Alcubierre drive has trouble with quantum effects
In summary, a recent paper has suggested that Alcubierre's warp drive may not be feasible due to quantum effects. There is also ongoing research into the interface between quantum mechanics and general relativity, with some theories suggesting that black holes may not exist or may have different properties than previously thought.
bcrowell
Staff Emeritus
Insights Author
431
A recent paper says that Alcubierre's warp drive probably won't work due to quantum effects:
http://www.technologyreview.com/blog/arxiv/23292/ -- nontechnical summary
http://arxiv.org/abs/0904.0141 -- paper
Speaking as a non-specialist, it seems hard to tell which predictions about the interface between QM and GR to take seriously and which ones not to take seriously. Some, like Hawking radiation, seem fairly secure. Hawking radiation has been studied thoroughly over a long period of time, and the reasons behind it seem relatively model-independent.
On the other hand, semiclassical gravity makes some predictions that seem relatively shaky, as far as I can tell as an outsider looking in, and without having mastered the techniques of the field. For instance, there's a claim that quantum-mechanical effects can strongly affect the process of formation of black holes, even causing the collapse to halt under certain conditions: http://arxiv.org/abs/0909.4157
We already have a thread discussing this. I reported the same article and Tech Review item in April 2009:
https://www.physicsforums.com/showthread.php?t=305091
It looks sound. Alcubierre's goose is probably cooked. May even be overdone. :biggrin:
About what really happens at the (supposed) classical black hole singularity, you cited just one of many recent papers which explore what might happen in the bh pit, when quantum effects are factored in.
There is a lot of work in progress. We just need to keep an open mind and wait.
As quantum gravity BH papers appear, they usually get spotted and added to the QG bibliography in Beyond forum. That is a separate question. I'd say forget Alcubierre but keep an eye out for the next few QG papers on BH.
The paper from Visser and colleagues is motivated as follows. Is Lorentz invariance fundamental? Maybe not (no working models, but several very interesting lines of pursuit from Volovik, Visser, Xiao-Gang Wen, and Horava). However, if Lorentz invariance is not fundamental and black holes exist, we can have a perpetual motion machine (I think this is Ted Jacobson's result). So maybe black holes don't exist.
However, there is mention of "black holes" in the literature about Horava gravity. A footnote in http://arxiv.org/abs/0905.4480 says "Due to the lack of Lorentz invariance in UV, the very meaning of the horizons and Hawking temperature would be changed from the conventional ones. The light cones would differ for different wavelengths and so different particles with different dispersion relations would see different Hawking temperature TH and entropies, the Hawking spectrum would not be thermal. But from the recovered Lorentz invariance in IR (with = 1), the usual meaning of the horizons and T as the Hawking temperature would be “emerged” for long wavelengths. The calculation and meaning of the temperature should be understood in this context."
Ah, thanks for pointing that out. I feel silly. Arxiv blog is giving a retrospective of 2009, but I didn't realize that, thought this was a new article.
FAQ: Alcubierre drive has trouble with quantum effects
What is the Alcubierre drive, and how does it work?
The Alcubierre drive is a theoretical concept for a type of spacecraft propulsion that would allow for faster-than-light travel. It works by creating a bubble or "warp" in spacetime around the spacecraft, which would then be able to move through space at speeds greater than the speed of light.
What are quantum effects, and how do they affect the Alcubierre drive?
Quantum effects are phenomena that occur at the quantum level, which is the scale of atoms and subatomic particles. These effects include things like quantum entanglement and uncertainty. They affect the Alcubierre drive because at superluminal speeds, the drive would encounter high levels of energy and matter, which could cause quantum fluctuations and potentially destabilize the drive.
What are the main challenges with implementing the Alcubierre drive?
The main challenges with implementing the Alcubierre drive are related to its reliance on negative energy and matter. These are theoretical concepts that have not yet been observed or produced, and their existence is still a subject of debate among scientists. Additionally, the drive would require immense amounts of energy to create and maintain the warp bubble, making it currently unfeasible with our current technology.
Is there any evidence to support the existence of the Alcubierre drive?
Currently, there is no evidence to support the existence of the Alcubierre drive. It is a theoretical concept that has not yet been tested or proven in any way. However, some scientists continue to explore the idea and conduct experiments to try to validate its feasibility.
Could the Alcubierre drive be used for time travel?
The Alcubierre drive is not designed or intended for time travel. However, some theories suggest that the warping of spacetime could potentially lead to time dilation, where time would pass differently for the occupants of the spacecraft compared to those outside of the warp bubble. However, this is still a highly debated and hypothetical concept.
