The Ballistic Coefficient of Pumpkins
In summary, trebuchets were used in the Middle Ages to hurl boulders at castle walls. Modern trebuchet competitions involve launching pumpkins for distance. The optimal launch angle for maximum range depends on the projectile's drag coefficient and can be determined using mathematical equations. This differs from the commonly believed 45 degree angle, as proven by both numerical and analytical solutions.
Grozny
A trebuchet is a type of catapult that converts the potential energy of a counterweight into the kinetic energy of a projectile. The simplest version operates like a see-saw, with the counterweight suspended from a hanger attached to the short arm and the projectile held in a sling attached to the throwing arm. When the short arm is raised and then released, the throwing arm rotates faster because it is longer and the sling rotates even faster as it whips around the end of the throwing arm.
At their inception during the Middle Ages, trebuchets were used to hurl boulders at or over castle walls in an attempt, usually successful, to batter them down. Modern trebuchet designers, lacking castles to besiege and fair maidens to rescue, must content themselves with hurling cooking pumpkins for distance. Competition, however, is fierce, and the winner of the contest can expect any fair maidens present at the pumpkin festival to hurl themselves at him. Thus, it behooves us to put as much study into the ballistics of pumpkins as old-time mathematicians put into the study of cannonballs.
Visit The Ballistic Coefficient of Pumpkins to read the rest of my paper.
Ron Toms said:
You need a lower angle to get the most distance. That 45° nonsense only works in a vacuum because the horizontal component must remain constant (no drag) for it to work out that way. Go talk to any — let me repeat that last word... ANY — college freshman-level engineering physics professor. I dare you.
Ron Toms, the owner of the Catapult Message Board, dares me to go talk to an engineering or physics professor regarding that nonsense I've been peddling about 45° being the optimal launch angle.
Very well. I will take that dare. Are there any engineering or physics professors on this forum who would like to comment on the accuracy of my paper?
The short answer is that he is right. You are correct that 45 degrees is best if there is no air resistance (which can be assumed for many projectiles), but for something as un-aerodynamic as a pumpkin, you cannot ignore drag effects and then the maximum range angle depends on what the drag coefficient, k, is.
The long answer:
From my Classical Dynamics book (Thornton and Marion 5th Ed, pg. 68), we have the formula for maximum range without drag:
[tex]r_{max}=\frac{v^2}{g}Sin(2\theta)[/tex] where v is the initial velocity of the projectile.
If you take the derivative of this you can easily see that the maximum range occurs when [tex]\theta=\frac{\pi}{4}[/tex] or 45 degrees exactly.
Now, using a perturbation method we can derive the effects of air resistance to a good approximation by expanding and keeping the highest order terms. If we do this we arrive at:
[tex]R_{max}=r*(1-\frac{4kV}{3g})[/tex] where r is the function for range without air resistance, k is the "retarding force constant" due to air resistance, V is the vertical component of the initial velocity, ie [tex]V=v*Sin(\theta)[/tex], and g is gravity.
Now, if we use Mathematica, we can find the angles that give maximum values for a given value of k. We keep V constant to find these values. You can also optimize the function by hand, but it was faster to just plug in a series of value and see what happens. So basically, I defined functions [tex]r[\theta][/tex] and [tex]V[\theta][/tex], then I ran:
NMaximize[{r*(1-(4*k*V)/(3*g), 0 <= Theta <= Pi/2, k = ?}, {Theta,k}]
where I have used the following values for k: 0.0, 0.01, 0.02, 0.03, 0.04, 0.05
This gives me an output that looks like this: {586.576, {k -> 0.05, Theta -> 0.573102}} (for k = 0.05). The first number is the maximum range obtained for v = 100 m/s. Then it gives the optimum value for Theta, which in this case is 0.573 radians.
Here is the table summarized:
k (Theta)
0.00 (.785) (45 degrees exactly)
0.01 (.758)
0.02 (.752)
0.03 (0.680)
0.04 (0.629) (about 36 degrees)
0.05 (0.573)
Thus we see that the optimum angle for firing the trebuchet for a projectile with a lot of air resistance is lower than 45 degrees. The exact value depends on how much air resistance there is. I have no idea what the k-value for a pumpkin is, but I can tell you that it will be greater than zero.
Cheers.
Neville de Mestre said:
It is possible to assume constant atmospheric density and, as long as the projectile’s velocity is less than 240 m/s, it is a reasonable approximation to take the drag to be proportional everywhere to the square of the speed. These approximations were first suggested by Euler (1707 – 1783).
Source: The Mathematics of Projectiles in Sports
Your equation flies in the face of Leonard Euler's assumption that drag is proportional everywhere to the square of the speed.
How do your reconcile your work with that of Euler?
I make the same assumption as Euler.
If you still don't believe me, here is an article from USC:
http://physics.ucsc.edu/~peter/115/range.nb.pdf
Near the top of the penultimate page, the author writes: "Note that the range increases rapidly as q increases and reaches a maximum at a value less than pi/4 (which is the value without air resistance)."
He solves this by integrating the equations of motion. I did it numerically by making a perturbation approximation. We both arrived at the same answer.
Why do you think my equation "flies in the face of...Euler's assumption"?
My analysis is based almost entirely on de Mestre’s book, The Mathematics of Projectiles in Sports. It is out of print, though much of it is available online here. The first four chapters are titled:
1) Motion Under Gravity Alone
2) Motion in a Linear Resisting Medium
3) Motion in a Non-Linear Resisting Medium
4) The Basic Equations and their Numerical Solutions
Chapter One is just the parabola that everybody learns about in Physics 101. In the introduction to Chapter Two (p. 24), we read:
de Mestre said:
For projectiles moving through air at very low speeds, or for motion through other fluids where the Reynolds number is small, the drag can often be assumed to be directly proportional to the speed. This linear model shows the effects of the inclusion of drag without the mathematics becoming too complicated at first. This approximation will be pursued here and other drag approximations will be considered in the next chapter.
The resisting force exerted on a projectile always acts in the direction tangential to the path of the projectile and so continuously changes in direction as the trajectory curves back toward the earth. In general, this variation in direction of the drag causes difficulties in the mathematical solution because it leads to a system of coupled non-linear differential equations. The particular advantage of the assumption that the drag is proportional to the speed is that this is the only case in which the governing equations are linear and uncoupled.
Six pages later (p. 30) we arrive at this conclusion:
de Mestre said:
Now [tex]v_{0}^2 sin(2\alpha) / g[/tex] is the no-drag result while [tex]-4kv_{0}^3 sin(2\alpha) sin(\alpha) / (3g^2)[/tex] gives the approximate correction for small [tex]kt_{f}[/tex].
This just happens to be exactly the result that your Mathematica guy obtained.
I am not familiar with Mathematica, so I cannot follow this guy’s reasoning, but I believe that you have been misled. He starts out saying that drag is proportional to the square of velocity, but then he solves the linear and uncoupled equations for the simple case where drag is proportional to velocity.
This should be obvious since, even without an intimate knowledge of Mathematica, it is clear that this guy is not solving a system of coupled non-linear differential equations. That would be vastly more complicated than what I saw in his PDF file.
My paper is based on Chapter Three of de Mestre’s book, Motion in a Non-Linear Resisting Medium, and my Java Applet is based on Chapter Four of de Mestre’s book, The Basic Equations and their Numerical Solutions.
The professional version, which I have not yet written, will be based on Chapter Six of de Mestre’s book, Corrections Due to Other Effects, particularly wind corrections. Also, it will take hills into consideration.
If there is air resistance the optimum angle is less than (pi/4).
The table of Bacat is of little value however, because k and V are so high, that the approximation isn't valid anymore. With a k of 0.01, a 100m/s pumpkin will decelerate with 100m/s^2. The approximation will only work if this value is small compared to g.
Numerically integrating [itex] a_x = -k v_x v [/itex], [itex] a_y = -k v_y v - g [/itex]
for various initial angles, gives a distance of only 170m at a maximum angle of about 0.18[itex]\pi[/itex]. The maximum distance without friction is 1020m.
I have [tex] k = \frac {F_{fric}} {v^2 m} = \frac {C_w A \rho_{air}} {2 m} [/tex]
Grozny's pumpkins seem to have a k of about 0.002 and v = 54.3 m/s. (the maximum angle depends on v)
angle/pi range
0.2 205.9
0.22 209.3
0.23 210.0
0.24 210.0
0.25 209.3
0.3 195.5
the maximum is at 0.235 pi (42.3 degrees) and a range of 210.1 m
the difference in range with 45 degrees of 0.8m is probably unmeasurable with a trebuchet.
I think wind speed and pumpkin wobble will give much larger errors.
You could measure the difference between 0.2pi and 0.3pi to get an idea which one is
closer to the maximum.
The experiment might be better done even more friction and less mass, for example with a soccer ball.
The original question for the physics community was whether an angle less than 45 degrees is really optimal for a projectile subject to air resistance. The answer is that this is true.
We can hash the numbers about pumpkins and talk about techniques for proving it, but the theory supports the reality that an angle less than 45 degrees is optimal.
Cheers.
Related to The Ballistic Coefficient of Pumpkins
What is the ballistic coefficient of a pumpkin?
The ballistic coefficient of a pumpkin is a measure of its ability to maintain its velocity and trajectory in flight. It takes into account the shape, weight, and drag of the pumpkin.
How is the ballistic coefficient of a pumpkin calculated?
The ballistic coefficient of a pumpkin is calculated by dividing its weight by its drag coefficient, which is a value that represents the amount of resistance the pumpkin experiences as it moves through the air.
Why is the ballistic coefficient of a pumpkin important?
The ballistic coefficient of a pumpkin is important because it helps predict the pumpkin's flight path and impact force. This information is useful for activities such as pumpkin launching competitions and studying the physics of projectile motion.
Can the ballistic coefficient of a pumpkin be changed?
Yes, the ballistic coefficient of a pumpkin can be changed by altering its weight, shape, or drag coefficient. For example, adding a stabilizing fin to the pumpkin can improve its ballistic coefficient and make it more accurate in flight.
How does the ballistic coefficient of a pumpkin compare to other objects?
The ballistic coefficient of a pumpkin can vary greatly depending on its size, shape, and other factors. However, in general, pumpkins have a lower ballistic coefficient compared to objects like bullets or rockets due to their irregular shape and relatively low weight.
  • General Discussion
