possible that the authors have made a mistake in their derivation and have accidentally left out this term.
it is important to always question and double-check our calculations and results. If you have verified your work and are confident that the extra term is indeed missing from the book, you may want to reach out to the authors and ask for clarification or point out the mistake. This can help improve the accuracy of the book for future readers.
In the meantime, you can continue to use your derived expression for the four-point correlation function, including the extra term, in your research and calculations. This will not affect the validity of your results, as long as your calculations are correct.
Keep up the good work and always stay curious. Best of luck in your studies!
Related to Four Point Correlation function from Generating Functional
1. What is the "Four Point Correlation function" in the context of Generating Functional?
The Four Point Correlation function is a mathematical tool used in the field of theoretical physics, specifically in the study of quantum field theory. It is derived from the Generating Functional, which is a mathematical expression used to describe the probability of a specific event occurring in a system.
2. How is the Four Point Correlation function calculated from the Generating Functional?
The Four Point Correlation function is calculated by taking the functional derivative of the Generating Functional with respect to the fields in the system. This results in a mathematical expression that relates the correlation between four points in the system.
3. What information can be obtained from the Four Point Correlation function?
The Four Point Correlation function provides information about the interactions between particles in a quantum field theory. It can also be used to calculate physical quantities such as scattering amplitudes and decay rates.
4. How is the Four Point Correlation function used in practical applications?
The Four Point Correlation function is used in many practical applications, such as in the study of condensed matter systems, quantum chromodynamics, and cosmology. It is also used in the development of new theoretical models and in the analysis of experimental data.
5. Are there any limitations or assumptions to consider when using the Four Point Correlation function?
Yes, there are limitations and assumptions to consider when using the Four Point Correlation function. It is based on a perturbative approach and may not accurately describe strong interactions between particles. Additionally, it assumes that the system is in thermal equilibrium and neglects the effects of quantum fluctuations.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
